查看: 614|回复: 7
[Pads_VX.2x] 汇川MD500E变频器开发方案 PCB原理图 源码等资料
    长期免费代管18-28岁小
    发表于 2024-6-20 17:03:23 | 显示全部楼层 |阅读模式
    重要提示:PCB作品文件展下载说明
    Matlab仿真模型.7z (253.43 KB, 下载次数: 3)
    MD500e原理图(PADS软件打开).7z (1.24 MB, 下载次数: 7)
    PMSM_SMO仿真资料.7z (33.38 KB, 下载次数: 6)
    SVC代码开发调试.pdf (19.62 MB, 下载次数: 5)
    电机控制学习笔记.pdf (21.46 MB, 下载次数: 7)
    汇川MD380核心代码解析.pdf (7.38 MB, 下载次数: 61)
    NamePart TypePCB DecalValue
    BAR_CODEBAR_CODE(42\27X6)BARCODE-27X6
    CN115020003-CON3-5MM-10A-300VCON-3-5MMJTB552-04-1-03-3-M6
    CN215020004-CON6-DL-5.08MM-10ACON-6-5.08MMJTB870-05-2-03-3-M3
    CN315020004-CON6-DL-5.08MM-10ACON-6-5.08MMJTB870-05-2-03-3-M3
    CN415020004-CON6-DL-5.08MM-10ACON-6-5.08MMJTB870-05-2-03-3-M3
    D106013004-S-DIO-30V-200MA-BAT54SLT1GSOT23BAT54SLT1G
    D206013004-S-DIO-30V-200MA-BAT54SLT1GSOT23BAT54SLT1G
    D310021004-LED-DIO-RED-0805SAWLED-SD08050805SAW
    D406013004-S-DIO-30V-200MA-BAT54SLT1GSOT23BAT54SLT1G
    D506013004-S-DIO-30V-200MA-BAT54SLT1GSOT23BAT54SLT1G
    D606013004-S-DIO-30V-200MA-BAT54SLT1GSOT23BAT54SLT1G
    D706013004-S-DIO-30V-200MA-BAT54SLT1GSOT23BAT54SLT1G
    D806013004-S-DIO-30V-200MA-BAT54SLT1GSOT23BAT54SLT1G
    D906013004-S-DIO-30V-200MA-BAT54SLT1GSOT23BAT54SLT1G
    D1010021003-LED-DIO-GREEN-0805HGWLED-SD08050805HGW
    D2306012002-SW-DIO-100V-200MA-MMBD7000LT1GSOT23MMBD7000LT1G
    D2406012002-SW-DIO-100V-200MA-MMBD7000LT1GSOT23MMBD7000LT1G
    D2506016002-BTS-DIO-7V-7V-SMBJ5.0CASMB--2215SMBJ5.0CA
    D2606016002-BTS-DIO-7V-7V-SMBJ5.0CASMB--2215SMBJ5.0CA
    D2706016002-BTS-DIO-7V-7V-SMBJ5.0CASMB--2215SMBJ5.0CA
    D2806016002-BTS-DIO-7V-7V-SMBJ5.0CASMB--2215SMBJ5.0CA
    D2906013002-S-DIO-40V-100MA-BAS40-06LT1GSOT23BAS40-06LT1G
    D3006013004-S-DIO-30V-200MA-BAT54SLT1GSOT23BAT54SLT1G
    D3106013004-S-DIO-30V-200MA-BAT54SLT1GSOT23BAT54SLT1G
    D3206013004-S-DIO-30V-200MA-BAT54SLT1GSOT23BAT54SLT1G
    D3306013004-S-DIO-30V-200MA-BAT54SLT1GSOT23BAT54SLT1G
    D3406013004-S-DIO-30V-200MA-BAT54SLT1GSOT23BAT54SLT1G
    D3506013004-S-DIO-30V-200MA-BAT54SLT1GSOT23BAT54SLT1G
    D3606012002-SW-DIO-100V-200MA-MMBD7000LT1GSOT23MMBD7000LT1G
    D3706012002-SW-DIO-100V-200MA-MMBD7000LT1GSOT23MMBD7000LT1G
    D3806013001-S-DIO-40V-100MA-BAS40-04LT1GSOT23BAS40-04LT1G
    D3906013001-S-DIO-40V-100MA-BAS40-04LT1GSOT23BAS40-04LT1G
    D4006013001-S-DIO-40V-100MA-BAS40-04LT1GSOT23BAS40-04LT1G
    D4106013001-S-DIO-40V-100MA-BAS40-04LT1GSOT23BAS40-04LT1G
