REFDES | COMP_DEVICE_TYPE | COMP_VALUE | SYM_NAME |
D1 | PESD5V0U2BT_SOT23-3_PESD5V0U2BT | PESD5V0U2BT_SOT23-3 | PESD5V0U2BT_SOT23-3 |
D2 | RCLAMP0524PATCT_SLP2510P8-10-9_ | RCLAMP0524PATCT_SLP2510P8-10-9 | RCLAMP0524PATCT_SLP2510P8-10-9 |
D3 | RCLAMP0524PATCT_SLP2510P8-10-9_ | RCLAMP0524PATCT_SLP2510P8-10-9 | RCLAMP0524PATCT_SLP2510P8-10-9 |
D4 | AZC199-02SPR7G_SOT23-3_AZC199-0 | AZC199-02SPR7G_SOT23-3 | AZC199-02SPR7G_SOT23-3 |
D5 | PJSOT24C_SOT23-3_PJSOT24C_SOT23 | PJSOT24C_SOT23-3 | PJSOT24C_SOT23-3 |
D6 | RB751V-40_SOD323-2_RB751V-40_SO | RB751V-40_SOD323-2 | RB751V-40_SOD323-2 |
D7 | RCLAMP0524PATCT_SLP2510P8-10-9_ | RCLAMP0524PATCT_SLP2510P8-10-9 | RCLAMP0524PATCT_SLP2510P8-10-9 |
D8 | IP4223CZ6_SO6-6_IP4223CZ6_SO6-6 | CM1293A_SC-74 | IP4223CZ6_SO6-6 |
D9 | IP4223CZ6_SO6-6_IP4223CZ6_SO6-6 | CM1293A_SC-74 | IP4223CZ6_SO6-6 |
D10 | RCLAMP0524PATCT_SLP2510P8-10-9_ | RCLAMP0524PATCT_SLP2510P8-10-9 | RCLAMP0524PATCT_SLP2510P8-10-9 |
D11 | RCLAMP0524PATCT_SLP2510P8-10-9_ | RCLAMP0524PATCT_SLP2510P8-10-9 | RCLAMP0524PATCT_SLP2510P8-10-9 |
D15 | IP4223CZ6_SO6-6_IP4223CZ6_SO6-6 | CM1293A_SC-74 | IP4223CZ6_SO6-6 |
D16 | RCLAMP0524PATCT_SLP2510P8-10-9_ | RCLAMP0524PATCT_SLP2510P8-10-9 | RCLAMP0524PATCT_SLP2510P8-10-9 |
D17 | RCLAMP0524PATCT_SLP2510P8-10-9_ | RCLAMP0524PATCT_SLP2510P8-10-9 | RCLAMP0524PATCT_SLP2510P8-10-9 |
D18 | RCLAMP0524PATCT_SLP2510P8-10-9_ | RCLAMP0524PATCT_SLP2510P8-10-9 | RCLAMP0524PATCT_SLP2510P8-10-9 |
D22 | RB521CS-30GT2RA_VMN2-2_RB521CS- | RB521CS-30GT2RA_VMN2-2 | RB521CS-30GT2RA_VMN2-2 |
D23 | RB521CS-30GT2RA_VMN2-2_RB521C_1 | RB521CM_30 | RB521CS-30GT2RA_VMN2-2 |
D24 | RB491D_SOT23-3_RB491D_SOT23-3_R | RB491D_SOT23-3 | RB491D_SOT23-3 |
D25 | RB521CS-30GT2RA_VMN2-2_RB521CS- | RB521CS-30GT2RA_VMN2-2 | RB521CS-30GT2RA_VMN2-2 |
D59 | RB521CS-30GT2RA_VMN2-2_RB521C_1 | RB521CM_30 | RB521CS-30GT2RA_VMN2-2 |
D60 | RB521CS-30GT2RA_VMN2-2_RB521C_1 | RB521CM_30 | RB521CS-30GT2RA_VMN2-2 |
D61 | RB521CS-30GT2RA_VMN2-2_RB521C_1 | RB521CM_30 | RB521CS-30GT2RA_VMN2-2 |
D62 | RB521CS-30GT2RA_VMN2-2_RB521C_1 | RB521CM_30 | RB521CS-30GT2RA_VMN2-2 |
D63 | RB521CS-30GT2RA_VMN2-2_RB521C_1 | RB521CM_30 | RB521CS-30GT2RA_VMN2-2 |
D64 | RB521CS-30GT2RA_VMN2-2_RB521C_1 | RB521CM_30 | RB521CS-30GT2RA_VMN2-2 |
DA1 | BAT54CW_SOT323-3_BAT54CW_SOT323 | BAT54CW_SOT323-3 | BAT54CW_SOT323-3 |
DA3 | RB751V-40_SOD323-2_RB751V-40_SO | RB751V-40_SOD323-2 | RB751V-40_SOD323-2 |
DA4 | RB751V-40_SOD323-2_RB751V-40_SO | RB751V-40_SOD323-2 | RB751V-40_SOD323-2 |
DA5 | RB751V-40_SOD323-2_RB751V-40_SO | RB751V-40_SOD323-2 | RB751V-40_SOD323-2 |
DC23 | RB521CS-30GT2RA_VMN2-2_RB521CS- | RB521CS-30GT2RA_VMN2-2 | RB521CS-30GT2RA_VMN2-2 |
DEV1 | P_RB751V-40_SOD323-2_RB751V-40_ | RB751V-40_SOD323-2 | RB751V-40_SOD323-2 |
