[Allegro17.4以下] 8层工控 电脑主板PCB文件共享
查看3980 | 回复65 | 2022-3-5 14:35:49 | 显示全部楼层 |阅读模式
重要提示:PCB作品文件展下载说明
ATXPWR1CON5X2_165U_1MINI-ATXCONN/10PINCON5X2_165U_1
ATXPWR2CON5X2_165U_1MINI-ATXCONN/10PINCON5X2_165U_1
ATXPWR3CON5X2_165U_1MINI-ATXCONN/10PINCON5X2_165U_1
AUDIO1PH2X5_2D_S180PINHEADER 2X5_2.0MM_S180PH2X5_2D_S180
AUDIO2PH2X5_2D_S180PINHEADER 2X5_2.0MM_S180PH2X5_2D_S180
AUTO1MYLAN_WAKE_UPPINHEADER 1X3_2.0MM_D180MYLAN_WAKE_UP
A_USB1PH2X4_2D_S180PINHEADER 2X4_2.0MM_S180PH2X4_2D_S180
A_USB2PH2X4_2D_S180PINHEADER 2X4_2.0MM_S180PH2X4_2D_S180
A_USB3USBUSBX2_9_2.77MM_D90_USBUSB
BAT1BAT3P_23D1X5D8BATTERYHOLDER CR2032LBAT3P_23D1X5D8
BR1GBJ15_DGBJ1502/DIPGBJ15_D
BZ1BZ_250BUZERBZ_250
B_USB1USB-1USBX1_D90USB-1
B_USB2USB-1USBX1_D90USB-1
C632SM1206C0.001UF/2KV(1206)SM1206C
CF1CF50_450XXW101CONNECTOR_CF/25X2P/SMDCF50_450XXW101
CLR_CMOS1PH1X3_2D_D180PINHEADER 1X3_2.0MM_D180PH1X3_2D_D180
COM1DCON9M-TCOM9M_DB9_D90DCON9M-T
COM2PH2X5_2D_S180PINHEADER 2X5_2.0MM_S180PH2X5_2D_S180
COM3DCON9M-TCOM9M_DB9_D90DCON9M-T
COM4DCON9M-TCOM9M_DB9_D90DCON9M-T
COM5DCON9M-TCOM9M_DB9_D90DCON9M-T
COM6DCON9M-TCOM9M_DB9_D90DCON9M-T
C_USB1PH2X4_2D_S180PINHEADER 2X4_2.0MM_S180PH2X4_2D_S180
C_USB2PH2X4_2D_S180PINHEADER 2X4_2.0MM_S180PH2X4_2D_S180
C_USB3USBUSBX2_9_2.77MM_D90_USBUSB
D11N5817A1N58171N5817A
D2BAT54C_132BAT54C_SOT23BAT54C_132
D3BAT54_132BAS19_SOT23BAT54_132
D4SM1206D_AC1N4148SM1206D_AC
D51N5817A1N58171N5817A
D6BAT54C_132BAT54C_SOT23BAT54C_132
D71N5817A1N58171N5817A
D8BAT54C_132BAT54C_SOT23BAT54C_132
D9BAT54C_132BAT54C_SOT23BAT54C_132
D101N5817ASM260A_DO214AC1N5817A
D111N5817A1N58171N5817A
D12BAT54S_132BAT54S_SOT23BAT54S_132
D13BAT54S_132BAT54S_SOT23BAT54S_132
D14BAT54C_132BAT54C_SOT23BAT54C_132
D15SM1206D_AC1N4148SM1206D_AC
D16SM1206D_AC1N4148SM1206D_AC
D17BAT54C_132BAT54C_SOT23BAT54C_132
D18SM1206D_AC1N4148/NCSM1206D_AC
D19BAT54S_132BAT54S_SOT23BAT54S_132
DC12V_IN1KDJACK_POWERPOWER_JACK2X2PINKDJACK_POWER
