REFDES | COMP_DEVICE_TYPE | COMP_VALUE | SYM_NAME |
B1 | BEEP_RB12_8_BEEP | BEEP | RB12_8 |
BT1 | BATTERY_CR1220-2_DISCRETE_CR122 | CR1220 | CR1220-2 |
D1 | TSOP4838_1_A | 3638A | SEN3-100-0606 |
D3 | SBD_SOT_23_LBAT54CLT1G | LBAT54CLT1G | SOT_23 |
D4 | PESD5V0X1BL | PESD5V0X1BL | HSOD882 |
D5 | PESD5V0X1BL | PESD5V0X1BL | HSOD882 |
D6 | PESD5V0X1BL | PESD5V0X1BL | HSOD882 |
D7 | PESD5V0X1BL | PESD5V0X1BL | HSOD882 |
D8 | PESD5V0X1BL | PESD5V0X1BL | HSOD882 |
D10 | PESDALC10N5VU | RCLAMP0524P | MLF10-050-0301L |
D11 | PESD5V0X1BL | PESD5V0X1BL | HSOD882 |
D12 | PESD5V0X1BL | PESD5V0X1BL | HSOD882 |
D13 | PESD5V0X1BL | PESD5V0X1BL | HSOD882 |
D14 | PESD5V0X1BL | PESD5V0X1BL | HSOD882 |
D15 | BAT60BE6327 | BAT60BE6327 | HSOD323A |
D16 | PESD5V0X1BL | PESD5V0X1BL | HSOD882 |
D18 | 1SMA13CAT3G | 1SMA13CAT3G | SD1710A |
D24 | TVS_DO-214AA_SPD4200B | SPD4200B | DO-214AA |
D30 | PESD5V0X1BL | PESD5V0X1BL | HSOD882 |
D31 | PESD5V0X1BL | PESD5V0X1BL | HSOD882 |
D32 | P3100_ESD0603_NC/PUSI1608S170_1 | NC/PUSI1608S170 | ESD0603 |
D33 | P3100_ESD0603_NC/PUSI1608S170_1 | NC/PUSI1608S170 | ESD0603 |
D34 | TVS_DO-214AA_SPD4200B | SPD4200B | DO-214AA |
D35 | TVS_DO-214AA_SPD4200B | SPD4200B | DO-214AA |
D36 | TVS_DO-214AA_SPD4200B | SPD4200B | DO-214AA |
D39 | TVS_DO-214AA_SPD4200B | SPD4200B | DO-214AA |
D40 | TVS_DO-214AA_SPD4200B | SPD4200B | DO-214AA |
D41 | TVS_DO-214AA_SPD4200B | SPD4200B | DO-214AA |
D42 | TVS_DO-214AA_SPD4200B | SPD4200B | DO-214AA |
D43 | PESDALC10N5VU | RCLAMP0524P | MLF10-050-0301L |
D44 | TVS_DO-214AA_SPD4200B | SPD4200B | DO-214AA |
E28 | ESD_PCB_ESD_PCB_NC_ESD_PCB | NC_ESD_PCB | ESD_PCB |
F1 | 0451005MRL | 0451005MRL | SF6127 |
ID1 | PCB_MARKPOINT | ID-BOARD | ID-BOARD |
ID2 | PCB_MARKPOINT | ID-BOARD | ID-BOARD |
ID3 | PCB_MARKPOINT | ID-BOARD | ID-BOARD |
ID4 | PCB_MARKPOINT | ID-BOARD | ID-BOARD |
ID5 | PCB_MARKPOINT | ID-BOARD | ID-BOARD |
ID6 | PCB_MARKPOINT | ID-BOARD | ID-BOARD |
J8 | DC2026_00 | PWC3_A | PWC0103-M-C |
J10 | SATA_7_SATA7-M-A_SATASOCKET | SATASOCKET | SATA7-M-A |
J11 | ZH1.5-4P | WBC1X41 | FPC4-1_5-9_2X3_8-H5_1 |
J12 | DB15-3M2_DB15-3RF-A_DB15-3M2 | DB15-3M2 | DB15-3RF-A |
J14 | CON-RJ45&USBX2_RJC5_RJ45&USBX2 | RJ45&USBx2 | RJC5 |
J16 | HDMI | HDMISOCKET | RUSB19-050-1512 |
J23 | SATA_POWER_SIP-4P-200_SATA_POWE | SATA_POWER | SIP-4P-200 |
J26 | ZH1.5-4P | WBC1X41 | FPC4-1_5-9_2X3_8-H5_1 |
J102 | RCA1X2_RCA1X2_RCA1X2 | RCA1X2 | RCA1X2 |
J105 | BNC4_0_BNC4_BNC4X1 | BNC4X1 | BNC4 |
J106 | BNC4_0_BNC4_BNC4X1 | BNC4X1 | BNC4 |
