查看: 1119|回复: 27
[Allegro17.4以下] MPC948和IBS  6层电脑主板PCB文件共享
    终身成就奖社区居民忠实会员宣传大使奖优秀斑竹奖
    发表于 2023-10-12 15:24:51 | 显示全部楼层 |阅读模式
    REFDESCOMP_DEVICE_TYPESYM_NAME
    B1A_BAT3_BAT3-BAT3,6026A0018401A_BTY-10MM
    CR1A_LED_LED-BLUE,6011A0025601A_LED2-934E
    CR2A_DIODE_A_DIODE-5V,6011A0019601A_DIODE-0603
    CR3A_DIODE_A_DIODE-5V,6011A0019601A_DIODE-0603
    CR4A_DIODE_A_DIODE-5V,6011A0019601A_DIODE-0603
    CR5A_DIODE_A_DIODE-5V,6011A0019601A_DIODE-0603
    CR6A_LED_LED-GRN,60110GA0654TA_LED-0603
    CR7A_LED_LED-GRN,60110GA0654TA_LED-0603
    CR8A_LED_LED-GRN,60110GA0654TA_LED-0603
    CR9A_LED_LED-RED,6011A0001301A_LED-0603
    CR10A_LED_LED-GRN,60110GA0654TA_LED-0603
    CR11A_LED_LED-GRN,60110GA0654TA_LED-0603
    CR12A_LED_LED-GRN,60110GA0654TA_LED-0603
    CR13A_DIODE_A_DIODE-5V,6011A0019601A_DIODE-0603
    CR14A_LED_LED-GRN,60110GA0654TA_LED-0603
    CR15A_DIODE_A_DIODE-5V,6011A0019601A_DIODE-0603
    CR16A_DIODE_A_DIODE-5V,6011A0019601A_DIODE-0603
    CR17A_DIODE_A_DIODE-5V,6011A0019601A_DIODE-0603
    CR18A_LED_LED-GRN,60110GA0654TA_LED-0603
    CR19A_LED_LED-GRN,60110GA0654TA_LED-0603
    CR20A_LED_LED-GRN,60110GA0654TA_LED-0603
    CR21A_LED_LED-GRN,60110GA0654TA_LED-0603
    CR22A_LED_LED-GRN,60110GA0654TA_LED-0603
    CR23A_LED_LED-GRN,60110GA0654TA_LED-0603
    CR24A_LED_LED-RED,6011A0001301A_LED-0603
    CR25A_LED_LED-GRN,6011A0015101A_LED-71
    CR26A_LED_LED-RED,6011A0001301A_LED-0603
    CR27A_LED_LED-RED,6011A0001301A_LED-0603
    CR28A_LED_LED-RED,6011A0001301A_LED-0603
    D1A_DSOT23A_SOT23-BAV99,6011A000AA_SOT23FT
    D2A_DSOT23A_SOT23-BAV99,6011A000AA_SOT23FT
    D3A_DSOT23A_SOT23-BAV99,6011A000AA_SOT23FT
    D4A_DSOT23A_SOT23-BAV99,6011A000AA_SOT23FT
    D5A_DSOT23A_SOT23-BAV99,6011A000AA_SOT23FT
    D6A_DSOT23A_SOT23-BAV99,6011A000AA_SOT23FT
    D7A_DE4PAK_SOIC8-DE4PAK,60110GA0AA_SOIC8-50X208
    D8A_DSOT23A_SOT23-BAV99,6011A000AA_SOT23FT
    D9A_DSOT23A_SOT23-BAV99,6011A000AA_SOT23FT
    D11A_DIODE_DO-136-LS4148,6011A001AA_DO-136
    D13A_DIODE3_C_DIODE-6V,6011A00224AA_SOT23FT
    D14A_DIODE_SDO95A-40V,60110GA0632TA_DIODE-SDO95A
