Name | Part Type | PCB Decal |
ANT1 | F_ANTENNA_F_ANTENNA_DIG528-2_IC | F_ANTENNA_DIG528-2 |
BT1 | BATTERY_BATTERY_HOLDER_2032_SM_ | BATTERY_HOLDER_2032_SM |
D1 | LED_LED_0603_IC_0.7MM_370-76693 | LED_0603 |
D2 | DIODE_SCHTKY_SOD-128_IC_1.1_MM_ | SOD-128 |
D3 | DIODE_SCHTKY_PMDU_SOD123_IC_0.9 | PMDU_SOD123 |
D4 | DIODE_SCHTKY_PMDU_SOD123_IC_0.9 | PMDU_SOD123 |
D5 | DIODE_SCHTKY_PMDU_SOD123_IC_0.9 | PMDU_SOD123 |
D6 | DIODE_SCHTKY_PMDU_SOD123_IC_0.9 | PMDU_SOD123 |
D8 | DIODE_SCHTKY_PMDU_SOD123_IC_0.9 | PMDU_SOD123 |
D10 | DIODE_SCHTKY_PMDU_SOD123_IC_0.9 | PMDU_SOD123 |
D11 | DIODE_SOD123W_IC_1.1MM_480-7964 | SOD123W |
D12 | DIODE_SCHTKY_PMDU_SOD123_IC_0.9 | PMDU_SOD123 |
D13 | DIODE_SCHTKY_PMDU_SOD123_IC_0.9 | PMDU_SOD123 |
J1 | CONN_HDR_8X1_CON_1X8_SKT_2P54_T | CON_1X8_SKT_2P54_TH |
J2 | CONN_HDR_10X1_CON_SKT1X10_TH_IO | CON_SKT1X10_TH |
J3 | CONN_HDR_8X1_CON_1X8_SKT_2P54_T | CON_1X8_SKT_2P54_TH |
J4 | CONN_HDR_6X1_CON_SKT1X6_TH_IO_8 | CON_SKT1X6_TH |
J5 | CONN_HDR_3X1_HDR103_IO_8.9MM_21 | HDR103 |
J6 | CONN_HDR_2X1_SH_HDR102_BOTTOM_I | SH_HDR102_BOTTOM |
J7 | CONN_HDR_2X1_SH_HDR102_BOTTOM_I | SH_HDR102_BOTTOM |
J8 | CONN_HDR_2X1_SH_HDR102_BOTTOM_I | SH_HDR102_BOTTOM |
J9 | CONN_HDR_2X1_SH_HDR102_BOTTOM_I | SH_HDR102_BOTTOM |
J10 | CONN_HDR_2X1_SH_HDR102_BOTTOM_I | SH_HDR102_BOTTOM |
J11 | MICRO_USB_CONN_9PIN_CON9_MICROA | CON9_MICROAB_USB_SHELL_TH |
J12 | CONN_HDR_5X2_HDR_2X5_6X3_1P27MM | HDR_2X5_6X3_1P27MM_TH |
J13 | CONN_HDR_4X1_CON_HDR_4M_100_TH_ | CON_HDR_4M_100_TH_RA |
J14 | CONN_HDR_5X2_HDR_2X5_6X3_1P27MM | HDR_2X5_6X3_1P27MM_TH |
J15 | CONN_HDR_2X1_SH_HDR102_BOTTOM_I | SH_HDR102_BOTTOM |
J16 | CONN_HDR_2X1_SH_HDR102_BOTTOM_I | SH_HDR102_BOTTOM |
J17 | CONN_HDR_2X1_SH_HDR102_BOTTOM_I | SH_HDR102_BOTTOM |
J21 | CONN_COAX_1P_F_CON5_SMA_7SQ_SM_ | CON5_SMA_7SQ_SM |
J23 | CONN_HDR_4X1_CON_HDR_4M_100_TH_ | CON_HDR_4M_100_TH_RA |
J24 | CONN_HDR_3X1_HDR103_IO_8.9MM_21 | HDR103 |
J27 | CONN_HDR_2X1_HDR_1X2_2P54MM_IO_ | HDR_1X2_2P54MM |
J28 | CONN_HDR_2X1_SH_HDR102_BOTTOM_I | SH_HDR102_BOTTOM |
J29 | CONN_HDR_2X1_SH_HDR102_BOTTOM_I | SH_HDR102_BOTTOM |
J30 | CONN_HDR_2X1_HDR_1X2_2P54MM_IO_ | HDR_1X2_2P54MM |
J31 | CONN_HDR_2X1_SH_HDR102_BOTTOM_I | SH_HDR102_BOTTOM |
J32 | DC_POWER_JACK_SHD_CON3_PWR_JACK | CON3_PWR_JACK_TH_PJ051A |
J33 | CONN_HDR_2X1_HDR_1X2_2P54MM_IO_ | HDR_1X2_2P54MM |
J34 | CONN_HDR_3X1_HDR103_IO_8.9MM_21 | HDR103 |
