查看: 3354|回复: 34
[Allegro17.4以下] RTL8211F-CG+HDM1216D+GL850G+BMA250 做的底板PCB文件共享
    终身成就奖社区居民忠实会员宣传大使奖优秀斑竹奖
    发表于 2022-3-15 09:22:12 | 显示全部楼层 |阅读模式
    重要提示:PCB作品文件展下载说明
    Lindenis_V536_Expanding_Board_PCB_V2_0.zip (1.13 MB, 下载次数: 13)
    ANT2ANT_0_ANT3B300_310H125_IPEXIPEXANT3B300_310H125
    ANT3SMA/RF_1_ANT3B300_310H125_GPS-AGPS-ANTANT3B300_310H125
    D7DIODE_SCHOTTKY_0_SOD80_120H80_RRB521S-30SOD80_120H80
    D10ESD9B5VL_ESD0402_NC-ESD5451XNC-ESD5451XESD0402
    D111_1.5KE100A_ESD0402_ESD9B5VL-2/ESD9B5VL-2/TRESD0402
    D35ESD9B5VL_ESD0402_NC-ESD5451XNC-ESD5451XESD0402
    D39ESD5451X_ESD0402_ESD5451X-2-TRESD5451X-2-TRESD0402
    D40ESD5451X_ESD0402_ESD5451X-2-TRESD5451X-2-TRESD0402
    D41D_0_SOD155_270H118_1N5819HW-7-F1N5819HW-7-FSOD155_270H118
    D608DIODE_SCHOTTKY_3_SOD80_120H80_RRB521S-30SOD80_120H80
    D6091_1.5KE100A_ESD0402_ESD5451XESD5451XESD0402
    D6101_1.5KE100A_ESD0402_ESD5451XESD5451XESD0402
    DH21_1.5KE100A_ESD0402_ESD5451XESD5451XESD0402
    DH31_1.5KE100A_ESD0402_ESD5451XESD5451XESD0402
    DH41_1.5KE100A_ESD0402_ESD5451XESD5451XESD0402
    DH51_1.5KE100A_ESD0402_ESD5451XESD5451XESD0402
    DH12DIO-B5819W_SOD155_270H118_B5819B5819WSOD155_270H118
    DK1TVS-FBP-02C_ESD0402_ESD9B5V-2/TESD9B5V-2/TRESD0402
    DK2TVS-FBP-02C_ESD0402_ESD9B5V-2/TESD9B5V-2/TRESD0402
    DL6LED_0_LED0603_REDREDLED0603
    DL7LED_0_LED0603_GREENGREENLED0603
    DL491_1.5KE100A_ESD0402_NC/ESD5451XNC/ESD5451XESD0402
    DL501_1.5KE100A_ESD0402_NC/ESD5451XNC/ESD5451XESD0402
    DL511_1.5KE100A_ESD0402_NC/ESD5451XNC/ESD5451XESD0402
    DL521_1.5KE100A_ESD0402_NC/ESD5451XNC/ESD5451XESD0402
    DM1LED_3_LED0805_POWERPOWERLED0805
    FB12INDUCTOR_4_L0603_0R0RL0603
    FB22INDUCTOR_L0603_600R@100M-1A600R@100M-1AL0603
    J1CON3_HDR1_3P200B670_600H610_BATBATTARYHDR1_3P200B670_600H610
    J3SDMMCSLOT_0_SDC13B1450_1472H24MICROSD/TF_SLOTSDC13B1450_1472H245
    J7CON40-B070EW01_0_FPC42P50B450_2CON30-P05FPC42P50B450_2410H150_B
    J9USB_A_4_USB-2400-DIP_USB/AUSB/AUSB-2400-DIP
    J11HEADER10X2_HDR2_10P254B500_2540Header10x2HDR2_10P254B500_2540H254
    J12XH2.54MM-5P-M_HDR1_5P250B570_15XH2.54MM-5P-MHDR1_5P250B570_1500H700
