[Allegro17.4以下] Hi3751 (Hi3751ARBCV3500N0N) 双面设计的PCB文件共享
查看1128 | 回复27 | 2024-1-21 14:45:56 | 显示全部楼层 |阅读模式
重要提示:PCB作品文件展下载说明
A1AHOLE138_0_HOLD_D3_2_AHOLE138AHOLE138HOLD_D3_2
A2AHOLE138_0_HOLD_D3_2_AHOLE138AHOLE138HOLD_D3_2
A3AHOLE138_0_HOLD_D3_2_AHOLE138AHOLE138HOLD_D3_2
A4AHOLE138_0_HOLD_D3_2_AHOLE138AHOLE138HOLD_D3_2
AMP_L+TEST-SIGNAL_TEST1_5MM_BL_ONBL_ONTEST1_5MM
AMP_L-TEST-SIGNAL_TEST1_5MM_BL_ONBL_ONTEST1_5MM
AMP_R+TEST-SIGNAL_TEST1_5MM_BL_ONBL_ONTEST1_5MM
AMP_R-TEST-SIGNAL_TEST1_5MM_BL_ONBL_ONTEST1_5MM
AVDDTEST-SIGNAL_TEST1_5MM_+12V_STB+12V_STBTEST1_5MM
AW1ANT-PLUG_IPEX3-3X3_1_ANT-PLUGANT-PLUGIPEX3-3X3_1
CON1327F_AV_CK327F_327F_AV327F_AVCK327F
CON2327F_MUSIC_CK327F_327F_MUSIC327F_MusicCK327F
D2DIODEBI-DIR TRIG_E0402_NC/ESD_NC/ESD_0.5PE0402
D3DIODEBI-DIR TRIG_E0402_NC/ESD_NC/ESD_0.5PE0402
D4DIODEBI-DIR TRIG_E0402_NC/ES_1NC/ESD_8PE0402
D5DIODEBI-DIR TRIG_E0402_NC/ES_1NC/ESD_8PE0402
D6DIODEBI-DIR TRIG_E0402_NC/ES_1NC/ESD_8PE0402
D7DIODEBI-DIR TRIG_E0402_NC/ES_1NC/ESD_8PE0402
D8DIODEBI-DIR TRIG_E0402_NC/ES_1NC/ESD_8PE0402
D9DIODEBI-DIR TRIG_E0402_NC/ES_1NC/ESD_8PE0402
D11DIODEBI-DIR TRIG_E0402_NC/ESD_NC/ESD_0.5PE0402
D12DIODEBI-DIR TRIG_E0402_NC/ESD_NC/ESD_0.5PE0402
D17DIODE_SINGLE-2_SMA-DO-214AC-SHASS14-ASMA-DO-214AC-SHAPE
D20DIODE_DOUBLE_SOT-23_LBAV99LT1GLBAV99LT1GSOT-23
D21DIODE_DOUBLE_SOT-23_LBAV99LT1GLBAV99LT1GSOT-23
DETTEST-SIGNAL_TEST1_5MM_BL_ONBL_ONTEST1_5MM
EAR_LTEST-SIGNAL_TEST1_5MM_BL_ONBL_ONTEST1_5MM
EAR_RTEST-SIGNAL_TEST1_5MM_BL_ONBL_ONTEST1_5MM
FB1BEAD_FB0402_FB1K/300MAFB1K/300mAFB0402
FB2BEAD_FB0402_FB120R/1.2AFB120R/1.2AFB0402
FB3BEAD_FB0402_FB120R/1.2AFB120R/1.2AFB0402
FB4BEAD_FB0402_FB120R/1.2AFB120R/1.2AFB0402
FB5BEAD_FB0402_NC/120R/1000MHZNC/120R/1000MHZFB0402
FBA1BEAD_FB0805_FB1K/1.5AFB1K/1.5AFB0805
FBA2BEAD_FB0805_FB1K/1.5AFB1K/1.5AFB0805
FBA3BEAD_FB0805_NC/FB1K/1.5ANC/FB1K/1.5AFB0805
FBA4BEAD_FB0805_NC/FB1K/1.5ANC/FB1K/1.5AFB0805
