查看: 1384|回复: 23
[Allegro17.4以下] MC33FS6522LAE 方案PCB文件共享
    终身成就奖社区居民忠实会员宣传大使奖优秀斑竹奖
    发表于 2023-8-1 10:02:16 | 显示全部楼层 |阅读模式
    重要提示:PCB作品文件展下载说明
    MC33FS6522LAE.zip (3.26 MB, 下载次数: 0)
    BH1MOUNT_HOLE_PMC_MECH_HOLE_IC_0MMMTG1PMC_MECH_HOLE
    BH2MOUNT_HOLE_PMC_MECH_HOLE_IC_0MMMTG1PMC_MECH_HOLE
    BH3MOUNT_HOLE_PMC_MECH_HOLE_IC_0MMMTG1PMC_MECH_HOLE
    BH4MOUNT_HOLE_PMC_MECH_HOLE_IC_0MMMTG1PMC_MECH_HOLE
    D1LED_LED2_2P1X1P5_NSP_IC_1.4MM_LED/GRNLED2_2P1X1P5_NSP
    D2DIODE_SCHTKY_CASE403A_03_IC_2.4SS24T3GCASE403A_03
    D3LED_LED2_2P1X1P5_NSP_IC_1.4MM_LED/GRNLED2_2P1X1P5_NSP
    D4LED_LED2_2P1X1P5_NSP_IC_1.4MM_LED/GRNLED2_2P1X1P5_NSP
    D5LED_LED2_2P1X1P5_NSP_IC_1.4MM_LED/GRNLED2_2P1X1P5_NSP
    D6DIODE_SCHTKY_CASE403A_03_IC_2.4SS24T3GCASE403A_03
    D7DIODE_SCHTKY_SOD-128_IC_1.1MM_4PMEG3030BEPSOD-128
    D8DIODE_SCHTKY_SOD-128_IC_1.1MM_1PMEG10030ELPSOD-128
    D9ZDIODE_SOD-323-A_IC_1.1MM_480-7PDZ36BSOD-323-A
    D10LED_LED2_2P1X1P5_NSP_IC_1.4MM_LED/GRNLED2_2P1X1P5_NSP
    D11LED_LED2_2P1X1P5_NSP_IC_1.4MM_LED/GRNLED2_2P1X1P5_NSP
    D12DIODE_SOD323_IC_1.05MM_480-75131N4148WSSOD323
    D13LED_LED2_2P1X1P5_NSP_IC_1.4MM_3REDLED2_2P1X1P5_NSP
    D14LED_LED2_2P1X1P5_NSP_IC_1.4MM_3REDLED2_2P1X1P5_NSP
    D15LED_LED2_2P1X1P5_NSP_IC_1.4MM_LED/GRNLED2_2P1X1P5_NSP
    D16ZDIODE_SOD-323-A_IC_1.1MM_480-7PDZ36BSOD-323-A
    D17LED_LED2_2P1X1P5_NSP_IC_1.4MM_LED/GRNLED2_2P1X1P5_NSP
    D18LED_LED2_2P1X1P5_NSP_IC_1.4MM_LED/GRNLED2_2P1X1P5_NSP
    D19ZDIODE_CASE403A_03_IC_2.56MM_41SMB5919BT3GCASE403A_03
    D20LED_LED2_2P1X1P5_NSP_IC_1.4MM_3REDLED2_2P1X1P5_NSP
    D21LED_LED2_2P1X1P5_NSP_IC_1.4MM_3REDLED2_2P1X1P5_NSP
    D50ZDIODE_SOD-323-A_IC_1.1MM_480-7PDZ36BSOD-323-A
    D51ZDIODE_SOD-323-A_IC_1.1MM_480-7PDZ36BSOD-323-A
    D52ZDIODE_SOD-323-A_IC_1.1MM_480-7PDZ36BSOD-323-A
    D53ZDIODE_SOD-323-A_IC_1.1MM_480-7PDZ36BSOD-323-A
    D54ZDIODE_SOD-323-A_IC_1.1MM_480-7PDZ36BSOD-323-A
    D55ZDIODE_SOD123LF_IC_1.2MM_480-78BZT52H-B18SOD123LF
    D56ZDIODE_SOD123LF_IC_1.2MM_480-78BZT52H-B18SOD123LF
    D57ZDIODE_SOD123LF_IC_1.2MM_480-79BZT52H-C20SOD123LF
    F50FUSE_FUSE_2X1P4_IC_0.55MM_510-MFU0805FF00500P100FUSE_2X1P4
    J1CONN_HDR_2X1_HDR102_IO_8.58MM_2HDR1X2HDR102