DL1 | RCLAMP0524PATCT_SLP2510P8-10-9_ | RCLAMP0524PATCT_SLP2510P8-10-9 | RCLAMP0524PATCT_SLP2510P8-10-9 |
DL2 | RCLAMP0524PATCT_SLP2510P8-10-9_ | RCLAMP0524PATCT_SLP2510P8-10-9 | RCLAMP0524PATCT_SLP2510P8-10-9 |
DL3 | BS401N_1206-2_BS401N_1206-2_BS4 | BS401N_1206-2 | BS401N_1206-2 |
DL4 | BS401N_1206-2_BS401N_1206-2_BS4 | BS401N_1206-2 | BS401N_1206-2 |
DL5 | BS401N_1206-2_BS401N_1206-2_BS4 | BS401N_1206-2 | BS401N_1206-2 |
DL6 | BS401N_1206-2_BS401N_1206-2_BS4 | BS401N_1206-2 | BS401N_1206-2 |
DV1 | RB751V-40_SOD323-2_RB751V-40_SO | RB751V-40_SOD323-2 | RB751V-40_SOD323-2 |
DV2 | RB751V-40_SOD323-2_RB751V-40_SO | RB751V-40_SOD323-2 | RB751V-40_SOD323-2 |
DV6 | RB751V-40_SOD323-2_RB751V-40_SO | RB751V-40_SOD323-2 | RB751V-40_SOD323-2 |
F1 | 1.1A_8V_SMD1812P110TF_F_SMD1812 | 1812L110PR1.1A | F_SMD1812P110TF |
F2 | 0.5A_8V_KMC3S050RY_F_KMC3S050RY | 0.5A_8V_KMC3S050RY | F_KMC3S050RY |
FD1 | FM_2_FIDUCIAL_C40M80_CF | CF | FIDUCIAL_C40M80 |
FD2 | FM_2_FIDUCIAL_C40M80_CF | CF | FIDUCIAL_C40M80 |
FD3 | FM_2_FIDUCIAL_C40M80_CF | CF | FIDUCIAL_C40M80 |
FD4 | FM_2_FIDUCIAL_C40M80_CF | CF | FIDUCIAL_C40M80 |
FD5 | FM_2_FIDUCIAL_C40M80_CF | CF | FIDUCIAL_C40M80 |
FD6 | FM_2_FIDUCIAL_C40M80_CF | CF | FIDUCIAL_C40M80 |
H1 | HOLE_PAD_C6P0D3P2_PAD_C6P0D3P2 | PAD_C6P0D3P2 | PAD_C6P0D3P2 |
H2 | HOLE_PAD_C6P0D3P2_PAD_C6P0D3P2 | PAD_C6P0D3P2 | PAD_C6P0D3P2 |
H3 | HOLE_PAD_C6P0D3P2_PAD_C6P0D3P2 | PAD_C6P0D3P2 | PAD_C6P0D3P2 |
H4 | HOLE_PAD_C6P0D3P2_PAD_C6P0D3P2 | PAD_C6P0D3P2 | PAD_C6P0D3P2 |
H5 | HOLE_PAD_C6P0D3P3_PAD_CT8P0B6P0 | PAD_CT8P0B6P0D3P3 | PAD_C6P0D3P3 |
H6 | HOLE_PAD_C6P0D3P3_PAD_CT8P0B6P0 | PAD_CT8P0B6P0D3P3 | PAD_C6P0D3P3 |
H7 | HOLE_PAD_C6P0D3P3_PAD_CT8P0B6P0 | PAD_CT8P0B6P0D3P3 | PAD_C6P0D3P3 |
H8 | HOLE_PAD_C8P0D2P5_PAD_C8P0D2P5 | PAD_C8P0D2P5 | PAD_C8P0D2P5 |
H10 | HOLE_PAD_CT8P0B6P0D2P5_PAD_CT8P | PAD_CT8P0B6P0D2P5 | PAD_CT8P0B6P0D2P5 |
H11 | HOLE_PAD_C5P0D2P5_PAD_C5P0D2P5 | PAD_C5P0D2P5 | PAD_C5P0D2P5 |
H12 | HOLE_PAD_C8P0D2P5_PAD_C8P0D2P5 | PAD_C8P0D2P5 | PAD_C8P0D2P5 |
H13 | HOLE_PAD_O3P9X2P7D3P9X2P7N_PAD_ | PAD_O3P9X2P7D3P9X2P7N | PAD_O3P9X2P7D3P9X2P7N |
H14 | HOLE_PAD_CT6P0B8P0D2P5_PAD_CT6P | PAD_CT6P0B8P0D2P5 | PAD_CT6P0B8P0D2P5 |
H15 | HOLE_PAD_SHAPET8P0X10P5CB8P0D2P | PAD_shapeT8P0X10P5CB8P0D2P5 | PAD_SHAPET8P0X10P5CB8P0D2P5 |
H16 | HOLE_PAD_O2P3X3P5D2P3X3P5N_PAD_ | PAD_O2P3X3P5D2P3X3P5N | PAD_O2P3X3P5D2P3X3P5N |
H17 | HOLE_PAD_CT6P0SHAPEB8P0X6P65D2P | PAD_CT6P0SHAPEB8P0X6P65D2P5 | PAD_CT6P0SHAPEB8P0X6P65D2P5 |
H18 | HOLE_PAD_C8P0D3P0_PAD_C8P0D2P5 | PAD_C8P0D2P5 | PAD_C8P0D3P0 |
H19 | HOLE_PAD_C5P0D2P3_PAD_C5P0D2P3 | PAD_C5P0D2P3 | PAD_C5P0D2P3 |
H20 | HOLE_PAD_C6P0D3P3_PAD_C6P0D3P3 | PAD_C6P0D3P3 | PAD_C6P0D3P3 |
H21 | HOLE_PAD_SHAPET8P0X10P5CB8P0D2P | PAD_shapeT8P0X10P5CB8P0D2P5 | PAD_SHAPET8P0X10P5CB8P0D2P5 |
H24 | HOLE_PAD_C8P0D2P5_PAD_C8P0D2P5 | PAD_C8P0D2P5 | PAD_C8P0D2P5 |