FBA5BEAD_FB0805_FB1K/1.5AFB1K/1.5AFB0805
FBA6BEAD_FB0805_FB1K/1.5AFB1K/1.5AFB0805
FBA7BEAD_FB0805_FB1K/1.5AFB1K/1.5AFB0805
H1TP_0_MARK_TPADTPADMARK
H2TP_MARK_TPADTPADMARK
H3TP_MARK_TPADTPADMARK
H4TP_0_MARK_TPADTPADMARK
H5TP_MARK_TPADTPADMARK
H6TP_MARK_TPADTPADMARK
IRINTEST-SIGNAL_TEST1_5MM_BL_ONBL_ONTEST1_5MM
J1PH-2AWB_PH-2AWD-SMD_PH-2AWBPH-2AWBPH-2AWD-SMD
J3IRM_IR3-2MM54-V_LF0038KBNLLF0038KBNLIR3-2MM54-V
J4HDMI-19P_HDMI_19P_DIP_HDMFB0191HDMFB01917-01513RHDMI_19P_DIP
J6PH-2AWB_PH-2AWD-SMD_PH-2AWBPH-2AWBPH-2AWD-SMD
J7HDMI-19P_HDMI_19P_DIP_HDMFB0191HDMFB01917-01513RHDMI_19P_DIP
J8USB2.0-H_2A_USB2_0_USB2.0-H_2AUSB2.0-H_2AUSB2_0
J9PH-2AWB_PH-2AWD-SMD_PH-2AWBPH-2AWBPH-2AWD-SMD
J111.25T-3AWB_1MM25T-3A-8_5X3_7-SM1.25T-3AWB1MM25T-3A-8_5X3_7-SMD
J13FPC60P_LCD_60PIN_FOG-RX058B-060FOG-RX058B-0600LCD_60PIN
J14DDHRFR01504-2X121R_VGA15-F-DXF_DHRFR01502-3X121RVGA15-F-DXF
J15PH-2AWB_PH-2AWD-SMD_PH-2AWBPH-2AWBPH-2AWD-SMD
J16PH-7P_PH-5AWD-SMD_PH-7PPH-7PPH-5AWD-SMD
J171.25T-4AWB_FPC_4PIN_0.5MM_4PIN0.5mm_4PINFPC_4PIN
L1INDUCTOR-NOR_CD54_4.7UH/3.3A4.7uH/3.3ACD54
L2INDUCTOR-NOR_CD0302_2.2UH/2A2.2uH/2ACD0302
L3INDUCTOR-NOR_CD0302_10UH/1.05A10uH/1.05ACD0302
L4INDUCTOR-NOR_CD43_10UH/1.5A10uH/1.5ACD43
L6INDUCTOR-NOR_CD0302_2.2UH/2A2.2uH/2ACD0302
L7INDUCTOR-NOR_CD0302_2.2UH/2A2.2uH/2ACD0302
LED_G1TEST-SIGNAL_TEST1_5MM_+12V_STB+12V_STBTEST1_5MM
LED_R1TEST-SIGNAL_TEST1_5MM_+12V_STB+12V_STBTEST1_5MM
LS_ADC0TEST-SIGNAL_TEST1_5MM_+12V_STB+12V_STBTEST1_5MM
LS_ADC1TEST-SIGNAL_TEST1_5MM_+12V_STB+12V_STBTEST1_5MM
NC/J2PH-2AWB_PH-2AWD-SMD_PH-2AWBPH-2AWBPH-2AWD-SMD
Q1TRANSISTOR-NPN_SOT-23_MMBT3904MMBT3904SOT-23
Q2TRANSISTOR-NPN_SOT-23_MMBT3904MMBT3904SOT-23
Q3TRANSISTOR-NPN_SOT-23_MMBT3904MMBT3904SOT-23
Q4TRANSISTOR-NPN_SOT-23_MMBT3904MMBT3904SOT-23
Q5MOS-P_SOT-23_LT1525SILT1525SISOT-23
Q6MOS-P_SOT-23_LT1525SILT1525SISOT-23
Q7TRANSISTOR-NPN_SOT-23_MMBT3904MMBT3904SOT-23
Q8TRANSISTOR-NPN_SOT-23_MMBT3904MMBT3904SOT-23
