查看: 3586|回复: 62
[Allegro17.4以下] LT9211D+RTL8211F-CG 做的开发板底板PCB
    终身成就奖社区居民忠实会员宣传大使奖优秀斑竹奖
    发表于 2023-4-22 09:31:48 | 显示全部楼层 |阅读模式
    重要提示:PCB作品文件展下载说明
    f8-rk3568-MB.zip (1.05 MB, 下载次数: 21)
    BACKSW-TACT_0_SW4-SMD_KEYKEYSW4-SMD
    BAT1BATTERY_0_BAT1_CR1220CR1220BAT1
    C306CAP_NP0603_C0402_0.1UF0.1uFC0402
    CON1CON40X2_0_8MM_CON2X40-0_5MM-AA_CON40X2_0_5MMCON40X2_0_5MMCON2X40-0_5MM-AA
    CON2CON40X2_0_8MM_CON2X40-0_5MM-AA_CON40X2_0_5MMCON40X2_0_5MMCON2X40-0_5MM-AA
    CON3CON40X2_0_8MM_CON2X40-0_5MM-AA_CON40X2_0_5MMCON40X2_0_5MMCON2X40-0_5MM-AA
    CON4CON40X2_0_8MM_CON2X40-0_5MM-AA_CON40X2_0_5MMCON40X2_0_5MMCON2X40-0_5MM-AA
    CON9CON_DB9_DSUB9-RA-FE_CON_DB9CON_DB9DSUB9-RA-FE
    D1DIODESCHOTTKY_5_DO214AA_B340AB340ADO214AA
    D2DIODE_D1206_IN4148IN4148D1206
    D3DIODE_D1206_IN4148IN4148D1206
    D4DIODEBI_DIR TRIG_ESD0402_ESD5311XESD5311XESD0402
    D5DIODEBI_DIR TRIG_ESD0402_ESD5311XESD5311XESD0402
    D7DIODEBI_DIR TRIG_ESD0402_ESD5311XESD5311XESD0402
    D8DIODEBI_DIR TRIG_ESD0402_ESD5311XESD5311XESD0402
    D9DIODEBI_DIR TRIG_ESD0402_ESD5341NESD5341NESD0402
    D10DIODEBI_DIR TRIG_ESD0402_ESD5341NESD5341NESD0402
    D17DIODEBI_DIR TRIG_ESD0402_ESD5341NESD5341NESD0402
    D18DIODEBI_DIR TRIG_ESD0402_ESD5341NESD5341NESD0402
    D19DIODEBI_DIR TRIG_ESD0402_ESD5341NESD5341NESD0402
    D20DIODEBI_DIR TRIG_ESD0402_ESD5341NESD5341NESD0402
    D21DIODE_SOD_323_B5819WSB5819WSSOD_323
    D35DIODEBI_DIR TRIG_ESD0402_ESD5451NESD5451NESD0402
    D36DIODEBI_DIR TRIG_ESD0402_ESD5451NESD5451NESD0402
    D37DIODEBI_DIR TRIG_ESD0402_ESD5451NESD5451NESD0402
    D38DIODEBI_DIR TRIG_ESD0402_ESD5451NESD5451NESD0402
    D44DIODE_SOD_123_NCNCSOD_123
    ED10DIODEBI_DIR TRIG_ESD0402_ESD5451NESD5451NESD0402
    ED11DIODEBI_DIR TRIG_ESD0402_ESD5451NESD5451NESD0402
    FB8BEAD0603_L0603_220R/100MHZ220R/100MHzL0603
    FB9FB1206_0_FB0603_FB0603FB0603FB0603
    FB10FB1206_0_FB0603_FB0603FB0603FB0603
    FB11BEAD0603_L0603_220R/100MHZ220R/100MHzL0603
    FB12BEAD0603_L0603_NC/220R/100MHZNC/220R/100MHzL0603
    FB13BEAD0603_L0603_220R/100MHZ220R/100MHzL0603
    FB14BEAD0603_L0603_220R/100MHZ220R/100MHzL0603
