Name | Part Type | PCB Decal | Value | ANT1 | AC_ANT_M | AC_ANT_M | ANTENNA | CON1 | TFT-AT070TN92 | FFC50P-0.5 | FPC-50PX0.5MM | CON2 | FPC-24PIN-0.5MM | FPC-24PIN-0.5MM | FPC24P/0.5MM | D2 | IN5401 | D5401-5MM | IN5401 | D3 | SOD123 | SOD123 | SS14 | D6 | D0603 | D0603 | IN4148 | D7 | D0603 | D0603 | IN4148 | D8 | SOD123 | SOD123 | 1N5819 | D9 | D0603 | D0603 | IN4148 | D10 | D0603 | D0603 | IN4148 | D11 | D0603 | D0603 | IN4148 | D15 | D0603 | D0603 | IN4148 | D26 | SOD123 | SOD123 | 1N5819 | D31 | DIODE | D-1206-4148 | IN4004 | FB2 | L0805 | L0805 | FB-120R/2A | FB7 | R0603 | R0603 | FB30R | FB8 | R0603 | R0603 | FB30R | J7 | AV6-RCA13 | AV6-RCA13 | AV6-8.4 | J9 | CON3P | AUX320A | AUX-4P | J10 | ISO-18P_AB | ISO-18P_AB | ISO-18P_AB | J11 | ANT-4PIN | ANT-4PIN | ANT | J13 | FPC-6PIN-0.5MM | FPC-6PIN-0.5MM | FPC6P/0.5MM | J15 | FPC-4PIN-1.0MM | FPC-4PIN-1.0MM | 4P-1.0MM-BOTTOM | L6 | CD32 | CD32 | 4.7UH | L7 | CD32 | CD32 | 4.7UH | L8 | CD32 | CD32 | 4.7UH | L9 | R0402 | R0402 | 8.2UH | L14 | R0402 | R0402 | FB120R | L15 | R0603 | R0603 | 10UH | L16 | R0402 | R0402 | 8.2UH | L17 | R0402 | R0402 | FB120R | L18 | CD105 | CD105 | 47UH3A | L20 | CD32 | CD32 | 4.7UH | L22 | R0603 | R0603 | 330NH | L23 | R0603 | R0603 | 220NH | L24 | R0603 | R0603 | 10UH | L25 | CD32 | CD32 | 4.7UH | L26 | TC-19V | TC-19V | 2500UH | L27 | R0603 | R0603 | 10UH | L28 | R0402 | R0402 | FB120R | L29 | R0603 | R0603 | NC | L32 | R0603 | R0603 | 330NH | L33 | R0603 | R0603 | 120NH | P1 | O_A | O_A | T | P2 | O_A | O_A | T | P3 | O_A | O_A | T | Q1 | NPN | NPN | 2SC3904 | Q2 | NPN | NPN | 2SC3904 | Q3 | NPN | NPN | BAT54S | Q4 | NPN | NPN | BAT54S | Q7 | NPN | NPN | 2SC3904 | Q8 | NPN | NPN | 2SC3904 | Q9 | NPN | NPN | 2SC3904 | Q10 | NPN | NPN | NC | Q13 | NPN | NPN | 2N3904 | Q14 | NPN | NPN | S8550 | Q16 | NPN | NPN | 2N3904 | Q19 | NPN | NPN | 2SC3904 | Q20 | NPN | NPN | S8050 | Q35 | NPN | NPN | AO3407 | Q36 | PNP | SOT23 | AO3407 | Q38 | PNP | SOT23 | AO3407 | RN1 | SOPRES-8 | RN0402_X4_2 | 470R | RN2 | SOPRES-8 | RN0402_X4_2 | 470R | RN3 | SOPRES-8 | RN0402_X4_2 | 10K | RN4 | SOPRES-8 | RN0402_X4_2 | 470R | RN5 | SOPRES-8 | RN0402_X4_2 | 470R | RN7 | SOPRES-8 | RN0402_X4_2 | 10K | RN8 | SOPRES-8 | RN0402_X4_2 | 100R | TP1 | TP | PAD1.2/3A | TP-1 | TP2 | TP | PAD1.2/3A | TP-1 | TP11 | TP | PAD1.2/3A | TP-1 | TP12 | TP | PAD1.2/3A | TP-1 | TP13 | TP | PAD1.2/3A | TP-1 | TP14 | TP | PAD1.2/3A | TP-1 | TQ1 | TSFP-3A | TSFP-3A | BFR380F | U2 | SOT23-6 | SOT23-6 | MCU | U5 | SOP8 | SOP8 | NDP2345KC | U13 | SOP14 | SOP14 | ZT0811 | U16 | TDA7388A | HZIP25P-1.00F2MM | TDA7388 | U17 | LQFP128-DB128 | LQFP128-DB128 | C800-ELQFP128 | U21 | MSOP-9PIN | MSOP-9PIN | MFI337S3959 | U23 | SOT23 | SOT23 | HP5017M33V | U24 | SOT23-6 | SOT23-6 | HP2302 | U25 | SC70-6 | SC70-6 | ET3157 | U26 | SOT23-5 | SOT-23-5A | SGM721 | U27 | SOP8-NOR | SOP8-NOR | MX25L6433F | U31 | SOT-25 | SOT-25 | HP1021B | U32 | SOT-25 | SOT-25 | HP1021B | U33 | SOT-25 | SOT-25 | HP1021B | U34 | LQFP48-7_7 | LQFP48-7_7 | AC6951B | U35 | SOT-25 | SOT-25 | HP2301 | Y2 | CRYSTAL3.2X2.5X0.8AA | CRYSTAL3.2X2.5X0.8AA | 24M-10PPM | Y3 | MC-146A | MC-146A | 32.768KHZ | Y7 | CRYSTAL3.2X2.5X0.8AA | CRYSTAL3.2X2.5X0.8AA | 24M |