DC48V_IN1KDJACK_POWERPOWER_JACK2X2PINKDJACK_POWER
DVI1KDCON12X2_1D27MFEMALEHEADER2X12_1.27MM_S180KDCON12X2_1D27M
DVI2FH2X12-HD-1P27MPINHEADER2X12_1.27MM_D180FH2X12-HD-1P27M
DVI_D1DVI30ADVI-D/NCDVI30A
EC1EC_10X12D547UF/100V(DIP)EC_10X12D5
EC2EC_10X12D547UF/100V(DIP)EC_10X12D5
FAN1MYFAN_LFAN_CONN/NCMYFAN_L
FP1PH2X5_2D_S180PINHEADER 2X5_2.0MM_S180PH2X5_2D_S180
FP2PH2X5_2D_S180PINHEADER 2X5_2.0MM_S180PH2X5_2D_S180
FS1FUSE_SMDFUSE_1.1AFUSE_SMD
FS2FUSE_SMDFUSE_1.1AFUSE_SMD
FS3FUSE_SMDFUSE_1.1AFUSE_SMD
GAS1TS-DO201CNR-GAS_C8G75/DIPTS-DO201
GAS2TS-DO201CNR-GAS_C8G75/DIPTS-DO201
GPIO1PH2X5_2D_S180PINHEADER 2X5_2.0MM_S180PH2X5_2D_S180
H1MTH360_157157DRILL / 360PADMTH360_157
IDE1PH2X22_2D_S180PINHEADER 2X22_2.0MM_S180PH2X22_2D_S180
INV1CON5_BWAFER1X5_2.0MM_D180CON5_B
JP1KDCON26X2_1D27MFEMALEHEADER2X26_1.27MM_S180KDCON26X2_1D27M
JP2PH1X2_2D_D180PINHEADER 1X2_2.0MM_D180PH1X2_2D_D180
JP3PH1X2_2D_D180PINHEADER 1X2_2.0MM_D180PH1X2_2D_D180
JP4KDCON4X2_2MPINHEADER 2X4_2.0MM_D180KDCON4X2_2M
JP5PH2X3_2D_S180PINHEADER 2X3_2.0MM_S180PH2X3_2D_S180
JP6PH2X4_2D_S180PINHEADER 2X4_2.0MM_S180PH2X4_2D_S180
JP7PH2X4_2D_S180PINHEADER 2X4_2.0MM_S180PH2X4_2D_S180
JP8PH2X5_2D_S180PINHEADER 2X5_2.0MM_S180PH2X5_2D_S180
JP9PH2X5_2D_S180PINHEADER 2X5_2.0MM_S180PH2X5_2D_S180
JP10PH2X3_2D_S180PINHEADER 2X3_2.0MM_S180PH2X3_2D_S180
JP11PH2X3_2D_S180PINHEADER 2X3_2.0MM_S180PH2X3_2D_S180
JP12PH2X3_2D_S180PINHEADER 2X3_2.0MM_S180PH2X3_2D_S180
JP13FH2X26-HD-1P27MPINHEADER2X26_1.27MM_D180FH2X26-HD-1P27M
L1SM0603LBEAD30SM0603L
L2SM0603LBEAD30SM0603L
L3SM0603LBEAD30SM0603L
L4SM0603LBEAD30SM0603L
L5GSD0735KS1UH/12A_GSD0735KS(SMD)GSD0735KS
L6SM0603LBEAD30SM0603L
L7GSD0735KS1UH/12A_GSD0735KS(SMD)GSD0735KS
L8TYL17X1012UH/9.6A(DIP)TYL17X10
L9SM0805L10UH(0805)SM0805L
L10GTLQH2510UH/190MA_GTLQH25-100K(SMD)GTLQH25
L11GSD0735KS1UH/12A_GSD0735KS(SMD)GSD0735KS
L12GTLQH2510UH/190MA_GTLQH25-100K(SMD)GTLQH25
L13SM0805L10UH(0805)SM0805L
L14GSD0735KS1UH/12A_GSD0735KS(SMD)GSD0735KS
