查看: 247|回复: 0
[Allegro17.4以下] LT6911UXC+RTL8211FI_CG+DIMM36M2+LT9611+TXS0108EPWR 做的PCB文件共享
人人为我,我为人人。
社区居民最爱沙发宣传大使奖终身成就奖社区明星忠实会员优秀斑竹奖
发表于 2024-7-22 17:09:08 | 显示全部楼层 |阅读模式
重要提示:PCB作品文件展下载说明
C000PD035-SD3403-CUSTOM-A01.7z (1.82 MB, 下载次数: 2)
REFDES
COMP_DEVICE_TYPE
COMP_VALUE
SYM_NAME
BT1
CON2_CON-SMT-2P-125MM_CON-SMT-2
con-smt-2p-125mm
CON-SMT-2P-125MM
CON1
SATA-HOST_7P__SMD_0_CN_SATA_HOS
MOLEX-473065001
CN_SATA_HOST
CON2
MOLEX-473065001
CN_SATA_HOST
D1
DZ3_0_SD1710A_1SMA13CAT3G
1SMA13CAT3G
SD1710A
D2
D_A_0_HSOD323A_BAT60BE6327
BAT60BE6327
HSOD323A
D3
DZ3_HSOD882_PESD5V0S1BL315
PESD5V0S1BL315
HSOD882
D4
LED2-3_A_2_DIP_LEDX2_LED2-3
LED2-3
DIP_LEDX2
D5
LED_1_LED0603_LED-G-0603
Led-G-0603
LED0603
D6
DIODE_SMA_1N5819
1N5819
SMA
D7
DIODE_SMA_1N5819
1N5819
SMA
D8
RCLAMP3346P_0_BCC7-080-0301L_RC
RCLAMP3346P
BCC7-080-0301L
D9
AZ1045-04F_0_DFN2510P10E_AZ1045
ESD5344D
DFN2510P10E_AZ1045
D10
BAT60BE6327
HSOD323A
D11
ESD5344D
DFN2510P10E_AZ1045
D12
D2-3_D_SOT23_SM12T1G
SM12T1G
SOT23
D13
SM12T1G
SOT23
D14
SM12T1G
SOT23
D15
D_A_SOD323_B5817WS
B5817WS
SOD323
D16
LED_0_LED0402_LED
LED
LED0402
D17
LED_0_LED0402_LED
LED
LED0402
D18
RCLAMP0521P_1_SR0402_RCLAMP0531
RCLAMP0531T
SR0402
D19
PESD5V0S1BL315
HSOD882
D20
DZ_L_HSOD882_PESD5V0S1BL315
PESD5V0S1BL315
HSOD882
D21
PESD5V0S1BL315
HSOD882
D22
LED_0_LED0402_LED
LED
LED0402
D23
LED_0_LED0402_LED
LED
LED0402
D25
BAT60BE6327
HSOD323A
D106
BAT60BE6327
HSOD323A
D116
Led-G-0603
LED0603
F1
FUSE2_0_SF6127_0451005MRL
0451005MRL
SF6127
F2
FS-A_0_SF1206_MF-NSMF150
MF-NSMF150
SF1206
F3
FS-A_0_SF1206_SF1206/1A
SF1206/1A
SF1206
ID1
ID-BOARD_1_ID-BOARD_ID-BOARD
ID-BOARD
ID-BOARD
ID2
ID-BOARD
ID-BOARD
ID3
ID-BOARD
ID-BOARD
ID4
ID-BOARD
ID-BOARD
ID5
ID-BOARD
ID-BOARD
ID6
ID-BOARD
ID-BOARD
ID7
ID-BOARD
ID-BOARD
ID8
ID-BOARD
ID-BOARD
J1
DB19S4_0_HDMI_19P-QJ3119CH16_4A
HDMI-AF-19PIN-DIP
J2
CON3X1X254MM_CON1X3PD1_25_CON1X
con1x3pd1_25
