REFDES | COMP_DEVICE_TYPE | COMP_VALUE | SYM_NAME |
D1 | DIODE_SCHTKY_SOD-323-A_IC_0.8MM_480-80163_PMEG4005EJ,115 | PMEG4005EJ,115 | SOD-323-A |
D2 | DIODE_SCHTKY_SOD-323-A_IC_0.8MM_480-80163_PMEG4005EJ,115 | PMEG4005EJ,115 | SOD-323-A |
D3 | DIODE_SCHTKY_SOD-323-A_IC_0.8MM_480-80163_PMEG4005EJ,115 | PMEG4005EJ,115 | SOD-323-A |
D4 | LED_LED_0603_IC_0.67MM_370-75622_LEDORANGE | LEDORANGE | LED_0603 |
D5 | LED_LED_0603_IC_0.67MM_370-75622_LEDORANGE | LEDORANGE | LED_0603 |
D6 | LED_LED_0603_IC_0.67MM_370-75622_LEDORANGE | LEDORANGE | LED_0603 |
D7 | DIODE_SCHTKY_SOD-128_IC_1.1MM_480-78943_PMEG4050EP | PMEG4050EP | SOD-128 |
D8 | LED_LED_0603_IC_0.80MM_370-76779_LEDRED | LEDRED | LED_0603 |
D9 | DIODE_BIDIR_SOD323_BID_IC_1.1MM_480-80372_PESD1IVN27-AX | PESD1IVN27-AX | SOD323_BID |
D10 | DIODE_SCHTKY_SOD-128_IC_1.1MM_480-78943_PMEG4050EP | PMEG4050EP | SOD-128 |
D11 | RCLAMP1654P_NEW_SLP1616P6_IC_0.65MM_480-78843_RCLAMP0854P.TCT | RClamp0854P.TCT | SLP1616P6 |
D12 | LED_TRI_COLOR_LED6_5X6MM_IC_2.6MM_370-76661_LED RED/GRN/BL | LEDRED/GRN/BL | LED6_5X6MM |
D13 | LED_LED_0603_IC_0.9MM_370-76460_LEDORANGE | LEDORANGE | LED_0603 |
D14 | LED_LED_0603_IC_0.80MM_370-76779_LEDRED | LEDRED | LED_0603 |
D15 | ZDIODE_SOD123_IC_1.35MM_480-76297_MMSZ8V2T1G | MMSZ8V2T1G | SOD123 |
D16 | DIODE_SCHTKY_SOD-128_IC_1.1MM_480-78943_PMEG4050EP | PMEG4050EP | SOD-128 |
F1 | FUSE_FUSE_3P1X1P5_DISCRETE_1.575MM_510-78294_0458003.DR | 0458003.DR | FUSE_3P1X1P5 |
GND1 | TEST_POINT_TP_TH_063_IC_5.6MM_210-30155_5006 | 5006 | TP_TH_063 |
J1 | CONN_HDR_2X1_HDR1X2_5P48X2P69_IO_8.69MM_210-80468_HDR1X2 | HDR1X2 | HDR1X2_5P48X2P69 |
J2 | CONN_HDR_1X1_TH_HDR_1X1_IO_8.59MM_210-81066_HDR1X1 | HDR1X1 | HDR_1X1 |
J3 | CONN_HDR_1X1_TH_HDR_1X1_IO_8.59MM_210-81066_HDR1X1 | HDR1X1 | HDR_1X1 |
J4 | CONN_HDR_1X1_TH_HDR_1X1_IO_8.59MM_210-81066_HDR1X1 | HDR1X1 | HDR_1X1 |
J5 | CONN_HDR_1X1_TH_HDR_1X1_IO_8.59MM_210-81066_HDR1X1 | HDR1X1 | HDR_1X1 |
J6 | CONN_HDR_1X1_TH_HDR_1X1_IO_8.59MM_210-81066_HDR1X1 | HDR1X1 | HDR_1X1 |
J7 | CONN_HDR_1X1_TH_HDR_1X1_IO_8.59MM_210-81066_HDR1X1 | HDR1X1 | HDR_1X1 |
J8 | CONN_HDR_4X1_HDR_1X4_SSW_TH_RA_IO_2.54MM_210-81411_CON_1X4 | CON_1X4 | HDR_1X4_SSW_TH_RA |
J9 | CONN_HDR_4X1_HDR_1X4_SSW_TH_RA_IO_2.54MM_210-81411_CON_1X4 | CON_1X4 | HDR_1X4_SSW_TH_RA |
