查看: 2926|回复: 50
[Allegro17.4以下] Lindenis 全志V536 底板扩展板PCB和原理图
    长期免费代管18-28岁小
    发表于 2023-5-11 15:48:26 | 显示全部楼层 |阅读模式
    重要提示:PCB作品文件展下载说明
    Lindenis_V536_Full_Function_Board_PCB_Source_Files.zip (1.38 MB, 下载次数: 17)
    ANT2ANT_0_ANT3B300_310H125_IPEXIPEXANT3B300_310H125
    ANT3SMA/RF_1_ANT3B300_310H125_GPS-AGPS-ANTANT3B300_310H125
    CU2C-C0603_C0603_2.2UF2.2uFC0603
    CW26CAPACITOR_0_C0402_NCNCC0402
    CW27CAPACITOR_0_C0402_NCNCC0402
    CW30CAPACITOR_0_C0402_22PF22pFC0402
    D7DIODE_SCHOTTKY_0_SOD80_120H80_RRB521S-30SOD80_120H80
    D10ESD9B5VL_ESD0402_NC-ESD5451XNC-ESD5451XESD0402
    D111_1.5KE100A_ESD0402_ESD9B5VL-2/ESD9B5VL-2/TRESD0402
    D121_1.5KE100A_ESD0402_ESD9B5VL-2/ESD9B5VL-2/TRESD0402
    D131_1.5KE100A_ESD0402_ESD9B5VL-2/ESD9B5VL-2/TRESD0402
    D141_1.5KE100A_ESD0402_ESD9B5VL-2/ESD9B5VL-2/TRESD0402
    D151_1.5KE100A_ESD0402_ESD9B5VL-2/ESD9B5VL-2/TRESD0402
    D161_1.5KE100A_ESD0402_ESD9B5VL-2/ESD9B5VL-2/TRESD0402
    D251_1.5KE100A_ESD0402_ESD9B5VL-2/ESD9B5VL-2/TRESD0402
    D261_1.5KE100A_ESD0402_ESD9B5VL-2/ESD9B5VL-2/TRESD0402
    D271_1.5KE100A_ESD0402_ESD9B5VL-2/ESD9B5VL-2/TRESD0402
    D281_1.5KE100A_ESD0402_ESD9B5VL-2/ESD9B5VL-2/TRESD0402
    D291_1.5KE100A_ESD0402_ESD9B5VL-2/ESD9B5VL-2/TRESD0402
    D301_1.5KE100A_ESD0402_ESD9B5VL-2/ESD9B5VL-2/TRESD0402
    D35ESD9B5VL_ESD0402_NC-ESD5451XNC-ESD5451XESD0402
    D39ESD5451X_ESD0402_ESD5451X-2-TRESD5451X-2-TRESD0402
    D40ESD5451X_ESD0402_ESD5451X-2-TRESD5451X-2-TRESD0402
    D41D_0_SOD155_270H118_1N5819HW-7-F1N5819HW-7-FSOD155_270H118
    D608DIODE_SCHOTTKY_3_SOD80_120H80_RRB521S-30SOD80_120H80
    D6091_1.5KE100A_ESD0402_ESD5451XESD5451XESD0402
    D6101_1.5KE100A_ESD0402_ESD5451XESD5451XESD0402
    DH21_1.5KE100A_ESD0402_ESD5451XESD5451XESD0402
    DH31_1.5KE100A_ESD0402_ESD5451XESD5451XESD0402
    DH41_1.5KE100A_ESD0402_ESD5451XESD5451XESD0402
    DH51_1.5KE100A_ESD0402_ESD5451XESD5451XESD0402
    DH12DIO-B5819W_SOD155_270H118_B5819B5819WSOD155_270H118
    DK1TVS-FBP-02C_ESD0402_ESD9B5V-2/TESD9B5V-2/TRESD0402
    DK2TVS-FBP-02C_ESD0402_ESD9B5V-2/TESD9B5V-2/TRESD0402
    DL6LED_0_LED0603_REDREDLED0603
    DL7LED_0_LED0603_GREENGREENLED0603
    DL491_1.5KE100A_ESD0402_NC/ESD5451XNC/ESD5451XESD0402
    DL501_1.5KE100A_ESD0402_NC/ESD5451XNC/ESD5451XESD0402
    DL511_1.5KE100A_ESD0402_NC/ESD5451XNC/ESD5451XESD0402
    DL521_1.5KE100A_ESD0402_NC/ESD5451XNC/ESD5451XESD0402
    DM1LED_3_LED0805_POWERPOWERLED0805
    FB12INDUCTOR_4_L0603_0R0RL0603
    FB22INDUCTOR_L0603_600R@100M-1A600R@100M-1AL0603
