查看: 1227|回复: 18
[Allegro17.4以下] 12层EP5CGX150C7F896+88E1111+88W8787+LTC3855EUH-1 做的PCIE PCB
    终身成就奖社区居民忠实会员宣传大使奖优秀斑竹奖
    发表于 2023-9-15 09:43:48 | 显示全部楼层 |阅读模式
    重要提示:PCB作品文件展下载说明
    PCIEPCB-finish.zip (2.89 MB, 下载次数: 6)
    BP1TBF-1608-245-R7_TBF-1608_TBF160TBF1608245R7TBF-1608
    CN1CAP_ARRAY_CAP_PACK_4_1206_0.1UF0.1uFCAP_PACK_4_1206
    CN2CAP_ARRAY_CAP_PACK_4_1206_0.1UF0.1uFCAP_PACK_4_1206
    CN3CAP_ARRAY_CAP_PACK_4_1206_0.1UF0.1uFCAP_PACK_4_1206
    CN4CAP_ARRAY_CAP_PACK_4_1206_0.1UF0.1uFCAP_PACK_4_1206
    CN5CAP_ARRAY_CAP_PACK_4_1206_0.1UF0.1uFCAP_PACK_4_1206
    CN6CAP_ARRAY_CAP_PACK_4_1206_0.1UF0.1uFCAP_PACK_4_1206
    D1LED_LUMEX_LED0805_GREEN_LEDGreen_LEDLUMEX_LED0805
    D2LED_LUMEX_LED0805_GREEN_LEDGreen_LEDLUMEX_LED0805
    D3LED_LUMEX_LED0805_GREEN_LEDGreen_LEDLUMEX_LED0805
    D4LED_LUMEX_LED0805_GREEN_LEDGreen_LEDLUMEX_LED0805
    D5LED_LUMEX_LED0805_GREEN_LEDGreen_LEDLUMEX_LED0805
    D6DIODEPACK 100V 200MA MMBD1205_MMBD1205SOT23
    D7DIODE,SCHOTTKY CMDSH-3_SOD323_CMDSH-3SOD323
    D8DIODE,SCHOTTKY CMDSH-3_SOD323_CMDSH-3SOD323
    D10DIODE,SCHOTTKY CMDSH-3_SOD323_CMDSH-3SOD323
    D11DIODE,SCHOTTKY CMDSH-3_SOD323_CMDSH-3SOD323
    D12DIODE,SCHOTTKY CMDSH-3_SOD323_CMDSH-3SOD323
    D13DIODE,SCHOTTKY CMDSH-3_SOD323_CMDSH-3SOD323
    D18GREEN_LED_LUMEX_LED0805_GREEN_LGreen_LEDLUMEX_LED0805
    D19DIODE,SCHOTTKY CMDSH-3_SOD323_CMDSH-3SOD323
    FB1INDUCTORFERRITE_L0402_BLM15PD1BLM15PD121SN1DL0402
    FB2INDUCTORFERRITE_L0402_BLM15PD1BLM15PD121SN1DL0402
    FB3INDUCTORFERRITE_L0402_BLM15PD1BLM15PD121SN1DL0402
    J1CONN,HSMC_MALE_SAMTEC_QSHDP120CONN,HSMC_MaleSAMTEC_QSHDP120CUSTOM
    J2PCIE_BRACKET_X4_PCIX-4PORT_PCIEPCIE_SlotPCIX-4PORT
    J3HFJ11-1G02E_RJ45_HFJ11-1G02EHFJ11-1G02ERJ45
    J4CONN,DC JACK RAPC712_RAPC712_CCONNJACK PWRRAPC712
    J7CONN,MINI SMB, THM, RA_SMB_RA_MiniSMBSMB_RA_JACK_RECEP
    J8CONN,MINI SMB, THM, RA_SMB_RA_MiniSMBSMB_RA_JACK_RECEP
    J9MM8130-2600_MM8130_MM8130-2600MM8130-2600MM8130
    J10CONN,MINI SMB, THM, RA_SMB_RA_MiniSMBSMB_RA_JACK_RECEP
    L1INDFERRITE 0402 300MA/220_0402BLM15AG221SN1402
    L2IND2.2UH IR=9A 7040 SMD _IND_W2.2uHIND_WURTH_744311470
    L3IND2.2UH IR=9A 7040 SMD _IND_16.5uHIND_WURTH_744311470
    L4IND0.52UH ISAT=20A SMD_IND_WUR0.52uHIND_WURTH_744310055
    L5IND0.52UH ISAT=20A SMD_IND_WUR0.52uHIND_WURTH_744310055
    L6INDFERRITE 0603 3A/30 OHMS_IND3A,30 Ohm FBIND_0603
    L7INDFERRITE 0603 3A/30 OHMS_IND3A,30 Ohm FBIND_0603