J10 | CONN_HDR_3X1_HDR103_A_IO_8.74MM_210-80732_HDR1X3 | HDR1X3 | HDR103_A |
J11 | CONN_HDR_2X1_HDR1X2_5P48X2P69_IO_8.69MM_210-80468_HDR1X2 | HDR1X2 | HDR1X2_5P48X2P69 |
J12 | CONN_HDR_10X2_HDR210_ESQ_SKT_IO_16.38MM_210-81129_CON 2X10 | CON2X10 | HDR210_ESQ_SKT |
J13 | CONN_HDR_8X2_HDR208_ESQ_SKT_645H_IO_16.38MM_210-80918_CON_2X8 | CON_2X8 | HDR208_ESQ_SKT_645H |
J14 | CONN_HDR_10X2_HDR210_ESQ_SKT_IO_16.38MM_210-81129_CON 2X10 | CON2X10 | HDR210_ESQ_SKT |
J15 | CONN_HDR_3X1_HDR103_A_IO_8.74MM_210-80732_HDR1X3 | HDR1X3 | HDR103_A |
J16 | CONN_HDR_2X1_HDR1X2_5P48X2P69_IO_8.69MM_210-80468_HDR1X2 | HDR1X2 | HDR1X2_5P48X2P69 |
J17 | CONN_HDR_2X1_HDR1X2_5P48X2P69_IO_8.69MM_210-80468_HDR1X2 | HDR1X2 | HDR1X2_5P48X2P69 |
J18 | DC_POWER_JACK_SHD_CON3_PWR_JACK_TH_PJ051A_IO_7.5MM_210-79945_CONPWR 3 | CONPWR 3 | CON3_PWR_JACK_TH_PJ051A |
J19 | CONN_HDR_2X1_HDR1X2_5P48X2P69_IO_8.69MM_210-80468_HDR1X2 | HDR1X2 | HDR1X2_5P48X2P69 |
J20 | CONN_HDR_5X2_CON_2RH_10_50_IO_3.91MM_210-07961-00_HDR 2X5 | HDR2X5 | CON_2RH_10_50 |
J21 | CONN_HDR_1X1_TH_HDR_1X1_IO_8.59MM_210-81066_HDR1X1 | HDR1X1 | HDR_1X1 |
J22 | CONN_HDR_3X1_HDR103_A_IO_8.74MM_210-80732_HDR1X3 | HDR1X3 | HDR103_A |
J23 | CONN_HDR_3X1_HDR103_A_IO_8.74MM_210-80732_HDR1X3 | HDR1X3 | HDR103_A |
J24 | CONN_HDR_1X1_TH_HDR_1X1_IO_8.59MM_210-81066_HDR1X1 | HDR1X1 | HDR_1X1 |
J25 | CONN_HDR_2X1_HDR1X2_5P48X2P69_IO_8.69MM_210-80468_HDR1X2 | HDR1X2 | HDR1X2_5P48X2P69 |
J26 | CONN_HDR_3X1_HDR103_A_IO_8.74MM_210-80732_HDR1X3 | HDR1X3 | HDR103_A |
J27 | CONN_HDR_1X1_TH_HDR_1X1_IO_8.59MM_210-81066_HDR1X1 | HDR1X1 | HDR_1X1 |
J28 | CONN_HDR_1X1_TH_HDR_1X1_IO_8.59MM_210-81066_HDR1X1 | HDR1X1 | HDR_1X1 |
J29 | CONN_HDR_1X1_TH_HDR_1X1_IO_8.59MM_210-81066_HDR1X1 | HDR1X1 | HDR_1X1 |
J30 | CONN_HDR_2X1_HDR1X2_5P48X2P69_IO_8.69MM_210-80468_HDR1X2 | HDR1X2 | HDR1X2_5P48X2P69 |
J31 | CONN_HDR_2X1_HDR1X2_5P48X2P69_IO_8.69MM_210-80468_HDR1X2 | HDR1X2 | HDR1X2_5P48X2P69 |
J32 | HDR-1X4_JUMP1X4-6040_IO_8.4MM_210-75688_HDR_1X4 | HDR_1X4 | JUMP1X4-6040 |
J33 | CONN_HDR_2X1_HDR1X2_5P48X2P69_IO_8.69MM_210-80468_HDR1X2 | HDR1X2 | HDR1X2_5P48X2P69 |
J34 | CONN_HDR_2X1_HDR1X2_5P48X2P69_IO_8.69MM_210-80468_HDR1X2 | HDR1X2 | HDR1X2_5P48X2P69 |
J35 | CONN_HDR_1X1_TH_HDR_1X1_IO_8.59MM_210-81066_HDR1X1 | HDR1X1 | HDR_1X1 |