    J1CON3_HDR1_3P200B670_600H610_BATBATTARYHDR1_3P200B670_600H610
    J3SDMMCSLOT_0_SDC13B1450_1472H24MICROSD/TF_SLOTSDC13B1450_1472H245
    J7CON40-B070EW01_0_FPC42P50B450_2CON30-P05FPC42P50B450_2410H150_B
    J9USB_A_4_USB-2400-DIP_USB/AUSB/AUSB-2400-DIP
    J11HEADER10X2_HDR2_10P254B500_2540Header10x2HDR2_10P254B500_2540H254
    J12XH2.54MM-5P-M_HDR1_5P250B570_15XH2.54MM-5P-MHDR1_5P250B570_1500H700
    J21PJ-327F_HP5B650_1400H500_PJ-327PJ-327FHP5B650_1400H500
    J33CON1X4-2_0.54-M_HDR1_3P254B250_CON1X3-2.54-MHDR1_3P254B250_762H254
    J35CON1X4-2.54-M_HDR1_4P254B250_10CON1X4-2.54-MHDR1_4P254B250_1016H254
    J36CON1X4-2.54-M_HDR1_4P254B250_10CON1X4-2.54-MHDR1_4P254B250_1016H254
    J56CON1X4-2_0.54-M_HDR1_3P254B250_CON1X3-2.54-MHDR1_3P254B250_762H254
    J79HP_JACK_HP5B650_1400H500_HP-JACHP-JACKHP5B650_1400H500
    J80CON1X4-2_1.54-M_KEY2B452_749H44SDA01H1SBDKEY2B452_749H445
    J81PHONEJACK_DCIN_0_DC-208_DC-IN-JDC-IN-JACKDC-208
    J82HEADER10X2_HDR2_10P254B500_2540Header10x2HDR2_10P254B500_2540H254
    JH1HDMI19_PLUG_HDMI23P50B1215_1500HDMI_19plugtype AHDMI23P50B1215_1500H838
    JL6FPC-6P-0_0.5MM-B_FPC8P50B320_50FPC-6P-0.5MM-BFPC8P50B320_500H150_B
    JL26SDMMCSLOT_5_SIM-6_1_SIM508CSIM508CSIM-6_1
    KK1SWITCH_PUSH_KEY4B620_620H430_VOVOL+KEY4B620_620H430
    KK2SWITCH_PUSH_KEY4B620_620H430__1VOL-KEY4B620_620H430
    KK3SWITCH_PUSH_KEY4B620_620H430_MEMENUKEY4B620_620H430
    KK4SWITCH_PUSH_KEY4B620_620H430_ENENTERKEY4B620_620H430
    KK5SWITCH_PUSH_KEY4B620_620H430_HOHOMEKEY4B620_620H430
    KK6SWITCH_PUSH_KEY4B620_620H430_FEFELKEY4B620_620H430
    KP1SW_PUSH_5_KEY4B620_620H430_PWROPWRONKEY4B620_620H430
    L12INDUCTOR_LP200_250H100_10UH_1A10uH_1ALP200_250H100
    LM1L-LP2_00X1_60H1_00_LP200_250H102.2uH/1ADCR<0.1RLP200_250H100
    LP7INDUCTOR_1_LP400_400H120_2.2UH@2.2uH@3ADCR<0.1RLP400_400H120
    MIC1MICPHONE_0_MIC2B600H500_MICPHONMicphoneMIC2B600H500
    OC5CAPACITOR_POL_0_CA660H770_220_1220uF/16VCA660H770
    OC6CAPACITOR_POL_0_CA660H770_220_1220uF/16VCA660H770
    Q2NMOS-2N7002_SOT3P95B130_290H1032N7002SOT3P95B130_290H103
    Q23NMOS-BSN20_SOT3P95B130_290H103_BSN20SOT3P95B130_290H103
    QL1NPN_SOT3P95B130_290H103_WNT2F04WNT2F04/MMBT3904SOT3P95B130_290H103
    QL3NPN_SOT3P95B130_290H103_MMBT390MMBT3904SOT3P95B130_290H103
    QL5NPN-MMBT3904_SOT3P95B130_290H10MMBT3904SOT3P95B130_290H103
    QL13NPN_SOT-23_MMBT3904MMBT3904SOT-23
    RU14R-R0402-5%_R0402_6.8K-1%6.8K-1%R0402
    TP5TESTPOINT SURFACE_TP_PAD_GNDGNDTP_PAD
    TP6TESTPOINT SURFACE_TP_PAD_GNDGNDTP_PAD
