查看: 1168|回复: 38
[Pads_VX.2x] Nuvoton MA35D16A887C 开发板PCB 和原理图 包含核心板和底板
    13万
    管理员
    原创先锋奖终身成就奖优秀斑竹奖宣传大使奖社区居民社区明星社区劳模最爱沙发新人进步奖忠实会员金点子奖特殊贡献奖
    发表于 2024-1-19 09:22:55 | 显示全部楼层 |阅读模式
    重要提示:PCB作品文件展下载说明
    NamePCB DecalPart TypeValue
    D2SOD-523ZENAR_0RB521S-30
    D3SOD-523ZENAR_0RB521S-30
    H1H-3.4X6TEST_POINTH-3.4X6(NC)
    H2H-3.4X6TEST_POINTH-3.4X6(NC)
    H3H-3.4X6TEST_POINTH-3.4X6(NC)
    J48HEADER2X1HEADER_2_1HEADER 2x1 (NC)
    L1MAMK2520T1R0MINDUCTOR_IRON1uH
    L2MAMK2520T1R0MINDUCTOR_IRON1uH
    L3MAMK2520T1R0MINDUCTOR_IRON1uH
    L4MAMK2520T1R0MINDUCTOR_IRON1uH
    P1DF40C-120DP-0.4V(51)SMDSTAMP_HOLE_0DF40C-120DP-0.4V(51)
    P2DF40C-120DP-0.4V(51)SMDSTAMP_HOLE_0DF40C-120DP-0.4V(51)
    SW1SW-2P-SMDSW_PUSHBUTTON_03x6x5 2PIN SMD
    T1PAD16MIL1PAD_2PJ3 (NC)
    U1BGA312MA35D1_BGA312_2MA35D16A887C
    U240-PIN_QFN_6X6MMDA9062DA9062-3AAMC
    U3TFBGA-169W55FA93_COB218_48PTE7A0MI-16GI
    U4QFN40_0_4RTL8211F(D)I-CG_0RTL8211F(D)I-CG
    U5QFN40_0_4RTL8211F(D)I-CG_0RTL8211F(D)I-CG
    X1XTAL_2P/1.5MMMA306/SM_2TXC-9H T9 SMD 32.768KHz 30ppm
    X2TXC7M-3.2X2.5MMCRYSTAL_SMD_224MHz
    X3TXC7M-3.2X2.5MMCRYSTAL_SMD_2X3225B 25MHz SMD
    X4TXC7M-3.2X2.5MMCRYSTAL_SMD_2X3225B 25MHz SMD
    CON1POWERJACK\3PDC-CON_3DC-CON (Core 2.0)
    CON2DF40C-120DS-0.4V_51HEADER_30X2_0DF40C-120DS-0.4V (51) (Pitch 0.4mm, female)
    CON3DF40C-120DS-0.4V_51HEADER_30X2_0DF40C-120DS-0.4V (51) (Pitch 0.4mm, female)
    CON4AXA2R63061AXA2R63061_1SD_Card_0
    CON5MICRO_USB_AB_LSUSB_TYPE_B_0USB MICRO_AB RECEP.
    CON6USB4PUSB_TYPE_A_CONNECTORUSB_TYPE-A_RECAP.
    CON7HEADER12X2_2.0MMCON24AHEADER 12x2 (2.0mm, male)
    CON8HEADER12X2_2.0MMCON24AHEADER 12x2 (2.0mm, male)
    CON9M_DIN_32X2/2.54ACON40A_0LCD
    CON10HEADER26X2_2.0MMCON40A_2HEADER 26x2 (2.0mm, male)
    CON11PHONE-PJK-634M_ASSJ-435107RS_92SJ3080-000111F SMD
    CON12SIM-CARDHEADER_6_0SIM_Card_1
    CON13DB9_FMALECONNECTOR_DB9_0DB9_FEMALE
    CON14DB9_FMALECONNECTOR_DB9_0DB9_FEMALE
    CON15SIP/2P_3.5MMHEADER_2HD-351-02P
    CON16SIP/2P_3.5MMHEADER_2HD-351-02P
    CON17SIP/2P_3.5MMHEADER_2HD-351-02P
    CON18SIP/2P_3.5MMHEADER_2HD-351-02P
    CON19BOX_HEADER_10X2HEADER_2X20_0SWJ (JTAG/SWD, BOX_HEADER_10x2)
    CON20FTHS_1.27_ES_10X2ETM_INTERFACE_1SMD 1.27mm 10x2
    CON21MICRO_USB_AB_LSUSB_TYPE_B_0USB MICRO_AB RECEP.