H25 | HOLE_PAD_C2P3D2P3N_PAD_C2P3D2P3 | PAD_C2P3D2P3N | PAD_C2P3D2P3N |
H26 | HOLE_PAD_O4P7X3P5D4P7X3P5N_PAD_ | PAD_O4P7X3P5D4P7X3P5N | PAD_O4P7X3P5D4P7X3P5N |
H27 | HOLE_PAD_C5P0D3P0_PAD_C5P0D2P5 | PAD_C5P0D2P5 | PAD_C5P0D3P0 |
H28 | HOLE_PAD_C6P0D2P3_PAD_C6P0D2P3 | PAD_C6P0D2P3 | PAD_C6P0D2P3 |
J1 | JOPEN_SHORTPADS_SHORTPADS | SHORTPADS | SHORTPADS |
J5 | P_JUMP_43X118_JUMP_43X118_JUMP_ | JUMP_43X118 | JUMP_43X118 |
J6 | P_JUMP_43X118_JUMP_43X118_JUMP_ | JUMP_43X118 | JUMP_43X118 |
JBATT1 | P_FOX_GS73071-10272-M-7H_FOX_GS | FOX_GS73071-10272-M-7H | FOX_GS73071-10272-M-7H_7P-T |
JC1 | P_JUMP_JUMP_43X79_JUMP_43X79 | JUMP_43X79 | JUMP_43X79 |
JC2 | P_JUMP_43X118_JUMP_43X118_JUMP_ | JUMP_43X118 | JUMP_43X118 |
JCMOS1 | JOPEN_SHORTPADS_SHORTPADS | SHORTPADS | SHORTPADS |
JCP | ACES_50506-01201-AT1_ACES_50506 | ACES_50506-01201-AT1 | ACES_50506-01201-AT1_12P |
JCR | ACES_51530-01401-W01_ACES_51530 | ACES_51530-01401-W01 | ACES_51530-01401-W01_14P-T |
JDIMM1 | LCN_DAN06-K4406-0102_LCN_DAN06- | LCN_DAN06-K4406-0102 | LCN_DAN06-K4406-0102_204P |
JDIMM2 | LCN_DAN06-K4406-0103_LCN_DAN06- | LCN_DAN06-K4406-0103 | LCN_DAN06-K4406-0103_204P |
JFAN | DRAPH_WS32050-S0471-HF_DRAPH_WS | DRAPH_WS32050-S0471-HF | DRAPH_WS32050-S0471-HF_5P-T |
JFPB | ACES_88514-0060N-071_ACES_88514 | ACES_88514-0060N-071 | ACES_88514-0060N-071_6P-T |
JHDD | HIGHS_SA2S0226-3201H_HIGHS_SA2S | HIGHS_SA2S0226-3201H | HIGHS_SA2S0226-3201H_22P |
JHDMI | CONCR_099ATAC19NBLCNF_CONCR_099 | CONCR_099ATAC19NBLCNF | CONCR_099ATAC19NBLCNF_19P |
JKB | JAE_FL10F032HA2R3000_JAE_FL10F0 | JAE_FL10F032HA2R3000 | JAE_FL10F032HA2R3000_32P |
JLCD | I-PEX_20525-030E-02_I-PEX_20525 | I-PEX_20525-030E-02 | I-PEX_20525-030E-02_30P-T |
JLINK | DRAPH_PJSS0296-MB21H_DRAPH_PJSS | DRAPH_PJSS0296-MB21H | DRAPH_PJSS0296-MB21H_29P-T |
JLOGO | TE_2041180-2_TE_2041180-2_2P-T_ | TE_2041180-2 | TE_2041180-2_2P-T |
JME1 | JOPEN_SHORTPADS_SHORTPADS | SHORTPADS | SHORTPADS |
JRJ451 | SINGA_2RJ3089-108211F_SINGA_2RJ | SINGA_2RJ3089-108211F | SINGA_2RJ3089-108211F_12P |
JRTC | TE_2041180-2_TE_2041180-2_2P-T_ | TE_2041180-2 | TE_2041180-2_2P-T |
JSPK | TYCO_2041180-4_TYCO_2041180-4_4 | TYCO_2041180-4 | TYCO_2041180-4_4P-T |
JTOUCH1 | ACES_50463-0104A-P01_ACES_50463 | ACES_50463-0104A-P01 | ACES_50463-0104A-P01_10P-T |
JTP | JAE_FL10F012HA1R3000_JAE_FL10F0 | JAE_FL10F012HA1R3000 | JAE_FL10F012HA1R3000_12P |
JU3AC | HIGHS_FC5AF261-1151H_HIGHS_FC5A | HIGHS_FC5AF261-1151H | HIGHS_FC5AF261-1151H_26P |
JUSB1 | SUYIN_020053GR009M283ZL_SUYIN_0 | SUYIN_020053GR009M283ZL | SUYIN_020053GR009M283ZL_9P |
JUSB2 | SUYIN_020053GR009M283ZL_SUYIN_0 | SUYIN_020053GR009M283ZL | SUYIN_020053GR009M283ZL_9P |
JV1 | P_JUMP_JUMP_43X79_JUMP_43X79 | JUMP_43X79 | JUMP_43X79 |
JV3 | JUMP_JUMP_43X39_JUMP_43X39 | JUMP_43X39 | JUMP_43X39 |