    D15A_DIODE_SDO95A-40V,60110GA0632TA_DIODE-SDO95A
    D16A_DIODE3_A_DIODE-100V,6011A001AA_SOT23FT
    D18A_DIODE_DO-136-LS4148,6011A001AA_DO-136
    D20A_DSHTKY_SM-20V,6011A0001901A_DO270-MBRS340
    D21A_DE4PAK_SOIC8-DE4PAK,60110GA0AA_SOIC8-50X208
    D22A_DIODE_DIODE-157-30V,6011B001AA_DIODE-157
    D23A_DIODE_DIODE-157-30V,6011B001AA_DIODE-157
    D24A_DIODE3_A_DIODE-100V,6011A001AA_SOT23FT
    D25A_DSOT23A_SOT23-BAV99,6011A000AA_SOT23FT
    D26A_DSOT23A_SOT23-BAV99,6011A000AA_SOT23FT
    D27A_DIODE_DO-136-LS4148,6011A001AA_DO-136
    D50A_DIODE_DO-136-LS4148,6011A001AA_DO-136
    D51A_DIODE_DO-136-LS4148,6011A001AA_DO-136
    J1A_COM_CN9-6012A0061401A_CN9-SERIAL
    J2A_VGACONN_VGA-6012A0060401A_CN15-DZ11AA2
    J3A_USBCONN_USBCONN-60120IA19150A_CN8-UB1112C
    J4A_2X6_5MP_CN12-2X6_5MP,6026A00AA_CN12-KM_A
    J5A_1X4_HD4-6012B0031801A_HD4-2P54MM
    J6A_1X25_3MP_CN25-6012A0061101A_CN25-PARALLEL_B
    J7A_RJ45LEDC_CN28-RJ45LEDC,6026AAA_CN28-RJ45LED2_C
    J8A_1X4_HD4-6012B0031801A_HD4-2P54MM
    J9A_PCIE8X_PCIE8X-6012A0100101A_CN98-2MM_FL
    J10A_TOOL1X1_1X1-ID-BATTP0-00A_BATTP
    J11A_PCI5V32B_A_CN124-6012A0046601A_CN124-PCI
    J12A_PCI5V32B_A_CN124-6012A0046601A_CN124-PCI
    J13A_PCI5V32B_A_CN124-6012A0046601A_CN124-PCI
    J14A_2X4_A_TH-6012B0037001A_CN8-165X217_A
    J15A_PCIE16X_PCIE16X-6012A0108002A_CN164-2MM_FL
    J16A_TEJAS_A_PGA775-TEJAS_A,6026AAA_SKTPGA775-1P17MM
    J17A_2X30_CN60-6012A0109001A_CN60-0P5MM_FL
    J18A_1X2_HD2-100-60120IA16990A_HD2-100
    J19A_2X7_B_CN14-6012B0037901A_CN14-100X100_D
    J20A_2X5_A_CN10-6012A0061301A_CN10-100X100_A
    J21A_2X5K10_A_CN10-6012A0061305A_CN10-100X100K10_A
    J22A_1X2_CN2-6012A0038902A_CN2-5P08MM
    J23A_DIMM240_DIMM240-DIMM240,6026AA_DIMM240
    J24A_DIMM240_DIMM240-DIMM240,6026AA_DIMM240
    J25A_DIMM240_DIMM240-DIMM240,6026AA_DIMM240
    J26A_DIMM240_DIMM240-DIMM240,6026AA_DIMM240
    J27A_2X5K9_TH-6012B0037301A_CN10_100X100_O9
    J28A_1X2_CN2-6012A0038902A_CN2-5P08MM
    J29A_1X2_HD2-79-6012A0074701A_HD2-79
    J30A_2X20_O20_CN40-6012A0037601A_CN40-100X100_O20
    J31A_2X17_CN34-6012A0045201A_CN34-2362705
