查看: 2961|回复: 26
[Allegro17.4以下] 国产飞腾FT1500A 四核CPU 服务器电脑主板PCB 文件
    终身成就奖社区居民忠实会员宣传大使奖优秀斑竹奖
    发表于 2022-3-30 13:48:01 | 显示全部楼层 |阅读模式
    重要提示:PCB作品文件展下载说明
    B1BUZZER_1_BZ_BUZZERBUZZERBZ
    D1CCL-CRS10/SM_0_LED0603_RED_LDERED_LDELED0603
    D2CCL-CRS10/SM_0_LED0603_GREEN_LDGREEN_LDELED0603
    D3CCL-CRS10/SM_0_LED0603_GREEN_LDGREEN_LDELED0603
    D4CCL-CRS10/SM_0_LED0603_GREEN_LDGREEN_LDELED0603
    D5CCL-CRS10/SM_0_LED0603_GREEN_LDGREEN_LDELED0603
    D6CCL-CRS10/SM_0_LED0603_GREEN_LDGREEN_LDELED0603
    D7CCL-CRS10/SM_0_LED0603_GREEN_LDGREEN_LDELED0603
    D8CCL-CRS10/SM_0_LED0603_GREEN_LDGREEN_LDELED0603
    D9CCL-CRS10/SM_0_LED0603_GREEN_LDGREEN_LDELED0603
    D10DIODE_DO0402_CDBQR0130RCDBQR0130RDO0402
    D11DIODE_DO0402_CDBQR0130RCDBQR0130RDO0402
    EU1TPS74801_U-SON-10-0_5-TEXAS-TPSTPS74801U-SON-10-0_5-TEXAS-TPS74701
    EU2TPS74801_U-SON-10-0_5-TEXAS-TPSTPS74801U-SON-10-0_5-TEXAS-TPS74701
    F1FUSE_FUSE-6_1X2_6M_6125FA15A6125FA15AFUSE-6_1X2_6M
    F2FUSE_FUSE-6_1X2_6M_6125FA15A6125FA15AFUSE-6_1X2_6M
    F3FUSE_FUSE-6_1X2_6M_6125FA15A6125FA15AFUSE-6_1X2_6M
    FB3BEAD_SMD0603_PBY160808T-301Y-NPBY160808T-301Y-NSMD0603
    FB4BEAD_SMD0603_PBY160808T-301Y-NPBY160808T-301Y-NSMD0603
    FB5BEAD_SMD0603_PBY160808T-301Y-NPBY160808T-301Y-NSMD0603
    FB6BEAD_SMD0603_PBY160808T-301Y-NPBY160808T-301Y-NSMD0603
    FB7BEAD_SMD0603_PBY160808T-301Y-NPBY160808T-301Y-NSMD0603
    FB8BEAD_SMD0603_PBY160808T-301Y-NPBY160808T-301Y-NSMD0603
    FB9BEAD_SMD1206_LCB3216-800Y-NLCB3216-800Y-NSMD1206
    FB10BEAD_SMD0603_0603603SMD0603
    FB17BEAD_SMD0603_0603603SMD0603
    FB18BEAD_SMD0402_MPZ1005S121CMPZ1005S121CSMD0402
    FB19BEAD_SMD0402_MPZ1005S121CMPZ1005S121CSMD0402
    FB20BEAD_SMD0603_PBY160808T-301Y-NPBY160808T-301Y-NSMD0603
    FB21BEAD_SMD0603_PBY160808T-301Y-NPBY160808T-301Y-NSMD0603
    J1CONN240_DDR3_CONN240_D92964002_CONN240_DDR3CONN240_D92964002
    J2CONN240_DDR3_CONN240_D92964002_CONN240_DDR3CONN240_D92964002
    J3CONN164_PCIE16X_CONN164_C352850?CONN164_C35285004
    J4CONN164_PCIE16X_CONN164_C352850?CONN164_C35285004
    J5CONN164_PCIE16X_CONN164_C352850?CONN164_C35285004
    J6CONN164_PCIE16X_CONN164_C352850?CONN164_C35285004
    J7JACK_RJ45_1TAB_RJ45_1TAB_??RJ45_1TAB
    J8DB9_0_DB9-90_??DB9-90
    J9CONN3_HEADER_J-CON-3-2_54-INTEL?J-CON-3-2_54-INTEL-FAN
    J11CON4_FAN_0_CON1X4-10_2X2_5M-IP_?CON1X4-10_2X2_5M-IP
