查看: 3163|回复: 73
[Allegro17.4以下] 飞思卡尔iMX536D  MCiMX536DJV8A 挂4个DDR3工业控制板PCB文件 8层
    17万
    管理员
    原创先锋奖终身成就奖优秀斑竹奖宣传大使奖社区居民社区明星社区劳模最爱沙发新人进步奖忠实会员金点子奖特殊贡献奖
    发表于 2023-6-15 13:48:03 | 显示全部楼层 |阅读模式
    D1LED_LED_0603_IC_0.8MM_370-75077LED_GREENLED_0603
    D4DIODE_TVS_SOD-923_IC_0.40MM_480ESD9L5.0ST5GSOD-923
    D8DIODE_SCHTKY_SOD323_IC_1.1MM_48BAT760SOD323
    D9LED_LED_0603_IC_0.8MM_370-75077LED_GREENLED_0603
    D10LED_LED_0603_IC_0.8MM_370-75078BLUELED_0603
    D11LED_LED_0603_IC_0.8MM_370-75078BLUELED_0603
    D12LED_LED_0603_IC_0.8MM_370-75078BLUELED_0603
    D13LED_LED_0603_IC_0.8MM_370-75078BLUELED_0603
    D14LED_LED_0603_IC_0.9MM_370-75079REDLED_0603
    D15DIODE_SCHTKY_SOD323_IC_1.1MM_48BAT760SOD323
    D16LED_LED_0603_IC_0.8MM_370-75077LED_GREENLED_0603
    D17SR05_SOT_143_IC_1.22MM_480-7809SR05SOT_143
    D18SR05_SOT_143_IC_1.22MM_480-7809SR05SOT_143
    F1FUSE_RST_FUSE_1P6X0P8_IC_0.55MMSF-0603FFUSE_1P6X0P8
    F2FUSE_RESETTABLE_IND_1210_IC_0.41.1AIND_1210
    J1DCPOWER JACK_PJ-202B_IO_11MM_2CON_1_PWRPJ-202B
    J2CONN_RJ45_DUAL_USB_22F_B_CON_RJRJ45-103YDD2CON_RJ45_USB_22F_50_TH_RA_C
    J3MICRO_USB_CON5_MICROUSB_SKT_SM_47346-0001CON5_MICROUSB_SKT_SM
    J4CONN_SDCARD_1X12_F_CON_SDCARD_1SD/MMCSKTCON_SDCARD_12F_43_SM_RA
    J5CONN_SDC013_19P_CON19_SDCARD_28CONNCRD 19CON19_SDCARD_28X16_SM
    J6SJ-43515TS_CON5_AUD_JACK_RA_TH_AUD_5CON5_AUD_JACK_RA_TH_SJ-43515TS
    J7SATA_PLUG7_CON7_SATA_TH_17X5MM_CON7 SATACON7_SATA_TH_17X5MM
    J8CONN_HDSUB15P_F_MTABS_CON_DB_15DB15SMTCON_DB_15F_29_SM_RA
    J9CON30_CON_DF_30F_1MM_SM_RA_IO_1CON30CON_DF_30F_1MM_SM_RA
    J13QSH060_CON_120S_QSH_SM_05PITCH_QSH-060-01-L-D-ACON_120S_QSH_SM_05PITCH
    J14CONN_HDR_3X1_HDR103_49MIL_IO_4.CON_1X3HDR103_49MIL
    J15TSW-110-05-G-D_HDR210_TST_RA_IOTST-110-05-T-D-RAHDR210_TST_RA
    J16CONN_DB9F_MTGTABS_CON_DB9P_190-DB9CON_DB9P_190-009-263R001
    J18SJ-43515TS_CON5_AUD_JACK_RA_TH_AUD_5CON5_AUD_JACK_RA_TH_SJ-43515TS
    J19CONN_HDR_2X1_HDR102_IO_4.19MM_2HDR1X2HDR102
    JP1CONN_HDR_1X1_HDR101_IO_8.59MM_2HDR1X1HDR101
    JP2CONN_HDR_1X1_HDR101_IO_8.59MM_2HDR1X1HDR101
    L1IND_IND_VLF4012_DISCRETE_1.2MM_4.7UH@100KHZIND_VLF4012
    L2INDUCTOR_IND_0402_DISCRETE_0.55120OHMIND_0402