    J34A_SATACONN_CN9-6012B0037601A_CN9-1P27MM
    J35A_SATACONN_CN9-6012B0037601A_CN9-1P27MM
    J36A_SATACONN_CN9-6012B0037601A_CN9-1P27MM
    J37A_SATACONN_CN9-6012B0037601A_CN9-1P27MM
    J38A_1X4_HD4-6012B0031801A_HD4-2P54MM
    J39A_2X5_A_CN10-6012A0061301A_CN10-100X100_A
    J40A_2X12_CN24-6012B0036501A_CN24-4P2MM
    J41A_2X15_K3K25K26_CN30-6012B0017AA_CN30-2P54MM_K3K25K26
    L1A_BEAD_BEAD-0603-600,6014B0009AA_BEAD-0603
    L2A_BEAD_BEAD-0603-600,6014B0009AA_BEAD-0603
    L3A_BEAD_BEAD-0603-600,6014B0009BA_BEAD-0603
    L4A_BEAD_BEAD-2012-60,6014B00098AA_BEAD-0603
    L5A_BEAD_BEAD-0603-600,6014B0009AA_BEAD-0603
    L6A_BEAD_BEAD-0603-600,6014B0009AA_BEAD-0603
    L7A_BEAD_BEAD-2012-60,6014B00098AA_BEAD-0603
    L8A_BEAD4_SM-90,6014A0018501A_BEAD4-1P5MM
    L9A_BEAD4_SM-90,6014A0018501A_BEAD4-1P5MM
    L10A_BEAD_BEAD-0603-600,6014B0009BA_BEAD-0603
    L11A_BEAD_BEAD-0603-600,6014B0009BA_BEAD-0603
    L12A_BEAD_BEAD-0603-600,6014B0009AA_BEAD-0603
    L13A_BEAD_BEAD-0603-600,6014B0009AA_BEAD-0603
    L14A_BEAD_BEAD-0603-600,6014B0009AA_BEAD-0603
    L15A_BEAD_BEAD-2012-60,6014B00098AA_BEAD-0603
    L16A_BEAD_BEAD-0603-600,6014B0009BA_BEAD-0603
    L17A_BEAD_BEAD-2012-60,6014B00098AA_BEAD-0603
    L18A_BEAD_BEAD-2012-60,6014B00098AA_BEAD-0603
    L19A_BEAD_BEAD-0603-600,6014B0009AA_BEAD-0603
    L20A_BEAD_BEAD-0603-600,6014B0009AA_BEAD-0603
    L21A_BEAD_BEAD-0805-2K,6014B00099AA_BEAD-0805
    L22A_BEAD_BEAD-0603-600,6014B0009BA_BEAD-0603
    L23A_BEAD_BEAD-0603-600,6014B0009BA_BEAD-0603
    L24A_BEAD_BEAD-0805-2K,6014B00099AA_BEAD-0805
    L25A_BEAD_BEAD-0603-600,6014B0009AA_BEAD-0603
    L26A_BEAD_BEAD-0603-600,6014B0009AA_BEAD-0603
    L27A_BEAD_BEAD-0805-2K,6014B00099AA_BEAD-0805
    L28A_BEAD_BEAD-0603-600,6014B0009AA_BEAD-0603
    L29A_INDUCT_INDUCT-0.5UH,6014B001AA_INDUCT_7P62MM_A
    L30A_BEAD_BEAD-0603-600,6014B0009AA_BEAD-0603
    L31A_BEAD_BEAD-0603-600,6014B0009AA_BEAD-0603
    L32A_BEAD_BEAD-0603-600,6014B0009AA_BEAD-0603
    L33A_INDUCT_INDUCT-0.5UH,6014B001AA_INDUCT_7P62MM_A
    L34A_INDUCT_INDUCT-2.2UH,6014A003AA_INDUCT_5P54MM