JWLBT | TE_2199230-8_TE_2199230-8_75P_T | TE_2199230-8 | TE_2199230-8_75P |
LC5 | R-SHORT_R0805_SHORT_0_0805_5% | 0_0805_5% | R0805_SHORT |
LE1 | BLM18PG121SN1D_2P_MURAT_BLM18PG | BLM18PG121SN1D_2P | MURAT_BLM18PG121SN1D_2P |
LE2 | BLM18PG121SN1D_2P_MURAT_BLM18PG | BLM18PG121SN1D_2P | MURAT_BLM18PG121SN1D_2P |
LL1 | L_TDK_FLF3215T-4R7M_2P_4.7UH_FL | 4.7UH_FLF3215T-4R7M_20% | TDK_FLF3215T-4R7M_2P |
LV3 | L_MURAT_BLM18PG221SN1D_2P_BLM18 | BLM18PG221SN1D_2P | MURAT_BLM18PG221SN1D_2P |
LV4 | BLM18PG121SN1D_2P_MURAT_BLM18PG | BLM18PG121SN1D_2P | MURAT_BLM18PG121SN1D_2P |
LV5 | BLM18PG121SN1D_2P_MURAT_BLM18PG | BLM18PG121SN1D_2P | MURAT_BLM18PG121SN1D_2P |
PD1 | P_RB751V-40_SOD323-2_RB751V-4_1 | RB751V-40 | RB751V-40_SOD323-2 |
PD2 | P_RB751V-40_SOD323-2_RB751V-4_2 | 1SS355 | RB751V-40_SOD323-2 |
PD3 | P_RB751V-40_SOD323-2_RB751V-4_1 | RB751V-40 | RB751V-40_SOD323-2 |
PD4 | P_RB751V-40_SOD323-2_RB751V-40_ | RB751V-40_SOD323-2 | RB751V-40_SOD323-2 |
PD5 | AZ5425-01F_DFN1006P2E2_AZ5425-0 | AZ5425-01F_DFN1006P2E2 | AZ5425-01F_DFN1006P2E2 |
PD6 | P_RB751V-40_SOD323-2_RB751V-4_1 | RB751V-40 | RB751V-40_SOD323-2 |
PD7 | PESD5V0U2BT_SOT23-3_PESD5V0U2BT | PESD5V0U2BT_SOT23-3 | PESD5V0U2BT_SOT23-3 |
PD101 | P_RB751V-40_SOD323-2_RB751V-4_1 | RB751V-40 | RB751V-40_SOD323-2 |
PD102 | P_RB751V-40_SOD323-2_RB751V-4_1 | RB751V-40 | RB751V-40_SOD323-2 |
PD103 | P_RB751V-40_SOD323-2_RB751V-4_1 | RB751V-40 | RB751V-40_SOD323-2 |
PD801 | P_RB751V-40_SOD323-2_RB751V-4_1 | RB751V-40 | RB751V-40_SOD323-2 |
PF1 | 7A_32V_0437007.WR_F_0437007PWR_ | 7A_32V_0437007.WR | F_0437007PWR |
PF2 | P_12A_65V_451012MRL_F_0437007PW | 12A_32V_0501012.WRS | F_0437007PWR |
PJ201 | P_JUMP_43X118_JUMP_43X79_JUMP_4 | JUMP_43X79 | JUMP_43X79 |
PL4 | L_TDK_MPZ1608S300AT_2P_MURATAB | MURATABLM18KG300TN1D | TDK_MPZ1608S300AT_2P |
PL101 | P_L_CYNTE_PCMB053T-1R0MS_2P_1UH | 1UH_PCMB053T-1R0MS_20% | CYNTE_PCMB053T-1R0MS_2P |
PL102 | P_L_CYNTE_PCMB104T-100MS_2P_4.7 | 4.7UH_PCMB104T-4R7MS | CYNTE_PCMB104T-100MS_2P |
PL201 | P_L_CYNTE_PCMB063T-2R2MS_2P_2.2 | 2.2UH_PCMB063T-2R2MS_8A_20% | CYNTE_PCMB063T-2R2MS_2P |
PL202 | P_L_CYNTE_PCMB063T-2R2MS_2P_2.2 | 2.2UH_PCMB063T-2R2MS_8A_20% | CYNTE_PCMB063T-2R2MS_2P |
PL301 | P_L_CYNTE_PCMB063T-1R0MS_2P_1UH | 1UH_PCMC063T-1R0MN_+-20% | CYNTE_PCMB063T-1R0MS_2P |
PL401 | L_TDK_MPZ1608S300AT_2P_BLM18KG3 | BLM18KG300TN1D | TDK_MPZ1608S300AT_2P |
PL402 | L_TDK_MPZ1608S300AT_2P_BLM18KG3 | BLM18KG300TN1D | TDK_MPZ1608S300AT_2P |
PL403 | P_L_CYNTE_CMLE064T-R15MS0R66788 | CMLE064T-R15MS0R725-88(0.72mohm+/-5%) | CYNTE_CMLE064T-R15MS0R66788_2P |
PL404 | L_TDK_MPZ1608S300AT_2P_BLM18KG3 | BLM18KG300TN1D | TDK_MPZ1608S300AT_2P |
PL405 | L_TDK_MPZ1608S300AT_2P_BLM18KG3 | BLM18KG300TN1D | TDK_MPZ1608S300AT_2P |
PL406 | P_L_CYNTE_CMLE064T-R15MS0R66788 | CMLE064T-R15MS0R725-88(0.72mohm+/-5%) | CYNTE_CMLE064T-R15MS0R66788_2P |
