查看: 578|回复: 2
[Allegro17.4以下] RK_TABLET_DEMO1_RK3576_LP4XD200P132SD6_V12(LPDDR4X) PCB原理图AP6276P
此广告位出租
发表于 2024-7-12 21:43:21 | 显示全部楼层 |阅读模式
重要提示:PCB作品文件展下载说明
PCB 原理图。一起打包。回复可见
RK_TABLET_DEMO1_RK3576_LP4XD200P132SD6_V12_20230530.7z (7.33 MB, 下载次数: 14)
REFDES
COMP_DEVICE_TYPE
COMP_VALUE
SYM_NAME
ANT6401
ANT_IIFA_CC2420_32MIL_MIR_0_SANDAI_WIFI_ANT_WIFI_ANT
WIFI_ANT
SANDAI_WIFI_ANT
ANT6402
WIFI_ANT
SANDAI_WIFI_ANT
CON7701
CPBA206-0102E_0_FPC-0R8MM-2P_WF12002-01200
WF12002-01200
FPC-0R8MM-2P
CON7702
WF12002-01200
FPC-0R8MM-2P
D2300
DIODE  ZENER2_ESD0603_PSUR1610DNV07
PSUR1610DNV07
ESD0603
D2400
DIODE_SOD_323_1N4148WS
1N4148WS
SOD_323
D4201
DIODE  BI_DIR TRIG_ESD0402_ESD5471X
ESD5471X
ESD0402
D4202
DIODE  BI_DIR TRIG_ESD0402_ESD5341N
ESD5341N
ESD0402
D4203
ESD5341N
ESD0402
D4204
ESD5341N
ESD0402
D4205
ESD5341N
ESD0402
D4206
ESD5341N
ESD0402
D4207
ESD5341N
ESD0402
D4208
DIODE_SOD_123_B5819W
B5819W
SOD_123
D5000
B5819W
SOD_123
D9803
ESD5471X
ESD0402
ED2512
ESD5341N
ESD0402
ED2513
ESD5341N
ESD0402
ED5000
ESD5341N
ESD0402
ED5001
ESD5341N
ESD0402
ED5002
ESD5341N
ESD0402
ED5003
ESD5341N
ESD0402
ED5004
DIODE  BI_DIR TRIG_ESD0402_NC
NC
ESD0402
ED5005
NC
ESD0402
ED9601
DIODE  BI_DIR TRIG_ESD0402_ESD5451N
ESD5451N
ESD0402
FB7400
BEAD_L0603_120R-100M
120R-100M
L0603
FB7401
120R-100M
L0603
FB7402
120R-100M
L0603
FB7403
120R-100M
L0603
J2000
JM_0_OPEN_JM
JM
OPEN
J2001
CON5_1R27_BAT-SMD_CON5_1R25
CON5_1R25
BAT-SMD
J2501
OK_118RF24_2_0_CNN24M_0R35_OK_118RF24_2_35
OK_118RF24_2_35
CNN24M_0R35
J2502
SMD4_0_FPC-6PIN-D_SMD4
SMD4
FPC-6PIN-D
J4201
LCM0200CE1A0_3_CNN25_0R30_FH26W_TF
TF
CNN25_0R30_FH26W
J4701
LCM0200CE1A0_7_CNN31_0R30_FH26W_GC02M2_F
GC02M2_F
CNN31_0R30_FH26W
J4702
LCM0200CE1A0_2_CNN31_0R30_FH26W_GC02M2_B
GC02M2_B
CNN31_0R30_FH26W
J5000
FPC_39_3.3_CNN39_0R30_FH26W_FPC-39PIN-0.35MM
FPC-39PIN-0.35MM
CNN39_0R30_FH26W
J7001
SMD4
FPC-6PIN-D
J7002
CON2_0_FPC-0R8MM-2P_CON-0.8MM-2P
CON-0.8MM-2P
FPC-0R8MM-2P
J7003
SMD4_2_FPC-6PIN-D_SMD4
SMD4
FPC-6PIN-D
J9001
SMD4
FPC-6PIN-D
J9900
SHIELD_3P_SHIELD_6R50X0R80_SHIELD_3P