    J12CON4_FAN_0_CON1X4-10_2X2_5M-IP_?CON1X4-10_2X2_5M-IP
    J13CON3_1X3-2MM54_CON3CON31X3-2MM54
    J14CON4_FAN_0_CON1X4-10_2X2_5M-IP_?CON1X4-10_2X2_5M-IP
    J15BAT029K01_J-BAT-2-20-LOTES-BAT03VJ-BAT-2-20-LOTES-BAT029K01
    J17CONNSOCKET 10X2_2X10_2MM54_CPLCPLD_3V32X10_2MM54
    J18JTAG_CPLD_CON2X5-12_7X5_1M-NJ_JJTAG_CPLDCON2X5-12_7X5_1M-NJ
    J19SW_PB_4PIN_KEY_SW_PB_4PINSW_PB_4PINKEY
    J20CONNSOCKET 10X2_2X10_2MM54_C_1CPLD_1V82X10_2MM54
    J21SW_PB_4PIN_KEY_SW_PB_4PINSW_PB_4PINKEY
    J22CON10AP_0_CON2X5-12_7X5_1M-IP_CCON10APCON2X5-12_7X5_1M-IP
    J23ATX2X12_1586495-4_J-CON-2X12-4_?J-CON-2X12-4_2-TYCO-1586495
    J24ATX_4PX2_J-CON-8-4_2-TYCO-79448?J-CON-8-4_2-TYCO-794486
    J25CON4_LGA_1150_CON4CON4LGA_1150
    J26A2-4PA-2_0.54DSA_J-CON-4-2_54-FANJ-CON-4-2_54-INTEL-FAN
    J27CON4_FAN_0_CON1X4-10_2X2_5M-IP_?CON1X4-10_2X2_5M-IP
    J28CON4_MH8-72X72-ADD-75X75-SOCKETCON4MH8-72X72-ADD-75X75-SOCKET
    JX1S25FL128P_2X8_1MM27_DEBUG_PINDEBUG_PIN2X8_1MM27
    L1TLRE1708-0R5_L-7_2X6_6M-SMPI0603.3U8AL-7_2X6_6M-SMPI06050
    L2TLRE1708-0R5_L-3_2X2_5-NLCV32T_0.1U2.85AL-3_2X2_5-NLCV32T
    L3INDUCTOR_SMI2525A_0.47U17.5A0.47U17.5ASMI2525A
    L4TLRE1708-0R5_SL-2-6_25-MAGIC-SI0.1U30ASL-2-6_25-MAGIC-SIHH0605
    L5TLRE1708-0R5_SL-2-6_25-MAGIC-SI0.1U30ASL-2-6_25-MAGIC-SIHH0605
    L6TLRE1708-0R5_L-7_2X6_6M-SMPI0603.3U8AL-7_2X6_6M-SMPI06050
    L7TLRE1708-0R5_L-3_2X2_5-NLCV32T_0.1U2.85AL-3_2X2_5-NLCV32T
    MK6TEST_POINT_MARKD2MM_ MARKD2MM
    Q1PDGS_2_SOT223_AMS1117-1.2AMS1117-1.2SOT223
    Q22N1069_0_SOT23_S8050/SOT23S8050/SOT23SOT23
    R603RESISTOR_0_SMD0402_2001% 04022001% 0402SMD0402
    R6041K_SMD0402_10K5% 040210K5% 0402SMD0402
    R6051K_SMD0402_10K5% 040210K5% 0402SMD0402
    R6061K_SMD0402_10K5% 040210K5% 0402SMD0402
    R6071K_SMD0402_10K5% 040210K5% 0402SMD0402
    R6081K_0_SMD0402_05% 0402_105% 0402SMD0402
    R6091K_0_SMD0402_05% 0402_105% 0402SMD0402
    SW1SW_10_SOJ20-13_9X5_8-P1_27M_SW_sw_10SOJ20-13_9X5_8-P1_27M
    TP1TESTPOINT_TP08_TESTPOINTTestPointTP08
    TP2TESTPOINT_TP08_TESTPOINTTestPointTP08
    TP3TESTPOINT_TP_26MIL_INT_NINT_NTP_26MIL
    TP108TESTPOINT_TP08_TESTPOINTTestPointTP08
    U1FT1500A4CORE_BGA1150_(S1+S2+S3+FT1500A4COREBGA1150
    U2PCA9517D_SOI8_15_50IA_PCA9517DPCA9517DSOI8_15_50IA
    U3PCA9517D_SOI8_15_50IA_PCA9517DPCA9517DSOI8_15_50IA