PL407 | L_TDK_MPZ1608S300AT_2P_BLM18KG3 | BLM18KG300TN1D | TDK_MPZ1608S300AT_2P |
PL408 | P_L_CYNTE_CMLE064T-R15MS0R667_1 | 0.47UH_PCMB063T-R47MS3R675_18A_20%(DCR+/-5%) | CYNTE_CMLE064T-R15MS0R66788_2P |
PL601 | L_TDK_MPZ1608S300AT_2P_MURATAB | MURATABLM18KG300TN1D | TDK_MPZ1608S300AT_2P |
PL602 | L_TDK_MPZ1608S300AT_2P_MURATAB | MURATABLM18KG300TN1D | TDK_MPZ1608S300AT_2P |
PL603 | P_L_CYNTE_PCMB063T-1R0MS_2P_.24 | .24UH20% PCME063T-R24MS1R145 35A | CYNTE_PCMB063T-1R0MS_2P |
PL604 | P_L_CYNTE_PCMB063T-1R0MS_2P_.24 | .24UH20% PCME063T-R24MS1R145 35A | CYNTE_PCMB063T-1R0MS_2P |
PL701 | P_L_CYNTE_PCMB063T-1R0MS_2P_1UH | 1UH_PCMC063T-1R0MN_+-20% | CYNTE_PCMB063T-1R0MS_2P |
PL801 | L_CYNTE_PH041H-1R0MS_2P_1UH_PH0 | 1UH_PH041H-1R0MS_20% | CYNTE_PH041H-1R0MS_2P |
PQ1 | P_MMBT3906_SOT23-3_0_MMBT3906_S | MMBT3906_SOT23-3 | MMBT3906_SOT23-3 |
PQ2 | P_MMBT3904_SOT23-3_0_MMBT3904_S | MMBT3904_SOT23-3 | MMBT3904_SOT23-3 |
PQ3 | P_2N7002KW_SOT323-3_2N7002KW_SO | 2N7002WT1G | 2N7002KW_SOT323-3 |
PQ4 | P_2N7002BKS_SOT363-6_2N7002BK_1 | 2N7002KDWH2N SOT363-6 | 2N7002BKS_SOT363-6 |
PQ101 | P_SIS406DN-T1-GE3_PAK1212-8-5_S | AON7466 | SIS406DN-T1-GE3_PAK1212-8-5 |
PQ102 | P_SIS406DN-T1-GE3_PAK1212-8-5_S | AON7466 | SIS406DN-T1-GE3_PAK1212-8-5 |
PQ103 | P_2N7002KW_SOT323-3_2N7002KW_SO | 2N7002WT1G | 2N7002KW_SOT323-3 |
PQ104 | P_SIS406DN-T1-GE3_PAK1212-8-5_S | AON7466 | SIS406DN-T1-GE3_PAK1212-8-5 |
PQ105 | P_2N7002KW_SOT323-3_2N7002KW_SO | 2N7002WT1G | 2N7002KW_SOT323-3 |
PQ106 | P_AON7408L_DFN8-5_1_SI7326DN-T1 | AON7408L | SI7326DN-T1-E3_PAK1212-8 |
PQ107 | P_AON7408L_DFN8-5_1_SI7326DN-T1 | AON7408L | SI7326DN-T1-E3_PAK1212-8 |
PQ201 | P_2N7002BKS_SOT363-6_2N7002BKS_ | 2N7002KDWH2N | 2N7002BKS_SOT363-6 |
PQ301 | P_AON7408L_DFN8-5_1_SI7326DN-T1 | AON7408L | SI7326DN-T1-E3_PAK1212-8 |
PQ302 | P_AON7408L_DFN8-5_1_SI7326DN-_1 | AON7534 | SI7326DN-T1-E3_PAK1212-8 |
PQ401 | P_TPCA8065-H_PPAK56-8-5_0_TPCA8 | TPCA8065-H | TPCA8065-H_PPAK56-8-5 |
PQ402 | P_TPCA8059-H_PPAK56-8-5_0_TPCA8 | TPCA8057-H | TPCA8059-H_PPAK56-8-5 |
PQ403 | P_TPCA8059-H_PPAK56-8-5_0_TPCA8 | TPCA8057-H | TPCA8059-H_PPAK56-8-5 |
PQ404 | P_TPCA8065-H_PPAK56-8-5_0_TPCA8 | TPCA8065-H | TPCA8065-H_PPAK56-8-5 |
PQ405 | P_TPCA8059-H_PPAK56-8-5_0_TPCA8 | TPCA8057-H | TPCA8059-H_PPAK56-8-5 |
PQ406 | P_TPCA8059-H_PPAK56-8-5_0_TPCA8 | TPCA8057-H | TPCA8059-H_PPAK56-8-5 |
PQ407 | P_AON7408L_DFN8-5_1_SI7326DN-T1 | AON7408L | SI7326DN-T1-E3_PAK1212-8 |
PQ408 | P_AON7408L_DFN8-5_1_SI7326DN-T1 | AON7408L | SI7326DN-T1-E3_PAK1212-8 |
PQ601 | P_TPCA8065-H_PPAK56-8-5_0_TPCA8 | TPCA8065-H | TPCA8065-H_PPAK56-8-5 |
PQ602 | P_TPCA8059-H_PPAK56-8-5_0_TPCA8 | TPCA8057-H | TPCA8059-H_PPAK56-8-5 |
PQ603 | P_TPCA8059-H_PPAK56-8-5_0_TPCA8 | TPCA8057-H | TPCA8059-H_PPAK56-8-5 |