    D1DFN1006DIODE_TAZ_BI-DIRES014005F4
    J1HEADER3X2HEADER_3X2HEADER 3X2 (2.54mm, male)
    J2HEADER5X2HEADER_5X2HEADER 5X2 (2.54mm, NC)
    J3HEADER8X2HEADER_8X2HEADER 8X2 (2.54mm, NC)
    J4HEADER4X1HEADER_4HEADER 4x1 (2.54mm, NC)
    J5HEADER5X1HEADER_5HEADER 5x1 (2.54mm, NC)
    J6HEADER5X2HEADER_5X2HEADER 5X2 (2.54mm, male)
    J7HEADER2X1HEADER_2_2HEADER 2x1 (2.54mm, male)
    J8HEADER5X1HEADER_5HEADER 5x1 (2.54mm, male)
    J9HEADER5X1HEADER_5HEADER 5x1 (2.54mm, NC)
    L1L0603INDUCTORFB
    L2SMTDR43INDUCTOR_IRON4.7uH
    L3SMTDR43INDUCTOR_IRON4.7uH
    L4L0603INDUCTORFB
    L5L0603INDUCTORFB
    L6L0603INDUCTORFB
    L7L0603INDUCTORFB
    L8L0603INDUCTORFB
    L9L0603INDUCTORFB
    L10L0603INDUCTORFB
    L11L0603INDUCTORFB
    L12L0603INDUCTORFB
    L13L0603INDUCTORFB
    L14L0603INDUCTORFB
    L15L0603INDUCTORFB
    L16L0603INDUCTORFB
    L17L0603INDUCTORFB
    LEDG1DIP/2.54MMLED_0Green (DIP LED 3.0mm)
    LEDG2LED0805LED_0Green (LED0805)
    LEDG3LED0805LED_0Green (LED0805)
    LEDG4LED0805LED_0Green (LED0805)
    LEDR1LED0805LED_0Red (LED0805)
    M19.7D2.54MMMICROPHONE_2MIC
    Q1SOT-23MOSFET_P_4SI2301 (PMOS)
    Q2SOT-23MOSFET_P_4SI2301 (PMOS)
    Q3SOT-23PNP_02N3904 (NPN)
    Q4SOT-23PNP_2S8550 (PNP)
    Q5SOT-23MOSFET_N_4SI2302 (NMOS)
    Q6SOT-23MOSFET_N_4SI2302 (NMOS)
    Q7SOT-23MOSFET_P_4SI2301 (PMOS)
    Q8SOT-23PNP_2S8550 (PNP)
    RR18P4RAR-PACK8_010K-8P4R
    RR28P4RAR-PACK8_010K-8P4R
    RR38P4RAR-PACK8_010K-8P4R
    SW1TS-13-A1-C-SPDTSW_SPDTT80-S/SPDT Slide Switch
    SW2STS-B5SW-SSMD 6X6X5H (Red)
    SW3STS-B5SW-SSMD 6X6X5H (Black)
    SW4SWDIP-8/SMDSW_DIP-8SW DIP 8 (SMD)
    SW5STS-B5SW-SSMD 6X6X5H (Black)
    SW6STS-B5SW-SSMD 6X6X5H (Black)
    SW7STS-B5SW-SSMD 6X6X5H (Black)
    T11PAD1.25X1.25MM1PAD_2VDD5V IN (NC)
    T21PAD1.25X1.25MM1PAD_2VDD5V IN (NC)
    T31PAD1.25X1.25MM1PAD_2GND (NC)
    T41PAD1.25X1.25MM1PAD_2GND (NC)
    T51PAD1.25X1.25MM1PAD_2GND (NC)
    T61PAD1.25X1.25MM1PAD_2GND (NC)
    T71PAD1.25X1.25MM1PAD_2GND (NC)
    T81PAD1.25X1.25MM1PAD_2GND (NC)
    T91PAD1.25X1.25MM1PAD_2NAND_VDD3V3 (NC)
    T101PAD1.25X1.25MM1PAD_2N_PRE (NC)
    T111PAD1.25X1.25MM1PAD_2N_RB2 (NC)
    T121PAD1.25X1.25MM1PAD_2N_CE2 (NC)
    T131PAD1.25X1.25MM1PAD_2N_PSL (NC)
    T141PAD1.25X1.25MM1PAD_2SPK R (NC)
    T151PAD1.25X1.25MM1PAD_2SPK L (NC)
    T161PAD1.25X1.25MM1PAD_2AUXO2 (NC)
    T171PAD1.25X1.25MM1PAD_2AUXO1 (NC)