J35 | CONN_HDR_3X1_HDR103_IO_8.9MM_21 | HDR103 |
J38 | CONN_HDR_3X1_HDR103_IO_8.9MM_21 | HDR103 |
L1 | BEAD_IND_0805_DISCRETE_1.05_MM_ | IND_0805 |
L2 | INDUCTOR_IND_0402_DISCRETE_0.55 | IND_0402 |
L3 | IND_FERRITE_IND_VLS4012E_DISCRE | IND_VLS4012E |
L4 | INDUCTOR_IND_0402_DISCRETE_0.6M | IND_0402 |
L5 | INDUCTOR_IND_0402_DISCRETE_0.6M | IND_0402 |
LED1 | LED_LED_0603_IC_0.7_MM_370-7669 | LED_0603 |
LED2 | LED_LED_0603_IC_0.7MM_370-76693 | LED_0603 |
LED3 | LED_LED_2P_0805_IC_1.1MM_370-76 | LED_2P_0805 |
LED4 | CLV1A_LED_4P_LED4_3P4X3MM_SMT_I | LED4_3P4X3MM_SMT |
Q1 | NMOS_2N7002BKW_3P_SOT23_A_IC_1. | SOT23_A |
Q2 | NMOS_2N7002BKW_3P_SOT23_A_IC_1. | SOT23_A |
Q3 | NMOS_2N7002BKW_3P_SOT23_A_IC_1. | SOT23_A |
Q4 | NMOS_2N7002BKW_3P_SOT23_A_IC_1. | SOT23_A |
SH17 | RES_SHORT-2_SH0603_DISCRETE_0.1 | SH0603 |
SW1 | SW2P_SW2_TACT_4X3_SM_IC_2_MM_51 | SW2_TACT_4X3_SM |
SW2 | SW2P_SW2_TACT_4X3_SM_IC_2_MM_51 | SW2_TACT_4X3_SM |
SW3 | SW2P_SW2_TACT_4X3_SM_IC_2_MM_51 | SW2_TACT_4X3_SM |
SW4 | SW2P_SW2_TACT_4X3_SM_IC_2_MM_51 | SW2_TACT_4X3_SM |
U1 | NTSX2102GU8H_8P_XQFN8_1P45X1P25 | XQFN8_1P45X1P25MM |
U2 | RCLAMP1654P_NEW_DFN1616-6_IC_0. | DFN1616-6 |
U3 | AT45DB021E_9P_DFN8_1P27_6X5MM_3 | DFN8_1P27_6X5MM_3P6X4P2 |
U4 | 74LVCH1T45_6P_UDFN6_1X1P5MM_IC_ | UDFN6_1X1P5MM |
U5 | PK20DX128V_QFN_32P_QFN32_S142EP | QFN32_S142EP |
U6 | 74LVC2T45GM_8P_QFN8_1P6X1P6MM_I | QFN8_1P6X1P6MM |
U7 | 74LVC2T45GM_8P_QFN8_1P6X1P6MM_I | QFN8_1P6X1P6MM |
U8 | NLX2G14_6P_UDFN6_1P45X1_0P5MM_I | UDFN6_1P45X1_0P5MM |
U9 | MIC2005-0.8YM6_SOT23-6_A_IC_1.4 | SOT23-6_A |
U10 | TJA1027T_8P_SO8_1P27_4X5_IC_1.7 | SO8_1P27_4X5 |
U11 | FXOS8700CQ_QFN_16P_QFN5X3_0P5_3 | QFN5X3_0P5_3X3 |
U12 | 74LVCH1T45_6P_UDFN6_1X1P5MM_IC_ | UDFN6_1X1P5MM |
U13 | 74LVCH1T45_6P_UDFN6_1X1P5MM_IC_ | UDFN6_1X1P5MM |
U14 | 74LVCH1T45_6P_UDFN6_1X1P5MM_IC_ | UDFN6_1X1P5MM |
U15 | LD1117AS18_SOT223_IC_1.8MM_315- | SOT223 |
U16 | LD1117AS18_SOT223_IC_1.8MM_312- | SOT223 |
U17 | 74LVCH1T45_6P_UDFN6_1X1P5MM_IC_ | UDFN6_1X1P5MM |
U18 | MKW36Z512_64P_MAPLGA48_7X7_0P5M | MAPLGA48_7X7_0P5MM |
U19 | TJA1057GT3_8P_SO8_1P27_4X5_IC_1 | SO8_1P27_4X5 |
U20 | 74LVCH1T45_6P_UDFN6_1X1P5MM_IC_ | UDFN6_1X1P5MM |
X1 | XTAL_CS_XTAL3_3P35X1P45_SM_IC_0 | XTAL3_3P35X1P45_SM |
Y1 | XTAL_13Y_XTAL4_2P1X1P7MM_SM_IC_ | XTAL4_2P1X1P7MM_SM |
Y2 | CRYSTAL_XTAL2-3P2X1P5-SM_IC_0.9 | XTAL2-3P2X1P5-SM |