    FB15BEAD0603_L0603_220R/100MHZ220R/100MHzL0603
    H1RCAJACK_0_HOLE2_3-M2_HOLEHOLEHOLE2_3-M2
    H2RCAJACK_0_HOLE2_3-M2_HOLEHOLEHOLE2_3-M2
    H3RCAJACK_0_HOLE2_3-M2_HOLEHOLEHOLE2_3-M2
    H4RCAJACK_0_HOLE2_3-M2_HOLEHOLEHOLE2_3-M2
    H5RCAJACK_0_HOLE3_2X6_HOLEHOLEHOLE3_2X6
    H6RCAJACK_0_HOLE3_2X6_HOLEHOLEHOLE3_2X6
    H7RCAJACK_0_HOLE3_2X6_HOLEHOLEHOLE3_2X6
    H8RCAJACK_0_HOLE3_2X6_HOLEHOLEHOLE3_2X6
    HOMESW-TACT_0_SW4-SMD_KEYKEYSW4-SMD
    IR1IRM_0_IJ3_IRM_3638_IRM_3638IRM_3638IJ3_IRM_3638
    J1U-MP2012DQ_2_SWITCH_DDSZ_PS_LPS_LSWITCH_DDSZ
    J2USB30_TYPE_A_V_2_USB30A9_25R70X7R32X13R85_USB30_A_VUSB30_A_VUSB30A9_25R70X7R32X13R85
    J5USB20_TPYEA_4_USB-A2_USB20_TPYEA_01USB20_TPYEA_01USB-A2
    J6USB20_TPYEA_4_USB-A2_USB20_TPYEA_01USB20_TPYEA_01USB-A2
    J7MD60-19P_4_HDMI-C_MD60-19PMD60-19PHDMI-C
    J9LVDS_QM_2_FPC30-050_LVDS_QMLVDS_QMFPC30-050
    J12CONN_MICRO_SDCARD_9P_TF-CARD_IO_CONN_SD_CARD9CONN_SD_CARD9TF-CARD
    J13HR911130C_0_RJ10-SRLBY_HR911130CHR911130CRJ10-SRLBY
    J15PHONOJACKSTEREO-15_0_EAR_JACK_VPH-3003J-CTVPH-3003J-CTEAR_JACK
    J16JACK_AU_EAR_JACK_JACK_AUJACK_AUEAR_JACK
    J26CON4_0_CN4M_2R54_V_P_DIP_CN4M_2R54_VCN4M_2R54_VCN4M_2R54_V_P_DIP
    J33CON2_2_54P_A4B-2PA-2_54DSA_A4B-2PA-2_54DSAA4B-2PA-2_54DSAA4B-2PA-2_54DSA
    J41CON15X2X200MM_CON15X2X200MM_CON15X2X200MMCON15X2X200MMCON15X2X200MM
    J4224PINFPC CON_0_FPC24-050_24PIN FPC CON24PINFPC CONFPC24-050
    J4340PINFPC CON_0_FPC40-050_40PIN FPC CON40PINFPC CONFPC40-050
    J446PINFPC CON_1_FPC6-100_6PIN FPC CON6PINFPC CONFPC6-100
    JACK1POWERJACK_3_JACK-2_5MM_B_POWER JACK_3POWERJACK_3JACK-2_5MM_B
    K1BUTTON_1_SW4-SMD_BUTTONBUTTONSW4-SMD
    L1LQH32C_0_L6X6-CDRH58D18R_4.7UH4.7uHL6X6-CDRH58D18R
    L3INDUCTORCOM_RP2_0405_NCNCRP2_0405
    L5INDUCTORCOM_RP2_0405_NCNCRP2_0405
    L6INDUCTORCOM_RP2_0405_NCNCRP2_0405
    L7INDUCTORSOF FERRITE_IND2520_2.2UH2.2uHIND2520
    L18INDUCTORSOF FERRITE_IND_303015_PCMB051H-2R2MS/6APCMB051H-2R2MS/6AIND_303015
    L19INDUCTOR0805_IND2520_2.2UH/1A2.2uH/1AIND2520
    LED1LED-RED_SMD_1_LED-2012_LED-RED(SMD 2012)LED-Red(SMD 2012)LED-2012
