TA的每日心情 | 开心 2024-7-10 20:37 |
签到天数: 1 天 [LV.1]初来乍到
- 20876
Comment | Pattern | Quantity | Components | | | | | 0 Ohm 1/16W | RES_C1005X04N | 1 | R3 | 0.01uF 100V | CAP_0603_1.60MM*0.80MM | 2 | C18, C30 | 0.1 M Header" | 2-PIN_MALE_HEADER_01-IN | 2 | H5, H7 | 0.1 M Header" | 2-PIN_MALE_NO 3D | 3 | TP_BME_I1, TP_GPS_UART1, TP_IMU_I1 | 0.1 M Header" | 3-PIN_MALE_HEADER_01-IN | 1 | H6 | 0.1 M Header" | 3-PIN_MALE_NO 3D | 1 | TP_DISP_SPI1 | 0.1uF 25V | CAP_0603_1.60MM*0.80MM | 7 | C1, C3, C4, C12, C16, C23, C26 | 0.22uF 25V | CAP_0603_1.60MM*0.80MM | 1 | C8 | 0ZCJ0012FF2E | PTCFUSE_1206 | 1 | PTC1 | 1 Ohm 1% 0.1W | RES_0603_1608X06 | 1 | R6 | 1.561GHZ/1.575GHZ CHIP | CHIP_ANTENNA | 1 | ANT2 | 1.5pF 50V | CAP_0403_1.00MM*0.50MM | 1 | C5 | 1.9nH 1A | IND_0402 | 2 | L1, L2 | 100 1% | RES_0603_1608X06 | 6 | R5, R20, R22, R23, R24, R25 | 100k 1% | RES_0603_1608X06 | 1 | R7 | 100pF 100V | CAP_0603_1.60MM*0.80MM | 1 | C6 | 100uF 6.3V | CAPC3216X18N | 2 | C29, C31 | 10k 1% | RES_0603_1608X06 | 4 | R8, R17, R18, R19 | 10pF 50V | CAP_0603_1.60MM*0.80MM | 2 | C7, C9 | 10uF 25V | CAP_0805_2MM | 2 | C14, C17 | 10uH 650mA | IND_WE-TPC-2813-TH | 1 | L5 | 1M | RES_0603_1608X06 | 2 | R4, R21 | 1nF | CAP_0603_1.60MM*0.80MM | 2 | C10, C11 | 1uF 50V | CAP_0603_1.60MM*0.80MM | 7 | C15, C19, C20, C21, C24, C25, C32 | 22uF 10V | CAP_0603_1.60mm*0.80mm | 2 | C27, C33 | 22uH 510mA | IND_WE-TPC-3816-S | 1 | L4 | 32.768kHz Crystal | SMD_2 CRYSTAL | 1 | X2 | 38.4 MHz Crystal | SMD_4 CRYSTAL | 1 | X1 | 4.22M 0.1W 1% | RES_0603_1608X06 | 1 | R12 | 4.75M 1% | RES_0603_1608X06 | 1 | R10 | 4.7k 1% | RES_0603_1608X06 | 2 | R1, R2 | 4.7uF 25V | CAP_0603_1.60MM*0.80MM | 4 | C2, C13, C22, C28 | 4.7uH 1.35A | IND_WE-TPC 2828 | 1 | L3 | 5.62M 0.1W 1% | RES_0603_1608X06 | 1 | R16 | 698 0.1W 1% | RES_0603_1608X06 | 1 | R9 | 7.5M 0.1W 1% | RES_0603_1608X06 | 1 | R15 | 715k 1% | RES_0603_1608X06 | 1 | R14 | 74279266 1 KOhm | FB_0603_1.60MM*0.80MM | 1 | FB3 | 8.06M 1% | RES_0603_1608X06 | 1 | R13 | 8.25M 0.1W 1% | RES_0603_1608X06 | 1 | R11 | BLM18AG601SN1D 100 MHz | FB_CHIP2PINSM127P600-8N | 2 | FB1, FB2 | BLM18AG601SN1D 100MHz | FB_CHIP2PINSM127P600-8N | 1 | FB6 | BME280 | BME280_PSON65P250X250X100-8N | 1 | U1 | BNO055 | BNO055-MFG | 1 | U4 | BQ25570RGRR PMIC | PMIC_RGR0020A_NV | 1 | U2 | CONN FFC FPC 10POS 0.50MM | FPC_AYF531035A | 1 | H3 | EFR32BG13P732F512GM48-C | MCU_QFN50P700X700X90_HS-49N | 1 | U5 | ESD Diode | ESD_SOD882 | 4 | ESD1, ESD2, ESD4, ESD5 | MAX-M8Q-0 | XCVR_MAX-M8C-0-10 | 1 | U6 | Mini Simplicity Debug Connector | FTSH-105-01-XXX-DV-K | 1 | H4 | Red LED | LED_0603_RED_WL-SMCW | 1 | LED1 | S2B-PH-SM4-TB | JST_S2B-PH-SM4-TB | 1 | J1 | SWITCH SPST-NO 50MA 12V | SW_TL3305AF260QG | 3 | S1, S2, S3 | Terminal Block - 2 Pin | 2-PIN_MALE_HEADER_01-282834-2 | 1 | H1 | TP_3V3_LOAD | TP10x_Probe | 1 | TP3 | TP_3V3_VDCDC | TP10x_Probe | 1 | TP2 | TP_PMUX_STAT | TP10x_Probe | 1 | TP1 | TPS2115ADRBT Power Mux | PMUX_SON127P600-8N | 1 | U3 | TPS22919DCKR Power Switch/Driver | LS_SOT65P210X110-6N | 1 | U9 | USB MICRO B RECPT | MICROUSB_AMPHENOL_10118194-0001LF | 1 | H2 | Yellow LED | LED_0603_YLW_WL-SMCW | 2 | LED2, LED3 |