L15WQPC0302100NH/5A_WQPC0302-R10N(SMD)WQPC0302
L16SM0805L0.1UH(0805)SM0805L
L17TYL17X1012UH/9.6A(DIP)TYL17X10
L18TYL17X103UH/10ATYL17X10
L19TYL17X1012UH/9.6A(DIP)TYL17X10
L20SM0805LBEAD120(0805)SM0805L
L21SM0603LBEAD30SM0603L
L22GSD0735KS1UH/12A_GSD0735KS(SMD)GSD0735KS
L23GSD0735KS1UH/12A_GSD0735KS(SMD)GSD0735KS
L24SM0603LBEAD30SM0603L
L25SM0603LBEAD30SM0603L
L26TYL17X1012UH/9.6A(DIP)TYL17X10
LAN1KDRJ45RJ-45KDRJ45
LAN2KDRJ45RJ-45KDRJ45
LCD_PWR1PH1X3_2D_D180PINHEADER 1X3_2.0MM_D180PH1X3_2D_D180
LED1LED-504LED(BLUE)LED-504
LED2LED-525LEDHOLDER(/BLUE/ORG)_5MM_D180LED-525
LINE_IN1AUDIO_JACK_1LPHONEJACKSTEREO SW(BLUE)AUDIO_JACK_1L
LINE_OUT1AUDIO_JACK_1LPHONEJACKSTEREO SW(GREEN)AUDIO_JACK_1L
LPT1CON13X2_2MCBOXHEADER 2X13_2.0MM_D180CON13X2_2MC
LVDS1CON15X2_1D25_01036WAFER2X15_1.25MM_S180CON15X2_1D25_01036
MIC1AUDIO_JACK_1LPHONEJACKSTEREO SW(PINK)AUDIO_JACK_1L
PCI1DP-PC104PLUSA_BD_D35PCI104DP-PC104PLUSA_BD_D35
POE_PWR1CON2_42X55_9359WPWR_CONN/2PINCON2_42X55_9359W
PS_1PS2_6P_T_1MINIDIN6(BLACK/THIN)PS2_6P_T_1
PWR_IN1CON2L_5M_5EHDRPOWERCONNECTOR_2PIN(5EHDR-02P)CON2L_5M_5EHDR
PWR_SW1PTA-118CBTACKSWITCHPTA-118CB
Q12N7002B2N7002/SOT232N7002B
Q2MYSMDTO252_GDSAP9974AGH_TO252MYSMDTO252_GDS
Q3MYSMDTO252_GDSAP9974AGH_TO252MYSMDTO252_GDS
Q4MYSMDTO252_GDSSTU5025NLS_TO252MYSMDTO252_GDS
Q52N7002B2N7002/SOT232N7002B
Q62N7002B2N7002/SOT232N7002B
Q7MYSMDTO252_GDSAP9974AGH_TO252MYSMDTO252_GDS
Q8MYSMDTO252_GDSAP9974AGH_TO252MYSMDTO252_GDS
Q9MYSMDTO252_GDSAP9974AGH_TO252MYSMDTO252_GDS
Q10MYSMDTO252_GDSSTU5025NLS_TO252MYSMDTO252_GDS
Q11MYSMDTO252_GDSAP9974AGH_TO252MYSMDTO252_GDS
Q12MYSMDTO252_GDSSTU5025NLS_TO252MYSMDTO252_GDS
Q13MYSMDTO252_GDSSTU5025NLS_TO252MYSMDTO252_GDS
Q14MYSMDTO252_GDSSTU5025NLS_TO252MYSMDTO252_GDS
Q152N7002B2N7002/SOT232N7002B
Q16SOT23_QA2N3904/SOT23SOT23_QA
Q172N7002B2N7002/SOT232N7002B
Q18MYSMDTO252_GDSAP9974AGH_TO252MYSMDTO252_GDS
Q192N7002B2N7002/SOT232N7002B
Q20SOT23_QA2N3904/SOT23SOT23_QA
