REFDES | COMP_DEVICE_TYPE | COMP_VALUE | SYM_NAME |
D1 | LTL-907/SM_0_SMB_M7 | M7 | SMB |
D2 | LTL-907/SM_0_LL_34_SMALL_4148 | 4148 | LL_34_SMALL |
D3 | LTL-907/SM_0_SMB_1N4148 | 1N4148 | SMB |
D4 | LTL-907/SM_0_SMB_1N4148 | 1N4148 | SMB |
D5 | LTL-907/SM_0_SMB_1N4148 | 1N4148 | SMB |
D6 | LTL-907/SM_0_SMB_1N4148 | 1N4148 | SMB |
D7 | LTL-907/SM_0_LL_34_SMALL_1N4148 | 1N4148 | LL_34_SMALL |
D8 | LTL-907/SM_0_LL_34_SMALL_1N4148 | 1N4148 | LL_34_SMALL |
D9 | LTL-907/SM_0_SMB_M7 | M7 | SMB |
D10 | LTL-907/SM_0_SMB_M7 | M7 | SMB |
E1 | CAPPOL_EC8_12_25V/470UF | 25V/470UF | EC8_12 |
E2 | CAPPOL_EC10_16_25V/1000UF | 25V/1000UF | EC10_16 |
E4 | CAPPOL_EC6_10_25V/220UF | 25V/220UF | EC6_10 |
E5 | CAPPOL_EC6_10_25V/220UF | 25V/220UF | EC6_10 |
F1 | RES_0_FU_TCH_5_20_RES | RES | FU_TCH_5_20 |
F2 | RES_0_PTC_30_185_PTCJK60-030 | PTCJK60-030 | PTC_30_185 |
J1 | CON8_JK6_THC_E5_08_COM8 | com8 | JK6_THC_E5_08 |
J2 | CON_JK12_THC_E5_08_CON12 | CON12 | JK12_THC_E5_08 |
J9 | SWD_SIP5_SWD | SWD | SIP5 |
JQ1 | RE_JQ_HF115F_HF115F-012-1HS3 | HF115F-012-1HS3 | JQ_HF115F |
JQ2 | RE_JQ_HF115F_HF115F-012-1HS3 | HF115F-012-1HS3 | JQ_HF115F |
L1 | RSE_4_R1206_0R | 0R | R1206 |
L10 | BEAD_0_R0603_BEAD | bead | R0603 |
L11 | INDUCTOR/SM_L0603_30OHM | 30ohm | L0603 |
LED1 | F5F1_0_LED0805__R_LED | R_LED | LED0805_ |
LED2 | F5F1_0_LED0805__R_LED | R_LED | LED0805_ |
LED3 | F5F1_0_LED0805__R_LED | R_LED | LED0805_ |
LED4 | F5F1_0_LED0805__F5F1 | F5F1 | LED0805_ |
LED5 | F5F1_0_LED0805__F5F1 | F5F1 | LED0805_ |
LED6 | F5F1_0_LED0805__F5F1 | F5F1 | LED0805_ |
LED7 | F5F1_0_LED0805__F5F1 | F5F1 | LED0805_ |
LED9 | F5F1_0_LED0805__F5F1 | F5F1 | LED0805_ |
LED10 | F5F1_0_LED0805__F5F1 | F5F1 | LED0805_ |
LED15 | F5F1_0_LED0805__R_LED | R_LED | LED0805_ |
LED16 | F5F1_0_LED0805__R_LED | R_LED | LED0805_ |
LS1 | MICROPHONE_FMQ2_THC_FMQ5V | FMQ5V | FMQ2_THC |
M1 | M_UHF_RX_THC6_E2_54_RX_MODULE2 | RX_MODULE2 | UHF_RX_THC6_E2_54 |
P1 | EL817_PC817_THC_EL817 | EL817 | PC817_THC |
Q1 | 2N2016_0_SOT23_8050 | 8050 | SOT23 |
Q2 | MAC5443_4_TO-220_SR_BTA16-600CW | BTA16-600CW | TO-220_SR |
Q3 | 2N2016_0_SOT23_8050 | 8050 | SOT23 |
Q4 | 2N4398_1_SOT23_8550 | 8550 | SOT23 |
Q5 | 2N2016_0_SOT23_8050 | 8050 | SOT23 |
R100 | RSE_4_R0805__10K | 10K | R0805_ |
SW2 | SWDIP-6_1_SW6_DIP_BM_BM6 | BM6 | SW6_DIP_BM |
SW8 | SWPUSHBUTTON_SB_MSD2_6_SW | SW | SB_MSD2_6 |
SW9 | SWPUSHBUTTON_SB_MSD2_6_SW | SW | SB_MSD2_6 |
T1 | L2_0_TR_THC_4P_SMALL_L2 | L2 | TR_THC_4P_SMALL |
T2 | TRANSFORMER5_8_TR_6P_TRANSFORME | transformer5 | TR_6P |
T3 | TRANSFORMER5_6_TR_4P_TR-4 | TR-4 | TR_4P |
U1 | 74HC165_SOP16_74HC165 | 74HC165 | SOP16 |
U2 | L7805_TO_220_L7805 | L7805 | TO_220 |
U3 | OC3_0_DIP6_MOC3052 | MOC3052 | DIP6 |
U4 | ULN2003A_SOP16_ULN2003A | ULN2003A | SOP16 |
U6 | ULN2003A_SOP16_ULN2003A | ULN2003A | SOP16 |
U8 | M051LDN_1_LQFP_48_M051LDN | M051LDN | LQFP_48 |
U13 | ESP8266_MOD_1_COM10_ESP8266_MOD | ESP8266_MOD | COM10 |
U15 | LM1117_SOT223_LM1117 | LM1117 | SOT223 |
U33 | SW1_1_SW2_THC_8P__6PIN | 6PIN | SW2_THC_8P_ |
X2 | 7A14300038_3_CRYSTAL_3225_XTAL- | XTAL-32MHz | CRYSTAL_3225 |