    L3INDUCTOR_IND_0402_DISCRETE_0.55120OHMIND_0402
    L4INDUCTOR_IND_0402_DISCRETE_0.55120OHMIND_0402
    L5DLW43_CHOKE_0805_DISCRETE_1MM_190OHMCHOKE_0805
    L6DLW43_CHOKE_0805_DISCRETE_1MM_190OHMCHOKE_0805
    L7BEAD_0603_CC_DISCRETE_0.95MM_18120OHM0603_CC
    L8INDUCTOR_IND_0402_DISCRETE_0.55120OHMIND_0402
    L9BEAD_0603_CC_DISCRETE_0.95MM_18120OHM0603_CC
    L10BEAD_IND_0603_0.95MM_180-75039_120OHMIND_0603
    L11INDUCTOR_IND_0402_DISCRETE_0.55120OHMIND_0402
    L12BEAD_IND_0603_0.95MM_180-75039_120OHMIND_0603
    L13INDUCTOR_IND_VLS3012_SM_DISCRET2.2UHIND_VLS3012_SM
    L14INDUCTOR_CDRH2D18_DISCRETE_2MM_2.2UHCDRH2D18
    L15INDUCTOR_CDRH2D18_DISCRETE_2MM_2.2UHCDRH2D18
    L16INDUCTOR_IND_VLS3012_SM_DISCR_14.7UHIND_VLS3012_SM
    L17INDUCTOR_CDRH2D18_DISCRETE_2MM_2.2UHCDRH2D18
    L18INDUCTOR_CDRH2D18_DISCRETE_2MM_2.2UHCDRH2D18
    L19BEAD_0603_CC_DISCRETE_0.95MM_18120OHM0603_CC
    L20INDUCTOR_FERRITE_IND_0402_DISCR220OHMIND_0402
    L21INDUCTOR_FERRITE_IND_0402_DISCR220OHMIND_0402
    L22INDUCTOR_FERRITE_IND_0402_DISCR220OHMIND_0402
    L23INDUCTOR_FERRITE_IND_0402_DISCR220OHMIND_0402
    L24INDUCTOR_FERRITE_IND_0402_DISCR220OHMIND_0402
    L25INDUCTOR_FERRITE_IND_0402_DISCR220OHMIND_0402
    L26BEAD_IND_0402_DISCRETE_0.55MM_1600OHMIND_0402
    L27INDUCTOR_IND_0402_DISCRETE_0.55120OHMIND_0402
    L28INDUCTOR_IND_0402_DISCRETE_0.55120OHMIND_0402
    Q1MOSFET_P_SOT-23_IC_1.12MM_480-7IRLML6401SOT-23
    Q7MOSFET_P_SOT-23_IC_1.12MM_480_1Si2333DSSOT-23
    Q8MOSFET_EN_DIODE_SCH_8P_WDFN6_0PNTLJF4156NWDFN6_0P65_2X2
    Q9MOSFET_2N_CHAN_SC70-6_IC_1.1MM_BSS138DW-7SC70-6
    Q10MOSFET_2N_CHAN_SC70-6_IC_1.1MM_BSS138DW-7SC70-6
    Q11MOSFET_2N_CHAN_SC70-6_IC_1.1MM_BSS138DW-7SC70-6
    Q12MOSFET_2N_CHAN_SC70-6_IC_1.1MM_BSS138DW-7SC70-6
    Q13FDC6321C_SOT23-6_IC_1.22MM_480FDC6321C_NLSOT23-6
    Q14MOSFET_P_SOT-23_IC_1.12MM_480-7IRLML6401SOT-23
    Q152N7002_SOT23_IC_1.3MM_480-751592N7002SOT23
    QZ1CRYSTAL_1P8X3P5_IC_0.9MM_230-332.768KHZ1P8X3P5
    SS5SPACER_SPACER_150T_IC_16.13MM_2.635"LONGSPACER_150T
    SW1SW_DIP-10_DIP10_1P27MM_SM_IC_1.SW_DIP-10/SMDIP10_1P27MM_SM
    SW2SW_SPNO_2P_SW2_SPST_4X3_SM_IC_2TL1015AF160QGSW2_SPST_4X3_SM