J107 | BNC4_0_BNC4_BNC4X1 | BNC4X1 | BNC4 |
J109 | BNC4_0_BNC4_BNC4X1 | BNC4X1 | BNC4 |
J110 | SATA_7_SATA7-M-A_SATASOCKET | SATASOCKET | SATA7-M-A |
L1 | INDUCTORFERRITE_L5X5H4_4.7UH | 4.7uH | L5X5H4 |
L2 | INDUCTORFERRITE_L2X2H2_2.2UH | 2.2uH | L2X2H2 |
L3 | INDUCTORFERRITE_L4X4H3_1.0UH | 1.0uH | L4X4H3 |
L4 | INDUCTORFERRITE_L5X5H4_4.7UH | 4.7uH | L5X5H4 |
L5 | INDUCTORFERRITE_0_SL0603_150NH | 150nH | SL0603 |
L6 | INDUCTORFERRITE_0_SL0603_150NH | 150nH | SL0603 |
L7 | INDUCTORFERRITE_0_SL0603_150NH | 150nH | SL0603 |
L9 | INDUCTORFERRITE_L2X2H2_2.2UH | 2.2uH | L2X2H2 |
L10 | INDUCTORFERRITE_L2X2H2_2.2UH | 2.2uH | L2X2H2 |
L11 | BEAD_SR0603_30OHM/100MHZ | 30ohm/100MHz | SR0603 |
LB10 | BEAD_SL0402_1000OHM/100MHZ | 1000ohm/100MHz | SL0402 |
LB11 | BEAD_SL0402_1000OHM/100MHZ | 1000ohm/100MHz | SL0402 |
LB12 | BEAD_SL0402_1000OHM/100MHZ | 1000ohm/100MHz | SL0402 |
LB13 | BEAD_SL0603_30OHM/100MHZ | 30ohm/100MHz | SL0603 |
LB18 | BEAD_SL0402_1000OHM/100MHZ | 1000ohm/100MHz | SL0402 |
LB19 | BEAD_SL1210_600OHM/100MHZ | 600ohm/100MHz | SL1210 |
LB20 | BEAD_SL1210_600OHM/100MHZ | 600ohm/100MHz | SL1210 |
LB83 | BEAD_SL0402_1000OHM/100MHZ | 1000ohm/100MHz | SL0402 |
LB94 | BEAD_SL0402_1000OHM/100MHZ | 1000ohm/100MHz | SL0402 |
LB96 | BEAD_SL0402_1000OHM/100MHZ | 1000ohm/100MHz | SL0402 |
LB97 | BEAD_SL0402_1000OHM/100MHZ | 1000ohm/100MHz | SL0402 |
LB99 | BEAD_SL0402_1000OHM/100MHZ | 1000ohm/100MHz | SL0402 |
LB100 | BEAD_SL1210_600OHM/100MHZ | 600ohm/100MHz | SL1210 |
LB101 | BEAD_SL0603_30OHM/100MHZ | 30ohm/100MHz | SL0603 |
LB102 | BEAD_SL0603_30OHM/100MHZ | 30ohm/100MHz | SL0603 |
LB103 | BEAD_SL0603_30OHM/100MHZ | 30ohm/100MHz | SL0603 |
LB104 | BEAD_SL0603_30OHM/100MHZ | 30ohm/100MHz | SL0603 |
LB105 | BEAD_SL0603_30OHM/100MHZ | 30ohm/100MHz | SL0603 |
LB106 | BEAD_SL0603_30OHM/100MHZ | 30ohm/100MHz | SL0603 |
LB107 | BEAD_SL0603_30OHM/100MHZ | 30ohm/100MHz | SL0603 |
LB108 | BEAD_SL0603_30OHM/100MHZ | 30ohm/100MHz | SL0603 |
LB109 | BEAD_SL0603_30OHM/100MHZ | 30ohm/100MHz | SL0603 |
LB110 | BEAD_SL0402_1000OHM/100MHZ | 1000ohm/100MHz | SL0402 |
LB121 | BEAD_SL0402_1000OHM/100MHZ | 1000ohm/100MHz | SL0402 |
LB122 | BEAD_SL0402_1000OHM/100MHZ | 1000ohm/100MHz | SL0402 |
LB123 | BEAD_SL0603_30OHM/100MHZ | 30ohm/100MHz | SL0603 |
LB124 | BEAD_SL0603_30OHM/100MHZ | 30ohm/100MHz | SL0603 |
LB125 | BEAD_SL0603_30OHM/100MHZ | 30ohm/100MHz | SL0603 |
LB126 | BEAD_SL0603_30OHM/100MHZ | 30ohm/100MHz | SL0603 |
LB127 | BEAD_SL0603_30OHM/100MHZ | 30ohm/100MHz | SL0603 |