    D4206016002-BTS-DIO-7V-7V-SMBJ5.0CASMB--221533V
    D4306016002-BTS-DIO-7V-7V-SMBJ5.0CASMB--221533V
    J115013003-SIP8-2.5MM-P2500J-08CON-8-100P2500J-08
    J215010039-CON2X5-2.54CON10-100CON10
    J315010028-SSED18-1MM-W-EFC-PM24-SD18H3-3ZSED20-23.8X6.65EFC-PM24-SD18H3-3Z
    J415011003-SIP3-2.54MM-3A-201K0300SIP-3-100201K0300
    J515011003-SIP-3-100-3A-201K0300SIP-3-100201K0300
    J615011001-SIP2-2.54MM-3A-201K0200SIP-2-100201K0200
    J715050001-CON8-RJ45-9030800004CON8-15X13-RJ45(KZ)
    9030800004
    J815011003-SIP-3-100-3A-201K0300SIP-3-100201K0300
    J915011003-SIP-3-100-3A-201K0300SIP-3-100201K0300
    J1015011003-SIP-3-100-3A-201K0300SIP-3-100201K0300
    J1115010024-DIP34-2.54MM-2313411001CON-34-1001236-341-121-1
    J1215015001-DSED28-2MM-263K2821CON-28-SMT263K2821
    J1315011003-SIP-3-100-3A-201K0300SIP-3-100201K0300
    K112010003-RLY5-892-1CC-C/24VRLY5-7.62MM-20.5X10.224V-125VAC-10A(NO)-125VAC-3A(NC)
    L111011002-L-100UH-SMTSPL100μH±10%
    L211011001-L-100MHZ-PBY201209T-101Y-NSL0805PBY201209T-101Y-N
    L311011001-L-100MHZ-PBY201209T-101Y-NSL0805PBY201209T-101Y-N
    L411011001-L-100MHZ-PBY201209T-101Y-NSL0805PBY201209T-101Y-N
    L511011001-L-100MHZ-PBY201209T-101Y-NSL0805PBY201209T-101Y-N
    MM1M3_138_NPM3_138NP
    MM2M3_138_240M3_138_240
    MM3M3_138_NPM3_138NP
    Q106021007-NPN-DYN-40V-0.6A-MMBT4401LT1GSOT23MMBT4401LT1G
    Q206021007-NPN-DYN-40V-0.6A-MMBT4401LT1GSOT23MMBT4401LT1G
    Q306021007-NPN-DYN-40V-0.6A-MMBT4401LT1GSOT23MMBT4401LT1G
    Q406021007-NPN-DYN-40V-0.6A-MMBT4401LT1GSOT23MMBT4401LT1G
    Q506021007-NPN-DYN-40V-0.6A-MMBT4401LT1GSOT23MMBT4401LT1G
    Q606021007-NPN-DYN-40V-0.6A-MMBT4401LT1GSOT23MMBT4401LT1G
    Q706021007-NPN-DYN-40V-0.6A-MMBT4401LT1GSOT23MMBT4401LT1G
    Q806021007-NPN-DYN-40V-0.6A-MMBT4401LT1GSOT23MMBT4401LT1G
    Q906021004-NPN-DYN-40V-1A-PBSS4140TSOT23PBSS4140T
    Q1006021004-NPN-DYN-40V-1A-PBSS4140TSOT23PBSS4140T
    Q1106021004-NPN-DYN-40V-1A-PBSS4140TSOT23PBSS4140T
    Q1206021004-NPN-DYN-40V-1A-PBSS4140TSOT23PBSS4140T
    U109030005-COMP-LM393DR2G-SOP8SOP8-50-150LM393DR2G
    U209030005-COMP-LM393DR2G-SOP8SOP8-50-150LM393DR2G
    U309030005-COMP-LM393DR2G-SOP8SOP8-50-150LM393DR2G
    U409030008-AMP-TL082IDR-SOIC8SOP8-50-150TL082IDR
    U509030005-COMP-LM393DR2G-SOP8SOP8-50-150LM393DR2G
    U609030005-COMP-LM393DR2G-SOP8SOP8-50-150LM393DR2G
