查看: 4402|回复: 77
[Allegro17.4以下] PI3L500ZFE+SIL9024A+RTL8211FI-CG+SGM8903+TXB0104QPWRQ1 做的海思底板PCB
    长期免费代管18-28岁小
    发表于 2022-11-1 10:14:29 | 显示全部楼层 |阅读模式
    3519TEST.7z (1.18 MB, 下载次数: 14)
    D3LED_0_HSD0603-LED_LEDLEDHSD0603-LED
    D10DZ_L_0_HSOD882_DZ_LDZ_LHSOD882
    D11DZ_L_0_HSOD882_DZ_LDZ_LHSOD882
    D12DZ3_0_HSOD882_DZ3DZ3HSOD882
    D13DZ3_0_HSOD882_DZ3DZ3HSOD882
    D16DZ3_0_HSOD882_DZ3DZ3HSOD882
    D17DZ3_0_HSOD882_DZ3DZ3HSOD882
    D18DZ_L_0_HSOD882_DZ_LDZ_LHSOD882
    D19RCLAMP0524P_0_MLF10-050-0301L_RRCLAMP0524PMLF10-050-0301L
    D20RCLAMP0524P_0_MLF10-050-0301L_RRCLAMP0524PMLF10-050-0301L
    D21RCLAMP0524P_0_MLF10-050-0301L_RRCLAMP0524PMLF10-050-0301L
    D22RCLAMP0524P_0_MLF10-050-0301L_RRCLAMP0524PMLF10-050-0301L
    D24DZ_L_0_HSOD882_DZ_LDZ_LHSOD882
    D26DZ3_0_SD1710A_DZ3DZ3SD1710A
    D31DZ3_0_SD1714D_DZ3DZ3SD1714D
    D35LED_0_SD0805-LED_LEDLEDSD0805-LED
    D36LED_0_SD0805-LED_LEDLEDSD0805-LED
    D37LED_0_SD0805-LED_LEDLEDSD0805-LED
    D38D_A_0_HSOD323A_D_AD_AHSOD323A
    D39D_A_0_HSOD323A_D_AD_AHSOD323A
    D40D_A_0_HSOD323A_D_AD_AHSOD323A
    D41D_A_0_HSOD323A_D_AD_AHSOD323A
    D42RCLAMP0524P_0_MLF10-050-0301L_RRCLAMP0524PMLF10-050-0301L
    F1FUSE2_0_SF6127_FUSE2FUSE2SF6127
    H1TPOINT A_HOLE_2D3_HOLEHOLEHOLE_2D3
    H2TPOINT A_HOLE_2D3_HOLEHOLEHOLE_2D3
    H3TPOINT A_HOLE_2D3_HOLEHOLEHOLE_2D3
    H4TPOINT A_HOLE_2D3_HOLEHOLEHOLE_2D3
    J8SIMM10S4_B_0_HSDC10-1614B_SIMM1SIMM10S4_BHSDC10-1614B
    J10MIC6M1_B_0_VAF6-1406E_MIC6M1_BMIC6M1_BVAF6-1406E
    J12MIC6M1_B_0_VAF6-1406E_MIC6M1_BMIC6M1_BVAF6-1406E
    J13PWC3_A_0_PWC0103-M-N_PWC3_APWC3_APWC0103-M-N
    J15USB-9S2_A_CN_USB3_90_TH_700_USBUSB-9S2_ACN_USB3_90_TH_700
    J19MJ8-S-M2_0_MJ8-SR-BZ-A_MJ8-S-M2MJ8-S-M2MJ8-SR-BZ-A
    J29USB-4_0_USB_A_90_5D72_USB-4USB-4USB_A_90_5D72
    J33DB19S4_0_MOLEX_47151_DB19S4DB19S4MOLEX_47151
    J34DB19S4_0_MOLEX_47151_DB19S4DB19S4MOLEX_47151
    J36CONNSOCKET 90X2/SM_0_DDR4_SODISODDR4260PINDDR4_SODIMM_STD_260PIN_H5P2MM
    J401CONNECTOREDGE 15X2_CN_2D0_2X15CONNECTOREDGE 15x2CN_2D0_2X15P_4D0
    J402CONNECTOREDGE 6X2_CN_2D0_2X6_1CONNECTOREDGE 6x2CN_2D0_2X6P_4D0
    J403CONNECTOREDGE 15X2_CN_2D0_2X15CONNECTOREDGE 15x2CN_2D0_2X15P_4D0
    J404CONNECTOREDGE 6X2_CN_2D0_2X6_1CONNECTOREDGE 6x2CN_2D0_2X6P_4D0
    J1201CONNECTOREDGE 6X2_CN_2D0_2X6P_WIFICN_2D0_2X6P_4D0
    J1301CONNECTOREDGE 15X2_CN_2D0_2X15CONNECTOREDGE 15x2CN_2D0_2X15P_4D0
    J1302CONNECTOREDGE 10X2_CN_2D0_2X10CONNECTOREDGE 10x2CN_2D0_2X10P_4D0
    J1303SIP2_SIP-2P_SIP2SIP2SIP-2P
    J1304SIP2_SIP-2P_SIP2SIP2SIP-2P
    J1305SIP2_SIP-2P_SIP2SIP2SIP-2P
    J1306SIP2_SIP-2P_SIP2SIP2SIP-2P
    J1307CON2_CN_2P_2D0_6D5_CON2CON2CN_2P_2D0_6D5
    L1L_0_SL2828_4.7UH4.7UHSL2828
    L4L_0_HSL1008_2.2UH2.2UHHSL1008
    L11L_0_SPL0303A_4.7U4.7USPL0303A