    L8IND2.2UH IR=6A 7345 SMD _IND_W2.2uHIND_WURTH_744777002
    L9INDFERRITE 0805 4A/33 OHMS_IND4A,33 Ohm FBIND_0805
    L10IND1.2UH IR=6.5A CUBE SMD_IND_1.2uHIND_SUSUMU_PCMC_BTYPE
    L11IND5.6NH 0.76A 0402_0402_5.6NH5.6nH402
    L12IND5.6NH 0.76A 0402_0402_5.6NH5.6nH402
    L13INDFERRITE 0603 2A/120 OHM_060120ohm FB603
    L14IND5.6NH 0.76A 0402_0402_5.6NH5.6nH402
    L15L0201_L0402_2.2NH2.2nHL0402
    L16L0201_L0402_2.2NH2.2nHL0402
    L17L0201_L0402_2.2NH2.2nHL0402
    L18L0201_L0402_0.9NH0.9nHL0402
    L19L0201_L0402_NCNCL0402
    L20L0201_L0402_1.6NH1.6nHL0402
    L21L0201_L0402_2.2NH2.2nHL0402
    L22IND2.2UH IR=6A 7345 SMD _IND_W2.2uHIND_WURTH_744777002
    Q1MOSFETN-CHANNEL, FDMC8878_FDMCFDMC8878FDMC8878
    Q2MOSFETN-CHANNEL, FDMC8878_FDMCFDMC8878FDMC8878
    Q3MOSFETN-CHANNEL, FDMC8878_FDMCFDMC8878FDMC8878
    Q4MOSFETN-CHANNEL HILO SI4816BDYSI4816BDYSO8
    Q5MOSFETN-CHANNEL HILO SI4816BDYSI4816BDYSO8
    Q6MOSFETN-CHANNEL, FDMC8878_FDMCFDMC8878FDMC8878
    Q7MOSFETN-CHANNEL, FDMC8878_FDMCFDMC8878FDMC8878
    Q8MOSFETN-CHANNEL HILO SI4916DY_SI4916DYSO8
    Q9MOSFETN-CHANNEL HILO SI4916DY_SI4916DYSO8
    R240RES15K OHM 1% 1/16W 0402_0402_15K402
    R241RES100K OHM 1.0% 1/16W 0402_04100K402
    R242RES4.30K OHMS 1% 1/16W 0402_042.94K402
    R243RES118K OHM 1% 1/16W 0402_040253.6K402
    RN1RES_PACK_0_RES_PACK_8_S1+S2+S3+51RES_PACK_8
    RN2RES_PACK_0_RES_PACK_8_S1+S2+S3+51RES_PACK_8
    RN3RES_PACK_0_RES_PACK_8_S1+S2+S3+51RES_PACK_8
    RN4RES_PACK_0_RES_PACK_8_S1+S2+S3+51RES_PACK_8
    RN5RES_PACK_0_RES_PACK_8_S1+S2+S3+51RES_PACK_8
    RN6RES_PACK_0_RES_PACK_8_S1+S2+S3+51RES_PACK_8
    SW1SWITCH,DIP X4, TDA04H0SB1_DIPSSwitch,DIP x4, TDA04H0SB1DIPSWITCH_SMT_QUAD
    SW2SW,SLIDE-4P2T, RA, EG4208A_EG4SWSLIDE-4P2TEG4208A
    TP1TESTPOINT1MM5_TP_CIR_500_TESTPOTESTPOINT1MM5TP_CIR_500
    TP2TESTPOINT1MM5_TP_CIR_500_TESTPOTESTPOINT1MM5TP_CIR_500
    TP3TESTPOINT1MM5_TP_CIR_500_TESTPOTESTPOINT1MM5TP_CIR_500
    TP4TESTPOINT1MM5_TP_CIR_500_TESTPOTESTPOINT1MM5TP_CIR_500
    U15CGXFC7150_F896_V1_15_F896_(S1+EP5CGX150C7F896F896
    U2LEVELSHIFTER, MAX3378_TSSOP14_LevelShifter, MAX3378TSSOP14
    U3CLOCKGEN, SI5338A_CUSTOM, A5SKSi5338A-CUSTOMQFN24
    U4CLOCKBUFFER, IDT5T9306_VFQFPN-ClockBuffer, IDT5T9306VFQFPN-28_EPAD
    U5CLKBUFFER 1TO3 LVCMOS SL18860_SL18860DCTDFN-10
    U6MT41J128M8JP_0_MICRON_DDR3_78_8MT41J128M8JPMICRON_DDR3_78_8X11P5