    U5KS8995M_0_QFN40P800X800X80-65N_KSZ9031MNXQFN40P800X800X80-65N
    U6SP3243EA_0_SOP28-10_4X5_4-P0_65SP3243EASOP28-10_4X5_4-P0_65M
    U7S25FL128P_J-SCON-2X8-WIESON-G61S25FL128PJ-SCON-2X8-WIESON-G6179
    U8PCA9517D_SOI8_15_50IA_PCA9517DPCA9517DSOI8_15_50IA
    U9S25FL128P_J-SCON-2X8-WIESON-G61S25FL128PJ-SCON-2X8-WIESON-G6179
    U10PCA9517D_SOI8_15_50IA_PCA9517DPCA9517DSOI8_15_50IA
    U11PCA9517D_SOI8_15_50IA_PCA9517DPCA9517DSOI8_15_50IA
    U12DS1339U_SOP8-3_1X3_1-P0_65M_??SOP8-3_1X3_1-P0_65M
    U13EPM1270T256_FBGA256-06_(S1+S2+SEPM1270F256C5NFBGA256-06
    U14TPS54620RGY_QFN14-3_5X3_5-P0_5MTPS54620RGYQFN14-3_5X3_5-P0_5M_NEW
    U15VT1596M_0_QFN48-7X7-P0_5M_VT159VT1596MQFN48-7X7-P0_5M
    U17VT1676SA_QFN16-VT1676SA_VT1676SVT1676SAQFN16-VT1676SA
    U18VT1676SA_QFN16-VT1676SA_VT1676SVT1676SAQFN16-VT1676SA
    U19INDUCTOR2_L-11X18M-PA3142HL_50N50NH50AL-11X18M-PA3142HL
    U20VT1596M_0_QFN48-7X7-P0_5M_VT159VT1596MQFN48-7X7-P0_5M
    U21VT1676SA_QFN16-VT1676SA_VT1676SVT1676SAQFN16-VT1676SA
    U22VT1676SA_QFN16-VT1676SA_VT1676SVT1676SAQFN16-VT1676SA
    U23INDUCTOR2_L-11X18M-PA3142HL_50N50NH50AL-11X18M-PA3142HL
    U24TPS51200DRCR_U-SON-10-0_5-TI-TPTPS51200DRCRU-SON-10-0_5-TI-TPS74701
    U25TPS54620RGY_QFN14-3_5X3_5-P0_5MTPS54620RGYQFN14-3_5X3_5-P0_5M_NEW
    U41SI52147-A01AGMR_QFN49_SI52147-ASI52147-A01AGMRQFN49
    U42TPS51200DRCR_U-SON-10-0_5-TI-TPTPS51200DRCRU-SON-10-0_5-TI-TPS74701
    Y2CRYSTAL_4P_L-5X7_2-P5_08M_125MH125MHzNCL-5X7_2-P5_08M
    Y3CRYSTAL_0_SIP_HC49_25MHZ25MHzSIP_HC49
    Y4OSC_L-5X7_2-P5_08M_OSC50M NCOSC50M NCL-5X7_2-P5_08M
    Y5RTC_RTC_CIR_04X08_RTCRTCRTC_CIR_04X08
    Y6G43270004_SY-4-5_5-PERICOM-G43232.768khzSY-4-5_5-PERICOM-G4327
    Y7OSC_L-5X7_2-P5_08M_OSC50MOSC50ML-5X7_2-P5_08M
    Y812MHZ_Y-2-9_5-TXC-XTAL-14_318M_25MHzY-2-9_5-TXC-XTAL-14_318M
    重要提示:PCB作品文件展下载说明
     楼主| 发表于 2022-3-30 13:49:19 | 显示全部楼层
    8层 PCB设计。 赚5个RMB 。
    FT-1500A-4_V2_0905.7z (2.05 MB, 下载次数: 17)
    前天 09:49
  • 签到天数: 222 天
    发表于 2022-3-30 18:01:29 | 显示全部楼层
    发表于 2022-3-30 21:26:13 | 显示全部楼层
    资料不错,拿来看看
    资料不错,拿来看看
    资料不错,拿来看看
    发表于 2022-3-30 21:35:13 | 显示全部楼层
    发表于 2022-3-31 07:39:30 | 显示全部楼层
    孤独的奔跑者
    终身成就奖社区居民
    发表于 2022-3-31 08:25:56 | 显示全部楼层
    发表于 2022-3-31 08:38:21 | 显示全部楼层
    发表于 2022-4-1 17:36:35 | 显示全部楼层
  • 签到天数: 5 天
    发表于 2022-4-2 08:08:00 | 显示全部楼层