    L12L_0_SL2828_2.2UH2.2UHSL2828
    L401L_HSL1008_2.2UH2.2UHHSL1008
    L402L_HSL1008_2.2UH2.2UHHSL1008
    LB10LB_0_SL0402_LBLBSL0402
    M1HOLE-8STARS_0_MTH_C6MMD3P2MM_HOHOLE-8STARSMTH_C6MMD3P2MM
    M2HOLE-8STARS_0_MTH_C6MMD3P2MM_HOHOLE-8STARSMTH_C6MMD3P2MM
    M3HOLE-8STARS_0_MTH_C6MMD3P2MM_HOHOLE-8STARSMTH_C6MMD3P2MM
    M4HOLE-8STARS_0_MTH_C6MMD3P2MM_HOHOLE-8STARSMTH_C6MMD3P2MM
    M5HOLE-8STARS_0_MTH_C6MMD3P2MM_HOHOLE-8STARSMTH_C6MMD3P2MM
    Q1FETP-GSD_0_SOT23_PMOS-GSDPMOS-GSDSOT23
    Q2NPN-BEC_0_SOT23_NPN-BECNPN-BECSOT23
    S6MSW4_SSW-PUSH_MSW4MSW4SSW-PUSH
    T1G2401CE_0_STFM24-40-280_G2401CEG2401CESTFM24-40-280
    TP1TESTPOINT_0_TP24-SMD_TESTPOINTTESTPOINTTP24-SMD
    U1RTL8211FI-CG_0_QFN40-8211FI_RTLRTL8211FI-CGQFN40-8211FI
    U2NCP308_1_WDFN6-0R65-2X2-H1R6X1RNCP308WDFN6-0R65-2X2-H1R6X1R00
    U7SN74AVCH2T45_0_SOP8-20-91_SN74ASN74AVCH2T45SOP8-20-91
    U10NCP308_1_WDFN6-0R65-2X2-H1R6X1RNCP308WDFN6-0R65-2X2-H1R6X1R00
    U12SN74AVCH2T45_0_SOP8-20-91_SN74ASN74AVCH2T45SOP8-20-91
    U19TPS564201DDCR_0_SOT23-6-DCC_TPSTPS564201DDCRSOT23-6-DCC
    U20TPS564201DDCR_0_SOT23-6-DCC_TPSTPS564201DDCRSOT23-6-DCC
    U22SGM8903_0_SGM8903_SGM8903SGM8903SGM8903
    U27PI3L500ZFE_0_MLF56-050-1105_PI3PI3L500ZFEMLF56-050-1105
    U30PCA9306DCTT_0_SOP8-20-91_PCA930PCA9306DCTTSOP8-20-91
    U42AZC199-04S_0_SOT23-6L-KTB_AZC19AZC199-04SSOT23-6L-KTB
    U43AZC199-04S_0_SOT23-6L-KTB_AZC19AZC199-04SSOT23-6L-KTB
    U45SIL9024A_1_QFN-72_SIL9024ASIL9024AQFN-72
    U485PB1102CMG_0_DFN8-050-2X2-DPT_55PB1102CMGDFN8-050-2X2-DPT
    U51SN74LVC1G125Q-Q1_0_HSOT-SC70-DCSN74LVC1G125Q-Q1HSOT-SC70-DCK
    U53SC4215A_0_IC_SO_8_TH_1D7_SC4215SC4215AIC_SO_8_TH_1D7
    U55PWR1-2_SBAT2-13A_PWR1-2PWR1-2SBAT2-13A
    U501CON6_0_SOT23-6_WS222WS222SOT23-6
    U704DS8008_3_SOT23-5_SY6280/TT9107/SY6280/TT9107/UP7534GMA5-10SOT23-5
    U705DS8008_3_SOT23-5_SY6280/TT9107/SY6280/TT9107/UP7534GMA5-10SOT23-5
    U706CON14_0_IC_SSOP14_0D65X6D4_1D2_TXB0104QPWRQ1IC_SSOP14_0D65X6D4_1D2
    U707CON14_0_IC_SSOP14_0D65X6D4_1D2_TXB0104QPWRQ1IC_SSOP14_0D65X6D4_1D2
    U708CON14_0_IC_SSOP14_0D65X6D4_1D2_TXB0104QPWRQ1IC_SSOP14_0D65X6D4_1D2
    X1X_B_0_HSX4-0302_2525HSX4-0302
    暑假期间,免费代管18-28岁小孩,限女性。
    发表于 2022-11-1 13:43:11 | 显示全部楼层
    发表于 2022-11-1 14:53:35 | 显示全部楼层
    昨天 16:24
  • 签到天数: 154 天
    社区居民社区劳模原创先锋奖终身成就奖特殊贡献奖优秀斑竹奖
    发表于 2022-11-1 15:43:59 | 显示全部楼层
    1 小时前
  • 签到天数: 155 天
    发表于 2022-11-1 16:02:27 | 显示全部楼层
    昨天 14:03
  • 签到天数: 160 天
    发表于 2022-11-1 18:35:40 | 显示全部楼层
    23 分钟前
  • 签到天数: 179 天
    发表于 2022-11-1 18:54:57 | 显示全部楼层
    昨天 14:49
  • 签到天数: 95 天
    社区居民终身成就奖特殊贡献奖原创先锋奖
    发表于 2022-11-1 20:26:27 | 显示全部楼层
    4 天前
  • 签到天数: 107 天
    你必须非常努力才能显
    发表于 2022-11-1 20:33:31 | 显示全部楼层
    1 小时前
  • 签到天数: 140 天
    社区居民终身成就奖特殊贡献奖原创先锋奖
    发表于 2022-11-1 22:59:28 | 显示全部楼层