    TP7TESTPOINT SURFACE_TP_PAD_GNDGNDTP_PAD
    TP8TESTPOINT SURFACE_TP_PAD_GNDGNDTP_PAD
    TP9TESTPOINT SURFACE_MH320CIR500DGNDMH320CIR500D
    TP10TESTPOINT SURFACE_MH320CIR500DGNDMH320CIR500D
    TP11TESTPOINT SURFACE_MH320CIR500DGNDMH320CIR500D
    TP12TESTPOINT SURFACE_MH320CIR500DGNDMH320CIR500D
    U2UP0107_0_SOT5P95B160_300H130_AAP2127k-ADJSOT5P95B160_300H130
    U3BAT_0_CSE_BATBATCSE
    U8FEB1216_DFN24P110B1220_1600H270NC-HDM1216DDFN24P110B1220_1600H270
    U11NAND_FLASH_TSOP48_9_HDR2_7P254_2_54_16PHDR2_7P254
    U12HDR11X2_1_HDR2_7P2_00_DIP14_2_0DIP14_2_0HDR2_7P2_00
    U13HDR11X2_2_HDR2_8P2_00_DIP16_2_0DIP16_2_0HDR2_8P2_00
    U19HFJ11-1G01E_2_RJ45-HFJ11-1G01E_RMS-086C-10F0-GYRJ45-HFJ11-1G01E
    U22CON10X2 2.0MM_IDC200-20_CON 10CON10x2 2.0mmIDC200-20
    U23SSM2402/SO_2_SOP11P50B300_300H1SMG8905SOP11P50B300_300H110
    U24UP0107_0_SOT23-5_AP2127K-1.8AP2127k-1.8SOT23-5
    U27AP1511B_2_SUB_4G87B3000_3000H29SIM7600CSUB_4G87B3000_3000H290
    U32GL850G_SSOP28_SOP28P65B530_1020GL850G_SSOP28SOP28P65B530_1020H200
    U39RT9293B_SOT6P95B160_290H145_RT9RT9293B20GJ6SOT6P95B160_290H145
    U51SGM7227_SOP10P50B300_300H110_SGSGM7227SOP10P50B300_300H110
    U901A10_MODE_20_V536_156PIN_V536_MOV536_MODEV536_156PIN
    U902BMA222_QFN12P50B200_200H100_BMABMA250QFN12P50B200_200H100
    UH1RRCLAMP0524P_RCLAMP0524P_AZ1345AZ1345-04FRCLAMP0524P
    UH2RRCLAMP0524P_RCLAMP0524P_AZ1345AZ1345-04FRCLAMP0524P
    UL9SY8088_0_SOT6P95B180_310H100_SYSY8120B1ABCSOT6P95B180_310H100
    UM1RTL8169S_1_QFN41P40B500_500H75_RTL8211F-CGQFN41P40B500_500H75
    UM2NAND_FLASH_TSOP48_1_GB042-34P-HGB042-34S-H10-PlugGB042-34P-H10-PLUG
    USB1USB_MINI_SOCKET_0_USB9P65B495_7MIRCO_USB_5PUSB9P65B495_740H235
    UU3SY6280_SOT5P95B160_300H130_SY62SY6280SOT5P95B160_300H130
    X3CRYSTAL-4_0_X4B250_320H80_SMD_NNC/25M-12pF-20PPMX4B250_320H80_SMD
    Y3XTAL-4P_X4B250_320H80_SMD_12MHZ12MHz/3225X4B250_320H80_SMD
    重要提示:PCB作品文件展下载说明
    暑假期间,免费代管18-28岁小孩,限女性。
  • 签到天数: 28 天
    PADS20210412初级班
    发表于 2023-5-11 22:40:18 | 显示全部楼层
    发表于 2023-5-12 00:06:03 | 显示全部楼层
    发表于 2023-5-12 00:09:27 | 显示全部楼层
  • 签到天数: 53 天
    发表于 2023-5-12 07:15:07 | 显示全部楼层
    前天 10:32
  • 签到天数: 128 天
    你必须非常努力才能显
    发表于 2023-5-12 07:15:12 | 显示全部楼层
    2 小时前
  • 签到天数: 174 天
    社区居民忠实会员社区劳模终身成就奖社区明星宣传大使奖优秀斑竹奖特殊贡献奖原创先锋奖
    发表于 2023-5-12 08:27:49 | 显示全部楼层
    7 天前
  • 签到天数: 52 天
    终身成就奖社区居民特殊贡献奖原创先锋奖
    发表于 2023-5-12 08:32:24 | 显示全部楼层
    昨天 13:20
  • 签到天数: 198 天
    发表于 2023-5-12 08:33:56 | 显示全部楼层
    昨天 21:24
  • 签到天数: 60 天
    发表于 2023-5-12 08:38:52 | 显示全部楼层
