查看: 432|回复: 0
[供应] Different SoC models -IPQ9574, IPQ9554, IPQ8074 and IPQ8072- different WiFi t
发表于 2023-9-21 09:57:14 | 显示全部楼层 |阅读模式
Different SoC models -IPQ9574, IPQ9554, IPQ8074 and IPQ8072- different WiFi technologies
The IPQ9574, IPQ9554, IPQ8074, and IPQ8072 are different models of network processors (SOCs) introduced by Qualcomm for wireless routers and networking devices. They each have different characteristics and areas of application, the following are their frequency bands and key advantages:
IPQ9574:
Frequency band: The IPQ9574 supports dual bands of 2.4GHz and 5GHz.
Advantages:
High performance: The IPQ9574 is Qualcomm's high-end SoC with powerful processing power for high-performance routers and enterprise-class networking equipment.
4x4 MU-MIMO: Supports 4x4 MU-MIMO technology, which can connect multiple devices at the same time to provide better performance and throughput.
Advanced Security: Support for advanced security features, such as WPA3 encryption, to protect network security.
Suitable for multiple uses: Suitable for high-density network environments, such as large home or enterprise networks.
IPQ9554:
Frequency band: The IPQ9554 also supports dual bands of 2.4GHz and 5GHz.
Advantages:
High performance: Although not as powerful as the IPQ9574, it still provides good performance and is suitable for mid - to high-end routers and networking devices.
4x4 MU-MIMO: Also supports 4x4 MU-MIMO technology, which provides excellent device connection performance.
Home and Small Business: For home networks and small business networks, providing reliable performance and coverage.
IPQ8074
Frequency band: The IPQ8074 mainly supports the 5GHz band.
Advantages:
High performance: The IPQ8074 is designed for high performance wireless routers and enterprise-class networking equipment to deliver superior performance.
4x4 MU-MIMO: Support for 4x4 MU-MIMO technology helps achieve better device connection performance.
Suitable for high-density networks: Suitable for network environments that require high throughput and connection density, such as enterprises and public places.
■ Qualcomm Atheros IPQ8074A AR Quad Core CPU
■ On-board 5GHz radio, up to 4804Mbps physical data rate 32MB NOR Flash, 256MB NAND Flash
■ On-board 2.4GHz radio, up to 1147Mbps physical data rate
■ Support 11ax TX Beamforming
■ Support 11ac/ax MU-MIMO DL and UL
■ Support OFDMA DL and UL
■ Tri-band support with 5G SBS (4x4/5GHz + 4x4/5GHz) + 4x4/2.4GHz
■ Supports Dynamic Frequency Selection (DFS)
IPQ8072
Frequency band: The IPQ8072 also mainly supports the 5GHz band.
Advantages:
High performance: The IPQ8072 is suitable for high performance routers with considerable processing power and wireless performance.
2x2 MU-MIMO: Although not as many MU-MIMO channels as other chips, it still supports 2x2 MU-MIMO technology, which helps improve device connection performance.
Home and Small business: Suitable for small businesses and home networks that require higher performance.
■ Qualcomm Atheros IPQ8072A AR Quad Core CPU
■ On-board 5GHz radio, up to 2475 Mbps physical data rate,On-board 2.4GHz radio, up to 1147Mbps physical data rate
■ 8 MB NOR Flash, 256MB NAND Flash(NAND Flash can be up to 1GB as optional)
■ Support 11ax TX Beamforming,Support 11ac/ax MU-MIMO DL and UL,Support OFDMA DL and UL
■ DDR 1GB DDR3L(Support DDR3L can be up to 2GB as optional)
■ M.2 connector can support QCN9074 production
What are the differences between the WiFi technologies they use:
IPQ9574, IPQ9554, IPQ8074, and IPQ8072 all support the WiFi 6 (802.11ax) standard, but they may differ in some ways, such as performance and functionality. Here are some possible differences between them:
Performance level:
The IPQ9574 and IPQ8074 typically have higher performance, including higher data transfer speeds and more device connectivity capabilities, and are suitable for high-end routers and enterprise-class networking devices.
The IPQ9554 and IPQ8072 have lower performance and are suitable for mid-range and low-end routers, as well as home networks.
Number of MU-MIMO channels:
The IPQ9574 and IPQ8074 typically support more MU-MIMO channels, so more devices can be connected simultaneously, providing better performance. IPQ9574 is currently mainly used for the wiif7 motherboard SOC, so MU-MIMO will be more, 16x16, etc., depending on how much WiFi card is paired.
The IPQ9554 and IPQ8072 support 8x8 MU-MIMO channels.
Frequency band support:
The IPQ9574 and IPQ9554 support dual bands of 2.4GHz and 5GHz.
The IPQ8074 and IPQ8072 mainly support the 5GHz band, but also support 2.4GHz.
Processing capacity:
The IPQ9574 and IPQ8074 are designed for high performance with more processing power to handle complex network tasks and high loads.
IPQ9554 and IPQ8072 have lower processing power and are suitable for simple network environments.
Application field:
The IPQ9574 and IPQ8074 are suitable for high-density networking environments, such as enterprise-class networks and large homes, where high performance and reliability are required.
The IPQ9554 and IPQ8072 are suitable for home networks and small businesses with lower performance but affordable.
Their application advantages in agricultural intelligence:
These processors can be used for agricultural intelligence applications, especially when building smart agricultural equipment and network infrastructure. Here are some uses and ways:
Agricultural Internet of Things (IoT) devices: These processors can be used to connect and manage agricultural iot devices such as sensors, cameras, weather stations, and automation devices. They provide reliable connectivity to collect and transmit data on soil, climate, water and crop growth.
Remote Monitoring and Management: By working with these processors, you can set up remote monitoring and management systems to monitor all aspects of your farm. These systems can help you understand the status of your farm in real time, make timely decisions, and improve agricultural productivity.
Precision Farming: These processors can be used to support precision farming practices, such as smart irrigation systems, automated farm machinery, and crop management. When used in conjunction with sensors and machine learning algorithms, resources can be used more efficiently, reducing waste and increasing production.
Agricultural network coverage: If you need to establish reliable network coverage in larger farms or rural areas, these processors can be used to build a robust wireless network infrastructure to ensure that all areas of the farm are connected to the Internet.
Data Analytics and decision support: These processors enable high-performance computing and can be used in data analytics and decision support systems to help farmers optimize decisions, such as planting, irrigation, fertilization, and pest control.
It is important to note that in addition to processors, appropriate sensors, communication devices, software platforms, and data analysis tools are needed to build a complete agricultural intelligence solution. In addition, considering that the farm environment can be challenging, such as adverse weather conditions and long-distance communication needs, it is also important to ensure the reliability and stability of the system.
We have a strong hardware design team, and experienced people know that the most difficult part of hardware design is RF circuit design, baseband, etc., while wallys team made 0 error to achieve signal integrity, such as frequency conversion of network card, from 2.4G to 900M, which is a technological breakthrough.
Clients: TIP,Facebook, Openwrt, etc
Email:sales@wallystech.com
WEB:https://www.wallystech.com/