Q9MOS-P_SOT-23_LT1525SILT1525SISOT-23
Q10TRANSISTOR-NPN_SOT-23_MMBT3904MMBT3904SOT-23
U1TMI3253S_SOT23-6_JW5057CSOTBJW5057CSOTBSOT23-6
U2TMI3253S_SOT23-6_JW5052CSOTBJW5052CSOTBSOT23-6
U3TMI6030_SOT23-5_LP399233B5FLP399233B5FSOT23-5
U4TMI6030_SOT23-5_LP399218N5FLP399218N5FSOT23-5
U5EMMC_0_BGA153-0MM5-11_5X13_EMMCEMMCBGA153-0MM5-11_5X13
U6ESD-CS0806S_SLP2710P8_ESD_0.05PESD_0.05P/NCSLP2710P8
U7ESD-CS0806S_SLP2710P8_ESD_0.05PESD_0.05P/NCSLP2710P8
U8MT3608_DC_5026_TCS3558TCS3558DC_5026
U9TMI3411_SOT23-5_JW5252SOTAJW5252SOTASOT23-5
U10M-WIFI20-CDW-B18723D-U0_M-WIFI-BL-M8723DU1M-WIFI-RTL8723DUU-20P
U11ESD-CS0806S_SLP2710P8_ESD_0.05PESD_0.05P/NCSLP2710P8
U12TMI3411_SOT23-5_JW5250SSOTAJW5250SSOTASOT23-5
U13ESD-CS0806S_SLP2710P8_ESD_0.05PESD_0.05P/NCSLP2710P8
U14NS4165B_NS4165B_NC/NS4165BNC/NS4165BNS4165B
U15NS4165B_NS4165B_NS4165BNS4165BNS4165B
U16M-WIFI14-CDW-N37632U-10_M-WIFI-NC/CDW-N37632U-10M-WIFI-MT7632UNU-14P
US1HI3751V350Hi3751ARBCV3500N0NBGA278-0MM8-16_7X15_1-HI3751
USB2_DM2TEST-SIGNAL_TEST1_5MM_+12V_STB+12V_STBTEST1_5MM
USB2_DP2TEST-SIGNAL_TEST1_5MM_+12V_STB+12V_STBTEST1_5MM
VCC-PANELTEST-SIGNAL_TEST1_5MM_+12V_STB+12V_STBTEST1_5MM
VSNTEST-SIGNAL_TEST1_5MM_+12V_STB+12V_STBTEST1_5MM
VSPTEST-SIGNAL_TEST1_5MM_+12V_STB+12V_STBTEST1_5MM
X1CRYSTAL-4P_XTAL4-3225-SMD_24MHZ24MHz/20pFXTAL4-3225-SMD
ZD1DIODE_ZENER_SOD-123_BZT52B5V6BZT52B5V6SOD-123
ZD2DIODE_ZENER_SOD-123_BZT52B5V6BZT52B5V6SOD-123
ZX1FERRITEBEAD_SHORT_1_SHORTSHORTSHORT_1
重要提示:PCB作品文件展下载说明
暑假期间,免费代管18-28岁小孩,限女性。
sii9000 | 2024-1-21 14:46:49 | 显示全部楼层
PCB文件。回复可见下载
游客,如果您要查看本帖隐藏内容请回复
mohammadfa91 | 2024-1-21 15:08:23 | 显示全部楼层
jielove2003 | 2024-1-21 16:48:19 | 显示全部楼层
fhjvfjdr | 2024-1-21 17:20:25 | 显示全部楼层
bidezhi7777 | 2024-1-21 18:57:24 | 显示全部楼层
junkyoung | 2024-1-21 20:24:06 | 显示全部楼层
11_11 | 2024-1-22 00:09:46 | 显示全部楼层
io357 | 2024-1-22 08:50:24 | 显示全部楼层
dzbao180 | 2024-1-22 08:58:04 | 显示全部楼层
长期免费代管18-28岁小
