接C语言指针(上篇)/*********************************************************************************************注意:函数指针变量与指针函数的区别:函数指针:指向函数的指针变量指针函数:返回指针也就是地址的函数他们侧重点不一样**********************************************************************************************///函数指针变量#if 0int max(int a,int b){if( a > b ) return a;elsereturn b;}void main(void){int x,y,z;int ( *pfun )(int,int);//定义函数指针变量ser_init();printf("input two numbers:n");scanf("%d%d",&x,&y);pfun = max;//把函数名(函数入口地址)赋给函数指针变量z=(*pfun)(x,y);//调用函数指针变量,实参x和y的值传递给形参a和bprintf("max=%dn",z);//形参a和b的值发生交换存储在max函数存储区,因为pfun指针变量指向函数max首地址} //所以z取得max函数的最大值#endif//--------------------------------------------------------------------------------------------#if 0//返回指针的函数,函数返回值为地址char *day(int n){static char *weekday[ ]={ //指针数组由指针元素组成"Illegal day","Monday","Tuesday","Wednesday","Thursday","Friday","Saturday","Sunday"};if( n<0||n>6)return weekday[0] ;//返回指针元素也就是地址elsereturn weekday[n];}void main(void){while(1){if(!bflag){int i;//char *day(int n);//指针函数声明ser_init();printf("input No.:n");scanf("%d",&i);printf("Num=%d--->Day=%sn",i,day(i));bflag = 1;}}}#endif//---------------------------------------------------------------------------------#if 0void main(void){char string[]="I love you!"; //字符数组访问字符串ser_init();printf("string = %s",string);}void main(void){char *string="I love you! my baby";//字符指针变量访问字符串ser_init();printf("string = %s",string);}#endif//---------------------------------------------------------------------------------#if 0//选择法排序(由小到大排序)void SelectSort(char *name[],int n)//形参指针数组---由指向字符的指针元素组成{int i,j,k;//k为中间变量,暂存下标号char *ps; //中间指针变量,暂存值for(i=0;i{// x0 x1 x2 x3 ...x(n-1) x(n)k = i;//从下标0开始选择一个数,然后在后面的序列里比较,//如果有小于前面的那个数就交换下标号for(j=i+1;j<n;j++){if(strcmp(name[k],name[j])>0 )k=j;}if(k!=i){//后面序列有大于前面那个数ps=name;//name[]中的元素为指针地址name=name[k];name[k]=ps;}}}void print(char *name[],int n){int i;for(i=0;i}<n;i++)printf("%sn",name);void main(void){while(1){if(!bflag){int n;static char *name[]={"CHINA","AMERICAN","ENGLANGD","JANPANESE","GERMANY","FRANCE","AUSTRALIAN"};//定义指针数组:数组中的每个元素为一个指针n=7;ser_init();SelectSort(name,n);//指针数组的首地址传递给形参变量print(name,n);printf("%c",*name[0]);bflag = 1;}}}#endif//----------------------------------------------------------------------------------------#if 0//选择法排序(由小到大排序)void SelectSort(int *name[],int n)//形参指针数组---由指向字符的指针元素组成{int i,j,k;//k为中间变量,暂存下标号int *ps; //中间指针变量,暂存值for(i=0;i{// x0 x1 x2 x3 ...x(n-1) x(n)k = i;//从下标0开始选择一个数,然后在后面的序列里比较,//如果有小于前面的那个数就交换下标号for(j=i+1;j<n;j++){//if( strcmp(name[k],name[j]) > 0 )k=j;}if(k!=i){//后面序列有大于前面那个数ps=name;//name[]中的元素为指针地址name=name[k];name[k]=ps;}}}<n;j++)void print(int *name[],int n){int i;for(i=0;i}<n;i++)printf("%dn",name);void main(void){while(1){if(!bflag){int n;static int *name[]={11,22,33,44,55,66};//name[0]=0xaa;//name[1]=0xbb;//name[2]=0xcc;//name[3]=0xdd;//name[4]=0xee;//name[5]=0xff;//定义指针数组:数组中的每个元素为一个指针n=20;ser_init();SelectSort(name,n);//指针数组的首地址传递给形参变量print(name,n);bflag = 1;}}}#endif//---------------------------------------------------------------------------------------#if 0//指向指针变量的指针变量void main(void){while(1){if(!bflag){int x,*p,**pp;//pp为 指向整型的指针变量 的指针变量ser_init();printf("input one number:n");scanf("%d",&x);p=&x;//p=&x;pp=&p;//q=&x;printf("%dn",*p);//变量x的值printf("%dn",**pp);//变量x的值bflag=1;}}}#endif</n-1 |