Q21SOT223_GDSAPM2054NVC_SOT223_GDSSOT223_GDS
Q22MYSMDTO252_GDSSTU5025NLS_TO252MYSMDTO252_GDS
Q23SOIC8APM4461AKC-TRL_SOIC8SOIC8
Q24MYSMDTO252_GDSAP9974AGH_TO252MYSMDTO252_GDS
Q25MYSMDTO252_GDSAP9974AGH_TO252MYSMDTO252_GDS
Q26MYSMDTO252_GDSAP9974AGH_TO252MYSMDTO252_GDS
Q27MYSMDTO252_GDSSTU5025NLS_TO252MYSMDTO252_GDS
Q282N7002B2N7002/SOT232N7002B
Q29MYSMDTO252_GDSSTU5025NLS_TO252MYSMDTO252_GDS
Q30SOT23_QA2N3904/SOT23SOT23_QA
Q31MYSMDTO252_GDSAP9974AGH_TO252MYSMDTO252_GDS
Q32MYSMDTO252_GDSSTU5025NLS_TO252MYSMDTO252_GDS
Q33MYSMDTO252_GDSSTU5025NLS_TO252MYSMDTO252_GDS
Q34SOIC8APM4435KC-TRL_SOIC8SOIC8
Q35MYSMDTO252_GDSSTU5025NLS_TO252MYSMDTO252_GDS
Q36MYSMDTO252_GDSAP9974AGH_TO252MYSMDTO252_GDS
Q37MYSMDTO252_GDSSTU5025NLS_TO252MYSMDTO252_GDS
Q38SOT23_QA2N3906/SOT23SOT23_QA
Q39MYSMDTO252_GDSAP9974AGH_TO252MYSMDTO252_GDS
Q40SOT23_QA2N3904/SOT23/NCSOT23_QA
Q41SOT23_QA2N3904/SOT23SOT23_QA
Q42SOT23_QA2N3904/SOT23SOT23_QA
Q43SOT23_QA2N3904/SOT23SOT23_QA
Q44SOT23_QA2N3904/SOT23SOT23_QA
RT1SM0603RTHERS_10K1%/NCSM0603R
SATA1SATA7P_MOLEXSATA_SATA7P_MOLEXSATA7P_MOLEX
SATA2SATA7P_MOLEXSATA_SATA7P_MOLEXSATA7P_MOLEX
SATA_PWR1CON5_BWAFER1X5_2.0MM_D180CON5_B
SC1MYEC138_350270UF/16VMYEC138_350
SC2MYEC200_400470UF/16VMYEC200_400
SC3MYEC200_400470UF/16VMYEC200_400
SC4MYEC138_350270UF/16VMYEC138_350
SC5MYEC200_400470UF/16VMYEC200_400
SC6MYEC138_350270UF/16VMYEC138_350
SC7MYEC138_350270UF/16VMYEC138_350
SC8MYEC138_350270UF/16VMYEC138_350
SMBUS1MYLAN_WAKE_UPWAFER1X3_2.0MM_D180/NCMYLAN_WAKE_UP
SODIMM1DDR_SODIMM_HLDDR2SODIMM 200PIN_9.2MMDDR_SODIMM_HL
SPDIF1MYLAN_WAKE_UPWAFER1X3_2.0MM_D180/NCMYLAN_WAKE_UP
U1SSOP28ZT213_SSOP28SSOP28
U2SOT23-5HIP1020_SOT23-5SOT23-5
U3TSSOP64F-240IC-SICS9LP505-1HGLFT_TSSOP64TSSOP64F-240
U4SSOP28ZT213_SSOP28SSOP28
U5TSSOP16_D65_GNDALT3800EFE_TSSOP16TSSOP16_D65_GNDA
U6QFN64_9X9RTL8111C_QFN64_9X9QFN64_9X9
U7QFN64_9X9RTL8111C_QFN64_9X9QFN64_9X9
U8SOIC14ISL6522CBSOIC14
U9SOIC893C46_SOIC8SOIC8
U10SOIC14ISL6522CBSOIC14