    L35A_INDUCT_INDUCT-1UH,6014B00104AA_INDUCT_6P5MM
    L36A_INDUCT_INDUCT-0.5UH,6014B001AA_INDUCT_7P62MM_A
    L37A_INDUCT_INDUCT-0.5UH,6014B001AA_INDUCT_7P62MM_A
    L38A_BEAD_BEAD-0603-600,6014B0009BA_BEAD-0603
    L39A_BEAD_BEAD-0603-600,6014B0009BA_BEAD-0603
    L40A_BEAD_BEAD-0603-600,6014B0009BA_BEAD-0603
    L41A_BEAD_BEAD-60,6014B0012301A_BEAD-0603
    L42A_BEAD_BEAD-1206-300,6014B0010AA_BEAD-1206
    L43A_BEAD_BEAD-0805-100,6014A0030AA_BEAD-0805
    L44A_BEAD_BEAD-1206-300,6014B0010AA_BEAD-1206
    L45A_BEAD_BEAD-0805-100,6014A0030AA_BEAD-0805
    L46A_BEAD4_SM-90,6014A0018501A_BEAD4-1P5MM
    L47A_BEAD4_SM-90,6014A0018501A_BEAD4-1P5MM
    L48A_BEAD_BEAD-0805-100,6014A0030AA_BEAD-0805
    L49A_INDUCT_INDUCT-0.5UH,6014B001AA_INDUCT_7P62MM_A
    L50A_BEAD_BEAD-0603-600,6014B0009BA_BEAD-0603
    L51A_INDUCT_INDUCT-1.0UH,6014B000AA_INDUCT-2P2MM_A
    L52A_INDUCT_INDUCT-1.0UH,6014B000AA_INDUCT-2P2MM_A
    L53A_BEAD_BEAD-0603-600,6014B0009BA_BEAD-0603
    L54A_BEAD_BEAD-60,6014B0012301A_BEAD-0603
    L55A_BEAD_BEAD-0805-100,6014A0030AA_BEAD-0805
    L56A_INDUCT_INDUCT-1UH,6014A00272AA_INDUCT_5P54MM
    L57A_INDUCT_INDUCT-1UH,6014A00272AA_INDUCT_5P54MM
    L58A_INDUCT_INDUCT-2.5UH,6014B001AA_INDUCT_5P5MM_A
    L59A_INDUCT_INDUCT-1UH,6014B00105AA_INDUCT_6P5MM
    L60A_BEAD_BEAD-0603-600,6014B0009AA_BEAD-0603
    L61A_BEAD_BEAD-0603-600,6014B0009AA_BEAD-0603
    L62A_BEAD_BEAD-0603-600,6014B0009AA_BEAD-0603
    L63A_BEAD_BEAD-0603-600,6014B0009AA_BEAD-0603
    L64A_BEAD_BEAD-0603-600,6014B0009AA_BEAD-0603
    L65A_BEAD_BEAD-0603-600,6014B0009AA_BEAD-0603
    L66A_BEAD_BEAD-0603-600,6014B0009AA_BEAD-0603
    L67A_BEAD_BEAD-2012-60,6014B00098AA_BEAD-0603
    L68A_BEAD_BEAD-2012-60,6014B00098AA_BEAD-0603
    L69A_BEAD_BEAD-2012-60,60140NE013AA_BEAD-2012
    L70A_BEAD_BEAD-0603-600,6014B0009AA_BEAD-0603
    L71A_BEAD_BEAD-0603-600,6014B0009AA_BEAD-0603
    L72A_BEAD_BEAD-0805-100,6014A0030AA_BEAD-0805
    L73A_INDUCT_INDUCT-10UH,6014A0037AA_INDUCT-130
    L74A_INDUCT_INDUCT-10UH,6014A0037AA_INDUCT-130
    L75A_BEAD_BEAD-0805-100,6014A0030AA_BEAD-0805
    L76A_BEAD_BEAD-0603-600,6014B0009AA_BEAD-0603
