The AP6608 is a constant frequency, 6-pin SOT23current mode step-up converter intended for small,low power applications. The AP6608 switches at1.2MHz and allows the use of tiny, low costcapacitors and inductors 2mm or less in height.Internal soft-start results in small inrush current andextends battery life.The AP6608 features automatic shifting to pulsefrequency modulation mode at light loads. TheAP6608 includes under-voltage lockout, currentlimiting, and thermal overload protection to preventdamage in the event of an output overload. TheAP6608 is available in a small 6-pin SOT-23
package.
FEATURES? Integrated 80mΩ Power MOSFET? 2V to 24V Input Voltage? 1.2MHz Fixed Switching Frequency? Internal 4A Switch Current Limit? Adjustable Output Voltage? Internal Compensation? Up to 28V Output Voltage? Automatic Pulse Frequency ModulationMode at Light Loads? up to 97% Efficiency? Available in a 6-Pin SOT23-6 PackageAPPLICATIONS? Battery-Powered Equipment? Set-Top Boxed? LCD Bais Supply? DSL and Cable Modems and Routers? Networking cards powered from PCIor PCI express slots