SHIELD_3P
SHIELD_6R50X0R80
J9901
SHIELD_3P
SHIELD_6R50X0R80
J9902
SHIELD_3P
SHIELD_6R50X0R80
J9903
SHIELD_3P
SHIELD_6R50X0R80
J9904
SHIELD_3P
SHIELD_6R50X0R80
J9905
SHIELD_3P
SHIELD_6R50X0R80
J9911
HOLE_HOLE_A_HOLE
HOLE
HOLE_A
J9912
HOLE_HOLE_A_HOLE
HOLE
HOLE_A
J9913
HOLE_HOLE_A_HOLE
HOLE
HOLE_A
J9914
HOLE_HOLE_A_HOLE
HOLE
HOLE_A
J9915
HOLE_HOLE_A_HOLE
HOLE
HOLE_A
L2002
INDUCTORS  OF FERRITE_IND_505015_1.0UH
1.0uH
IND_505015
L2300
INDUCTORS  OF FERRITE_IND_201610_0.47UH
0.47uH
IND_201610
L2301
INDUCTORS  OF FERRITE_IND_252012_0.24UH
0.24uH
IND_252012
L2302
0.47uH
IND_201610
L2303
0.24uH
IND_252012
L2304
0.47uH
IND_201610
L2305
0.24uH
IND_252012
L2306
0.47uH
IND_201610
L2307
0.24uH
IND_252012
L2308
0.47uH
IND_201610
L2309
0.47uH
IND_201610
L2400
INDUCTORS  OF FERRITE_IND_252010_1.0UH
1.0uH
IND_252010
L2401
1.0uH
IND_252010
L2500
INDUCTOR  COM_RP2_0405_NC
NC
RP2_0405
L2501
NC
RP2_0405
L4100
1.0uH
IND_252010
L4101
1.0uH
IND_252010
L4701
INDUCTOR  COM_RP2_0504_NC/MCZ1210DH900L2TA0G
RP2_0504
L4702
RP2_0504
L5000
INDUCTORS  OF FERRITE_IND_404030_10UH
10uH
IND_404030
L6400
INDUCTORS  OF FERRITE_IND_252012_2.2UH
2.2uH
IND_252012
L6401
2.2uH
IND_252012
L7803
0.47uH
IND_201610
Q2400
MOSFET  N_SOT_323_WNM2021-3/TR
WNM2021-3/TR
SOT_323
Q2401
WNM2021-3/TR
SOT_323
Q2402
WNM2021-3/TR
SOT_323
Q3800
MOSFET  N_SOT_23_NC/WNM2016-3/TR
NC/WNM2016-3/TR
SOT_23
Q3801
MOSFET  N_SOT_323_NC/WNM2021-3/TR
NC/WNM2021-3/TR
SOT_323
Q4100
MOSFET  P_SOT_23_WPM2015-3/TR
WPM2015-3/TR
SOT_23
Q4101
NPN_SOT_23_S8050
S8050
SOT_23
Q4201
MOSFET  P_SOT_23_WPM2026-3/TR
WPM2026-3/TR
SOT_23
Q4202
NPN_SOT_23_S8050
S8050
SOT_23
Q4701
NPN_SOT_23_S8050
S8050
SOT_23
Q4702
NPN_SOT_23_S8050
S8050
SOT_23
Q4703
NPN_SOT_23_S8050
S8050
SOT_23
Q4704
NPN_SOT_23_S8050
S8050
SOT_23
Q7000
MOSFET  N_SOT_23_WNM2016-3/TR
WNM2016-3/TR
SOT_23
Q7001
WNM2016-3/TR
SOT_23
U1000
SOC_RK3576_BGA698_16R1X17R2X1R08_RK3576
RK3576
U2003
GAUGE_CW2217BAAC_WLCSP9_0P5_1P74X1P50_CW2217BAAC/SH36ZQ01
CW2217BAAC/SH36ZQ01
U2004