U11DIAMONDVILLE_BGA437INTELN270DIAMONDVILLE_BGA437
U12DIP4PC817C/DIPDIP4
U1382945GSE_BGA998945GSE82945GSE_BGA998
U14BGA652-ICH7MICH7-MBGA652-ICH7M
U15SOIC8APW7120KE-TRL_SOIC8SOIC8
U16MAX8796-QFN32MAX8796GTJ+_TQFN32_5X5MAX8796-QFN32
U17SOP8B-209SST25VF016B-50-4C-S2AF_SOP8B-209SOP8B-209
U18SOIC1474HCT14_SOIC14SOIC14
U19ISL6537-QFN28PISL6537ACRZ-TISL6537-QFN28P
U20LQFP48CH7307C_LQFP48LQFP48
U21SOIC1474F125_SOIC14SOIC14
U22SOIC1474HC08_SOIC14SOIC14
U23HN2436G_24HN2436G_HN2436G_24HN2436G_24
U24HN2436G_24HN2436G_HN2436G_24HN2436G_24
U25TYQFP128_D5W83627UHG_TYQFP128_D5TYQFP128_D5
U26EPSOIC8ISL6506BCBZ-TEPSOIC8
U27SOIC893C46_SOIC8SOIC8
U28SOIC8-1ISL6612ACB-T_SOIC8-1SOIC8-1
U29SOT23-5HIP1020_SOT23-5SOT23-5
U30MYSMDTO252_GOIAPL1084-ADJ/TO252MYSMDTO252_GOI
U31MYSOT223_GOIAPL1117-ADJ_SOT223MYSOT223_GOI
U32SOIC8APW7120KE-TRL_SOIC8SOIC8
U33SOT23_OIGAPR3001-30AI-TRL_SOT-23/NCSOT23_OIG
U34SOT23_OIGAPR3001-30AI-TRL_SOT-23SOT23_OIG
U35SOT23-5SN74LVC1G14DBVR_SOT23-5SOT23-5
U36SOT23-5SN74LVC1G14DBVR_SOT23-5SOT23-5
U37LQFP48VT1708A_LQFP48LQFP48
U38SOIC1474F125_SOIC14SOIC14
U39SOIC8LTC485_SOIC8SOIC8
U40SOIC8LTC485_SOIC8SOIC8
U41SSOP28ZT213_SSOP28SSOP28
U42SOIC1474HCT14_SOIC14SOIC14
U43SSOP28ZT213_SSOP28SSOP28
U44SSOP28ZT213_SSOP28SSOP28
U45SSOP28ZT213_SSOP28SSOP28
U46SOIC8LTC485_SOIC8SOIC8
U47SOIC8LTC485_SOIC8SOIC8
VGA1VGACON15_S_KD-TDSUB_VGA_PORT(BLUE/THIN)VGACON15_S_KD-T
X1SMD_49_CRYSTAL25MHZ/SMDSMD_49_CRYSTAL
X2SMD_49_CRYSTAL25MHZ/SMDSMD_49_CRYSTAL
X3XTALS32.768KHZ/DIPXTALS
X4SMD_49_CRYSTAL14.318MHZ/SMDSMD_49_CRYSTAL
重要提示:PCB作品文件展下载说明
此广告位出租
sisi9000 | 2022-3-5 14:36:25 | 显示全部楼层
PCB文件。回复可见下载
游客,如果您要查看本帖隐藏内容请回复
此广告位出租
lf2k2022 | 2022-3-5 14:45:18 | 显示全部楼层
ljbhander | 2022-3-5 15:36:31 | 显示全部楼层
邵先生 | 2022-3-5 16:47:41 | 显示全部楼层
roezw | 2022-3-5 17:32:17 | 显示全部楼层
fengok008 | 2022-3-5 17:43:44 | 显示全部楼层
shuszhao | 2022-3-5 18:34:34 | 显示全部楼层
bidinghong | 2022-3-5 19:17:47 | 显示全部楼层
cml_l | 2022-3-5 20:09:48 | 显示全部楼层
