PRODUCT OVERVIEW
General
- 22nm process, BGA package with
0.4mm pitch.
- Operation temperature:
-40~85C(Industrial Grade)
-20~70C (Commercial Grade)
Application Processor
- ARM Cortex-R5 with 832MHz clock
32K I-Cache
32K D-Cache
64KB ATCM and 64KB
BTCM
- 54KB ROM and 64KB on-chip
SRAM for application usage
Memory
- Embedded 8bit Octal-SPI UHS
pSRAM, support DDR mode. Up to
1066Mbyte/s bandwidth.
- Embedded flash with XIP (eXecute
In Place) and QPI mode support, up
to 102MHz.
Peripheral Controllers
- Keypad controller:
Support 6x6 keypad with
hardware scanner and
internal pull-up resistors.
Support multiple key press
for gaming
- GPIO (×32)
Pull-up/pull-down
programmable
1.8V IO8
- UART (×4)
With hardware flow-control,
up to 3.6Mbps
One UART support Full 8-
wire connection
- USB 2.0(×1)
- SD3.0 Host Controller(x2)
1 for SD card
1 for Wifi
- SDIO Device Controller for high
bandwidth host CPU connection
- I2C (×5)
Modes:
100KHz/400KHz/1MHz/3.4
MHz
- PWM (×4)
- Dual SIM/USIM card controller | - General SSP interface(×3)
Support both master and
slave mode
Can be configured to SPI,
PCM, I2S and Microwire
format.
Security System
- True Random Number Generator
- 512bits OTP for security key
- Secure Boot/Strap/Bonding
Wireless connection interfaces
- Bluetooth5.0, FM, GNSS
Auxiliary analog inputs
- 36X3 Auxiliary ADC with 2 input
- PMIC may provide up to 5 analog
input (depending on PMIC
choice)
Audio Codec
- Integrated High quality audio
codec and audio front-end
Debug System
- JTAG for CPU & DSP sub
system
- UARTs and USB
Boot System
- Initial AP boot from
UART/USB/SPI NAND
- Strap pin & OTP for boot control
- 54KB BootROM
With hardware flow
control, up to 3.6Mbps
- USB 2.0(×1)
Modem baseband
- FDD/TDD LTE
CAT1/WCDMA/CAT-M/GSM
- Dual VoLTE
Integrated RF transceiver
- Cover frequency bands from
450MHz to 2.7GHz
- Support up to 10 Rx ports and 6
Tx ports
- Support both DCXO and external
VCTCXO
32Kless
Ultra low power
- VoLTE 70mA
- WCDMA talking current 85mA
- GSM talking current 50mA |
ASR3603 datasheet V8--.pdf
(10.37 MB, 下载次数: 13)
