查看: 577|回复: 1
[供应] 802.11be-IPQ9574+IPQ9554 802.11ax-IPQ8074+IPQ8072 Support 8 data streams in 4
发表于 2023-8-29 10:55:33 | 显示全部楼层 |阅读模式
802.11be-IPQ9574+IPQ9554 802.11ax-IPQ8074+IPQ8072 Support 8 data streams in 4 frequency bands, with a peak rate of 16Gbps
The IPQ8072 is designed to orchestrate a seamless connectivity experience. This powerful chip redefines high-speed networking, supporting up to four 2.5G Ethernet ports to meet the growing demands of data-intensive applications. Its dual-core ARM Cortex-A53 processor handles tasks, ensuring peak performance even with resource-intensive workloads. Integrated Wi-Fi 6 support adds another layer of luster, delivering lightning-fast wireless speeds and increased network efficiency.
  The IPQ8072 was a masterpiece in its own right, but the IPQ8074 stepped onto the stage as a true trailblazer, redefining what was achievable in networking capabilities. Equipped with a quad-core Krait 64-bit CPU, the SoC unleashes unrivaled processing power. The IPQ8074 is a testament to Qualcomm's dedication to pushing the boundaries, with an impressive combination of 2.2 GHz clock speed and a massive 14nm FinFET process.
With its tri-band Wi-Fi 6 support, the IPQ8074 is the ultimate catalyst for the evolution of the wireless experience. A dedicated 5 GHz band optimized for gaming and streaming, and dual 2.4 GHz bands for general use ensure lag-free, interference-free connectivity for all connected devices. Multi-User, Multiple-Input, Multiple-Output (MU-MIMO) technology takes this experience a step further, allowing data to be streamed to multiple devices simultaneously without compromising performance.
Design Differences: IPQ8072 and IPQ8074
While both the IPQ8072 and IPQ8074 are designed to provide extraordinary networking capabilities, their unique attributes set them apart in different ways:
Peak Performance: The IPQ8074's quad-core architecture and higher clock speeds make it the undisputed leader in raw processing power.
Multi-Band Advantage: The IPQ8074's tri-band Wi-Fi and MU-MIMO lay the foundation for a new era of connectivity, ideal for dense device environments.
Versatility and efficiency: IPQ8072 integrates multiple 2.5G Ethernet ports to meet diverse network needs and improve efficiency in home and business scenarios.
WiFi7 chip model IPQ9574, supports 8 data streams in 4 frequency bands, with a peak rate of 16Gbps, supports 4 2.5G ports, 1 5G port, and 1 10G port;
WiFi7 chip model IPQ9554, supports 3 frequency bands and 6 streams, peak speed 10Gbps, supports 4 2.5G ports, 1 10G port;
While both the IPQ9574 and IPQ9554 embody the hallmark of Qualcomm's dedication to innovation, they each have unique features that set them apart:
Wi-Fi 6E Dominance: The IPQ9574's Wi-Fi 6E support extends to the 6 GHz spectrum, delivering unrivaled wireless speed and capacity.
Balanced Performance: The IPQ9554 strikes a balance between performance and efficiency, making it an excellent choice for scenarios that require both.
Networking versatility: Both SoCs offer a range of Ethernet and wireless capabilities to meet different networking needs.
IPQ9574 and IPQ9554: Harnessing the High-Performance Networking Domain
Difference between IPQ9574 and IPQ9554. These advanced system-on-chip (SoC) solutions promise to reshape connectivity and performance paradigms. Join us as we learn about their features and capabilities, revealing the nuances that set them apart.
IPQ9574: Igniting the Fire of Innovation
At the heart of the IPQ9574 is a sophisticated fusion of cutting-edge engineering and visionary design. This powerful force is a testament to Qualcomm's commitment to pioneering the future of networking. The impressive clock speed of its quad-core ARM Cortex-A53 processor is key to its computing power. This setting ensures optimal performance and meets the demands of modern networking scenarios.
The crowning glory of the IPQ9574 is its ability to harness the potential of Wi-Fi 6E, the extension of the Wi-Fi 6 standard to the 6 GHz spectrum. This enables the SoC to deliver unrivaled wireless speeds, lower latency and enhanced network capacity. With MU-MIMO technology, it can efficiently serve multiple devices simultaneously, making it ideal for congested networks.
This SoC redefines the boundaries of what can be achieved in networking, making it the best choice for applications requiring high-speed connectivity, low latency, and reliable performance.
IPQ9554: Improve connection experience
In the field of network innovation, IPQ9554 is a symbol of enhancing the connection experience. Centered around a quad-core Krait CPU, the SoC delivers a symphony of processing power and efficiency. The IPQ9554 combines high performance and power optimization, making it ideal for applications requiring computing power and energy efficiency.
In terms of wireless capabilities, the IPQ9554 shines with its support for Wi-Fi 6. This ensures seamless connectivity, faster data rates and higher performance even in dense device environments. The SoC's multi-gigabit Ethernet ports provide lightning-fast wired connectivity for a wide range of networking needs.
  • 签到天数: 27 天
    1元学习Pads(221219)
    发表于 2023-8-29 11:13:22 | 显示全部楼层