    T181PAD1.25X1.25MM1PAD_2AUXI_R (NC)
    T191PAD1.25X1.25MM1PAD_2AUXI_L (NC)
    T201PAD1.25X1.25MM1PAD_2AUDIO_3V3 (NC)
    T211PAD1.25X1.25MM1PAD_2SIM_VDD3V3 (NC)
    T221PAD1.25X1.25MM1PAD_2SC0_VDD3V3 (NC)
    T231PAD1.25X1.25MM1PAD_2BZ+ (NC)
    T241PAD1.25X1.25MM1PAD_2BZ- (NC)
    T251PAD1.25X1.25MM1PAD_2VCOM_VDD3V3 (NC)
    T261PAD1.25X1.25MM1PAD_2QSPI0_VDD (NC)
    U1VTQFN2X2-9PNCT3520W-H15_6APL3561
    U2TSOT-25ZT7103S_0FP6381AS5CTR
    U3TSOT-25ZT7103S_0FP6381AS5CTR
    U4TSOP48-0.5MMNAND_4-8G_22W29N08GVSIAA (NAND Flash)
    U5TSOP-6PJ9293_0NSP4201MR6T1G
    U6TSOP-6PJ9293_0NSP4201MR6T1G
    U7SOIC16_300W25Q128BV_4W25Q128JV (SPI NOR, NC)
    U8SOIC8_208_EPW55X10_3W25N04KWZEIR (SPI NAND)
    U9SM51625ELGST5009BMGST5009BM
    U10RJ45\8P\JA\LEDRJ-45_8P8C_LED_R/ARJ45\8P\JA\LED
    U11RJ45\8P\JA\LEDRJ-45_8P8C_LED_R/ARJ45\8P\JA\LED
    U12SM51625ELGST5009BMGST5009BM
    U13TSOP-6PJ9293_0NSP4201MR6T1G
    U14MSOP-8NCT3520W-H15_0AP2511M8-13
    U15TSOP-6PJ9293_0NSP4201MR6T1G
    U16MSOP-8NCT3520W-H15_0AP2511M8-13
    U17TSOP-6PJ9293_0NSP4201MR6T1G
    U18QFN32L_5X5MM\0.5MM_PITCHNAU8501_0NAU88C22YG
    U19TSOP-6PJ9293_0NSP4201MR6T1G
    U20TSOP-6PJ9293_0NSP4201MR6T1G
    U21SOP16/150ADM232_0SN75C3232EDR
    U22SOP16/150ADM232_0SN75C3232EDR
    U23SO-8ADM232_1SN65HVD11DR
    U24SO-8ADM232_1SN65HVD11DR
    U25SOIC8TCAN332GD_0TCAN337GDR
    U26SOIC8TCAN332GD_0TCAN337GDR
    U27TSOP-6PJ9293_0NSP4201MR6T1G
    U28TSOP-6PJ9293_0NSP4201MR6T1G
    U29QFN33_5X5NUC101_QFN_0NUC123ZD4AN0
    U30TSOP-6PJ9293_0NSP4201MR6T1G
    U31HCLGA-5-3X4X1.06MM-4LDMP43DT01-MMP34DT01-M
    U32QFN-24-3X3X0.9MMMPU6881MPU6500
    X1TXC7M-3.2X2.5MMCRYSTAL_SMD_212MHz (SMD X3225B)
    重要提示:PCB作品文件展下载说明
    昨天 10:18
  • 签到天数: 120 天
    终身成就奖社区居民优秀斑竹奖特殊贡献奖原创先锋奖
    发表于 2024-1-19 09:23:34 | 显示全部楼层
    13万
    管理员
     楼主| 发表于 2024-1-19 09:24:23 | 显示全部楼层
    PCB 和原理图。回复可见下载
    游客,如果您要查看本帖隐藏内容请回复
    昨天 08:03
  • 签到天数: 205 天
    终身成就奖社区居民忠实会员社区劳模最爱沙发特殊贡献奖优秀斑竹奖
    发表于 2024-1-19 09:35:16 | 显示全部楼层
  • 签到天数: 134 天
    1元学习Allegro(2期)旁听
    发表于 2024-1-19 09:36:09 | 显示全部楼层
    3 天前
  • 签到天数: 110 天
    发表于 2024-1-19 09:45:28 | 显示全部楼层
    终身成就奖原创先锋奖特殊贡献奖
    发表于 2024-1-19 09:45:59 | 显示全部楼层
    头像被屏蔽
    禁止发言
    发表于 2024-1-19 09:52:30 | 显示全部楼层
    提示: 作者被禁止或删除 内容自动屏蔽
    昨天 08:00
  • 签到天数: 247 天
    发表于 2024-1-19 09:59:04 | 显示全部楼层
    郁闷
    2024-6-14 15:09
    发表于 2024-1-19 10:07:38 | 显示全部楼层