    U10DDR3SDRAM, MT41J128M16JT-125D_MT41J128M16JT-125MICRON_DDR3_96_9X14
    U11DDR3SDRAM, MT41J128M16JT-125D_MT41J128M16JT-125MICRON_DDR3_96_9X14
    U13SRAM,IS61VPS102418A-250TQL_TQFSRAM,IS61VPS102418A-250TQLTQFP100P
    U1488E1111_BCC96_88E111188E1111BCC96
    U15DIODECONTROLLER, LTC4357_DFN6_LTC4357DFN6_EPAD
    U16DIODECONTROLLER, LTC4357_DFN6_LTC4357DFN6_EPAD
    U17REGSWITCHING, LTC3855_QFN40_LTLTC3855EUH-1QFN40
    U18DIODECONTROLLER, LTC4357_DFN6_LTC4357DFN6_EPAD
    U19DIODECONTROLLER, LTC4352CDD_DFLTC4352CDDDFN12_EPAD
    U20DIODECONTROLLER, LTC4352CDD_DFLTC4352CDDDFN12_EPAD
    U21REGSWITCHING, LTC3855_QFN40_LTLTC3855EUH-1QFN40
    U22REGSWITCHING, LTC3603EUF_QFN20LTC3603EUFQFN20_4X4_05MM
    U23REGSWITCHING, LTC3605EUF_QFN24LTC3605EUFQFN24
    U24REGULATOR,LTC3025-1_DFN6-2X2_ELTC3025-1DFN6-2X2_EPAD
    U25REGULATOR,TPS51100DGQ_PSOP-DGQTPS51100DGQPSOP-DGQ10
    U26REGULATOR,TPS51100DGQ_PSOP-DGQTPS51100DGQPSOP-DGQ10
    U27REGULATOR,LTC3025-1_DFN6-2X2_ELTC3025-1DFN6-2X2_EPAD
    U32SDICABLE DRIVER, LMH0303SQX_LLSDICable Driver, LMH0303SQxLLP16_EPAD
    U33SDICABLE EQUALIZER, LMH0384SQ_SDICable Equalizer, LMH0384SQLLP16_EPAD
    U3488W8787_TFBGA-120_88W878788W8787TFBGA-120
    U35SE2574L_QFN-8_SE2574LSE2574LQFN-8
    U36AS179-92LF_SC-88_AS179-92LFAS179-92LFSC-88
    U37MT41J128M8JP_0_MICRON_DDR3_78_8MT41J128M8JPMICRON_DDR3_78_8X11P5
    U38MT41J128M8JP_0_MICRON_DDR3_78_8MT41J128M8JPMICRON_DDR3_78_8X11P5
    U39MT41J128M8JP_0_MICRON_DDR3_78_8MT41J128M8JPMICRON_DDR3_78_8X11P5
    U40REGSWITCHING, LTC3603EUF_QFN20LTC3603EUFQFN20_4X4_05MM
    V1TP_18_8_MIL,PTH_STAR_VIA_VIA_1VIA_1STAR_VIA
    X1XO,50MHZ CMOS, 3.2X5MM, SI510_Si510- 50MHzSMY3X5_4P
    X2OSC_ALT_XTAL_SG310_25.00MHZ25.00MHzXTAL_SG310
    Y1XTAL25MHZ 30PPM 18PF MINI_XTAL25.00MHzXTAL_FA-128
    Y3CRYSTAL14_0_SX-3225_XTL571100-FXTL571100-F98-001SX-3225
    重要提示:PCB作品文件展下载说明
    Allegro-230921高级班
    发表于 2023-9-15 10:57:16 | 显示全部楼层
  • 签到天数: 49 天
    发表于 2023-9-15 11:13:23 | 显示全部楼层
    前天 19:56
  • 签到天数: 90 天
    发表于 2023-9-15 13:19:24 | 显示全部楼层
  • 签到天数: 8 天
    终身成就奖社区居民忠实会员社区劳模最爱沙发优秀斑竹奖
    发表于 2023-9-15 14:16:52 | 显示全部楼层
    5 小时前
  • 签到天数: 189 天
    发表于 2023-9-15 14:39:37 | 显示全部楼层
    前天 18:09
  • 签到天数: 208 天
    发表于 2023-9-15 18:15:00 | 显示全部楼层
    1元学习Allegro(230718)
    发表于 2023-9-15 21:14:07 | 显示全部楼层
    3 天前
  • 签到天数: 135 天
    社区居民终身成就奖特殊贡献奖原创先锋奖
    发表于 2023-9-15 21:24:46 | 显示全部楼层
    发表于 2023-9-16 08:04:42 | 显示全部楼层