J36 | CONN_HDR_1X1_TH_HDR_1X1_IO_8.59MM_210-81066_HDR1X1 | HDR1X1 | HDR_1X1 |
J37 | CONN_HDR_2X1_HDR1X2_5P48X2P69_IO_8.69MM_210-80468_HDR1X2 | HDR1X2 | HDR1X2_5P48X2P69 |
J38 | CONN_HDR_8X2_HDR208_ESQ_SKT_645H_IO_16.38MM_210-80918_CON_2X8 | CON_2X8 | HDR208_ESQ_SKT_645H |
J39 | CONN_HDR_10X2_HDR210_ESQ_SKT_IO_16.38MM_210-81129_CON 2X10 | CON2X10 | HDR210_ESQ_SKT |
J40 | CONN_HDR_8X2_HDR208_ESQ_SKT_645H_IO_16.38MM_210-80918_CON_2X8 | CON_2X8 | HDR208_ESQ_SKT_645H |
J41 | USB_MINI_AB_RECEPTACLE_CON5_MICROUSB_IO_2.65MM_211-78722_MICROUSB AB 5 | MICROUSB AB 5 | CON5_MICROUSB |
J42 | CONN_HDR_5X2_CON_2RH_10_50_IO_3.91MM_210-07961-00_HDR 2X5 | HDR2X5 | CON_2RH_10_50 |
J43 | CONN_HDR_1X1_TH_HDR_1X1_IO_8.59MM_210-81066_HDR1X1 | HDR1X1 | HDR_1X1 |
J44 | CONN_HDR_1X1_TH_HDR_1X1_IO_8.59MM_210-81066_HDR1X1 | HDR1X1 | HDR_1X1 |
JASC1 | TEST_POINT_TP_TH_063_IC_5.6MM_210-30155_5006 | 5006 | TP_TH_063 |
L1 | INDUCTOR_IND_4_5P5X5P2_DISCRETE_3MM_180-81085_22UH | 22uH | IND_4_5P5X5P2 |
L2 | INDUCTOR_IND_1210_DISCRETE_2.4MM_180-81087_1UH | 1uH | IND_1210 |
L3 | INDUCTOR_IND_4_5P5X5P2_DISCRETE_3MM_180-81085_22UH | 22uH | IND_4_5P5X5P2 |
L4 | IND_FERRITE_IND_0603_DISCRETE_0.75MM_180-78352_BLM18KG121TZ1_25% | BLM18KG121TZ1 | IND_0603 |
Q1 | NPN_SOT23_A_IC_1.1MM_480-79881_BC846B | BC846B | SOT23_A |
Q2 | NPN_SOT23_A_IC_1.1MM_480-79881_BC846B | BC846B | SOT23_A |
Q3 | TRAN_NPN_SOT223_SOT223_IC_1.8MM_480-79956_BCP56-16TX | BCP56-16TX | SOT223 |
Q4 | NPN_SC_75_IC_0.9MM_480-80562_2SC4738-GR,LF | 2SC4738-GR,LF | SC_75 |
Q5 | NPN_SC_75_IC_0.9MM_480-80562_2SC4738-GR,LF | 2SC4738-GR,LF | SC_75 |
Q6 | NPN_SC_75_IC_0.9MM_480-80562_2SC4738-GR,LF | 2SC4738-GR,LF | SC_75 |
Q7 | NPN_SOT23_A_IC_1.1MM_480-80155_BC847B | BC847B | SOT23_A |
Q8 | NPN_SOT23_A_IC_1.1MM_480-80155_BC847B | BC847B | SOT23_A |
Q9 | PNP_SOT23_A_IC_1.1MM_480-79950_BC857B | BC857B | SOT23_A |
Q10 | PNP_SOT23_A_IC_1.1MM_480-79950_BC857B | BC857B | SOT23_A |
SW1 | SW3_SPDT_SLD_TH_SW3_SLD_SPDT_RA_IC_6.85MM_510-77905_500SSP3S1M6QEA | 500SSP3S1M6QEA | SW3_SLD_SPDT_RA |
SW2 | ELECTRODE_ELECTRODE_SQ_15MM_IC_0MM_510-76938_ELECTRODE | Electrode | ELECTRODE_SQ_15MM |
SW3 | ELECTRODE_ELECTRODE_SQ_15MM_IC_0MM_510-76938_ELECTRODE | Electrode | ELECTRODE_SQ_15MM |
SW4 | SW_PB_4P_SW4_6X6MM_TH_IC_7.7MM_510-78028_1825967-2 | 1825967-2 | SW4_6X6MM_TH |