    SW3SW_SPNO_2P_SW2_SPST_4X3_SM_IC_2TL1015AF160QGSW2_SPST_4X3_SM
    SW4SW_SPNO_2P_SW2_SPST_4X3_SM_IC_2TL1015AF160QGSW2_SPST_4X3_SM
    SW5SW_SPNO_2P_SW2_SPST_4X3_SM_IC_2TL1015AF160QGSW2_SPST_4X3_SM
    TP1TESTPAD_C035S_IC_0.1 MM_280-75TESTPOINTC035S
    TP2TESTPAD_C035S_IC_0.1 MM_280-75TESTPOINTC035S
    U1RT8010PQW_WDFN6_2X2MM_IC_0.8MM_RT8010WDFN6_2X2MM
    U2IMX536D_TEPBGA_529P_PBGA529_0P8MCiMX536DJV8APBGA529_0P8MM
    U32G_DDR3_SDRAM_128MX16_FBGA_96P_EDJ2116DASEBGA96_0P8_9P15X14P15
    U42G_DDR3_SDRAM_128MX16_FBGA_96P_EDJ2116DASEBGA96_0P8_9P15X14P15
    U52G_DDR3_SDRAM_128MX16_FBGA_96P_EDJ2116DASEBGA96_0P8_9P15X14P15
    U62G_DDR3_SDRAM_128MX16_FBGA_96P_EDJ2116DASEBGA96_0P8_9P15X14P15
    U9SGTL5000_QFN32_IC_0.9MM_315-779SGTL500032QFNQFN32
    U11FIN1001_SOT23_5P_SOT23-5_IC_1.4FIN1001M5SOT23-5
    U121T45_SOT23-6_IC_1.45MM_312-754774LVC1T45SOT23-6
    U131T45_SOT23-6_IC_1.45MM_312-754774LVC1T45SOT23-6
    U14TXB0102_PSOP8_IC_0.9MM_315-7889TXS0102PSOP8
    U15SRV05-4_SOT23_S6_IC_1.45MM_480-SRV05-4SOT23_S6
    U16SRV05-4_SOT23_S6_IC_1.45MM_480-SRV05-4SOT23_S6
    U17LAN8720A-QFN24_QFN24_4X4MM_SLUGLAN8720AQFN24_4X4MM_SLUG
    U20DA9053_VFBGA_169P_BGA169_0P5_7XDA9053BGA169_0P5_7X7
    U221G125_SC70-5_A_IC_1.1MM_312-301NC7SP125P5XSC70-5_A
    U23MMA8450QT_16P_QFN16_0P5_3P03X3PMMA8450QTQFN16_0P5_3P03X3P03
    U24SP3232E_SSOP16_IC_1.99MM_312-77SP3232SSOP16
    U251T45_SOT23-6_IC_1.45MM_312-754774LVC1T45SOT23-6
    U261T45_SOT23-6_IC_1.45MM_312-754774LVC1T45SOT23-6
    X1OSC4_SM_7X5MM_IC_1.9MM_230-30050MHz7X5MM
    Y1XTAL_13Y_A_XTAL4_SX_3225_IC_0.724MHzXTAL4_SX_3225
    17万
    管理员
     楼主| 发表于 2023-6-15 13:49:31 | 显示全部楼层
    PCB文件。回复可见下载
    游客,如果您要查看本帖隐藏内容请回复
    昨天 13:12
  • 签到天数: 105 天
    发表于 2023-6-15 16:03:06 | 显示全部楼层
    4 小时前
  • 签到天数: 178 天
    发表于 2023-6-15 18:38:12 | 显示全部楼层
    2 小时前
  • 签到天数: 95 天
    社区居民终身成就奖特殊贡献奖原创先锋奖
    发表于 2023-6-15 20:31:48 | 显示全部楼层
    发表于 2023-6-15 21:25:34 | 显示全部楼层
                        [s:151]
    PADS-170802高级班
    发表于 2023-6-15 21:37:20 | 显示全部楼层
    郁闷
    8 小时前
  • 签到天数: 141 天
    发表于 2023-6-15 22:21:12 | 显示全部楼层
  • 签到天数: 28 天
    PADS20210412初级班
    发表于 2023-6-15 22:41:51 | 显示全部楼层
    8 小时前
  • 签到天数: 171 天
    发表于 2023-6-16 00:08:47 | 显示全部楼层