PQ604 | P_TPCA8065-H_PPAK56-8-5_0_TPCA8 | TPCA8065-H | TPCA8065-H_PPAK56-8-5 |
PQ605 | P_TPCA8059-H_PPAK56-8-5_0_TPCA8 | TPCA8057-H | TPCA8059-H_PPAK56-8-5 |
PQ606 | P_TPCA8059-H_PPAK56-8-5_0_TPCA8 | TPCA8057-H | TPCA8059-H_PPAK56-8-5 |
PRT6 | 540_0402NEW_30%_PRF15BB541NB6RC | 540_0402NEW_30% | R_0402 |
PRT7 | P_100K_0402_1%_NCP15WF104F03RC_ | 100K_0402_1%_NCP15WF104F03RC | R_0402 |
PRT401 | P_MURAT_NCP03WF104F05RL_R_0402- | MURAT_NCP15WF104F03RC | R_0402-TH |
PRT402 | P_MURAT_NCP03WF104F05RL_R_0402- | MURAT_NCP15WF104F03RC | R_0402-TH |
PRT403 | P_MURAT_NCP03WF104F05RL_R_040_1 | MURAT_NCP15WM224J03RC | R_0402-TH |
PRT404 | P_MURAT_NCP03WF104F05RL_R_0402- | MURAT_NCP15WF104F03RC | R_0402-TH |
PRT405 | P_MURAT_NCP03WF104F05RL_R_0402- | MURAT_NCP15WF104F03RC | R_0402-TH |
PRT601 | P_MURAT_NCP18XH103D03RB_R_0402_ | 10K_0402_NTC | R_0402 |
PRT602 | P_470K_0402NEW_3%_TH05-4K474HR_ | 470K_0402NEW_3% | R_0402 |
PU1 | P_G718TM1U_SOT23-8_G718TM1U_SOT | G718TM1U_SOT23-8 | G718TM1U_SOT23-8 |
PU101 | P_BQ24780RUYR_QFN24_3_BQ24780RU | BQ24780SRUYR | BQ24780RUYR_QFN24_4X4 |
PU201 | P_SYX198BQNC_QFN10_3X3_SYX198BQ | SYX198BQNC_QFN10_3X3 | SYX198BQNC_QFN10_3X3 |
PU202 | P_SYX198CQNC_QFN10_3X3_SYX198CQ | SYX198CQNC_QFN10_3X3 | SYX198CQNC_QFN10_3X3 |
PU301 | P_RT8231AGQW_WQFN20_2_RT8231AGQ | RT8231AGQW | RT8231AGQW_WQFN20_3X3 |
PU401 | P_NCP81208MNTXG_QFN48_6X6_NCP81 | NCP81208MNTXG_QFN48_6X6 | NCP81208MNTXG_QFN48_6X6 |
PU402 | P_NCP81253MNTBG_DFN8_1_NCP81253 | NCP81253MNTBG_DFN8_2X2 | NCP81253MNTBG_DFN8_2X2 |
PU403 | P_NCP81151MNTBG_DFN8_0_NCP81253 | NCP81151MNTBG_DFN8_2X2 | NCP81253MNTBG_DFN8_2X2 |
PU404 | P_NCP81253MNTBG_DFN8_1_NCP81253 | NCP81253MNTBG_DFN8_2X2 | NCP81253MNTBG_DFN8_2X2 |
PU601 | P_ISL62771HRTZ_TQFN40_5_ISL6277 | ISL62771HRTZ_TQFN40_5X5 | ISL62771HRTZ_TQFN40_5X5 |
PU701 | P_TPS51367RVER_QFN28_3P5X4P5_TP | TPS51367RVER | TPS51367RVER_QFN28_3P5X4P5 |
PU801 | P_RT8068AZQW_WDFN10_1_RT8068AZQ | RT8068AZQW | RT8068AZQW_WDFN10_3X3 |
Q1 | MMST3904-7-F_SOT323-3_MMST3904- | MMST3904-7-F_SOT323-3 | MMST3904-7-F_SOT323-3 |
Q2 | MMST3904-7-F_SOT323-3_MMST3904- | MMST3904-7-F_SOT323-3 | MMST3904-7-F_SOT323-3 |
Q4 | P_2N7002KW_SOT323-3_2N7002KW__2 | 2N7002KW_SOT323-3 | 2N7002KW_SOT323-3 |
Q22 | AO3401A_SOT23-3_AO3401A_SOT23-3 | AO3401A_SOT23-3 | AO3401A_SOT23-3 |
Q23 | AO4430L_SO8_AO4430L_SO8_AO4430L | AO4430L_SO8 | AO4430L_SO8 |
Q24 | P_2N7002KDWH_SOT363-6_2N7002KDW | 2N7002KDWH_SOT363-6 | 2N7002KDWH_SOT363-6 |
Q26 | P_2N7002KW_SOT323-3_2N7002KW__1 | 2N7002WT1G_1N_SC-70-3 | 2N7002KW_SOT323-3 |
Q27 | AO3413_SOT23-3_AO3413_SOT23-3_A | AO3413_SOT23-3 | AO3413_SOT23-3 |
Q28 | P_2N7002KDWH_SOT363-6_2N7002KDW | 2N7002KDWH_SOT363-6 | 2N7002KDWH_SOT363-6 |
Q29 | AO3413_SOT23-3_AO3413_SOT23-3_A | AO3413_SOT23-3 | AO3413_SOT23-3 |
QC1 | P_2N7002KDWH_SOT363-6_2N7002KDW | 2N7002KDWH_SOT363-6 | 2N7002KDWH_SOT363-6 |