    L77A_BEAD_BEAD-0603-600,6014B0009AA_BEAD-0603
    L78A_BEAD_BEAD-0603-600,6014B0009AA_BEAD-0603
    L79A_BEAD_BEAD-0603-600,6014B0009AA_BEAD-0603
    L80A_BEAD_BEAD-0603-600,6014B0009AA_BEAD-0603
    L81A_BEAD_BEAD-0603-600,6014B0009AA_BEAD-0603
    L82A_BEAD_BEAD-0603-600,6014B0009AA_BEAD-0603
    L83A_BEAD_BEAD-0603-600,6014B0009AA_BEAD-0603
    L84A_BEAD_BEAD-0805-100,6014A0030AA_BEAD-0805
    LS1A_BUZZER_TH-40OHM,60390K004808A_BUZZER-256X480
    Q1A_PNP4_A_SM-40V,6015A0058201A_SOT223-90X248
    Q3A_NMFET_TO252-30V,6015B0003201A_TO252
    Q4A_NMFET_TO252-30V,6015B0003101A_TO252
    Q5A_NMFET_TO252-30V,6015B0003101A_TO252
    Q6A_NMFET_TO252-30V,6015B0003201A_TO252
    Q7A_NMFET_TO252-30V,6015B0003101A_TO252
    Q8A_NMFET_TO252-30V,6015B0003101A_TO252
    Q9A_NMFET_TO252-30V,6015B0003201A_TO252
    Q10A_NMFET_TO252-30V,6015B0003101A_TO252
    Q11A_NMFET_TO252-30V,6015B0003101A_TO252
    Q12A_NPN_SM-PMBT3904,6015B0007101A_SOT23FT
    Q13A_NMFET_TO252-30V,6015B0003201A_TO252
    Q14A_NMFET_TO252-30V,6015B0003101A_TO252
    Q15A_NMFET_TO252-30V,6015B0003101A_TO252
    Q16A_NPN_SM-PMBT3904,6015B0007101A_SOT23FT
    Q17A_NPN_SM-PMBT3904,6015B0007101A_SOT23FT
    Q18A_NPN_SM-PMBT3904,6015B0007101A_SOT23FT
    Q19A_NPN_SM-PMBT3904,6015B0007101A_SOT23FT
    Q20A_NPN_SM-PMBT3904,6015B0007101A_SOT23FT
    Q21A_NPN_SM-PMBT3904,6015B0007101A_SOT23FT
    Q22A_NPN_SM-PMBT3904,6015B0007101A_SOT23FT
    Q23A_NPN_SM-PMBT3904,6015B0007101A_SOT23FT
    Q24A_NPN_SM-PMBT3904,6015B0007101A_SOT23FT
    Q25A_NPN_SM-PMBT3904,6015B0007101A_SOT23FT
    Q26A_NPN_SM-PMBT3904,6015B0007101A_SOT23FT
    Q27A_NPN_SM-PMBT3904,6015B0007101A_SOT23FT
    Q28A_NPN_SM-PMBT3904,6015B0007101A_SOT23FT
    Q29A_NPN_SM-PMBT3904,6015B0007101A_SOT23FT
    Q30A_NMFET_A_SOT23FT-2N7002,6015BAA_SOT23FT
    Q31A_NPN_SM-PMBT3904,6015B0007101A_SOT23FT
    Q32A_NPN_SM-PMBT3904,6015B0007101A_SOT23FT
    Q33A_NPN_SM-PMBT3904,6015B0007101A_SOT23FT
    Q35A_NMFET_TO252-30V,6015B0003101A_TO252
    Q36A_NMFET_TO252-30V,6015B0003101A_TO252
    Q37A_NFET_SOT23FT-15V,6015B0008001A_SOT23FT
    Q38A_NMFET_TO252-30V,6015B0003101A_TO252
