1-1-1框架
  • 项目三作业布线布局
    项目三作业布线布局
  • 意法半导体的三端双向可控硅
    意法半导体的三端双向可控硅
  • 亿光反射式光电开关芯片ITR1204SR10A-TR
  • 如何提升微波网络分析仪的测量精度?
    如何提升微波网络分析仪的测量精度?
  • 14周年庆-发金币,500名额,每人50金币。学堂课程全场半价
[Allegro17.4以下] SD102 BGA324+DS90UB926QSQE/NOPB+DRV8889-Q1+RTL9010AA+MAX96706GTJ+T PCB文件
查看3433 | 回复81 | 2023-5-19 23:37:16 | 显示全部楼层 |阅读模式
重要提示:PCB作品文件展下载说明
B17020020-001-000002BLM18KG121TBLM18KG121T
CN10010027-001-000087FH52-50S-0.5SHFH52-50S-05SH
CN10020027-001-000086FH52-30S-0.5SHFH52-30S-05SH
CON1601FAKRA_FA1-NCRP-PCB-8_FKPPRNZD02FKPPRNZD02TFA1-NCRP-PCB-8
D401SS10PH10-M3/87A_TO-277A-3_SS10PSS10PH10-M3/87ATO-277A-3
D402DIODE_0_TPSMC27CA_TPSMC27CATPSMC27CATPSMC27CA
D4030026-001-00000119-217/GHC-YR1S2/3TSMD-LED-0603
D4040026-001-00000119-217/GHC-YR1S2/3TSMD-LED-0603
D4050026-001-00000119-217/GHC-YR1S2/3TSMD-LED-0603
D5010016-001-000011MBR0540T1GSOD_123
D5050022-001-000012PESD3V3S1BLDFN1006-2
D8010026-001-00000119-217/GHC-YR1S2/3TSMD-LED-0603
D9010022-001-000017RCLAMP0512TQTCTRCLAMP0512
D9020022-001-000017RCLAMP0512TQTCTRCLAMP0512
D10010016-001-000003RB160L-40TE25RB160L
D10020016-001-000013RBR2VWM60ATFRBR2VWM60ATF
D10030016-001-0000141N4148WQ-7-F1N4148WQ-7-F
D15010022-001-000008PESD2CAN.215SOT-23-3
D15020022-001-000008PESD2CAN.215SOT-23-3
D16010026-001-00000119-217/GHC-YR1S2/3TSMD-LED-0603
D17010026-001-00000119-217/GHC-YR1S2/3TSMD-LED-0603
D19010022-001-000017RCLAMP0512TQTCTRCLAMP0512
D19020026-001-00000119-217/GHC-YR1S2/3TSMD-LED-0603
D19030026-001-00000119-217/GHC-YR1S2/3TSMD-LED-0603
D19040026-001-00000119-217/GHC-YR1S2/3TSMD-LED-0603
J401DCPOWER JACK_PJ-202B_IO_PJ-202PJ-202AHPJ-202B
J4020027-001-000085UK-G0701-ZS-YUK-G0701-ZS-Y
J501JTAG20PIN_1_JTAG20PIN_300S-20P300S-20PJTAG20PIN
J5020027-001-000057TS-3025-A-A-BTS_3025
J5030027-001-000057TS-3025-A-A-BTS_3025
J5040027-001-000057TS-3025-A-A-BTS_3025
J7010027-001-000019TFCardTFCARD_CD
J8010027-001-0000992304372-1C-2304372-1
J9010027-001-000025ZX62D-B-5PA8MICROUSBB
J14010102-001-000001KPB3642SP10-1SIP_2
J14020034-001-000009SIP_2SIP_2
J15010034-001-000009SIP_2SIP_2
J15020027-001-000063EK500V-05PWIRINGCON5
J15030034-001-000009SIP_2SIP_2
J1702HSPPRNZS11T_HSPPRNZS11T_HSPPRNZHSPPRNZS11T/DESRHSPPRNZS11T
J18010027-001-000058HAD-04HWAG-2HAD-04HWAG