QC2 | P_2N7002KDWH_SOT363-6_2N7002KDW | 2N7002KDWH_SOT363-6 | 2N7002KDWH_SOT363-6 |
QC3 | P_2N7002KDWH_SOT363-6_2N7002KDW | 2N7002KDWH_SOT363-6 | 2N7002KDWH_SOT363-6 |
QD1 | DTC115TMT2L_VMT3_DTC115TMT2L_VM | DTC115TMT2L_VMT3 | DTC115TMT2L_VMT3 |
QE1 | P_2N7002KW_SOT323-3_2N7002KW__1 | 2N7002WT1G_1N_SC-70-3 | 2N7002KW_SOT323-3 |
QG1 | AO3413_SOT23-3_AO3413_SOT23-3_A | AO3413_SOT23-3 | AO3413_SOT23-3 |
QL2 | AO3413_SOT23-3_AO3413_SOT23-3_A | AO3413_SOT23-3 | AO3413_SOT23-3 |
QL3 | P_2N7002KW_SOT323-3_2N7002KW__1 | 2N7002WT1G_1N_SC-70-3 | 2N7002KW_SOT323-3 |
QV2 | P_2N7002KDWH_SOT363-6_2N7002KDW | 2N7002KDWH_SOT363-6 | 2N7002KDWH_SOT363-6 |
QV3 | MMST3904-7-F_SOT323-3_MMST3904- | MMST3904-7-F_SOT323-3 | MMST3904-7-F_SOT323-3 |
QV4 | P_2N7002KW_SOT323-3_2N7002KW__2 | 2N7002KW_SOT323-3 | 2N7002KW_SOT323-3 |
QV5 | AO3413_SOT23-3_AO3413_SOT23-3_A | AO3413_SOT23-3 | AO3413_SOT23-3 |
QV7 | P_2N7002KW_SOT323-3_2N7002KW__2 | 2N7002KW_SOT323-3 | 2N7002KW_SOT323-3 |
QV8 | P_2N7002KDWH_SOT363-6_2N7002KDW | 2N7002KDWH_SOT363-6 | 2N7002KDWH_SOT363-6 |
QV9 | AO4430L_SO8_AO4430L_SO8_AO4430L | AO4430L_SO8 | AO4430L_SO8 |
QV10 | P_2N7002KDWH_SOT363-6_2N7002KDW | 2N7002KDWH_SOT363-6 | 2N7002KDWH_SOT363-6 |
QV11 | P_2N7002KW_SOT323-3_2N7002KW__2 | 2N7002KW_SOT323-3 | 2N7002KW_SOT323-3 |
QV13 | NTJD5121NT1G_SC88-6_NTJD5121NT1 | NTJD5121NT1G_SC88-6 | NTJD5121NT1G_SC88-6 |
RPE5 | RP_8P4R_RP_0804_8P4R_2.2K_0804_ | 2.2K_0804_8P4R_5% | RP_0804_8P4R |
RRE20 | R_R_0402_4.99K_0402_1% | 4.99K_0402_1% | R_0402 |
RRE21 | R_R_0402_4.7K_0402_5% | 4.7K_0402_5% | R_0402 |
RRE22 | R_R_0402_4.7K_0402_5% | 4.7K_0402_5% | R_0402 |
RRE23 | R_R_0402_4.7K_0402_5% | 4.7K_0402_5% | R_0402 |
RRE24 | R_R_0402_4.7K_0402_5% | 4.7K_0402_5% | R_0402 |
RRE25 | R_R_0402_4.7K_0402_5% | 4.7K_0402_5% | R_0402 |
RRE26 | R_R_0402_4.7K_0402_5% | 4.7K_0402_5% | R_0402 |
RRE27 | R_R_0402_4.7K_0402_5% | 4.7K_0402_5% | R_0402 |
RRE28 | R_R_0402_4.7K_0402_5% | 4.7K_0402_5% | R_0402 |
RRE29 | R_R_0402_4.7K_0402_5% | 4.7K_0402_5% | R_0402 |
RRE30 | R_R_0402_4.7K_0402_5% | 4.7K_0402_5% | R_0402 |
RRE32 | R-SHORT_R0402_SHORT_0_0402_5% | 0_0402_5% | R0402_SHORT |
U1 | EMC1403-2-AIZL-TR_MSOP10_EMC140 | F75303M_MSOP10 | EMC1403-2-AIZL-TR_MSOP10 |
U3 | G524B1T11U_SOT23-5_G524B1T11U_S | G524B1T11U_SOT23-5 | G524B1T11U_SOT23-5 |
U4 | G524B1T11U_SOT23-5_G524B1T11U_S | G524B1T11U_SOT23-5 | G524B1T11U_SOT23-5 |
U5 | PS8713BTQFN24GTR2A_TQFN24_4X4_P | PS8713BTQFN24GTR2A_TQFN24_4X4 | PS8713BTQFN24GTR2A_TQFN24_4X4 |
U6 | PS8713BTQFN24GTR2A_TQFN24_4X4_P | PS8713BTQFN24GTR2A_TQFN24_4X4 | PS8713BTQFN24GTR2A_TQFN24_4X4 |
U8 | AH9246-W-7_SC59-3_AH9246-W-7_SC | AH9246-W-7_SC59-3 | AH9246-W-7_SC59-3 |
U11 | TPS22966DPUR_WSON14_2X3_TPS2296 | TPS22966DPUR_WSON14_2X3 | TPS22966DPUR_WSON14_2X3 |
