TA的每日心情 | 开心 2024-6-20 15:58 |
签到天数: 1 天 [LV.1]初来乍到
长期免费代管18-28岁小
- 8256
只有PCB 。没找到原理图
HI3531DV200DMEB_VER_B_PCB.zip
(3.26 MB, 下载次数: 21)
REFDES | COMP_DEVICE_TYPE | COMP_VALUE | SYM_NAME | D1 | MLF10D-050-0301L | ESD5344D | MLF10D-050-0301L | D2 | SD0402K | ESD5301N | SD0402K | D3 | SD0402K | ESD5301N | SD0402K | D4 | SD0402K | ESD5301N | SD0402K | D5 | SD0402K | ESD5301N | SD0402K | D6 | SD0402K | ESD5301N | SD0402K | D7 | SD0402K | ESD5301N | SD0402K | D8 | HSC0402B | SL_SDV1005E5R5C180NPTF | HSC0402B | D9 | HSC0402B | SL_SDV1005E5R5C180NPTF | HSC0402B | D10 | HSC0402B | SL_SDV1005E5R5C180NPTF | HSC0402B | D11 | HSOD882 | * | HSOD882 | D12 | HSOD882 | * | HSOD882 | D13 | HSOD882 | * | HSOD882 | D14 | HSOD882 | * | HSOD882 | D15 | SD0705A | D4-2 | SD0705A | D16 | HSD0603-LED | LED | HSD0603-LED | D17 | HSC0402B | SL_SDV1005E5R5C180NPTF | HSC0402B | D18 | HSC0402B | SL_SDV1005E5R5C180NPTF | HSC0402B | D19 | SD1710L | SPD9241A | SD1710L | D20 | SD1714D | TISP4350H3BJR_S | SD1714D | D21 | MLF10-050-0301L | OVEL608A1 | MLF10-050-0301L | D22 | MLF10-050-0301L | OVEL608A1 | MLF10-050-0301L | D23 | SD0805-LED | LED | SD0805-LED | D24 | SD0805-LED | LED | SD0805-LED | D25 | SD1710A | 1SMA13CAT3G | SD1710A | D26 | HSOD323A | D_A | HSOD323A | D27 | SOT23 | D2-3_D | SOT23 | D28 | HSC0402B | SL_SDV1005E5R5C180NPTF | HSC0402B | D29 | HSOD882 | * | HSOD882 | D30 | HSOD882 | * | HSOD882 | D31 | SEN3-100C | 3638A | SEN3-100C | D32 | SD0805-LED | LED | SD0805-LED | D33 | MLF10-050-0301L | OVEL608A1 | MLF10-050-0301L | D34 | SD0805-LED | LED | SD0805-LED | D35 | MLF10-050-0301L | OVEL608A1 | MLF10-050-0301L | D36 | HSOD882 | ESD8V0R1B_02LRH | HSOD882 | D37 | HSOD882 | ESD8V0R1B_02LRH | HSOD882 | D38 | SD1714D | TISP4350H3BJR_S | SD1714D | D39 | SD0805-LED | LED | SD0805-LED | D40 | SD0805-LED | LED | SD0805-LED | D41 | HSOD323A | D_A | HSOD323A | F1 | SF6127 | 0451005MRL | SF6127 | ID1 | ID-BOARD | PCB-MARKPOINT | ID-BOARD | ID2 | ID-BOARD | PCB-MARKPOINT | ID-BOARD | ID3 | ID-BOARD | PCB-MARKPOINT | ID-BOARD | ID4 | ID-BOARD | PCB-MARKPOINT | ID-BOARD | ID5 | ID-BOARD | PCB-MARKPOINT | ID-BOARD | ID6 | ID-BOARD | PCB-MARKPOINT | ID-BOARD | J1 | SIP-4P-200 | P2441 | SIP-4P-200 | J2 | USB9-200-1516 | BUSB_A1D328F_9L9C_W | USB9-200-1516 | J3 | SIP-4P-200 | P2441 | SIP-4P-200 | J4 | SHEAD-4P-49 | 53398_0471 | SHEAD-4P-49 | J5 | DIM0425-80-A | 2EG04927_D2D_DF | DIM0425-80-A | J6 | SHEAD-4P-49 | 53398_0471 | SHEAD-4P-49 | J7 | SHEAD-4P-49 | 53398_0471 | SHEAD-4P-49 | J9 | USB4-1415 | 292303_1 | USB4-1415 | J10 | USB4-1415 | 292303_1 | USB4-1415 | J11 | VAF2 | AV_84_5Y_HW | VAF2 | J12 | DB15-3RF-A | 17HE_R13150_73HC2 | DB15-3RF-A | J13 | MJ8-SR-BZ-A | 1_406541_1 | MJ8-SR-BZ-A | J14 | MOLEX_47151 | HDMI_CON | MOLEX_47151 | J15 | MOLEX_47151 | HDMI | MOLEX_47151 | J16 | SHEAD-4P-49 | 53398_0471 | SHEAD-4P-49 | J17 | SHEAD-4P-49 | 53398_0471 | SHEAD-4P-49 | J18 | SHEAD-4P-49 | 53398_0471 | SHEAD-4P-49 | J19 | SHEAD-8P-49 | NC | SHEAD-8P-49 | J20 | SATA7-M-A | 473065002 | SATA7-M-A | J21 | SATA7-M-A | 473065002 | SATA7-M-A | J22 | SED60-16F-A | MIPI_60_CON_F | SED60-16F-A | J23 | SED60-16F-A | MIPI_60_CON_F | SED60-16F-A | J24 | SED60-16F-A | MIPI_60_CON_F | SED60-16F-A | J25 | SED60-16F-A | MIPI_60_CON_F | SED60-16F-A | J26 | SIP-3P | 201_040_003_05_3 | SIP-3P | J27 | PWC0103-M-N | DC2026_00 | PWC0103-M-N | J44 | VAF3-A-MV | AV2_84_9_PB_HW | VAF3-A-MV | J46 | MJ8-SR-BZ-A | 1_406541_1 | MJ8-SR-BZ-A | L1 | SL2828 | 4.7UH | SL2828 | L2 | SL2828 | 4.7UH | SL2828 | L3 | SL1008H | 1UH | SL1008H | L4 | SL1008H | 1UH | SL1008H | L5 | HSL1008 | 2.2UH | HSL1008 | L10 | SL0805D | 470NH | SL0805D | L11 | SPL0707N | 4.7UH | SPL0707N | L12 | SPL0404J | 1UH | SPL0404J | L13 | HSL1008 | 2.2UH | HSL1008 | LB1 | SL0402 | BLM15HG102SN1D | SL0402 | LB2 | SL0402 | BLM15HG102SN1D | SL0402 | LB3 | SL0402 | BLM15HG102SN1D | SL0402 | LB4 | SL0402 | BLM15HG102SN1D | SL0402 | LB5 | SL0402 | BLM15HG102SN1D | SL0402 | LB6 | SL0402 | BLM15HG102SN1D | SL0402 | LB7 | SL0603 | MGLB1608_030T_LF | SL0603 | LB9 | SL1206 | MGLB3216_060T_LF | SL1206 | LB10 | SL0805 | MGLB2012_220T_LF | SL0805 | LB11 | SL0402 | BLM15BD601SN1D | SL0402 | LB12 | SL1206 | MGLB3216_060T_LF | SL1206 | LB13 | SL0805 | MGLB2012_220T_LF | SL0805 | LB14 | SL0402 | BLM15BD601SN1D | SL0402 | LB15 | SL0402 | BLM15BD601SN1D | SL0402 | LB16 | SL0402 | BLM15BD601SN1D | SL0402 | LB17 | SL0402 | BLM15HG102SN1D | SL0402 | LB18 | SL0402 | BLM15HG102SN1D | SL0402 | LB19 | SL0805 | MGLB2012_220T_LF | SL0805 | LB20 | SL0805 | MGLB2012_220T_LF | SL0805 | LB21 | SL0805 | MGLB2012_220T_LF | SL0805 | LB22 | SL0805 | MGLB2012_220T_LF | SL0805 | LB23 | SL0805 | MGLB2012_220T_LF | SL0805 | LB24 | SL0805 | MGLB2012_220T_LF | SL0805 | LB25 | SL0402 | BLM15BD601SN1D | SL0402 | LB26 | SL0402 | BLM15BD601SN1D | SL0402 | LB27 | SL0402 | BLM15BD601SN1D | SL0402 | LB28 | SL0402 | BLM15BD601SN1D | SL0402 | LB29 | SL0402 | BLM15HG102SN1D | SL0402 | LB30 | SL0805 | MGLB2012_220T_LF | SL0805 | LB31 | SL0402 | BLM15BD601SN1D | SL0402 | LB32 | SL0402 | BLM15HG102SN1D | SL0402 | LB33 | SL0402 | BLM15HG102SN1D | SL0402 | LB34 | SL0402 | BLM15HG102SN1D | SL0402 | LB35 | SL0402 | BLM15HG102SN1D | SL0402 | LB36 | SL0402 | BLM15HG102SN1D | SL0402 | LB79 | SL0805 | MGLB2012_220T_LF | SL0805 | LB80 | SL0805 | MGLB2012_220T_LF | SL0805 | M1 | MTH_C6MMD3P2MM | HOLE-8STARS | MTH_C6MMD3P2MM | M2 | MTH_C6MMD3P2MM | HOLE-8STARS | MTH_C6MMD3P2MM | M3 | MTH_C6MMD3P2MM | HOLE-8STARS | MTH_C6MMD3P2MM | M4 | MTH_C6MMD3P2MM | HOLE-8STARS | MTH_C6MMD3P2MM | M5 | MTH_C6MMD3P2MM | HOLE-8STARS | MTH_C6MMD3P2MM | M6 | MTH_C6MMD3P2MM | HOLE-8STARS | MTH_C6MMD3P2MM | M7 | MTH_C6MMD3P2MM | HOLE-8STARS | MTH_C6MMD3P2MM | M8 | MTH_C6MMD3P2MM | HOLE-8STARS | MTH_C6MMD3P2MM | M9 | HOLE126-158 | HOLE | HOLE126-158 | M10 | MTH_C6MMD3P2MM | HOLE-8STARS | MTH_C6MMD3P2MM | M11 | HOLE126-158 | HOLE | HOLE126-158 | OSC1 | SX4-0705 | 12.288MHZ/NC* | SX4-0705 | Q1 | SOT23 | NPN-BEC | SOT23 | S1 | SSW-PUSH | TL3301AF160RG | SSW-PUSH | S2 | PSW3-RA | BR-11C-11P6 | PSW3-RA | SW1 | SW4_6M6X5M4 | EMR_0415_T_V_T_R | SW4_6M6X5M4 | T1 | STFM24-40-280 | G24_0413ER | STFM24-40-280 | T2 | STFM24-40-280 | G24_0413ER | STFM24-40-280 | TP5 | TP24-SMD | TEST-SMD | TP24-SMD | TP6 | TP24-SMD | TESTPOINT-SMD | TP24-SMD | TP7 | TP24-SMD | TESTPOINT-SMD | TP24-SMD | TP8 | TP24-SMD | TESTPOINT-SMD | TP24-SMD | TP9 | TP24-SMD | TESTPOINT-SMD | TP24-SMD | TP10 | TP24-SMD | TESTPOINT-SMD | TP24-SMD | U1 | BGA791-32-2839 | HI3531DV200 | BGA791-32-2839 | U2 | BGA96-32-1609I | K4A8G165WC-BCTDTCV | BGA96-32-1609I | U3 | BGA96-32-1609I | K4A8G165WC-BCTDTCV | BGA96-32-1609I | U4 | BGA96-32-1609I | K4A8G165WC-BCTDTCV | BGA96-32-1609I | U5 | BGA96-32-1609I | K4A8G165WC-BCTDTCV | BGA96-32-1609I | U6 | MLF6-065-0202L | SY6287CABC | MLF6-065-0202L | U7 | MLF6-065-0202L | SY6287CABC | MLF6-065-0202L | U8 | MLF6-065-0202L | SY6287CABC | MLF6-065-0202L | U9 | SOP10-20-124A | INA220AIDGSR | SOP10-20-124A | U10 | SOP16-26-173 | 557GI_03LF | SOP16-26-173 | U11 | QFN40-8211FI | RTL8211FI-CG | QFN40-8211FI | U12 | SOP8-50-150 | ADM706RAR | SOP8-50-150 | U13 | SOP16-50-300A | NC* | SOP16-50-300A | U14 | SBAT2-13A | BR_1225F1AN_A | SBAT2-13A | U15 | HSOT-SC70-DCK | SN74LVC1G125DCKR | HSOT-SC70-DCK | U16 | MLF64C-050-0909L | LT8618SX | MLF64C-050-0909L | U17 | BGA153-20-1414-ENIG | H26M41204HPR | BGA153-20-1414-ENIG | U18 | SOP10-20-124A | INA220AIDGSR | SOP10-20-124A | U19 | SOT23-6J | CLAMP0504DL1HP | SOT23-6J | U24 | WSON8-MX25L12835ZN | 8PIN_SPI_FLASH | WSON8-MX25L12835ZN | U25 | SOP10-20-124A | INA220AIDGSR | SOP10-20-124A | U26 | SOP8-50-150 | ADM3485EAR_REEL7 | SOP8-50-150 | U28 | SOT23-6B | RT9065GE_A | SOT23-6B | U29 | MLF14-050-0302L | MP28251GD-Z | MLF14-050-0302L | U30 | HSOT583-8 | MP1614 | HSOT583-8 | U31 | SOT23-8 | MP1495D | SOT23-8 | U32 | SOT23-8 | MP1495D | SOT23-8 | U33 | QFN12-050-0302A-MV | MP2145 | QFN12-050-0302A-MV | U34 | HSOT-563 | MP1605C | HSOT-563 | U35 | HSOT-563 | MP1601A | HSOT-563 | U36 | MLF28A-045-0404L | ES8388 | MLF28A-045-0404L | U37 | QFN40-8211FI | RTL8211FI-CG | QFN40-8211FI | X1 | HSX4-0302 | 25MHZ | HSX4-0302 | X2 | HSX4-0302 | 25MHZ | HSX4-0302 | X3 | HSX4-0302 | 24MHZ | HSX4-0302 | X4 | HSX2-0302 | 32.768KHZ | HSX2-0302 | X5 | HSX4-0302 | 25MHZ | HSX4-0302 |