LB128 | BEAD_SL0603_30OHM/100MHZ | 30ohm/100MHz | SL0603 |
LB129 | BEAD_SL0603_30OHM/100MHZ | 30ohm/100MHz | SL0603 |
LB130 | BEAD_SL0603_30OHM/100MHZ | 30ohm/100MHz | SL0603 |
LB131 | BEAD_SL0603_30OHM/100MHZ | 30ohm/100MHz | SL0603 |
LB132 | BEAD_SL0603_30OHM/100MHZ | 30ohm/100MHz | SL0603 |
LB133 | BEAD_SL0402_1000OHM/100MHZ | 1000ohm/100MHz | SL0402 |
LB134 | BEAD_SL0402_1000OHM/100MHZ | 1000ohm/100MHz | SL0402 |
LED3 | LED_LED0603_YELLOW | YELLOW | LED0603 |
LED4 | LED_LED0603_BLUE | BLUE | LED0603 |
LED5 | LED_LED0603_RED | RED | LED0603 |
LED6 | LED_SD0805-LED_RED | RED | SD0805-LED |
M1 | 138MIL_STAR_HOLE_TO_M3_A | NC | HOLE160-8STAR |
M2 | 138MIL_STAR_HOLE_TO_M3_A | NC | HOLE160-8STAR |
M3 | 138MIL_STAR_HOLE_TO_M3_A | NC | HOLE160-8STAR |
Q4 | 2N835_SOT-23_S8050 | S8050 | SOT-23 |
RN26 | R8P4R_0_SRN8-0804_33 | 33 | SRN8-0804 |
SW2 | PUSH_BUTTON_KEY_2PIN_RESET | Reset | KEY_2PIN |
T5 | PAD1-SQ_PAD_SMD_001_S005_NC-PA | NC-PAD-0.5X0.5 | PAD_SMD_001_S005 |
U1 | MP1605_3_HSOT-563_MP1605 | MP1605 | HSOT-563 |
U4 | GD25Q127CSIG_WSON8-MX25L12835ZN | GD25Q127CSIG | WSON8-MX25L12835ZN |
U5 | GD25Q127CSIG_WSON8-MX25L12835ZN | GD25Q127CSIG | WSON8-MX25L12835ZN |
U8 | MP1605_3_HSOT-563_MP1605 | MP1605 | HSOT-563 |
U10 | K4A4G165WF-BCTD | K4A4G165WF-BCTD | BGA96-32-1609M |
U12 | MP1495S_TSOT23-8_MP1495S | MP1495S | TSOT23-8 |
U14 | ESD5305F-6/TR_0_SOT23-6L_ESD530 | ESD5305F-6/TR | SOT23-6L |
U15 | MP1495S_TSOT23-8_MP1495S | MP1495S | TSOT23-8 |
U17 | MP1653_HSOT-563_MP1653 | MP1653 | HSOT-563 |
U21 | MP1652_HSOT-563_MP1652 | MP1652 | HSOT-563 |
U35 | YJ_QFN88_DVP_QFN88_YJ_FH6210 | FH6210 | QFN88_YJ |
U37 | H1601CG_SOP16_270_50_H1601CG | H1601CG | SOP16_270_50 |
U38 | YJ_QFN88_DVP_QFN88_YJ_FH6210 | FH6210 | QFN88_YJ |
U44 | TPS51200 | TPS51200 | UQFN-10PIN |
U189 | TPS79301DBVR_SOT23_6_TPS79301DB | TPS79301DBVR | SOT23_6 |
U195 | CAT811 | CAT811 | SOT-143 |
U196 | MC6650_0_BGA462-32-2323_(S1+S2+ | MC6650 | BGA462-32-2323 |
U197 | K4A4G165WF-BCTD | K4A4G165WF-BCTD | BGA96-32-1609M |
U198 | ESD5305F-6/TR_0_SOT23-6L_ESD530 | ESD5305F-6/TR | SOT23-6L |
U199 | YJ_QFN88_DVP_QFN88_YJ_FH6210 | FH6210 | QFN88_YJ |
U200 | YJ_QFN88_DVP_QFN88_YJ_FH6210 | FH6210 | QFN88_YJ |
U202 | SN74LVC2G34DBVR | SN74LVC2G34DBVR | SOT23-6-P095-H1_45 |
U203 | SN74LVC2G34DBVR | SN74LVC2G34DBVR | SOT23-6-P095-H1_45 |
X1 | M24000E027 | 24MHz | HSX4-0302 |
X2 | CRY_HSX2-0302_32.768KHZ | 32.768KHZ | HSX2-0302 |
Y1 | OSC4P_HSX4-0302B_27MHZ | 27MHZ | HSX4-0302B |
Y2 | OSC4P_HSX4-0302B_27MHZ | 27MHZ | HSX4-0302B |