    Q39A_NFET_SOT23FT-15V,6015B0008001A_SOT23FT
    Q40A_NPN_SM-PMBT3904,6015B0007101A_SOT23FT
    Q41A_NMFET_TO252-30V,6015B0003101A_TO252
    Q42A_NMFET_TO252-FDD6690A,6015A00AA_TO252
    Q43A_NPN_SM-PMBT3904,6015B0007101A_SOT23FT
    Q44A_NPN_SM-PMBT3904,6015B0007101A_SOT23FT
    Q45A_NPN_SM-PMBT3904,6015B0007101A_SOT23FT
    Q46A_SI4501ADY_SO8-SI4542DY,6015AAA_SO8-50X208
    Q47A_PNP4_A_SM-40V,6015A0058201A_SOT223-90X248
    Q60A_NPN_SM-PMBT3904,6015A0065701A_SOT23FT
    Q61A_NPN_SM-PMBT3904,6015A0065701A_SOT23FT
    RP1A_SIP8_RS4N-1020-33,5%,1/16W,6AA_RS4N-1020
    RP24A_SIP8_RS4N-1020-2.7K,5%,1/16WAA_RS4N-1020
    RP25A_SIP8_RS4N-1020-2.7K,5%,1/16WAA_RS4N-1020
    SW1A_4SWPK_SWDIP8-4SWPK,60260IE03AA_SWDIP8-100X300
    TH1A_TO157_N1_TO159-ID-159TO-03A_159TOOL-SM2-CO-325
    TH2A_TO157_N1_TO159-ID-159TO-03A_159TOOL-SM2-CO-325
    TH3A_TO157_N1_TO159-ID-159TO-03A_159TOOL-SM2-CO-325
    TH4A_TO157_N1_TO157-ID-157TOOL-394A_157TOOL-SM2-394
    TH5A_TO157_N1_TO157-ID-157TOOL-394A_157TOOL-SM2-394
    TH6A_TO157_N1_TO157-ID-157TOOL-394A_157TOOL-SM2-394
    TH7A_TO157_N1_TO157-ID-157TOOL-394A_157TOOL-SM2-394
    TH8A_TO157_N1_TO159-ID-159TO-03A_159TOOL-SM2-CO-325
    TH9A_TO157_N1_TO159-ID-159TO-03A_159TOOL-SM2-CO-325
    TH10A_TO157_N1_TO159-ID-159TO-03A_159TOOL-SM2-CO-325
    TH11A_TO157_N1_TO159-ID-159TO-03A_159TOOL-SM2-CO-325
    TH12A_TO157_N1_TO159-ID-159TO-03A_159TOOL-SM2-CO-325
    TH13A_TO157_N1_TO159-ID-159TO-03A_159TOOL-SM2-CO-325
    U1A_AME1117_SOT223-AME1117,6019AAA_SOT223-90X248
    U4A_AT45DB011B_SOIC8-AT45DB011B,AA_SOIC8-50X284
    U7A_TSG08_SC70-NC7SZ08,6019B0048AA_SC70-0P65MMX1P9MM
    U8A_BCM5751_FPBGA100-BCM5751,601AA_FPBGA196_1MM
    U9A_RAGEXL_BGA272-RAGEXL,6019B00AA_BGA272
    U10A_24C256_SOIC8-24C256,6019A014AA_SOIC8-50X208
    U12A_DS75S_SOIC8-DS75S,6019A01094AA_SOIC8-50X208
    U13A_MAX211_SSOP28-MAX211,60190H1AA_SSOP28-25P6X275
    U14A_2MX32_TSOP86-2MX32,6019B0053AA_TSOP86-19P7X434
    U15A_TSG125_SC70-7SZ125,6019B0049AA_SC70-0P65MMX1P9MM
    U16A_PCA9511_TSSOP-PCA9511,6019A0AA_TSSOP8-25P6X166
    U17A_TSG125_SC70-7SZ125,6019B0049AA_SC70-0P65MMX1P9MM