    LED2LED_LED0603_LED_YELLOWLED_YellowLED0603
    LED3LED_LED0603_LED_GREENLED_GREENLED0603
    LED9LED_LED0603_LED_BLUELED_BLUELED0603
    PWRONSW-TACT_0_SW4-SMD_KEYKEYSW4-SMD
    Q2MOSFETN_SOT_323_2SK30182SK3018SOT_323
    Q5MOSFETN_SOT_323_2SK30182SK3018SOT_323
    Q6MOSFETN_SOT_323_2SK30182SK3018SOT_323
    Q7MOSFETN_SOT_323_2SK30182SK3018SOT_323
    Q8MOSFETP_SOT-23_AO3415AAO3415ASOT-23
    Q9L14P2/TO_1_SOT-23_L9014L9014SOT-23
    Q16NPN_SOT_23_S8050S8050SOT_23
    RESETSW-TACT_0_SW4-SMD_KEYKEYSW4-SMD
    SW3SWDIP-7_0_KHS01_SW DIP-1SWDIP-1KHS01
    U1RT8065_0_SOIC8_TPS54331TPS54331SOIC8
    U3RX8010_SOIC8_RX8010RX8010SOIC8
    U4SWITCH_SY6280_SOT_23_5_SY6280AAC/TCS9163SY6280AAC/TCS9163SOT_23_5
    U5TD6810_TD6810_SOT23-5_TMI111TMI111TD6810_SOT23-5
    U6ETHERNET_RTL8211F_QFN40_5R00X5R00X0R90_T_RTL8211F-CGRTL8211F-CGQFN40_5R00X5R00X0R90_T
    U9SGM2019-1.2YN5G/TR_SOT23-5_SGM2019-2.8YN5G/TRSGM2019-2.8YN5G/TRSOT23-5
    U11RTL8723_0_M-BL-R8723BT1_RTL8723RTL8723M-BL-R8723BT1
    U12UFL-R-SMT-1_0_RF_UFL-R-SMT-1UFL-R-SMT-1RF
    U20MAX3232EEAE_SOIC16_MAX3232CSEMAX3232CSESOIC16
    U25DCDC_NB680_QFN12_2R00X3R00X1R00_NB680GDNB680GDQFN12_2R00X3R00X1R00
    U56CON4P_SIP4-100_CON4PCON4PSIP4-100
    U57LT9211_19_QFN64_EPAD_LT9211D_U1LT9211D_U1QFN64_EPAD
    U58SGM2019-1.2YN5G/TR_SOT23-5_SGM2019-1.5YN5G/TR,SOT-23-5SGM2019-1.5YN5G/TR,SOT-23-5SOT23-5
    VOL+SW-TACT_0_SW4-SMD_KEYKEYSW4-SMD
    VOL-SW-TACT_0_SW4-SMD_KEYKEYSW4-SMD
    Y1CRYSTAL_4P_CRY4_3R20X2R50X0R80_25MHZ25MHzCRY4_3R20X2R50X0R80
    Y2CRYSTAL_4PIN_CRY4_3R20X2R50X0R80_25MHZ25MHzCRY4_3R20X2R50X0R80
    重要提示:PCB作品文件展下载说明
  • 签到天数: 198 天
    发表于 2023-4-22 09:38:35 | 显示全部楼层
  • 签到天数: 9 天
    发表于 2023-4-22 09:39:02 | 显示全部楼层
    发表于 2023-4-22 10:38:27 | 显示全部楼层
    头像被屏蔽
    禁止发言
    发表于 2023-4-22 13:08:17 | 显示全部楼层
    提示: 作者被禁止或删除 内容自动屏蔽
  • 签到天数: 122 天
    发表于 2023-4-22 13:39:14 | 显示全部楼层
    1元学习Allegro(1期)
    发表于 2023-4-22 13:51:36 | 显示全部楼层
    1元学习Pads(230718)
    终身成就奖原创先锋奖
    发表于 2023-4-22 13:53:05 | 显示全部楼层
    昨天 13:48
  • 签到天数: 203 天
    发表于 2023-4-22 14:40:10 | 显示全部楼层
    昨天 12:11
  • 签到天数: 215 天
    发表于 2023-4-22 15:04:49 | 显示全部楼层
