TA的每日心情![](source/plugin/dsu_paulsign/img/emot/kx.gif) | 开心 2024-6-20 15:58 |
签到天数: 1 天 [LV.1]初来乍到
长期免费代管18-28岁小
- 7147
![终身成就奖](static/image/common/zhongshenchengjiu.png) ![优秀斑竹奖](static/image/common/youxiubanzhu.png)
x3399bv2.7z
(1.71 MB, 下载次数: 0)
Name | Part Type | PCB Decal | Value | ANT2 | ANT2_40R00X9R00 | ANT2_40R00X9R00 | ANT_DIPOLE_1 | ANT4 | ANT2_40R00X9R00 | ANT2_40R00X9R00 | ANT_DIPOLE_1 | BT1 | RTC | RTC | 3V | CON1 | USB30A9_25R70X7R32X13R85 | USB30A9_25R70X7R32X13R85 | USB_A_30 | D1 | SOD_123 | SOD_123 | NC | D2 | SS34 | SS34 | SS34 | D5 | D0805 | D0805 | LED | D8 | SOD_123 | SOD_123 | BZT52C3V3 | D10 | D0805 | D0805 | LED | D11 | D0805 | D0805 | LED | D12 | D0805 | D0805 | LED | D13 | D0805 | D0805 | LED | D14 | SOD-323 | SOD-323 | 1N4148 | D20 | LED0603 | LED0603 | RED | D1701 | SOD_123 | SOD_123 | BZT52C3V3 | D1702 | SOD-323 | SOD-323 | 1N4148 | D1703 | SOD-323 | SOD-323 | 1N4148 | D1704 | SOD-323 | SOD-323 | 1N4148 | FB1 | L0603 | L0603 | 180R-100M | FB2 | L0603 | L0603 | 180R-100M | FB3 | L0603 | L0603 | 180R-100M | FB4 | L0603 | L0603 | 180R-100M | FB7 | R0603 | R0603 | 600R-100M | J2 | RJ45_HR911130C | RJ45_HR911130C | HR911130C | J3 | CN-SMD4P-H-1.25-B | CN-SMD4P-H-1.25-B | UKEY | J5 | FFC30-0.5MM-RL | FFC30-0.5MM-RL | 30PIN | J8 | FPC26-0.5MM-B | FPC26-0.5MM-B | 26PIN | J9 | FFC24-0.5MM-LR | FFC24-0.5MM-LR | OV2659 | J11 | SIP2S-2.0 | SIP2S-2.0 | CON2 | J12 | IDC20S | IDC20S | MATRIX_KEY/ADC | J13 | DQT-003 | DQT-003 | DLT1150A | J15 | USB_A | USB_A | USB_HOST | J16 | TYPEC3.1_GD-TC-002-03 | TYPEC3.1_GD-TC-002-03 | USB_TYPEC_115H0 | J17 | SIP3S-2.0 | SIP3S-2.0 | HS0038B | J18 | TF9_CKT01_009D | TF9_CKT01_009D | TF-CKT01-009D | J21 | CN-SMD4P-H-1.25-B | CN-SMD4P-H-1.25-B | UKEY | J27 | ZPK | ZPK | CON1 | J28 | ZPK | ZPK | CON1 | J30 | ZPK | ZPK | CON1 | J36 | ZPK | ZPK | CON1 | J7003 | PHONE1 | PHONE1 | HEADPHONE | J7004 | DC-044B | DC-044B | DC_5V | J7005 | R-S151L-O | R-S151L-O | HDMI_CNT | L1 | IND_505040 | IND_505040 | PCMB051H-2R2MS/6A | L4 | IND_303015 | IND_303015 | 2.2UH | L5 | L4D16 | L4D16 | 4.7UH/2A | L6 | L4D16 | L4D16 | 4.7UH | LS1 | BUZZER_6X12 | BUZZER_6X12 | SPEAKER | MIC1 | MIC-2P | MIC-2P | MIC-4020 | MIC2 | MIC-2P | MIC-2P | MICPHONE | P1 | DB9A | DB9A | UART1 | Q5 | SOT_323 | SOT_323 | WNM2021-3/TR | Q6 | SOT_323 | SOT_323 | WNM2021-3/TR | Q7 | SOT_323 | SOT_323 | WNM2021-3/TR | Q11 | SOT-23 | SOT-23 | MMBT3904 | Q15 | 2N3904 | 2N3904 | 2N3904 | Q17 | SO-8 | SO-8 | AO4407A | Q18 | 2N3904 | 2N3904 | 2N3904 | Q19 | KRLML6401 | KRLML6401 | CJ2305 | Q20 | SOT_323 | SOT_323 | WNM2021-3/TR | Q21 | SOT_323 | SOT_323 | WNM2021-3/TR | SIM2 | MICRO-SIM-6P | MICRO-SIM-6P | MICRO-SIM-6P | SW1 | KEY_SMD_2P_6X3 | KEY_SMD_2P_6X3 | VOL+/RECOVERY | SW2 | KEY_SMD_2P_6X3 | KEY_SMD_2P_6X3 | VOL- | SW3 | KEY_SMD_2P_6X3 | KEY_SMD_2P_6X3 | ESC | SW4 | KEY_SMD_2P_6X3 | KEY_SMD_2P_6X3 | MENU | SW5 | KEY_SMD_2P_6X3 | KEY_SMD_2P_6X3 | POWER | SW6 | KEY_SMD_2P_6X3 | KEY_SMD_2P_6X3 | RST | T7001 | TP_1R00 | TP_1R00 | TP_1.0 | U1 | QFN12_2R00X3R00X1R00 | QFN12_2R00X3R00X1R00 | NB680GD | U4 | X3399_CON | X3399_CON | RK3399_CORE | U5 | QFN48_6R00X6R00X1R00_T | QFN48_6R00X6R00X1R00_T | RTL8211E-VB-CG | U6 | SOT23-8 | SOT23-8 | MP2143DJ | U7 | SSOP16 | SSOP16 | SP3232E | U8 | PCIE52-AB | PCIE52-AB | MF210 | U9 | MSOP-8 | MSOP-8 | PCF8563/AT8563 | U12 | SOT-25 | SOT-25 | SGM2019-2.8YN5G/TR | U13 | SOT-25 | SOT-25 | SGM2019-1.8YN5G/TR | U14 | SOT-25 | SOT-25 | SGM2019-1.5YN5G/TR | U15 | QFN40_5R00X5R00X1R00 | QFN40_5R00X5R00X1R00 | ALC5651 | U16 | MSOP8 | MSOP8 | CS8120/NS4160/FT2011 | U22 | SOT_23_5 | SOT_23_5 | SY6280AAC | U25 | MLP14_2R50X2R50X0R80 | MLP14_2R50X2R50X0R80 | FUSB302MPX | U29 | MD44_AP6XXX_13RX15RX1R5 | MD44_AP6XXX_13RX15RX1R5 | AP6354 | U31 | SOT_23_5 | SOT_23_5 | SGM2019-3.0YN5G/TR | U32 | OPLGA6_2R35X1R80X1R00 | OPLGA6_2R35X1R80X1R00 | CM32181/NC | U33 | LGA-24L | LGA-24L | LSM330TR | U39 | SOT-25 | SOT-25 | SGM2019-3.0YN5G/TR | U40 | SOT-25 | SOT-25 | XC6219B182MR | U41 | FH19-50PIN-LR | FH19-50PIN-LR | 50PIN-MIPI | U42 | FFC30-0.5MM-LR | FFC30-0.5MM-LR | 30PIN-MIPI | U43 | SOT-25 | SOT-25 | SGM2019-1.2YN5G/TR | U44 | SOT_23_5 | SOT_23_5 | SY6280AAC | U8001 | BAG14-1.6X1.6 | BAG14-1.6X1.6 | AK8963C | U8002 | SOT-25 | SOT-25 | SGM2019-2.8YN5G/TR | U8003 | SOT-25 | SOT-25 | SGM2019-1.8YN5G/TR | U8004 | TSSOP20 | TSSOP20 | STM8S003F3 | U8005 | TP_0R50 | TP_0R50 | TP | U8006 | TP_0R50 | TP_0R50 | TP | U8007 | SOT-25 | SOT-25 | SGM2019-3.3YN5G/TR | VR1 | R0402 | R0402 | PESD5V0F1BL | X2 | MC-146 | XTAL-32.768KHZB | 32.768K | Y1 | CRY4_3R20X2R50X0R80 | CRY4_3R20X2R50X0R80 | 25MHZ | Y3 | CRY4_3R20X2R50X0R80 | CRY4_3R20X2R50X0R80 | 37.4MHZ |
