TA的每日心情 | 开心 2024-7-10 20:37 |
签到天数: 1 天 [LV.1]初来乍到
- 20876
REFDES | COMP_DEVICE_TYPE | COMP_VALUE | SYM_NAME | D1 | SOT23 | SCHOKITTY-041-70V | SOT23 | D2 | SOT23 | D2-3_D | SOT23 | D3 | HSD0603-LED | LED | HSD0603-LED | D4 | MLF10B-050-0301L | NONE | MLF10B-050-0301L | D5 | HSOD523 | DZ_A | HSOD523 | D6 | MLF10B-050-0301L | NONE | MLF10B-050-0301L | D7 | SD1107S | D_A | SD1107S | D9 | MLF10B-050-0301L | NONE | MLF10B-050-0301L | D10 | MLF10B-050-0301L | NONE | MLF10B-050-0301L | D13 | MLF10B-050-0301L | NONE | MLF10B-050-0301L | D15 | MLF10B-050-0301L | NONE | MLF10B-050-0301L | D17 | SOT23 | NONE | SOT23 | D18 | SOT23 | NONE | SOT23 | D21 | MLF10B-050-0301L | NONE | MLF10B-050-0301L | D23 | MLF10B-050-0301L | NONE | MLF10B-050-0301L | D25 | SOT23 | NONE | SOT23 | D27 | HSOT363-A | NONE | HSOT363-A | D29 | SD0503A | D_A | SD0503A | D30 | SD0503A | D_A | SD0503A | D31 | SD0503A | D_A | SD0503A | D32 | SD1107S | D_A | SD1107S | D33 | SOP8-50-173 | SLVU28_4 | SOP8-50-173 | D34 | SOP8-50-173 | SLVU28_4 | SOP8-50-173 | D35 | SD1710A | NONE | SD1710A | D40 | SOP8-50-173 | SLVU28_4 | SOP8-50-173 | D41 | SD2211 | D_A | SD2211 | D43 | SOP8-50-173 | SLVU28_4 | SOP8-50-173 | F1 | SF6127 | NONE | SF6127 | F3 | SF2-0302A | NONE | SF2-0302A | ICT1 | HOLE125 | NONE | HOLE125 | ICT2 | HOLE125 | NONE | HOLE125 | ID1 | ID-BOARD | NONE | ID-BOARD | ID2 | ID-BOARD | NONE | ID-BOARD | ID3 | ID-BOARD | NONE | ID-BOARD | J1 | CARD75-2207 | NONE | CARD75-2207 | J2 | CARD75-2206A | NONE | CARD75-2206A | J3 | HSDC10-1614B | NONE | HSDC10-1614B | J4 | RUSB24-050-1009 | NONE | RUSB24-050-1009 | J5 | RUSB18-200-1524A | NONE | RUSB18-200-1524A | J6 | RUSB19-050-1512 | NONE | RUSB19-050-1512 | J7 | RUSB19-050-1512 | NONE | RUSB19-050-1512 | J8 | RWBC0104-98T-A | NONE | RWBC0104-98T-A | J9 | RPWC0103-RM-C | NONE | RPWC0103-RM-C | J10 | FPC51-24E | NONE | FPC51-24E | J11 | SHEAD0220-100-100T-C | NONE | SHEAD0220-100-100T-C | J16 | SDIM02161-20B | NONE | SDIM02161-20B | J17 | RMJ2-0201SRL | NONE | RMJ2-0201SRL | L1 | SL0806A | 2.2uH | SL0806A | L2 | SL0806A | 2.2uH | SL0806A | L3 | SL1008H | 1uH | SL1008H | L4 | SPL0707N | 470n | SPL0707N | L5 | SPL0404L | 2.2uH | SPL0404L | L6 | SPL0302E | 4.7uH | SPL0302E | L7 | SPL0302E | 4.7uH* | SPL0302E | LB1 | SL0402C | NONE | SL0402C | LB2 | SL0402C | NONE | SL0402C | LB3 | SL0402C | NONE | SL0402C | LB4 | SL0402C | NONE | SL0402C | LB5 | SL0402C | NONE | SL0402C | LB6 | SL0402C | NONE | SL0402C | LB7 | SL0402C | NONE | SL0402C | LB8 | SL0402C | NONE | SL0402C | LB9 | SL0402C | NONE | SL0402C | LB10 | SL0402C | NONE | SL0402C | LB11 | SL0402C | NONE | SL0402C | LB12 | SL0402C | NONE | SL0402C | LB13 | SL0402C | NONE | SL0402C | LB14 | SL0402C | NONE | SL0402C | LB15 | SL0402C | NONE | SL0402C | LB16 | SL0402C | NONE | SL0402C | LB17 | SL0402C | NONE | SL0402C | LB18 | SL0805 | NONE | SL0805 | LB19 | SL0805 | * | SL0805 | LB20 | SL0402C | * | SL0402C | LED1 | SDA4-0606 | NONE | SDA4-0606 | LED3 | SDA4-0606 | NONE | SDA4-0606 | LED4 | SDA4-0606 | NONE | SDA4-0606 | M1 | RHOLE189-254 | NONE | RHOLE189-254 | M2 | RHOLE189-254 | NONE | RHOLE189-254 | M3 | RHOLE189-254 | NONE | RHOLE189-254 | M4 | RHOLE189-254 | NONE | RHOLE189-254 | M5 | HOLE138-M3 | NONE | HOLE138-M3 | M6 | HOLE138-M3 | NONE | HOLE138-M3 | M7 | HOLE138-M3 | NONE | HOLE138-M3 | M8 | HOLE138-M3 | NONE | HOLE138-M3 | M9 | HOLE177 | NONE | HOLE177 | M10 | RHOLE168-T244B188 | NONE | RHOLE168-T244B188 | M11 | RHOLE168-T244B188 | NONE | RHOLE168-T244B188 | M12 | RHOLE168-T244B188 | NONE | RHOLE168-T244B188 | MIC1 | SBEEP3-0302 | NONE | SBEEP3-0302 | OSC1 | SX4-0302Q | 50MHz* | SX4-0302Q | Q1 | SOT523-3A | FETN-GSD | SOT523-3A | Q2 | SOT23-3 | PMOS-GSD | SOT23-3 | Q3 | SOT23-3 | PMOS-GSD | SOT23-3 | Q4 | SOT23 | NPN-BEC | SOT23 | Q5 | SOT23 | NPN-BEC | SOT23 | Q6 | SOT523-3A | FETN-GSD | SOT523-3A | Q8 | SOT23 | NPN-BEC | SOT23 | Q10 | SOT23 | NPN-BEC | SOT23 | Q11 | RF8-NXP-PSMN1R0 | MOS_SGD | RF8-NXP-PSMN1R0 | Q12 | SOT23 | NPN-BEC | SOT23 | Q13 | SOT23 | NPN-BEC | SOT23 | Q14 | SOT23 | NPN-BEC | SOT23 | Q15 | SOT23 | NPN-BEC | SOT23 | Q16 | SOT23 | NPN-BEC | SOT23 | T5 | SL4-0102 | -99.999999H* | SL4-0102 | T6 | SL4-0102 | -99.999999H* | SL4-0102 | T7 | SL4-0102 | -99.999999H* | SL4-0102 | T8 | SL4-0102 | -99.999999H* | SL4-0102 | T9 | SL4-0102 | -99.999999H* | SL4-0102 | T10 | SL4-0102 | -99.999999H* | SL4-0102 | T19 | STFM24-40-280 | NONE | STFM24-40-280 | T20 | STFM24-40-280 | NONE | STFM24-40-280 | T21 | SL4-0102 | -99.999999H | SL4-0102 | TP8 | TP2-50-5MIL | NONE | TP2-50-5MIL | TP9 | TP2-50-5MIL | NONE | TP2-50-5MIL | U1 | MLF48A-040-0606L | NONE | MLF48A-040-0606L | U2 | MLF48A-040-0606L | NONE | MLF48A-040-0606L | U3 | SOT23-6A | SRV05-4 | SOT23-6A | U4 | SOT23-6A | SRV05-4 | SOT23-6A | U5 | MLF20A-050-0503L | NONE | MLF20A-050-0503L | U6 | SOT23-6A | SRV05-4 | SOT23-6A | U7 | SOP8-50-154C | NONE | SOP8-50-154C | U8 | MLF6C-065-0202L | NONE | MLF6C-065-0202L | U9 | MLF6C-065-0202L | NONE | MLF6C-065-0202L | U10 | MLF48T-050-0707L | NONE | MLF48T-050-0707L | U11 | SBAT2-1512 | NONE | SBAT2-1512 | U12 | SOP10-20-118 | NONE | SOP10-20-118 | U13 | MLF14A-050-0404L | NONE | MLF14A-050-0404L | U14 | SOT666-6A | NONE | SOT666-6A | U15 | MLF20J-050-0404L | NONE | MLF20J-050-0404L | U16 | SOT23-5F | NONE | SOT23-5F | U17 | MLF8A-050-0203L | NONE | MLF8A-050-0203L | U18 | SOP8-26-118C | NONE | SOP8-26-118C | U19 | SOP24-26-173A | NONE | SOP24-26-173A | U20 | SOP14-26-173C | NONE | SOP14-26-173C | U21 | SOP14-26-173C | NONE | SOP14-26-173C | U22 | SOP8-26-118C | NONE | SOP8-26-118C | U23 | SOP8-26-118C | NONE | SOP8-26-118C | U24 | SOP14-26-173C | NONE | SOP14-26-173C | U25 | SOP14-26-173C | NONE | SOP14-26-173C | U26 | MLF10P-050-0303L | NONE | MLF10P-050-0303L | U27 | BGA153-20-1414-ENIG | * | BGA153-20-1414-ENIG | U28 | SOT23-6A | SRV05-4 | SOT23-6A | U29 | SOT23-6A | SRV05-4 | SOT23-6A | U30 | SOT23-8 | NONE | SOT23-8 | U31 | SOT23-6A | SRV05-4 | SOT23-6A | U32 | SOP14-26-173C | NONE | SOP14-26-173C | U33 | SOP14-26-173C | NONE | SOP14-26-173C | U34 | SOP14-26-173C | NONE | SOP14-26-173C | U35 | SOP14-26-173C | NONE | SOP14-26-173C | U36 | MLF76L-040-0909L | NONE | MLF76L-040-0909L | U37 | SOP8-50-208 | * | SOP8-50-208 | U38 | MLF76Q-040-0909L | * | MLF76Q-040-0909L | VCXO1 | HSX4-0503 | 100MHz | HSX4-0503 | X1 | HSX4-0302B | 25MHz | HSX4-0302B | X2 | HSX4-0302B | 25MHz | HSX4-0302B | X3 | SX4-0303K | 12MHz | SX4-0303K | X4 | HSX4-0302B | 25MHz* | HSX4-0302B |