SW5 | SW_PB_4P_SW4_6X6MM_TH_IC_7.7MM_510-78028_1825967-2 | 1825967-2 | SW4_6X6MM_TH |
SW6 | SW_PB_4P_SW4_6X6MM_TH_IC_7.7MM_510-78028_1825967-2 | 1825967-2 | SW4_6X6MM_TH |
U1 | LM2655_TSSOP16_TSSOP16_IC_1.2MM_315-83816_LM2655MTCX-3.3/NOPB | LM2655MTCX-3.3/NOPB | TSSOP16 |
U2 | DIODEZ_SOT23_SOT23_A_IC_1.1MM_480-79638_BZX84-A5V6 | BZX84-A5V6 | SOT23_A |
U3 | DIODEZ_SOT23_SOT23_A_IC_1.1MM_480-79638_BZX84-A5V6 | BZX84-A5V6 | SOT23_A |
U4 | S32K311_100MAXQFP_MQFP100_0P65_10X10_IC_1.75MM_TMP-CIP-10802_S32K311_100MAXQFP | S32K311_100MAXQFP | MQFP100_0P65_10X10 |
U5 | PFS2320AMBEP_QFN48_PQFN48_7X7_0P5MM_IC_1MM_315-83150_PFS2320AMBEP | PFS2320AMBEP | PQFN48_7X7_0P5MM |
U6 | ESD_DIODE_2LINE_SOT23_A_IC_1.1MM_480-80426_PESD2CANFD24L-TR | PESD2CANFD24L-TR | SOT23_A |
U7 | DIODEZ_SOT23_SOT23_A_IC_1.1MM_480-79638_BZX84-A5V6 | BZX84-A5V6 | SOT23_A |
U8 | NTS0102_XSON8_0P5_3P1X2P1_IC_0.5MM_312-82318_NTS0102GD | NTS0102GD | XSON8_0P5_3P1X2P1 |
U9 | NTS0102_XSON8_0P5_3P1X2P1_IC_0.5MM_312-82318_NTS0102GD | NTS0102GD | XSON8_0P5_3P1X2P1 |
U10 | 74LVCH1T45_6P_SOT-363_0P65_SMT_IC_1.1MM_312-81277_74LVC1T45GW,125 | 74LVC1T45GW,125 | SOT-363_0P65_SMT |
U11 | MK26FN2M0VMI18_BGA_169P_BGA169_0P65_9X9_IC_1.33MM_344-02189_MK26FN2M0VMI18 | MK26FN2M0VMI18 | BGA169_0P65_9X9 |
U12 | 74LVCH1T45_6P_SOT-363_0P65_SMT_IC_1.1MM_312-81277_74LVC1T45GW,125 | 74LVC1T45GW,125 | SOT-363_0P65_SMT |
U13 | 74LVCH1T45_6P_SOT-363_0P65_SMT_IC_1.1MM_312-81277_74LVC1T45GW,125 | 74LVC1T45GW,125 | SOT-363_0P65_SMT |
U14 | DIODEZ_SOT23_SOT23_A_IC_1.1MM_480-79638_BZX84-A5V6 | BZX84-A5V6 | SOT23_A |
U15 | 74LVCH1T45_6P_SOT-363_0P65_SMT_IC_1.1MM_312-81277_74LVC1T45GW,125 | 74LVC1T45GW,125 | SOT-363_0P65_SMT |
U16 | MIC2005-0.8YM6_SOT23-6_A_IC_1.45MM_315-79199_MIC2005-0.8YM6 | MIC2005-0.8YM6 | SOT23-6_A |
U17 | DIODEZ_SOT23_SOT23_A_IC_1.1MM_480-79638_BZX84-A5V6 | BZX84-A5V6 | SOT23_A |
U18 | DIODEZ_SOT23_SOT23_A_IC_1.1MM_480-79638_BZX84-A5V6 | BZX84-A5V6 | SOT23_A |
U19 | DIODEZ_SOT23_SOT23_A_IC_1.1MM_480-79638_BZX84-A5V6 | BZX84-A5V6 | SOT23_A |
U20 | LM4040_SOT23_SOT23-3_IC_1.13MM_315-80874_LM4040C30IDBZR | LM4040C30IDBZR | SOT23-3 |
Y1 | XTAL_XTAL2_4_5P2X3P4_IC_1.5MM_230-78523_16MHZ | 16MHz | XTAL2_4_5P2X3P4 |
Y2 | XTAL_XTAL2_4_5P2X3P4_IC_1.5MM_230-78523_16MHZ | 16MHz | XTAL2_4_5P2X3P4 |
