TA的每日心情 | 开心 2024-7-10 20:37 |
签到天数: 1 天 [LV.1]初来乍到
- 20876
Name | Part Type | PCB Decal | Value | C508 | CAP_22UF_20%_6.3V_X5R_0603 | C0603 | 10uF/0603/10V | C511 | SC0402 | SC0402 | 1uF | C512 | SC0402 | SC0402 | 1uF | C513 | CTAN | C_TAN1 | 22uF/6V | C514 | SC0603 | SC0603 | 0.1uF | C515 | SC0402 | SC0402 | 1uF | C516 | CAP_0805 | 0805C | 10uF,16V | C517 | SC0402 | SC0402 | 47pF | C520 | SC0402 | SC0402 | 1uF | C535 | SC0402 | SC0402 | 33nF | C536 | SC0402 | SC0402 | 10nF | C539 | CTAN | C_TAN1 | 22uF/6V | C540 | SC0402 | SC0402 | 100nF | C541 | SC0402 | SC0402 | 100nF | C542 | SC0402 | SC0402 | 33nF | C543 | SC0402 | SC0402 | 47pF | C546 | SC0402 | SC0402 | 1uF | C552 | CAP_0805 | 0805C | 47uF | C553 | CAP_0603 | 0603_A | 100nF | C554 | CAP_0603 | 0603_A | 100pF | C555 | CAP_0603 | 0603_A | 10uF | C556 | CAP_0603 | 0603_A | 10uF | C570 | SC0805 | SC0805 | 22UF | C571 | SC0805 | SC0805 | 22UF | C577 | SC0402 | SC0402 | 0.1uF | C941 | SC0402 | SC0402 | 100nF | D1 | ESD5601W | ESD5601W | ESD5601W | D2 | ESD5641D07 | ESD5641D07 | ESD5641D07 | D3 | LED | LED_T | LED | D4 | ESD5641D07 | ESD5641D07 | ESD5641D07 | D5 | ESD5601W | ESD5601W | ESD5601W | D6 | LED | LED_T | LED | D7 | LED | LED_T | LED | D8 | LED | LED_T | LED | D202 | ZC2800E/SOT_0 | SOD-323 | NCZC2800E/SOT | J1 | MINI_USB_0 | UAF95-05254 | MINI_USB | J2 | SIM_CONNECTOR_0 | SIM3-CON-QFC | SM-030-L00 | J4 | HEADER_50 | HEADER25X2 | SFM-125-02-S-D-A | J5 | MICRO-SIM-PUSH-C-2174803 | MICRO-SIM-PUSH-C-2174803 | A15S03006A16 | J6 | HEADER_50 | HEADER25X2 | SFM-125-02-S-D-A | J8 | COAX_PWR_CON | DC_SOCKET | MAIN POWER | J13 | POWER_2P | POWER_2P_B | | JP1 | JUMPER_MUX | SIP-3P | | JP4 | JUMPER_MUX | SIP-3P | | Q2 | FET-N_SOT-523 | SOT-523 | | Q3 | TRIODE-PNP-SOT89 | SOT089 | NF | RT | SR0402-RT | SR0402 | SDNT_0402 | RT1 | SR0402-RT | SR0402 | NCP15WB473J03RC | SW601 | SW_10X8 | SW-J | SW PUSHBUTTON | SW602 | SW_10X8 | SW-J | SW PUSHBUTTON | TP2 | TP | TP0.5 | TP | TP4 | NCP334FCT2G | NCP334 | | TP15 | TESTPORT | TESTPAD15 | | TP56 | TP | TP0.5 | TP | TP_X26 | TESTPIONT_60 | TESTPOINT_60 | | U1 | PHASE_SHIFTER_BETA_0 | SMA_5P_A | SMA_5P_3.5 | U2 | SIP_2 | SIP_2P | | U3 | SN74AVC4T245 | TVSOP16 | SN74AVC4T245 | U4 | SIP_1 | SIP_1P | | U5 | SN74AVC4T245 | TVSOP16 | SN74AVC4T245 | U6 | LDO_SGM2007 | LDO_SGM2007 | SGM2007 | U7 | LDO_SGM2007 | LDO_SGM2007 | SGM2007 | U8 | SIP_2 | SIP_2P | | U9 | SIP_2 | SIP_2P | | U10 | LDO_LM1084 | LDO_LM1084_TO263 | LM1084 | U11 | SIP_2 | SIP_2P | | U12 | SIP_2 | SIP_2P | | U13 | FT2232_(_RS232_PINOUT_) | LQFP48 | FT2232 ( RS232 PINOUT ) | U14 | LT1117CST-ADJ | SOT223 | LT1117CST-ADJ | U15 | SIP_2 | SIP_2P | | U16 | SIP_2 | SIP_2P | | U17 | SIP_2 | SIP_2P | | U18 | SIP_2 | SIP_2P | | U19 | SN74AVC4T245 | TVSOP16 | SN74AVC4T245 | U20 | SIP_2 | SIP_2P | | U21 | SIP_2 | SIP_2P | | U22 | SIP_2 | SIP_2P | | U23 | RDA8908A-U01 | RDA8908A | RDA8908A | U24 | SIP_2 | SIP_2P | | U26 | SIP_2 | SIP_2P | | U27 | SIP_2 | SIP_2P | | U28 | SIP_2 | SIP_2P | | U29 | RDASW61 | RDASW61 | | U46 | SIP_1 | SIP_1P | | U55 | MINI_USB_0 | UAF95-05254 | MIC_USB | U98 | SIP_2 | SIP_2P | | U401 | DEA160960LT-5044C1 | DEA160960LT-5044C1_LB | | U402 | DEA161990LT-1182A8 | DEA161990LT-1182A8_HB | | U409 | RDA6821_0 | RPM6569 | RPM6569 | U412 | PHASE_SHIFTER_BETA_0 | SMA_5P_A | SMA_5P_3.5 | U425 | LM3241 | LM3241 | | X2 | DSX211SH | TCXO_2016 | 26MHZ(7.3pF) | X32 | 9H03200012 | CRYSTAL-32.768K-2012 | 32.768KHz | Y6 | CRYSTAL | XTAL/HC49US | 6MHz CRYSTAL |