    J2HDR-2X2_JUMP2X2-6040_IO_8.58MM_HDR2X2JUMP2X2-6040
    J3CONN_HDR_2X1_HDR102_IO_8.58MM_2HDR1X2HDR102
    J4DCPOWER JACK_PJ-102AH_IO_11MM_CON_1_PWRPJ-102AH
    J5CONN_HDR_3X1_HDR103_IO_8.72MM_2HDR1X3HDR103
    J6CONN_HDR_2X1_HDR102_IO_8.58MM_2HDR1X2HDR102
    J7HDR-2X2_JUMP2X2-6040_IO_8.58MM_HDR2X2JUMP2X2-6040
    J8CONN_HDR_2X1_CON1X2_3P81_9P2X9PPLUG_1X2CON1X2_3P81_9P2X9P01
    J9CONN_HDR_2X1_HDR102_IO_8.58MM_2HDR1X2HDR102
    J10HDR-2X2_JUMP2X2-6040_IO_8.58MM_HDR2X2JUMP2X2-6040
    J11CONN_HDR_3X1_HDR103_IO_8.72MM_2HDR1X3HDR103
    J12HDR-2X2_JUMP2X2-6040_IO_8.58MM_HDR2X2JUMP2X2-6040
    J13CONN_HDR_3X2_HDR203_IO_8.5MM_21HDR2X3HDR203
    J14CONN_HDR_2X1_HDR102_IO_8.58MM_2HDR1X2HDR102
    J15CONN_HDR_2X1_HDR102_IO_8.58MM_2HDR1X2HDR102
    J16CONN_HDR_2X1_HDR102_IO_8.58MM_2HDR1X2HDR102
    J18CONN_HDR_3X1_HDR103_IO_8.72MM_2HDR1X3HDR103
    J20CONN_HDR_5X2_CON_2RH_10_50_IO_3HDR2X5CON_2RH_10_50
    J21CONN_HDR_3X1_HDR103_IO_8.72MM_2HDR1X3HDR103
    J22CONN_HDR_3X1_HDR103_IO_8.72MM_2HDR1X3HDR103
    J23CONN_HDR_2X1_CON1X2_3P81_9P2X9PPLUG_1X2CON1X2_3P81_9P2X9P01
    J24CONN_HDR_4X2_HDR2X4_IO_8.71MM_HDR_2X4HDR2X4
    J25CONN_HDR_2X1_HDR102_IO_8.58MM_2HDR1X2HDR102
    J26CONN_HDR_2X1_HDR102_IO_8.58MM_2HDR1X2HDR102
    J27CONN_HDR_2X1_HDR102_IO_8.58MM_2HDR1X2HDR102
    J28CONN_HDR_2X1_HDR102_IO_8.58MM_2HDR1X2HDR102
    J29HDR-2X2_JUMP2X2-6040_IO_8.58MM_HDR2X2JUMP2X2-6040
    J30CONN_HDR_2X1_CON1X2_3P81_9P2X9PPLUG_1X2CON1X2_3P81_9P2X9P01
    J31CONN_HDR_3X2_HDR203_IO_8.5MM_21HDR2X3HDR203
    J32CONN_HDR_3X1_HDR103_IO_8.72MM_2HDR1X3HDR103
    J33USB_MINI_AB_RECEPTACLE_CON5_USBCONNUSB MINI-BCON5_USB_RA_SMT
    J34HDR-2X2_JUMP2X2-6040_IO_8.58MM_HDR2X2JUMP2X2-6040
    J35CONN_HDR_2X1_HDR102_IO_8.58MM_2HDR1X2HDR102
    J36CONN_HDR_5X2_HDR205_IO_8.6MM_21HDR2X5HDR205
    J37CONN_HDR_10X2_HDR210_IO_8.71MMHDR_10X2HDR210
    J38CONN_HDR_3X1_HDR103_IO_8.72MM_2HDR1X3HDR103
    J39CONN_HDR_2X1_HDR102_IO_8.58MM_2HDR1X2HDR102
    J40CONN_HDR_2X1_HDR102_IO_8.58MM_2HDR1X2HDR102
    J41SMB_CON_SMB_IO_8.26MM_210-7575CON_1_SMBCON_SMB
    J42SMB_CON_SMB_IO_8.26MM_210-7575CON_1_SMBCON_SMB
    J43CONN_HDR_2X1_HDR102_IO_8.58MM_2HDR1X2HDR102
    JP1CONN_HDR_10X1_CON1X10_3P81_9P2XPLUG_1X10CON1X10_3P81_9P2X39P49