    U19A_TSG08_SC70-NC7SZ08,6019B0048AA_SC70-0P65MMX1P9MM
    U20A_ISL6612_SO8-ISL6612,6019B007AA_SOIC8-50X208
    U21A_BCM5751_FPBGA100-BCM5751,601AA_FPBGA196_1MM
    U22A_AT45DB011B_SOIC8-AT45DB011B,AA_SOIC8-50X284
    U23A_ISL6612_SO8-ISL6612,6019B007AA_SOIC8-50X208
    U24A_ISL6561_MLFP-ISL6561,6019B00AMLFP40_6_50MA
    U25A_24C256_SOIC8-24C256,6019A014AA_SOIC8-50X208
    U26A_ISL6612_SO8-ISL6612,6019B007AA_SOIC8-50X208
    U27A_ISL6612_SO8-ISL6612,6019B007AA_SOIC8-50X208
    U28A_TPS54612_TSSOP-TPS54612,6019AA_SSOP28-25P6X224_TP
    U29A_MAX6640AEE_QSOP16-MAX6640AEEAA_QSOP16-25X208_C
    U30A_PCA9511_TSSOP-PCA9511,6019A0AA_TSSOP8-25P6X166
    U32A_TTL157_SOIC16-74VHC157,60190AA_SOIC16-50X208
    U33A_TTL07_TSSOP14-74LCX07,6019A0AA_TSSOP14-25P6X216
    U34A_24C256_SOIC8-24C256,6019A014AA_SOIC8-50X208
    U35A_L6910_SOIC16-L6910,6019A0175AA_SOIC16-50X208
    U36A_TTL00_SOIC14-74LCX00,60190H3AA_SOIC14-50X208
    U37A_TTL08_TSSOP14-74LCX08,6019A0AA_TSSOP14-25P6X216
    U38A_H8S2168_TQFP144-H8S2168,6019AA_TQFP144-0P4MM
    U39A_ICS954141_TSSOP56-ICS954141,BA_TSSOP56-197X284
    U40A_MAX211_SSOP28-MAX211,60190H1AA_SSOP28-25P6X275
    U42A_9DB104_SSOP28-9DB104,6019A01AA_SSOP28-25P6X275
    U43A_1587CM_19_TO-252-1587CM,6019AA_TO-252
    U44A_TSG08_SC70-NC7SZ08,6019A0251AA_SC70-0P65MMX1P9MM
    U45A_TSG08_SC70-NC7SZ08,6019A0251AA_SC70-0P65MMX1P9MM
    U46A_MMCH_DDR2_FCBGA1202-MMCH_DDRAA_FCBGA1202_TMP
    U47A_MIC5219_SOT23-MIC5255,6019B0AA_SOT23-5P
    U48A_DS75S_SOIC8-DS75S,6019A01094AA_SOIC8-50X208
    U49A_ICH7_BGA-ICH7,6019B0053401A_BGA961
    U50A_PCA9511_TSSOP-PCA9511,6019A0AA_TSSOP8-25P6X166
    U52A_SC1592_A_SOIC-SC1592,6019B00AA_SOICEDP8-50X208
    U53A_FWH_PLCC-FWH,6026A0011001A_PLCC32SK-50X520
    U54A_87366_PQFP128-87366,60190H40AA_PQFP128-197
    U55A_TPS54672_SSOP28-TPS54672,601AA_SSOP28-25P6X224_T
    U56A_L6910_SOIC16-L6910,6019A0175AA_SOIC16-50X208
    U57A_TSG14_SC70-NC7SZ14,6019B0048AA_SC70-0P65MMX1P9MM
    U58A_TSG14_SC70-SN74LVC,6019A0246AA_SC70-0P65MMX1P9MM
    U59A_TSG14_SC70-SN74LVC,6019A0246AA_SC70-0P65MMX1P9MM
