重要提示:PCB作品文件展下载说明
REFDES | COMP_DEVICE_TYPE | COMP_VALUE | SYM_NAME | ATX_PSU1 | ATX_2X10P_4D2MM_H12D8 | 33502-Power,20PIN,180D, | ATX_2X10P_4D2MM_H12D8 | B1 | FB0603 | 600ohm_1A | FB0603 | BT1 | BATCON3P_5MM_H21-KST | 3PIN,180D, | BATCON3P_5MM_H21-KST | BZ1 | BZ_2P_12_6D5MM_H9 | BUZZER-5V | BZ_2P_12_6D5MM_H9 | CN3 | SFP_2X10P_53D5X16D06X14D9 | 33614-OpticalFiber,20PIN,90D, | SFP_2X10P_53D5X16D06X14D9 | CN4 | SFP_2X10P_53D5X16D06X14D9 | 33614-OpticalFiber,20PIN,90D, | SFP_2X10P_53D5X16D06X14D9 | CON5 | H3P_2D54MM_H8D6 | 3PIN,180D,P:2.54mm | H3P_2D54MM_H8D6 | CON6 | HSMD2X4P_1D27MM_H5D97 | 33503-Header,8PIN,180D,P:1.27MM | HSMD2X4P_1D27MM_H5D97 | CON7 | H2X5P_2D54MM_H8D6-K10 | 9PIN,180D,P:2.54mm | H2X5P_2D54MM_H8D6-K10 | CON8 | WAFER_4P_2MM_H6D1 | 33505-WiretoBoard,4PIN,180D,P=2.0mm | WAFER_4P_2MM_H6D1 | CON9 | HB2X5P_2MM_H5D7 | 33503-Header,10PIN,180D,P=2.0mm | HB2X5P_2MM_H5D7 | CON10 | FPC20P_D5MM-IMSA-9637S-20Y905 | 20PIN,90D,P:0.5mm | FPC20P_D5MM-IMSA-9637S-20Y905 | CON11 | HSMD2X10P_1D27MM_H7 | 33503-Header,20PIN,180D,P=1.27mm | HSMD2X10P_1D27MM_H7 | CON12 | HSMD2X4P_2D54MM_H10D4 | 8PIN,180D,P:2.54mm | HSMD2X4P_2D54MM_H10D4 | CON13 | HSMD2X4P_2D54MM_H10D4 | 8PIN,180D,P:2.54mm | HSMD2X4P_2D54MM_H10D4 | CPLD_PS_ON1 | H1P_2D54MM_H8D6 | 33503-Header,1PIN,180D,P=2.54MM | H1P_2D54MM_H8D6 | CX6_P1V2_1 | H1P_2D54MM_H8D6 | 33503-Header,1PIN,180D,P=2.54MM | H1P_2D54MM_H8D6 | CX6_P1V8_1 | H1P_2D54MM_H8D6 | 33503-Header,1PIN,180D,P=2.54MM | H1P_2D54MM_H8D6 | CX6_VCORE1 | H1P_2D54MM_H8D6 | 33503-Header,1PIN,180D,P=2.54MM | H1P_2D54MM_H8D6 | D1 | SOT23_ACA | BAT54C | SOT23_ACA | D4 | D_SOD-523_ROHM | RB520SM-30T2R | D_SOD-523_ROHM | D7 | D_SOD-523_ROHM | RB520S-30-TE61 | D_SOD-523_ROHM | D8 | D_SOD-323_PANJIT | 1N4148WS | D_SOD-323_PANJIT | D9 | D_SOD-523_ROHM | RB520S-30-TE61 | D_SOD-523_ROHM | D12 | D_SK36A | RB051L-40_40V_3A | D_SK36A | D13 | D_SOD-323_PANJIT | 1N4148WS | D_SOD-323_PANJIT | D14 | D_SOD-323_PANJIT | 1N4148WS | D_SOD-323_PANJIT | D15 | D_SOD-323_PANJIT | 1N4148WS | D_SOD-323_PANJIT | D24 | D_SOD-323_MCC | SCS501V | D_SOD-323_MCC | D25 | D_SOD-523_ROHM | RB520S-30-TE61 | D_SOD-523_ROHM | D37 | D_SLP2510P8_SEMTECH | AZ1045-04F.R7G | D_SLP2510P8_SEMTECH | D38 | D_SLP2510P8_SEMTECH | AZ1045-04F.R7G | D_SLP2510P8_SEMTECH | D39 | D_SLP2510P8_SEMTECH | AZ1045-04F.R7G | D_SLP2510P8_SEMTECH | D40 | D_SLP2510P8_SEMTECH | AZ1045-04F.R7G | D_SLP2510P8_SEMTECH | D41 | D_SOD-323_PANJIT | 1N4148WS | D_SOD-323_PANJIT | D42 | D_SOD-323_PANJIT | 1N4148WS | D_SOD-323_PANJIT | EC21 | EC_SMD_6D3MM_H7D7 | 560.0UF_6.3V | EC_SMD_6D3MM_H7D7 | EC23 | DCASE_7343 | 680.0UF_2.5V | DCASE_7343 | EC24 | DCASE_7343 | 680.0UF_2.5V | DCASE_7343 | EC26 | DCASE_7343 | 680.0UF_2.5V | DCASE_7343 | EC29 | DCASE_7343 | 680.0UF_2.5V | DCASE_7343 | EC31 | DCASE_7343 | 680.0UF_2.5V | DCASE_7343 | EC33 | DCASE_7343 | 680.0UF_2.5V | DCASE_7343 | EC34 | DCASE_7343 | 680.0UF_2.5V | DCASE_7343 | EC36 | DCASE_7343 | 150.0UF_16V | DCASE_7343 | EC37 | DCASE_7343 | 150.0UF_16V | DCASE_7343 | EC38 | DCASE_7343 | 150.0UF_16V | DCASE_7343 | EC39 | DCASE_7343 | 150.0UF_16V | DCASE_7343 | EC73 | XCASE_7343 | 470.0UF_6.3V | XCASE_7343 | EC119 | EC_SMD_6D3MM_H7D7 | 270.0UF_16V | EC_SMD_6D3MM_H7D7 | EC120 | EC_SMD_6D3MM_H7D7 | 270.0UF_16V | EC_SMD_6D3MM_H7D7 | EC121 | EC_SMD_6D3MM_H7D7_N | 560.0UF_6.3V | EC_SMD_6D3MM_H7D7_N | EC122 | EC_SMD_6D3MM_H7D7_N | 270.0UF_16V | EC_SMD_6D3MM_H7D7_N | EC130 | DCASE_7343 | 150.0UF_16V | DCASE_7343 | EC159 | DCASE_7343 | 150.0UF_16V | DCASE_7343 | EC160 | DCASE_7343 | 150.0UF_16V | DCASE_7343 | EC161 | DCASE_7343 | 150.0UF_16V | DCASE_7343 | EC163 | DCASE_7343 | 150.0UF_16V | DCASE_7343 | EC164 | DCASE_7343 | 150.0UF_16V | DCASE_7343 | EC165 | EC_SMD_6D3MM_H7D7 | 270.0UF_16V | EC_SMD_6D3MM_H7D7 | EC166 | EC_SMD_6D3MM_H7D7 | 270.0UF_16V | EC_SMD_6D3MM_H7D7 | EC167 | EC_SMD_6D3MM_H7D7 | 270.0UF_16V | EC_SMD_6D3MM_H7D7 | EC168 | EC_SMD_6D3MM_H7D7 | 270.0UF_16V | EC_SMD_6D3MM_H7D7 | EC170 | EC_SMD_6D3MM_H7D7 | 270.0UF_16V | EC_SMD_6D3MM_H7D7 | EC171 | EC_SMD_6D3MM_H7D7 | 270.0UF_16V | EC_SMD_6D3MM_H7D7 | EC173 | DCASE_7343 | 680.0UF_2.5V | DCASE_7343 | F1 | FUSE_1D8X3D5_H1D6 | RESETTABLE-PTC,2A,6V | FUSE_1D8X3D5_H1D6 | F4 | FUSE_1D8X3D4_HD7 | RESETTABLE-PTC,1.1A,6V | FUSE_1D8X3D4_HD7 | FAN1 | WAFER_4P_2D54MM_11D5 | 4PIN,180D,P:2.54mm | WAFER_4P_2D54MM_11D5 | FAN2 | WAFER_4P_2D54MM_11D5 | 4PIN,180D,P:2.54mm | WAFER_4P_2D54MM_11D5 | FAN3 | WAFER_4P_2D54MM_11D5 | 4PIN,180D,P:2.54mm | WAFER_4P_2D54MM_11D5 | FAN4 | WAFER_4P_2D54MM_11D5 | 4PIN,180D,P:2.54mm | WAFER_4P_2D54MM_11D5 | FAN5 | WAFER_4P_2D54MM_11D5 | 4PIN,180D,P:2.54mm | WAFER_4P_2D54MM_11D5 | FB1 | FB0603 | 80ohm/600mA | FB0603 | FB2 | FB0603 | 80ohm/600mA | FB0603 | FB3 | FB0603 | 80ohm/600mA | FB0603 | FB7 | L0805 | 30ohm/3A | L0805 | FB8 | L0805 | 30ohm/3A | L0805 | FB10 | L0805 | 30ohm/3A | L0805 | FB11 | L0805 | 30ohm/3A | L0805 | FB12 | L0805 | 30ohm/3A | L0805 | FB16 | FB0805 | 120ohm_300mA | FB0805 | FB83 | FB0603 | 120ohm_3A | FB0603 | H25 | HOLE-OB7X19D4_2X16_2 | OB7X19D4 | HOLE-OB7X19D4_2X16_2 | H26 | HOLE-OB7X19D4_2X16_2 | OB7X19D4 | HOLE-OB7X19D4_2X16_2 | HS4 | HEATSINK_28X28X30 | 28X28X30MM | HEATSINK_28X28X30 | J1 | PJACK_5P_9D2X14_H5 | 33604-AudioJack,5PIN,90D, | PJACK_5P_9D2X14_H5 | JDIMM1 | DDR4_288P_1D7_H21D3 | 33401-MemoryConnectors,288PIN,180D,P=0.85MM | DDR4_288P_1D7_H21D3 | JDIMM3 | DDR4_288P_1D7_H21D3 | 33401-MemoryConnectors,288PIN,180D,P=0.85MM | DDR4_288P_1D7_H21D3 | JDIMM4 | DDR4_288P_1D7_H21D3 | 33401-MemoryConnectors,288PIN,180D, | DDR4_288P_1D7_H21D3 | JDIMM5 | DDR4_288P_1D7_H21D3 | 33401-MemoryConnectors,288PIN,180D,P=0.85MM | DDR4_288P_1D7_H21D3 | JDIMM7 | DDR4_288P_1D7_H21D3 | 33401-MemoryConnectors,288PIN,180D,P=0.85MM | DDR4_288P_1D7_H21D3 | JDIMM8 | DDR4_288P_1D7_H21D3 | 33401-MemoryConnectors,288PIN,180D, | DDR4_288P_1D7_H21D3 | JDIMM9 | DDR4_288P_1D7_H21D3 | 33401-MemoryConnectors,288PIN,180D,P=0.85MM | DDR4_288P_1D7_H21D3 | JDIMM10 | DDR4_288P_1D7_H21D3 | 33401-MemoryConnectors,288PIN,180D, | DDR4_288P_1D7_H21D3 | JDIMM11 | DDR4_288P_1D7_H21D3 | 33401-MemoryConnectors,288PIN,180D,P=0.85MM | DDR4_288P_1D7_H21D3 | JDIMM13 | DDR4_288P_1D7_H21D3 | 33401-MemoryConnectors,288PIN,180D,P=0.85MM | DDR4_288P_1D7_H21D3 | JDIMM14 | DDR4_288P_1D7_H21D3 | 33401-MemoryConnectors,288PIN,180D, | DDR4_288P_1D7_H21D3 | JDIMM15 | DDR4_288P_1D7_H21D3 | 33401-MemoryConnectors,288PIN,180D,P=0.85MM | DDR4_288P_1D7_H21D3 | JP4 | H3P_2D54MM_H8D6 | 3PIN,180D,P:2.54mm | H3P_2D54MM_H8D6 | JP11 | H8P_2D54MM_H8D6 | 8PIN,180D,P:2.54MM | H8P_2D54MM_H8D6 | JP13 | H2X4P_2D54MM_H6D5 | 8PIN,180D,2.54MM | H2X4P_2D54MM_H6D5 | JP15 | HSMD2X4P_1D27MM_H5D97 | 33503-Header,8PIN,180D,P:1.27MM | HSMD2X4P_1D27MM_H5D97 | JP21 | H3P_2D54MM_H8D6 | 3PIN,180D,P:2.54mm | H3P_2D54MM_H8D6 | L10 | L_4D15X4_H1D8 | 3.3uH_2.5A | L_4D15X4_H1D8 | L54 | L_10D7X8_H8D3 | 0.15uH_55A | L_10D7X8_H8D3 | L55 | L_4D2X4_H4 | 65nH_19A | L_4D2X4_H4 | L56 | L_4D2X4_H4 | 65nH_19A | L_4D2X4_H4 | L57 | L_4D2X4_H4 | 65nH_19A | L_4D2X4_H4 | L98 | L_10D7X8_H8D3 | 0.15uH_55A | L_10D7X8_H8D3 | L101 | L_10D7X8_H8D3 | 0.15uH_55A | L_10D7X8_H8D3 | L102 | L_4D5X4_H2 | 0.22uH_9A | L_4D5X4_H2 | L103 | L_10D7X8_H8D3 | 0.15uH_55A | L_10D7X8_H8D3 | L104 | L_7D3X6D6_H3 | 3.3uH_6A | L_7D3X6D6_H3 | L105 | L_11D5X10_H3D8 | 1uH_18A | L_11D5X10_H3D8 | L106 | L_6D95X6D6_H2D8 | 2.2uH_8A | L_6D95X6D6_H2D8 | LAN1 | RJ45X2_LED-M1-ZZ-0073 | 33603-RJ,28PIN,90D, | RJ45X2_LED-M1-ZZ-0073 | LED3 | LED0603 | YELLOW | LED0603 | LED4 | LED4P_SMD1D1_2X1D25XD8 | GREEN+YELLOW | LED4P_SMD1D1_2X1D25XD8 | LED5 | LED0603 | YELLOW | LED0603 | LED6 | LED4P_SMD1D1_2X1D25XD8 | GREEN+YELLOW | LED4P_SMD1D1_2X1D25XD8 | LED12 | LED7X2_20P_1D5MM_14D6X12X4D05 | ORANGE | LED7X2_20P_1D5MM_14D6X12X4D05 | LED14 | LED0603 | GREEN | LED0603 | LED20 | LED4P_SMD1D9_1D9X1D6XD8 | RED+GREEN | LED4P_SMD1D9_1D9X1D6XD8 | M2 | GBX_100P_1D8MM_H13D5-90 | 33611-HighFrequency,100PIN,90D, | GBX_100P_1D8MM_H13D5-90 | M3 | GBX_100P_1D8MM_H13D5-90 | 33611-HighFrequency,100PIN,90D, | GBX_100P_1D8MM_H13D5-90 | M5 | GBX_100P_1D8MM_H13D5-90 | 33611-HighFrequency,100PIN,90D, | GBX_100P_1D8MM_H13D5-90 | M9 | GBX_54P_2MM_H11D45-90 | AIRMAX,VS2,54PIN,90D,P=1.4MM | GBX_54P_2MM_H11D45-90 | P1V8_1 | H1P_2D54MM_H8D6 | 33503-Header,1PIN,180D,P=2.54MM | H1P_2D54MM_H8D6 | P1V8_AUX1 | H1P_2D54MM_H8D6 | 33503-Header,1PIN,180D,P=2.54MM | H1P_2D54MM_H8D6 | P3V3_1 | H1P_2D54MM_H8D6 | 33503-Header,1PIN,180D,P=2.54MM | H1P_2D54MM_H8D6 | P3V3_AUX1 | H1P_2D54MM_H8D6 | 33503-Header,1PIN,180D,P=2.54MM | H1P_2D54MM_H8D6 | P5V_1 | H1P_2D54MM_H8D6 | 33503-Header,1PIN,180D,P=2.54MM | H1P_2D54MM_H8D6 | P5V_AUX1 | H1P_2D54MM_H8D6 | 33503-Header,1PIN,180D,P=2.54MM | H1P_2D54MM_H8D6 | P12V1 | H1P_2D54MM_H8D6 | 33503-Header,1PIN,180D,P=2.54MM | H1P_2D54MM_H8D6 | P12V_AUX1 | H1P_2D54MM_H8D6 | 33503-Header,1PIN,180D,P=2.54MM | H1P_2D54MM_H8D6 | P12V_DUAL | H1P_2D54MM_H8D6 | 33503-Header,1PIN,180D,P=2.54MM | H1P_2D54MM_H8D6 | P1 | SOCKET_LGA4094 | 33404-CPUSocket,,180D, | SOCKET_LGA4094 | PCIE1 | PCIEX16_SMD164P_1MM_H11D1 | 33403-EdgecardCard,164PIN,180D, | PCIEX16_SMD164P_1MM_H11D1 | PCIE2 | PCIEX16_SMD164P_1MM_H11D1 | 33403-EdgecardCard,164PIN,180D, | PCIEX16_SMD164P_1MM_H11D1 | PSU1_PWRGOOD | H1P_2D54MM_H8D6 | 33503-Header,1PIN,180D,P=2.54MM | H1P_2D54MM_H8D6 | PSU2_PWRGOOD | H1P_2D54MM_H8D6 | 33503-Header,1PIN,180D,P=2.54MM | H1P_2D54MM_H8D6 | PVDDCR_CPU1 | H1P_2D54MM_H8D6 | 33503-Header,1PIN,180D,P=2.54MM | H1P_2D54MM_H8D6 | PVDDCR_SOC1 | H1P_2D54MM_H8D6 | 33503-Header,1PIN,180D,P=2.54MM | H1P_2D54MM_H8D6 | PVDDCR_SOC_AUX1 | H1P_2D54MM_H8D6 | 33503-Header,1PIN,180D,P=2.54MM | H1P_2D54MM_H8D6 | PVDDIO_ABCD1 | H1P_2D54MM_H8D6 | 33503-Header,1PIN,180D,P=2.54MM | H1P_2D54MM_H8D6 | PVDDIO_EFGH1 | H1P_2D54MM_H8D6 | 33503-Header,1PIN,180D,P=2.54MM | H1P_2D54MM_H8D6 | PVPP_ABCD1 | H1P_2D54MM_H8D6 | 33503-Header,1PIN,180D,P=2.54MM | H1P_2D54MM_H8D6 | PVPP_EFGH1 | H1P_2D54MM_H8D6 | 33503-Header,1PIN,180D,P=2.54MM | H1P_2D54MM_H8D6 | PVTT_ABCD1 | H1P_2D54MM_H8D6 | 33503-Header,1PIN,180D,P=2.54MM | H1P_2D54MM_H8D6 | PVTT_EFGH1 | H1P_2D54MM_H8D6 | 33503-Header,1PIN,180D,P=2.54MM | H1P_2D54MM_H8D6 | PWROK_3V3_1 | H1P_2D54MM_H8D6 | 33503-Header,1PIN,180D,P=2.54MM | H1P_2D54MM_H8D6 | PWROK_3V3_2 | H1P_2D54MM_H8D6 | 33503-Header,1PIN,180D,P=2.54MM | H1P_2D54MM_H8D6 | PWROK_3V3_3 | H1P_2D54MM_H8D6 | 33503-Header,1PIN,180D,P=2.54MM | H1P_2D54MM_H8D6 | PWR_BTN_N1 | H1P_2D54MM_H8D6 | 33503-Header,1PIN,180D,P=2.54MM | H1P_2D54MM_H8D6 | PWR_GOOD1 | H1P_2D54MM_H8D6 | 33503-Header,1PIN,180D,P=2.54MM | H1P_2D54MM_H8D6 | PWR_GOOD2 | H1P_2D54MM_H8D6 | 33503-Header,1PIN,180D,P=2.54MM | H1P_2D54MM_H8D6 | Q9 | SOT23_GDS | 2N7002 | SOT23_GDS | Q10 | SOT23_BCE | PMBS3904 | SOT23_BCE | Q11 | SOT23_BCE | PMBS3904 | SOT23_BCE | Q12 | SOT23_GDS | 2N7002 | SOT23_GDS | Q16 | SOT23_GDS | 2N7002 | SOT23_GDS | Q24 | SOT363_6 | NX7002AKS | SOT363_6 | Q25 | SOT363_6 | NX7002AKS | SOT363_6 | Q28 | SOT23_6 | SM2601PSCC-TRG | SOT23_6 | Q29 | SOT23_GDS | 2N7002 | SOT23_GDS | Q34 | SOT23_GDS | 2N7002 | SOT23_GDS | Q45 | SOT23_GDS | 2N7002 | SOT23_GDS | Q46 | SOT23_GDS | 2N7002 | SOT23_GDS | Q50 | SOT23_GDS | 2N7002 | SOT23_GDS | Q70 | SOT23_GDS | 2N7002 | SOT23_GDS | Q71 | SOT23_GDS | 2N7002 | SOT23_GDS | Q94 | SOT23_GDS | 2N7002 | SOT23_GDS | Q95 | SOT23_GDS | 2N7002 | SOT23_GDS | Q117 | SOT23_GDS | SM2416NSAN | SOT23_GDS | Q123 | SOT23_GDS | NX7002AK | SOT23_GDS | Q124 | SOT363_6 | SM1660DSCS | SOT363_6 | Q125 | SOT363_6 | SM1660DSCS | SOT363_6 | Q126 | SO8_PWRPAK_5P | SM4311PSKPC-TRG | SO8_PWRPAK_5P | Q127 | SOT363_6 | NX7002AKS | SOT363_6 | Q128 | SOT23_GDS | SM2416NSAN | SOT23_GDS | Q130 | SOT23_GDS | 2N7002 | SOT23_GDS | Q131 | SOT23_GDS | 2N7002 | SOT23_GDS | RSMRST_N1 | H1P_2D54MM_H8D6 | 33503-Header,1PIN,180D,P=2.54MM | H1P_2D54MM_H8D6 | RT8 | THR2P_DIP_2D54_4X3D5X4D5 | 10.0Kohm | THR2P_DIP_2D54_4X3D5X4D5 | RT9 | THR2P_DIP_2D54_4X3D5X4D5 | 10.0Kohm | THR2P_DIP_2D54_4X3D5X4D5 | RT10 | THR2P_DIP_2D54_4X3D5X4D5 | 10.0Kohm | THR2P_DIP_2D54_4X3D5X4D5 | RT11 | THR2P_DIP_2D54_4X3D5X4D5 | 10.0Kohm | THR2P_DIP_2D54_4X3D5X4D5 | SFP1 | SFP_20P_11X8D52X5D45 | 33614-OpticalFiber,20PIN,90D,P=0.8MM | SFP_20P_11X8D52X5D45 | SFP2 | SFP_20P_11X8D52X5D45 | 33614-OpticalFiber,20PIN,90D,P=0.8MM | SFP_20P_11X8D52X5D45 | SLP_S3_N1 | H1P_2D54MM_H8D6 | 33503-Header,1PIN,180D,P=2.54MM | H1P_2D54MM_H8D6 | SLP_S5 | H1P_2D54MM_H8D6 | 33503-Header,1PIN,180D,P=2.54MM | H1P_2D54MM_H8D6 | SW1 | SW_DTSML-32Y-V-TR | TACTSWITCH,2PIN | SW_DTSML-32Y-V-TR | SW2 | SW_BTS-1102VB-1-B-ST46 | TACTSWITCH,2PIN | SW_BTS-1102VB-1-B-ST46 | TPM1 | HSMD2X10P_1D27MM_H6D6-F-L2 | 33503-Header,19PIN,180D,P=1.27mm | HSMD2X10P_1D27MM_H6D6-F-L2 | U3 | SOT89_GIO | S-1206B15-U3T1U | SOT89_GIO | U8 | SC70_5P | SN74LVC1G08DCKR | SC70_5P | U11 | SON6_D65_TH1D6X1 | TPS2553DRVT | SON6_D65_TH1D6X1 | U12 | SON6_D65_TH1D6X1 | TPS2553DRVT | SON6_D65_TH1D6X1 | U21 | SOT23_5 | SN74LVC1G07DBVR | SOT23_5 | U22 | SSOP16_D635 | LTC2629CGN-1#TRPBF | SSOP16_D635 | U23 | SSOP24_D635 | LTC4306CGN#TRPBF | SSOP24_D635 | U24 | SSOP16_D635 | LTC2629CGN-1#TRPBF | SSOP16_D635 | U28 | SO8_W5D2 | MX25L25645GM2I-08G | SO8_W5D2 | U31 | SC70_5P | SN74LVC1G07DCKR | SC70_5P | U36 | BGA256_1MM_17X17 | LCMXO2-1200UHC-4FTG256C | BGA256_1MM_17X17 | U39 | TSSOP16_D65 | SN74AVC4T245PWR | TSSOP16_D65 | U48 | SC70_6P | NC7WV07P6X | SC70_6P | U50 | SOT23_5 | SN74LVC1G17DBVR | SOT23_5 | U51 | TSOT-238_D65 | MP1475DJ-LF-Z | TSOT-238_D65 | U64 | QFN29_D5_5X4 | MPQ8632GVE-15-Z | QFN29_D5_5X4 | U65 | QFN16_D5-T2D55X2D05-V6 | SN74AVC4T774RGYR | QFN16_D5-T2D55X2D05-V6 | U66 | SC70_5P | SN74LVC1G07DCKR | SC70_5P | U75 | LQFP128_D4 | IT8528E/FX | LQFP128_D4 | U76 | SOT23_GVR | TLV809K33DBVR | SOT23_GVR | U85 | QFN21_D4-MPQ8633AGLE | MPQ8633AGLE-Z | QFN21_D4-MPQ8633AGLE | U93 | QFN16_D5_3X4 | MPQ8636GLE-10-Z | QFN16_D5_3X4 | U120 | QFN21_D4-MPQ8633AGLE | MPQ8633AGLE-Z | QFN21_D4-MPQ8633AGLE | U122 | TSOT-238_D65 | MP1475DJ-LF-Z | TSOT-238_D65 | U124 | SO8_W5D2 | MX25L25645GM2I-08G | SO8_W5D2 | U126 | FCBGA320_D8MM_15X15 | MT28942A0-NCCF-AE | FCBGA320_D8MM_15X15 | U139 | SO8 | W25Q16JVSNIQ | SO8 | U141 | SO8 | W25Q16JVSNIQ | SO8 | U142 | QFN56_D4-T5D2X5D2 | KTI225VSLMNG | QFN56_D4-T5D2X5D2 | U143 | QFN56_D4-T5D2X5D2 | KTI225VSLMNG | QFN56_D4-T5D2X5D2 | U144 | QFN24_D5-T2D9X2D9 | TUSB522PRGER | QFN24_D5-T2D9X2D9 | U145 | QFN24_D5-T2D9X2D9 | TUSB522PRGER | QFN24_D5-T2D9X2D9 | U146 | SSOP16_D65 | MAX3232ECDBRG4 | SSOP16_D65 | U149 | QFN48_D4-T4D2X4D2 | 9ZXL0851EKILFT | QFN48_D4-T4D2X4D2 | U154 | TSOT-238_D65 | MP1475DJ-LF-Z | TSOT-238_D65 | U155 | VQFN18_D5-D65 | TPS56C215RNNR | VQFN18_D5-D65 | U156 | HTSSOP14_D65-T2D31X2D46 | TPS54426PWPR | HTSSOP14_D65-T2D31X2D46 | U158 | SO8 | MX25L512EMI-10G | SO8 | U159 | SO8 | 24LC04BT-I/SNG | SO8 | U161 | QFN52_D4-T4D7X4D7 | ISL69247IRAZ-T | QFN52_D4-T4D7X4D7 | U162 | QFN39_D45-ISL99390R | ISL99390FRZ-TR5935 | QFN39_D45-ISL99390R | U163 | QFN39_D45-ISL99390R | ISL99390FRZ-TR5935 | QFN39_D45-ISL99390R | U164 | QFN39_D45-ISL99390R | ISL99390FRZ-TR5935 | QFN39_D45-ISL99390R | U165 | QFN39_D45-ISL99390R | ISL99390FRZ-TR5935 | QFN39_D45-ISL99390R | U166 | QFN39_D45-ISL99390R | ISL99390FRZ-TR5935 | QFN39_D45-ISL99390R | U169 | QFN32_D4-TH2D7X2D7 | ISL69243 | QFN32_D4-TH2D7X2D7 | U170 | QFN39_D45-ISL99390R | ISL99390FRZ-TR5935 | QFN39_D45-ISL99390R | U171 | QFN39_D45-ISL99390R | ISL99390FRZ-TR5935 | QFN39_D45-ISL99390R | U172 | QFN52_D4-T4D7X4D7 | ISL68224IRAZ-T | QFN52_D4-T4D7X4D7 | U173 | QFN39_D45-ISL99390R | ISL99390FRZ-TR5935 | QFN39_D45-ISL99390R | U174 | QFN39_D45-ISL99390R | ISL99390FRZ-TR5935 | QFN39_D45-ISL99390R | U175 | QFN39_D45-ISL99390R | ISL99390FRZ-TR5935 | QFN39_D45-ISL99390R | U176 | QFN52_D4-T4D7X4D7 | ISL68224IRAZ-T | QFN52_D4-T4D7X4D7 | U177 | QFN39_D45-ISL99390R | ISL99390FRZ-TR5935 | QFN39_D45-ISL99390R | U178 | QFN39_D45-ISL99390R | ISL99390FRZ-TR5935 | QFN39_D45-ISL99390R | U198 | QFN39_D45-ISL99390R | ISL99390FRZ-TR5935 | QFN39_D45-ISL99390R | U201 | QFN39_D45-ISL99390R | ISL99390FRZ-TR5935 | QFN39_D45-ISL99390R | U202 | QFN39_D45-ISL99390R | ISL99390FRZ-TR5935 | QFN39_D45-ISL99390R | U205 | QFN24_D5-T2D9X2D9 | TUSB522PRGER | QFN24_D5-T2D9X2D9 | U207 | QFN24_D4-G5329B | G5329BQU1U | QFN24_D4-G5329B | U208 | QFN16_D5_3X4 | MPQ8636GLE-10-Z | QFN16_D5_3X4 | U209 | SC70_5P | SN74LVC1G08DCKR | SC70_5P | U210 | TQFN42_D5-T2D05X7D55-V18 | PI3EQX16000ZHEX | TQFN42_D5-T2D05X7D55-V18 | U211 | TQFN42_D5-T2D05X7D55-V18 | PI3EQX16000ZHEX | TQFN42_D5-T2D05X7D55-V18 | U212 | TQFN42_D5-T2D05X7D55-V18 | PI3EQX16000ZHEX | TQFN42_D5-T2D05X7D55-V18 | U213 | TQFN42_D5-T2D05X7D55-V18 | PI3EQX16000ZHEX | TQFN42_D5-T2D05X7D55-V18 | U214 | TQFN42_D5-T2D05X7D55-V18 | PI3EQX16000ZHEX | TQFN42_D5-T2D05X7D55-V18 | U215 | TQFN42_D5-T2D05X7D55-V18 | PI3EQX16000ZHEX | TQFN42_D5-T2D05X7D55-V18 | U216 | TQFN42_D5-T2D05X7D55-V18 | PI3EQX16000ZHEX | TQFN42_D5-T2D05X7D55-V18 | U217 | TQFN42_D5-T2D05X7D55-V18 | PI3EQX16000ZHEX | TQFN42_D5-T2D05X7D55-V18 | U218 | QFN39_D45-ISL99390R | ISL99390FRZ-TR5935 | QFN39_D45-ISL99390R | U219 | QFN39_D45-ISL99390R | ISL99390FRZ-TR5935 | QFN39_D45-ISL99390R | USB_CON1 | USB_2_A_2MM_15X17D5X16D4 | 33601-USB,18PIN,90D, | USB_2_A_2MM_15X17D5X16D4 | USB_CON2 | USB_1_A_2MM_14D8X16D5X7D8 | 33601-USB,9PIN,90D, | USB_1_A_2MM_14D8X16D5X7D8 | USB_DOM1 | HBSMD2X4P_2D54MM_H12D3-FKN | *PINHEADER2*4,8PIN,180D,P:2.54mm | HBSMD2X4P_2D54MM_H12D3-FKN | Y1 | CRYSMD3D2X2D5_6P_EPSON | 156.25MHz | CRYSMD3D2X2D5_6P_EPSON | Y3 | CRYSMD3D2X2D5_4P_FUJICOM | 25MHz | CRYSMD3D2X2D5_4P_FUJICOM | Y4 | CRYSMD6D9X1D4_4P_AKER | 32.768KHz | CRYSMD6D9X1D4_4P_AKER | Y5 | CRYSMD3D2X2D5_4P_HARM | 48MHz | CRYSMD3D2X2D5_4P_HARM | Y7 | CRYSMD3D2X2D5_4P_FUJICOM | 25MHz | CRYSMD3D2X2D5_4P_FUJICOM |
重要提示:PCB作品文件展下载说明