J18020027-001-000065EK500V-04PWIRINGCON4
J18050034-001-000009SIP_2SIP_2
J18060034-001-000009SIP_2SIP_2
J18070027-001-000063EK500V-05PWIRINGCON5
J19010027-001-000025ZX62D-B-5PA8MICROUSBB
L4020003-001-0000333.3uHSMD5D6X5D4X3
L4030003-001-00003722uHSMD7D4X6D9X4D5
L4040003-001-0000383.3uHIND252012
L4050003-001-0000361uHSMD5D6X5D4X3
L406INDUCTOR_P2_SMD7D1X6D5X3_5.6UH@5.6uH@5.4ASMD7D1X6D5X3
L4070003-001-0000361uHSMD5D6X5D4X3
L8010003-001-0000383.3uHIND252012
L8020039-001-000006DLW32MH101XT2DLW32MH101XT2
L10010003-001-00003722uHSMD7D4X6D9X4D5
L15010019-001-000002ACT45B-510-2P-TL003SMD1812_P4
L15020019-001-000002ACT45B-510-2P-TL003SMD1812_P4
L1601INDUCTOR_VLS3015CX_VLS3015CX-10VLS3015CX-101M-HVLS3015CX
L1602INDUCTANCE_0_VLS3015CX_VLS3015CVLS3015CX-6R8M-HVLS3015CX
L1603INDUCTOR_NLV25X_NLV25T-R33J-EFDNLV25T-R33J-EFDNLV25X
L1701COMMON_INDUCTANCE_0_L4-2_2X1_4-90R@100MHzL4-2_2X1_4-H1_4
L1702INDUCTOR_P2_SMD7D1X6D5X3_5.6UH@5.6uH@5.4ASMD7D1X6D5X3
M3MHOLE_HOLE_C7R00D3R20_MHOLE_3.2MHOLE_3.2MMHOLE_C7R00D3R20
M4MHOLE_HOLE_C7R00D3R20_MHOLE_3.2MHOLE_3.2MMHOLE_C7R00D3R20
M5MHOLE_HOLE_C7R00D3R20_MHOLE_3.2MHOLE_3.2MMHOLE_C7R00D3R20
M6MHOLE_HOLE_C7R00D3R20_MHOLE_3.2MHOLE_3.2MMHOLE_C7R00D3R20
Q401DMC4029SSDQ-13_SOP8-1_27-4_95X3DMC4029SSDQ-13SOP8-1_27-4_95X3_95-H1_75
Q4030015-001-000011SQ2315ES-T1_GE3SQ2315ES
Q4040015-001-000012SQ2310ES-T1_GE3SQ2310ES
Q4050015-001-000050AP30P30QAP30P30Q
Q5010015-001-000012SQ2310ES-T1_GE3SQ2310ES
Q7010015-001-000011SQ2315ES-T1_GE3SQ2315ES
Q7020015-001-000013LBSS139WT1GLBSS139WT
Q7030015-001-000012SQ2310ES-T1_GE3SQ2310ES
Q7040015-001-000011SQ2315ES-T1_GE3SQ2315ES
Q7050015-001-000012SQ2310ES-T1_GE3SQ2310ES
Q8010015-001-000012SQ2310ES-T1_GE3SQ2310ES
Q8020015-001-000012SQ2310ES-T1_GE3SQ2310ES
Q8030015-001-000012SQ2310ES-T1_GE3SQ2310ES
Q8040015-001-000012SQ2310ES-T1_GE3SQ2310ES
Q10010015-001-000011SQ2315ES-T1_GE3SQ2315ES
Q11010015-001-000012SQ2310ES-T1_GE3SQ2310ES
Q16010015-001-000012SQ2310ES-T1_GE3SQ2310ES
Q16020015-001-000012SQ2310ES-T1_GE3SQ2310ES
Q16030015-001-000012SQ2310ES-T1_GE3SQ2310ES
Q16040015-001-000012SQ2310ES-T1_GE3SQ2310ES
Q16050015-001-000011SQ2315ES-T1_GE3SQ2315ES
Q16060015-001-000012SQ2310ES-T1_GE3SQ2310ES
Q18010062-001-000013MMBT3904LC-SOT-23_SOT-23-3_