    J21PJ-327F_HP5B650_1400H500_PJ-327PJ-327FHP5B650_1400H500
    J33CON1X4-2_0.54-M_HDR1_3P254B250_CON1X3-2.54-MHDR1_3P254B250_762H254
    J35CON1X4-2.54-M_HDR1_4P254B250_10CON1X4-2.54-MHDR1_4P254B250_1016H254
    J36CON1X4-2.54-M_HDR1_4P254B250_10CON1X4-2.54-MHDR1_4P254B250_1016H254
    J56CON1X4-2_0.54-M_HDR1_3P254B250_CON1X3-2.54-MHDR1_3P254B250_762H254
    J79HP_JACK_HP5B650_1400H500_HP-JACHP-JACKHP5B650_1400H500
    J80CON1X4-2_1.54-M_KEY2B452_749H44SDA01H1SBDKEY2B452_749H445
    J81PHONEJACK_DCIN_0_DC-208_DC-IN-JDC-IN-JACKDC-208
    J82HEADER10X2_HDR2_10P254B500_2540Header10x2HDR2_10P254B500_2540H254
    JH1HDMI19_PLUG_HDMI23P50B1215_1500HDMI_19plugtype AHDMI23P50B1215_1500H838
    JL6FPC-6P-0_0.5MM-B_FPC8P50B320_50FPC-6P-0.5MM-BFPC8P50B320_500H150_B
    JL26SDMMCSLOT_5_SIM-6_1_SIM508CSIM508CSIM-6_1
    KK1SWITCH_PUSH_KEY4B620_620H430_VOVOL+KEY4B620_620H430
    KK2SWITCH_PUSH_KEY4B620_620H430__1VOL-KEY4B620_620H430
    KK3SWITCH_PUSH_KEY4B620_620H430_MEMENUKEY4B620_620H430
    KK4SWITCH_PUSH_KEY4B620_620H430_ENENTERKEY4B620_620H430
    KK5SWITCH_PUSH_KEY4B620_620H430_HOHOMEKEY4B620_620H430
    KK6SWITCH_PUSH_KEY4B620_620H430_FEFELKEY4B620_620H430
    KP1SW_PUSH_5_KEY4B620_620H430_PWROPWRONKEY4B620_620H430
    L12INDUCTOR_LP200_250H100_10UH_1A10uH_1ALP200_250H100
    LM1L-LP2_00X1_60H1_00_LP200_250H102.2uH/1ADCR<0.1RLP200_250H100
    LP7INDUCTOR_1_LP400_400H120_2.2UH@2.2uH@3ADCR<0.1RLP400_400H120
    MIC1MICPHONE_0_MIC2B600H500_MICPHONMicphoneMIC2B600H500
    OC5CAPACITOR_POL_0_CA660H770_220_1220uF/16VCA660H770
    OC6CAPACITOR_POL_0_CA660H770_220_1220uF/16VCA660H770
    Q2NMOS-2N7002_SOT3P95B130_290H1032N7002SOT3P95B130_290H103
    Q23NMOS-BSN20_SOT3P95B130_290H103_BSN20SOT3P95B130_290H103
    QL1NPN_SOT3P95B130_290H103_WNT2F04WNT2F04/MMBT3904SOT3P95B130_290H103
    QL3NPN_SOT3P95B130_290H103_MMBT390MMBT3904SOT3P95B130_290H103
    QL5NPN-MMBT3904_SOT3P95B130_290H10MMBT3904SOT3P95B130_290H103
    QL13NPN_SOT-23_MMBT3904MMBT3904SOT-23
    TP88TESTPOINT SURFACE_TP_PAD_TESTTESTPOINT SURFACETP_PAD
    U2UP0107_0_SOT5P95B160_300H130_AAP2127k-ADJSOT5P95B160_300H130
    U3BAT_0_CSE_BATBATCSE