    U709030005-COMP-LM393DR2G-SOP8SOP8-50-150LM393DR2G
    U809030005-COMP-LM393DR2G-SOP8SOP8-50-150LM393DR2G
    U908011006-GATE-SN74ACT244-SOP20SOP20-25-17374ACT244
    U10TEMP-IC-TMS320F28035-QFP80QFP80-050-1212TMS320F28035
    U1109020005-VMON-AMAX708-TG-SOP8SOP8-50-150ADM708-4.4V
    U1207030004-IC-AT24C32AN-SOP8SOP8-50-150AT24C32AN_32K
    U1308012019-GATE-SN74LVC244APWR-SOP20SOP20-25-173SN74LVC244APWR
    U1408011006-GATE-SN74ACT244-SOP20SOP20-25-17374ACT244
    U1508011006-GATE-SN74ACT244-SOP20SOP20-25-17374ACT244
    U1610010008-GO-HCPL-181-00BE-SOP4PS2701\PHCPL-181-00BE
    U1708011006-GATE-SN74ACT244-SOP20SOP20-25-17374ACT244
    U1808011006-GATE-SN74ACT244-SOP20SOP20-25-17374ACT244
    U1908012019-GATE-SN74LVC244APWR-SOP20SOP20-25-173SN74LVC244APWR
    U2010012001-GO-TLP114A-TPR-SDOP5SGO5-50-173TLP114A-TPR
    U2110012001-GO-TLP114A-TPR-SDOP5SGO5-50-173TLP114A-TPR
    U2210012001-GO-TLP114A-TPR-SDOP5SGO5-50-173TLP114A-TPR
    U2310012001-GO-TLP114A-TPR-SDOP5SGO5-50-173TLP114A-TPR
    U2409030014-AMP-MC33272ADR2G-SOP8SOP8-50-150MC33272ADR2G
    U2507030004-IC-AT24C32AN-SOP8SOP8-50-150AT24C32AN_32K
    U2609010004-VREG-TLV1117-33CDCYR-SOT223SOT-223TLV1117-33CDCYR
    U2708012010-GATE-SN74ACT14DR-SOIC14SOP14-50-150SN74ACT14DR
    U2809030004-AMP-LM324DR-SOP14SOP14-50-150LM324DR
    U2910012001-GO-TLP114A-TPR-SDOP5SGO5-50-173TLP114A-TPR
    U3010012001-GO-TLP114A-TPR-SDOP5SGO5-50-173TLP114A-TPR
    U3110012001-GO-TLP114A-TPR-SDOP5SGO5-50-173TLP114A-TPR
    U3209020003-VREG-LM317LDR2G-SOP8SOP8-50-150LM317LDR2G
    U3308012016-DCK-SN74LVC1G14DCKRDCKSN74LVC1G14DCKR
    U3408012016-DCK-SN74LVC1G14DCKRDCKSN74LVC1G14DCKR
    U3508012016-DCK-SN74LVC1G14DCKRDCKSN74LVC1G14DCKR
    X114010005-X3-20MHZ-50PPMX3-2.44MM-10.24X4.6520MHz
    Z1MARKMARK
    Z2MARKMARK_IC
    Z3MARKMARK_IC
    Z4MARKMARK
    Z5MARKMARK
    Z6MARKMARK
    重要提示:PCB作品文件展下载说明
    发表于 2024-8-14 10:06:53 | 显示全部楼层
    昨天 19:43
  • 签到天数: 140 天
    1元学习PADS(3期)
    发表于 2024-8-14 19:49:52 | 显示全部楼层
    谢谢分享,我记得其他地方卖挺贵
    6 小时前
  • 签到天数: 111 天
    发表于 2024-8-15 09:23:40 | 显示全部楼层
    昨天 19:43
  • 签到天数: 140 天
    1元学习PADS(3期)
    发表于 2024-9-6 10:17:42 | 显示全部楼层
    6 小时前
  • 签到天数: 193 天
    发表于 2024-9-6 14:43:04 | 显示全部楼层
    是目前流行的方案吗?
    6 小时前
  • 签到天数: 4 天
    社区居民忠实会员社区劳模最爱沙发原创达人终身成就奖特殊贡献奖优秀斑竹奖
    发表于 2024-9-7 17:09:49 | 显示全部楼层
    郁闷
    2024-12-7 09:14
    发表于 2024-12-7 09:15:26 | 显示全部楼层