Q18020015-001-000012SQ2310ES-T1_GE3SQ2310ES
Q18030015-001-000012SQ2310ES-T1_GE3SQ2310ES
Q18040015-001-000012SQ2310ES-T1_GE3SQ2310ES
Q18050015-001-000012SQ2310ES-T1_GE3SQ2310ES
Q19010015-001-000012SQ2310ES-T1_GE3SQ2310ES
Q19020015-001-000012SQ2310ES-T1_GE3SQ2310ES
Q19030015-001-000012SQ2310ES-T1_GE3SQ2310ES
Q19040015-001-000012SQ2310ES-T1_GE3SQ2310ES
TVS8010022-001-000019AVRH10C101KT141NE8AVRH10C101KT141NE8
TVS8020022-001-000019AVRH10C101KT141NE8AVRH10C101KT141NE8
TVS19010022-001-000013PESD5V0S1BLDDFN1006D-2
U4030011-001-000020NM/MPQ2179AGQHE-AEC1-ZMPQ217X
U4040010-001-000031BD00IC0MEFJ-ME2HTSOP-J8
U4051011-001-000019NM/MPQ2167AGQE_AEC1_C07V_ZQFN-14
U407MPQ4313GRE-AEC1_MPQ4313GRE-AEC1MPQ4313GRE-AEC1MPQ4313GRE-AEC1
U4080011-001-000019MPQ2167AGQE_AEC1_C07V_ZQFN-14
U5010061-001-000005SD_E3E3Q_BGA324
U5020152-001-000004NM/TPS3823-25QDBVRQ1TPS382X
U6020077-001-000003IS45S32160F-7BLA2TFBGA90
U7021010-001-000031NM/BD00IC0MEFJ-ME2HTSOP-J8
U8020064-001-000004RTL9010AAQFN-48-EP-RTL9010AA
U10020047-001-000006MPQ3364MPQ3364
U11020057-001-000004IS25LP064D-JBLA3SOIC8_SPIFLASH
U14020036-001-000003TAS2505-Q1TAS2505TRGERQ1
U14030066-001-000003AK4619AK4619
U14040083-001-000002SA2718T421-WT01SA2718T421-WT01
U14050083-001-000002SA2718T421-WT01SA2718T421-WT01
U15010059-001-000003TJA1043TTJA1043T
U15020059-001-000002TLE9251VSJPG-DSO-8
U16020024-001-000006TPS1H000AQDGNRQ1TPS1H000_VSSOP8
U16030101-001-000001MAX96706GTJ+TTQFN32-EP
U17020092-001-000003DS90UB926QSQE/NOPBDS90UB926QSQE
U18020080-001-000002DRV8889-Q1HTSSOP24-PWP
U1901CP2105-F01-GM_QFN24_CP2105-F01-CP2105-F01-GMQFN24
U1902MPQ4313GRE-AEC1_MPQ4313GRE-AEC1MPQ4313GRE-AEC1MPQ4313GRE-AEC1
X5010025-001-000018CX2016SA24000D0HSSCCXTAL2016
X50232768_NX3215SA_NX3215SA-32.768KNX3215SA-32.768KHZ(STD-MUS-2)NX3215SA
X8011025-001-000018CX2016SA25000D0HSSCCXTAL2016
重要提示:PCB作品文件展下载说明
老吴 | 2023-5-19 23:38:05 | 显示全部楼层
PCB文件。回复可见下载
游客,如果您要查看本帖隐藏内容请回复
nj20044 | 2023-5-20 00:52:41 | 显示全部楼层
kanxue_nmg | 2023-5-20 05:15:05 | 显示全部楼层
jielove2003 | 2023-5-20 07:37:55 | 显示全部楼层
·风来了 | 2023-5-20 08:02:43 | 显示全部楼层
314528624 | 2023-5-20 08:04:36 | 显示全部楼层
yiminchen | 2023-5-20 08:16:22 | 显示全部楼层
chinachen | 2023-5-20 08:29:52 | 显示全部楼层
shuszhao | 2023-5-20 08:30:36 | 显示全部楼层