U14 | TPS2546RTER_QFN16_4X4_TPS2546RT | TPS2546RTER_QFN16_4X4 | TPS2546RTER_QFN16_4X4 |
U15 | G524B2T11U_SOT23-5_G524B2T11U_S | G524B2T11U_SOT23-5 | G524B2T11U_SOT23-5 |
U16 | PS8713BTQFN24GTR2A_TQFN24_4X4_P | PS8713BTQFN24GTR2A_TQFN24_4X4 | PS8713BTQFN24GTR2A_TQFN24_4X4 |
U17 | G524B1T11U_SOT23-5_G524B1T11U_S | G524B1T11U_SOT23-5 | G524B1T11U_SOT23-5 |
U148 | P_SIP32451DB-T2-GE1_WCSP4_SIP32 | SIP32451DB-T2-GE1_WCSP4 | SIP32451DB-T2-GE1_WCSP_4P |
U149 | P_SLG5NT1533VTR_STDFN8-6_1X1P6_ | SLG5NT1533VTR_STDFN8-6_1X1P6 | SLG5NT1533VTR_STDFN8-6_1X1P6 |
UA1 | CX11852-11Z_QFN40_5X5_CX11852-1 | CX11852-11Z_QFN40_5X5 | CX11852-11Z_QFN40_5X5 |
UC4M1 | W25Q32FVSSIQ_SO8_W25Q32FVSSIQ_S | W25Q32FVSSIQ_SO8 | W25Q32FVSSIQ_SO8 |
UC8M1 | W25Q64FVSSIQ_SO8_W25Q64FVSSIQ_S | W25Q64FVSSIQ_SO8 | W25Q64FVSSIQ_SO8 |
UC1 | SKYLAKE-U_BGA1356_SKYLAKE-U_BGA | SKYLAKE-U_BGA1356 | SKYLAKE-U_BGA_1356P-T |
UC3 | TC7SG17FE_SON5_TC7SG17FE_SON5_T | TC7SG17FE_SON5 | TC7SG17FE_SON5 |
UE1 | IT8586E-AX_LQFP128_14X14_IT8586 | IT8586E-AX_LQFP128_14X14 | IT8586E-AX_LQFP128_14X14 |
UGSEN1 | LIS3DHTR_LGA16_3X3_LIS3DHTR_LGA | LIS3DHTR_LGA16_3x3 | LIS3DHTR_LGA16_3X3 |
UL1 | WGI219LM-QREF-A0_QFN48_6X6_WGI2 | WGI219LM-QREF-A0_QFN48_6X6 | WGI219LM-QREF-A0_QFN48_6X6 |
UM1 | PI3EQXDP1201ZBEX_TQFN48_7X7_PI3 | PI3EQXDP1201ZBEX_TQFN48_7X7 | PI3EQXDP1201ZBEX_TQFN48_7X7 |
URE1 | PS8401ATQFN40GTR2A4_TQFN40_5X5_ | PS8407ATQFN40GTR2A4_TQFN40_5X5 | PS8401ATQFN40GTR2A4_TQFN40_5X5 |
USROM1 | PCA24S08AD_SO8_PCA24S08AD_SO8_P | PCA24S08AD_SO8 | PCA24S08AD_SO8 |
UTPM1 | NPCT650LA0YX_QFN32_5X5_NPCT650L | NPCT650LA0YX_QFN32_5X5 | NPCT650LA0YX_QFN32_5X5 |
UV3 | 216-0858020-A0_FCBGA631_216-085 | 216-0858020-A0_FCBGA631 | 216-0858020-A0_FCBGA_631P |
UV4 | MC74VHC1G08DFT2G_SC70-5_MC74VHC | MC74VHC1G08DFT2G_SC70-5 | MC74VHC1G08DFT2G_SC70-5 |
UV5 | K4W4G1646B-HC11_FBGA96_MT41K256 | K4W4G1646D-BC1A_FBGA96 | MT41K256M16HA107_FBGA_96P-A39P |
UV6 | K4W4G1646B-HC11_FBGA96_MT41K256 | K4W4G1646D-BC1A_FBGA96 | MT41K256M16HA107_FBGA_96P-A39P |
UV7 | K4W4G1646B-HC11_FBGA96_MT41K256 | K4W4G1646D-BC1A_FBGA96 | MT41K256M16HA107_FBGA_96P-A39P |
UV8 | K4W4G1646B-HC11_FBGA96_MT41K256 | K4W4G1646D-BC1A_FBGA96 | MT41K256M16HA107_FBGA_96P-A39P |
UV9 | 74AVCH2T45GD_XSON8_3X2_74AVCH2T | 74AVCH2T45GD_XSON8_3X2 | 74AVCH2T45GD_XSON8_3X2 |
UV11 | TPS22965DSGR_WSON8_2X2_TPS22965 | TPS22965DSGR_WSON8_2X2 | TPS22965DSGR_WSON8_2X2 |
UV12 | TPS22965DSGR_WSON8_2X2_TPS22965 | TPS22965DSGR_WSON8_2X2 | TPS22965DSGR_WSON8_2X2 |
YC1 | 32.768KHZ_12.5PF_9H03200042_Y_9 | 32.768KHZ_12.5PF_9H03200042 | Y_9H03200042_2P |
YC2 | 24MHZ_10PF_8Y24000011_Y_8Y24000 | 24MHZ_10PF_8Y24000011 | Y_8Y24000011_4P |
YL1 | 25MHZ_10PF_8Y25000010_Y_8Y25000 | 25MHZ_10PF_8Y25000010 | Y_8Y25000010_4P |
YV1 | 27MHZ_16PF_X3G027000FG1H-HX_Y_X | 27MHZ_16PF_7V27000011 | Y_X3G027000FG1H-HX_4P |
