查看: 2123|回复: 44
[Allegro17.4以下] ATSAM3X8CA-AU +LCMXO2-1200HC-4TG100I-TR 做的PCB文件共享
    终身成就奖社区居民忠实会员宣传大使奖优秀斑竹奖
    发表于 2023-12-11 17:15:02 | 显示全部楼层 |阅读模式
    重要提示:PCB作品文件展下载说明
    ATSAM3X8CA.zip (9.19 MB, 下载次数: 0)
    D1TRANSIL_D_SMB_DO-214AA_SM6T15ASM6T15AD_SMB_DO-214AA
    F1TPS25200_U_SON6_SPWSONN6_TPS252TPS25200U_SON6_SPWSONN6
    FE1CEWKA_IND0603_T-0_8MM_BLM18KG70BLM18KG700TN1IND0603_T-0_8MM
    FE2DLP11SA_FE_0504-4_DLP11SN900HL2DLP11SN900HL2LFE_0504-4
    FE3CEWKA_IND0603_T-0_8MM_BLM18KG70BLM18KG700TN1IND0603_T-0_8MM
    FE4CEWKA_IND0603_T-0_8MM_BLM18KG70BLM18KG700TN1IND0603_T-0_8MM
    FE5CEWKA_IND0603_T-0_8MM_BLM18KG70BLM18KG700TN1IND0603_T-0_8MM
    FE6CEWKA_IND0603_T-0_8MM_BLM18KG70BLM18KG700TN1IND0603_T-0_8MM
    FE7SRF1105-301Y_PL2842_FE_SRF0502-SRF0502-101YFE_SRF0502-101Y
    FE8CEWKA_IND0603_T-0_8MM_BLM18KG70BLM18KG700TN1IND0603_T-0_8MM
    J2MICRO_SD_J_TF-9F01_TF-9F01TF-9F01J_TF-9F01
    J3HEADER10X2_J_15-91-2200_MOLEX_15-91-2200(Molex)J_15-91-2200_MOLEX
    J5TERMINAL_BLOCK_2PIN_J_TE-796644TE-796644-2J_TE-796644-2
    J10MICRO_USB_J_C-MUB5A-02XXB304_C-C-MUB5A-02XXB304J_C-MUB5A-02XXB304
    J111X4PIN_J_RSM1-04-SG-SMT-A_124111241150-4J_RSM1-04-SG-SMT-A
    J121X4PIN_J_RSM1-04-SG-SMT-A_124111241150-4J_RSM1-04-SG-SMT-A
    J14CON20A_J_FSI-110-X-D-M-PCB-MATICON20AJ_FSI-110-X-D-M-PCB-MATING
    J15PCMCIA-68P_J_PCMCIA_G659EU1_G65G659RS681X82EUJ_PCMCIA_G659EU1
    L1CEWKA_IND_PIHA06030_MWSA0603-3RMWSA0603-3R3MTIND_PIHA06030
    L2CEWKA_IND_SWPA4020_SWPA4020S2R2SWPA4020S2R2NTIND_SWPA4020
    LED1LED_RED_LED_0402_Q282R4-GQ282R4-GLED_0402
    LED2LED_GREEN_LED_0402_Q282YG4-GQ282YG4-GLED_0402
    LED3LED_GREEN_LED_0402_Q282YG4-GQ282YG4-GLED_0402
    OR1OR_OR_1_6MM-SOLDER_OROROR_1_6MM-SOLDER
    OR2OR_SQUARE_TOP_1_6MM_OR_SQUARE_TOROR_SQUARE_TOP_1_6MM
    P1DB9_J_DSUB9_RA_THT_A-DF09 A/KGA-DF09 A/KG-T2SJ_DSUB9_RA_THT
    Q2CRYSTAL4_PINS_V2_Q_3_2X2_5X0_7CX3225GB12000D0Q_3_2X2_5X0_75MM_ASX3F
    U1ATSAM3X8CA-AU_U_QFP50P1600X1600ATSAM3X8CA-AUU_QFP50P1600X1600X160-100N
    U2MAX232DR_U_SOIC_R-PDSO-G16_MAX2MAX232DRU_SOIC_R-PDSO-G16
    U3TLV809K33_U_SOT23_CAT803TTBICAT803TTBIU_SOT23
    U4TPD4E001DBV_U_SOT23-6L_TPD4E001TPD4E001DBVU_SOT23-6L
    U5TPD4E001DBV_U_SOT23-6L_TPD4E001TPD4E001DBVU_SOT23-6L
    U6SN74LVC245A_U_PVQFN20_4_5X3_5MMSN74LVC245ARGYRU_PVQFN20_4_5X3_5MM
    U7LCMXO2-1200HC-4TG100I_U_QFP50P1LCMXO2-1200HC-4TG100I-TRU_QFP50P1600X1600X160-100N
    U8SN74LVC245A_U_PVQFN20_4_5X3_5MMSN74LVC245ARGYRU_PVQFN20_4_5X3_5MM
    U9SN74LVC245A_U_PVQFN20_4_5X3_5MMSN74LVC245ARGYRU_PVQFN20_4_5X3_5MM
    U10TPS54427_U_S-PVSON-N10_TPS54427TPS54427DRCU_S-PVSON-N10
    U11TLV62568_U_SOT23-6L_TLV62568DBVTLV62568DBVU_SOT23-6L
    U12TPD4E001DBV_U_SOT23-6L_TPD4E001TPD4E001DBVU_SOT23-6L
    U13TPD4E001DBV_U_SOT23-6L_TPD4E001TPD4E001DBVU_SOT23-6L
    U14TPD4E001DBV_U_SOT23-6L_TPD4E001TPD4E001DBVU_SOT23-6L
    U15TPD4E001DBV_U_SOT23-6L_TPD4E001TPD4E001DBVU_SOT23-6L
    重要提示:PCB作品文件展下载说明
    发表于 2023-12-11 18:41:13 | 显示全部楼层
    6 小时前
  • 签到天数: 201 天
    发表于 2023-12-11 19:53:51 | 显示全部楼层
    10 小时前
  • 签到天数: 233 天
    发表于 2023-12-11 19:57:51 | 显示全部楼层
    2 小时前
  • 签到天数: 228 天
    1元学习PADS(3期)
    社区居民终身成就奖特殊贡献奖原创先锋奖
    发表于 2023-12-12 00:03:00 | 显示全部楼层
    发表于 2023-12-12 04:49:12 | 显示全部楼层
    发表于 2023-12-12 06:31:43 | 显示全部楼层
  • 签到天数: 53 天
    发表于 2023-12-12 07:23:02 | 显示全部楼层
    9 小时前
  • 签到天数: 147 天
    发表于 2023-12-12 08:09:30 | 显示全部楼层
  • 签到天数: 15 天
    PADS20210616高级班(留级)
    发表于 2023-12-12 08:30:13 | 显示全部楼层
    芯片为什么45度放置?