    L1COIL_IND2_10P4X10P4_DISCRETE_4.22UHIND2_10P4X10P4
    L2INDUCTOR_FERRITE_A_IND2_6P4_7P51uHIND2_6P4_7P5SQ
    L3IND_IND_1608_DISCRETE_0.75MM_18100OHMIND_1608
    L4INDUCTOR_FERRITE_A_IND2_6P4_7_12.2uHIND2_6P4_7P5SQ
    L5BEAD_IND_0805_DISCRETE_1.05MM_330OHMIND_0805
    L50BEAD_IND_0805_DISCRETE_1.05MM_330OHMIND_0805
    Q1NDT3055_SOT223_IC_1.8MM_480-78BUK9832-55ASOT223
    Q2NMOS_NX3008NBK_SOT23_A_IC_1.1MMNX3008NBKSOT23_A
    Q3MOSFET_P_SOT-23_IC_1.11MM_480-7BSS84LT1SOT-23
    Q4MOSFET_P_SOT-23_IC_1.11MM_480-7BSS84LT1SOT-23
    Q50PNP_4B123E5C_LFPAK5_1P27_5X4_ICPHPT60603PYLFPAK5_1P27_5X4
    Q51PNP_4B123E5C_LFPAK5_1P27_5X4_ICPHPT60603PYLFPAK5_1P27_5X4
    Q53NMOS_NX3008NBK_SOT23_A_IC_1.1MMNX3008NBKSOT23_A
    SW1SW_DIP-4_SM_97C04_IC_1.50MM_51SWDIP-4/SM97C04
    SW2SW3_SPDT_SLD_TH_SW3_SLD_SPDT_RA500SSP3S1M6QEASW3_SLD_SPDT_RA
    SW3SW_DIP-6_HALF-PITCH6_IC_1.50MM_SW_DIP-6_SMHALF-PITCH6
    SW4SW3_SPDT_SLD_TH_SW3_SLD_SPDT_RA500SSP3S1M6QEASW3_SLD_SPDT_RA
    SW5SW_DIP-4_SM_97C04_IC_1.50MM_51SWDIP-4/SM97C04
    SW6SW_DIP-4_SM_97C04_IC_1.50MM_51SWDIP-4/SM97C04
    U1DIODE_2LINE_ESD_SOT23_A_IC_1.15GSOT05C-GS08SOT23_A
    U50OPAMP_QUAD_14P_SOIC14_1P27_4X8_MCP6004-I/SLSOIC14_1P27_4X8
    U5174HC4050_16P_SO16_1P27_10X4_IC_74HC4050DSO16_1P27_10X4
    U521T45_SO6_IC_0.6MM_312-79762_SNSN74LVC1T45SO6
    U53OPAMP_QUAD_14P_SOIC14_1P27_4X8_MCP6004-I/SLSOIC14_1P27_4X8
    U54MKL25Z128VFT4_49P_QFN_48_0P5_7XMKL25Z128VFT4QFN_48_0P5_7X7
    U55MC33FS6522LAE_LQFP_48_A_LQFP48_MC33FS6522LAELQFP48_EP146MIL
    Y50CRYSTAL_JXS63_XTLOSC4_5X3MM_SM_8MHZXTLOSC4_5X3MM_SM
    重要提示:PCB作品文件展下载说明
    头像被屏蔽
    禁止发言
    发表于 2023-8-1 10:11:07 | 显示全部楼层
    提示: 作者被禁止或删除 内容自动屏蔽
    昨天 09:59
  • 签到天数: 138 天
    发表于 2023-8-1 10:26:26 | 显示全部楼层
    发表于 2023-8-1 10:41:19 | 显示全部楼层
    半小时前
  • 签到天数: 90 天
    发表于 2023-8-1 11:25:31 | 显示全部楼层
    难过
    2024-8-26 14:59
    Allegro240812初级
    发表于 2023-8-1 22:27:26 | 显示全部楼层
    昨天 21:24
  • 签到天数: 60 天
    发表于 2023-8-2 08:15:39 | 显示全部楼层
    12 小时前
  • 签到天数: 169 天
    发表于 2023-8-2 08:17:57 | 显示全部楼层
    12 小时前
  • 签到天数: 174 天
    社区居民忠实会员社区劳模终身成就奖社区明星宣传大使奖优秀斑竹奖特殊贡献奖原创先锋奖
    发表于 2023-8-2 08:23:29 | 显示全部楼层
    9 小时前
  • 签到天数: 199 天
    发表于 2023-8-2 08:30:57 | 显示全部楼层