    U60A_TSG14_SC70-NC7SZ14,6019B0048AA_SC70-0P65MMX1P9MM
    U61A_TSG14_SC70-SN74LVC,6019A0246AA_SC70-0P65MMX1P9MM
    U62A_TSG14_SC70-NC7SZ14,6019B0048AA_SC70-0P65MMX1P9MM
    U63A_TSG14_SC70-NC7SZ14,6019B0048AA_SC70-0P65MMX1P9MM
    U64A_TSG14_SC70-NC7SZ14,6019B0048AA_SC70-0P65MMX1P9MM
    U65A_EPM3128A_TQFP100P-EPM3128A,6AA_PQFP100-197
    U66A_TSG14_SC70-NC7SZ14,6019B0048AA_SC70-0P65MMX1P9MM
    U67A_TSG14_SC70-NC7SZ14,6019B0048AA_SC70-0P65MMX1P9MM
    U68A_TSG14_SC70-NC7SZ14,6019B0048AA_SC70-0P65MMX1P9MM
    U69A_TSG14_SC70-NC7SZ14,6019B0048AA_SC70-0P65MMX1P9MM
    U70A_TSG14_SC70-NC7SZ14,6019B0048AA_SC70-0P65MMX1P9MM
    U71A_TSG14_SC70-NC7SZ14,6019B0048AA_SC70-0P65MMX1P9MM
    U72A_TSG14_SC70-NC7SZ14,6019B0048AA_SC70-0P65MMX1P9MM
    U73A_ADM809_SOT23FT-ADM809,6019B0AA_SOT23FT
    U80A_TSG14_SC70-SN74LVC,6019A0246AA_SC70-0P65MMX1P9MM
    U81A_TSG14_SC70-SN74LVC,6019A0246AA_SC70-0P65MMX1P9MM
    U101A_BCM5721_PBGA-BCM5721,6019B00AA_PBGA196
    U243A_74CBT3257_TSSOP16-74CBT3257,AA_TSSOP16-25P6X224
    U244A_74CBT3257_TSSOP16-74CBT3257,AA_TSSOP16-25P6X224
    U248A_74CBT3257_TSSOP16-74CBT3257,AA_TSSOP16-25P6X224
    U249A_74CBT3257_TSSOP16-74CBT3257,AA_TSSOP16-25P6X224
    Y1A_XTAL_CRY-25M,6018A0015801A_XTAL-7MM_A
    Y2A_XTAL_CRY-25M,6018A0015801A_XTAL-7MM_A
    Y3A_XTAL_CRY-25MHZ,6018A0008401A_XTAL-7MM
    Y4A_SM_XTAL_SM-14.318MHZ,6018A00AA_OSC-MA406H
    Y5A_XTAL_CRY-32.768K,60180E03449TA_XTAL2-100
     楼主| 发表于 2023-10-12 15:27:55 | 显示全部楼层
    PCB文件共享。回复可见下载
    游客,如果您要查看本帖隐藏内容请回复
    头像被屏蔽
    禁止发言
    发表于 2023-10-12 17:17:06 | 显示全部楼层
    提示: 作者被禁止或删除 内容自动屏蔽
    终身成就奖社区居民忠实会员灌水天才奖新人进步奖幽默大师奖贴图大师奖优秀斑竹奖宣传大使奖金点子奖社区明星
    发表于 2023-10-12 17:19:57 | 显示全部楼层
  • 签到天数: 81 天
    发表于 2023-10-12 18:00:18 | 显示全部楼层
    4 天前
  • 签到天数: 115 天
    终身成就奖社区居民特殊贡献奖原创先锋奖
    发表于 2023-10-13 07:37:57 | 显示全部楼层
    3 小时前
  • 签到天数: 166 天
    终身成就奖特殊贡献奖原创先锋奖金点子奖优秀斑竹奖
    发表于 2023-10-17 19:19:05 | 显示全部楼层
  • 签到天数: 47 天
    发表于 2023-10-27 09:41:14 | 显示全部楼层
    前天 14:10
  • 签到天数: 136 天
    发表于 2023-10-31 08:14:00 | 显示全部楼层
  • 签到天数: 26 天
    终身成就奖社区居民优秀斑竹奖特殊贡献奖原创先锋奖
    发表于 2023-12-24 21:59:15 | 显示全部楼层