    U8FEB1216_DFN24P110B1220_1600H270NC-HDM1216DDFN24P110B1220_1600H270
    U11NAND_FLASH_TSOP48_9_HDR2_7P254_2_54_16PHDR2_7P254
    U12HDR11X2_1_HDR2_7P2_00_DIP14_2_0DIP14_2_0HDR2_7P2_00
    U13HDR11X2_2_HDR2_8P2_00_DIP16_2_0DIP16_2_0HDR2_8P2_00
    U19HFJ11-1G01E_2_RJ45-HFJ11-1G01E_RMS-086C-10F0-GYRJ45-HFJ11-1G01E
    U22CON10X2 2.0MM_IDC200-20_CON 10CON10x2 2.0mmIDC200-20
    U23SSM2402/SO_2_SOP11P50B300_300H1SMG8905SOP11P50B300_300H110
    U24UP0107_0_SOT23-5_AP2127K-1.8AP2127k-1.8SOT23-5
    U27AP1511B_2_SUB_4G87B3000_3000H29SIM7600CSUB_4G87B3000_3000H290
    U32GL850G_SSOP28_SOP28P65B530_1020GL850G_SSOP28SOP28P65B530_1020H200
    U39RT9293B_SOT6P95B160_290H145_RT9RT9293B20GJ6SOT6P95B160_290H145
    U51SGM7227_SOP10P50B300_300H110_SGSGM7227SOP10P50B300_300H110
    U901A10_MODE_20_V536_156PIN_V536_MOV536_MODEV536_156PIN
    U902BMA222_QFN12P50B200_200H100_BMABMA250QFN12P50B200_200H100
    UH1RRCLAMP0524P_RCLAMP0524P_AZ1345AZ1345-04FRCLAMP0524P
    UH2RRCLAMP0524P_RCLAMP0524P_AZ1345AZ1345-04FRCLAMP0524P
    UL9SY8088_0_SOT6P95B180_310H100_SYSY8120B1ABCSOT6P95B180_310H100
    UM1RTL8169S_1_QFN41P40B500_500H75_RTL8211F-CGQFN41P40B500_500H75
    UM2NAND_FLASH_TSOP48_1_GB042-34P-HGB042-34S-H10-PlugGB042-34P-H10-PLUG
    USB1USB_MINI_SOCKET_0_USB9P65B495_7MIRCO_USB_5PUSB9P65B495_740H235
    UU3SY6280_SOT5P95B160_300H130_SY62SY6280SOT5P95B160_300H130
    X3CRYSTAL-4_0_X4B250_320H80_SMD_NNC/25M-12pF-20PPMX4B250_320H80_SMD
    Y3XTAL-4P_X4B250_320H80_SMD_12MHZ12MHz/3225X4B250_320H80_SMD
    重要提示:PCB作品文件展下载说明
    前天 10:32
  • 签到天数: 128 天
    你必须非常努力才能显
    发表于 2022-3-15 09:36:03 | 显示全部楼层
    发表于 2022-3-15 09:47:26 | 显示全部楼层
    11 小时前
    社区居民终身成就奖特殊贡献奖优秀斑竹奖
    发表于 2022-3-15 09:56:21 | 显示全部楼层
  • 签到天数: 30 天
    发表于 2022-3-15 09:57:23 | 显示全部楼层
    6 天前
  • 签到天数: 62 天
    PADS-171101高级班
    终身成就奖特殊贡献奖优秀斑竹奖
    发表于 2022-3-15 12:21:33 | 显示全部楼层
    社区居民忠实会员终身成就奖特殊贡献奖优秀斑竹奖
    发表于 2022-3-15 12:44:17 | 显示全部楼层
  • 签到天数: 4 天
    1元学习Allegro(1期)
    社区居民终身成就奖特殊贡献奖优秀斑竹奖
    发表于 2022-3-15 22:24:23 | 显示全部楼层
    昨天 19:43
  • 签到天数: 135 天
    社区居民终身成就奖特殊贡献奖原创先锋奖
    发表于 2022-3-15 22:30:25 | 显示全部楼层
    10 小时前
  • 签到天数: 220 天
    发表于 2022-3-16 00:05:35 | 显示全部楼层