CHARGER_BQ25890_0_QFN24_4R00X4R00X0R80_T_SGM41542YTQF24G/SC89890/BQ25890/SY6970
U2005
DCDC_SGM66055_WLCSP9_1R21X1R21_DCDC_SGM66055_5.0YGTR
WLCSP9_1R21X1R21
U2300
PMIC_RK806S-5_QFN68_7R00X7R00X0R80_T_RK806S-5
RK806S-5
U2400
DCDC_ETA3409_SOT_23_5_TMI3112H
TMI3112H
SOT_23_5
U2401
DCDC_SY8088_SOT_23_5_TMI3112H
TMI3112H
SOT_23_5
U2402
SWITCH_SY6280_SOT_23_5_SGM2590D
SGM2590D
SOT_23_5
U2404
RTC_HYM8563_TSSOP8_3R10X3R10X1R10_HYM8563TS
HYM8563TS
U2407
CW3301_LOAD  SWITCH_WLCSP4_0R80X0R80X0R50_CW3301
CW3301
U2500
USB_FUSB302B_MLP14_2R50X2R50X0R80_HUSB311
HUSB311
U2503
SWITCH_SY6280_SOT_23_5_SY6280AAC/TCS9163/SGM2590D
SOT_23_5
U3800
LPDDR4_1_BGA200_15R00X10R00X0R90_LPDDR4_200P
LPDDR4_200P
U4000
INAND_EMMC_153_2L_BGA153_13RX11R5X0R9_2L_EMMC_B153_2L
EMMC_B153_2L
U4100
NANDFLASH_UFS_153P_FBGA153_11R5X13R0X1R00_UFS_B153
UFS_B153
U4101
TMI3112H
SOT_23_5
U4102
TMI3112H
SOT_23_5
U4200
SGM2590D
SOT_23_5
U4701
LDO_PT5108_SOT_23_5_PT5108E23E-28
PT5108E23E-28
SOT_23_5
U4703
LDO_LP3983S_SOT_23_5_LP3983S
LP3983S
SOT_23_5
U4704
LDO_PT5108_SOT_23_5_PT5108E23E-18
PT5108E23E-18
SOT_23_5
U5000
DS8008_4_SOT_23_5_TCS2109-1.8V
TCS2109-1.8V
SOT_23_5
U5001
DCDC_MP1488_SOT23-6_SY7200A
SY7200A
SOT23-6
U5002
CON  / 10 / AXE510127_0_FP7721_FP7721BX2_E02-AXE510127-0000
FP7721BX2
FP7721
U5003
SWITCH_SY6280_SOT_23_5_NC/SGM2590D
NC/SGM2590D
SOT_23_5
U6400
MODULE_AP627XP_MD55_WIFI_15R0X13R0X1R85_AP6276P
AP6276P
U7000
AUDIO_ES8388_QFN28_4R00X4R00X0R90_T_ES8388
ES8388
U7400
AMPLIFIER_XA2613_BGA15_1R63X1R63X0R63_XA2613
XA2613
U7402
XA2613
U9100
U  / ITG-1010_0_LGA14_3R00X2R50X0R86_ICM-42607-C_U05-ITG-10100-0000
ICM-42607-C
Y1100
CRYSTAL_4P_CRY4_3R20X2R50X0R80_24MHZ
24MHz
CRY4_3R20X2R50X0R80
Y1300
CRYSTAL_4P_CRY4_3R20X2R50X0R80_26MHZ
26MHz
CRY4_3R20X2R50X0R80
Y2400
CRYSTAL_2P_CRY2_3R20X1R50X0R90_32.768KHZ
32.768KHz
CRY2_3R20X1R50X0R90
Y6400
CRYSTAL_4P_CRY4_3R20X2R50X0R80_37.4MHZ
37.4MHz
CRY4_3R20X2R50X0R80
重要提示:PCB作品文件展下载说明
    昨天 19:54
  • 签到天数: 186 天
    发表于 2024-7-12 22:45:03 | 显示全部楼层
    感谢分享,学习学习!
    昨天 12:11
  • 签到天数: 215 天
    发表于 2024-7-14 14:44:55 | 显示全部楼层
