1. Star ModelSim and Make filelistStar your modelsim and change the directory to youre project folder.Use “pwd “ to show your current directory.Use “cd d:verilog “ to change directory. Use “dir *.v /b/s >filelist.f “ to make file list. The file list is as follow, which contains all the .v files under current folder ,including file in subfolders. Tips: if codes are written in Verilog HDL , there is no need to adjust the sequence of the filelist , while in VHDL, some files should be compiled first , so the filelist sequence may need some adaptation.2. use UltraEdit to replace “” with “/”. 3. create your modelsim .lib and .work.change the directory to youre project folder ,and copy filelist.f there.Here we “cd projects”Use “vlib work “ to build work lib.Use “vmap work work “ to map work lib.4. compile the filelist.f with coverage to build work lib. -cover cbse means compile with condition , branch , statement ,expression coverage.-f filelist.f means compile files listed in this file.5. start simulation and check the coverage start simulation with “vsim – coverage work.top” and “run 10us “ for some time. And you can see the coverage like this. More detailed coverage information is as follow, You can get all the coverage information here . If you have any problem in the use of modelsim coverage ,please contact me and I am glad to help . |