CON1X3PD1_25
J3
PJ-313_2_PJ-313_PJ-313
PJ-313
PJ-313
J4
PJ-313
PJ-313
J5
CON3_CON1X3PD2_PH2.0-3P_180
PH2.0-3P_180
CON1X3PD2
J6
USB-9S4_RUSB9-180-0726A_MOLEX_4
Molex_484040003
RUSB9-180-0726A
J7
CON14_CON1X14PD2MM_NC
NC
CON1X14PD2MM
J8
PH2.0-3P_180
CON1X3PD2
J9
MIPI_90_CON_F_SED90-F-A_MIPI_90
MIPI_90_CON_F
SED90-F-A
J10
HEADER  3_PH-3P_PH-3P
PH-3P
PH-3P
J12
SIP4_SATA_POWER4-200_SIP4
SIP4
SATA_POWER4-200
J13
SIP4
SATA_POWER4-200
J15
4  HEADER_IMX334-HOLE_IMX334-HOL
imx334-hole
IMX334-HOLE
J16
con1x3pd1_25
CON1X3PD1_25
J17
SIMM10S4_B_HSDC10-1614B_SIMM10S
SIMM10S4_B
HSDC10-1614B
J20
DB19S4_0_HDMI_19P-QJ3119CH16__1
HDMI-19P-D057
J23
BNC_MCX-JE_SMA
SMA
MCX-JE
J24
MJ8-SL_5_TH-CN-254X254P-14N-HR9
HR911130C
TH-CN-254X254P-14N-HR911130C1
J25
HR911130C
J67
HDMI-AF-19PIN-DIP
JP1
PHONE  JACK-O_1_DC552X_DC-5521
DC-5521
DC552X
JU1
CON4_PH-4P_PH-4P
PH-4P
PH-4P
L1
L_HSL1008_2.2UH
2.2UH
HSL1008
L2
L_1_SPL0505H_4.7U/3A
4.7U/3A
SPL0505H
L3
L_SL0805_4.7UH
4.7UH
SL0805
L4
L_HSL1008_2.2UH
2.2UH
HSL1008
L5
INDUCTOR_SPL0404B_MPIT3015-2R2M
MPIT3015-2R2M-LF
SPL0404B
L50
L_SPL0707G_SPM6530T-2R2M
SPM6530T-2R2M
SPL0707G
L51
SPM6530T-2R2M
SPL0707G
LB1
LB_SL0603_BLM18PG121SN1D
BLM18PG121SN1D
SL0603
LB2
BLM18PG121SN1D
SL0603
LB3
BLM18PG121SN1D
SL0603
LB4
BLM18PG121SN1D
SL0603
LB5
LB_0_SR0402_LB
LB
SR0402
LB6
BLM18PG121SN1D
SL0603
LB7
BLM18PG121SN1D
SL0603
LB8
BLM18PG121SN1D
SL0603
LB9
BLM18PG121SN1D
SL0603
LB10
BLM18PG121SN1D
SL0603
LB11
LB_0_SR0402_LB
LB
SR0402
LB12
LB_0_SR0402_LB
LB
SR0402
LB13
LB_0_SR0402_LB
LB
SR0402
LB14
LB_0_SR0402_LB
LB
SR0402
LB15
LB_0_SR0402_LB
LB
SR0402
LB16
LB_0_SR0603_0R
0R
SR0603
LB17
LB_SR1206_13.2V/1.5A/LUHAI
13.2V/1.5A/LUHAI
SR1206
LB18
LB_SL0805_LB
LB
SL0805
LB19
LB_SL0805_LB
LB
SL0805
LB20
LB_SL0805_LB
LB
SL0805
LB21
LB_LB0603_BLM18PG121SN1D
BLM18PG121SN1D
LB0603
LB22
BLM18PG121SN1D
LB0603
LB23
LB_SR1206_6V/1.5A/BOURNS
6V/1.5A/BOURNS
SR1206
LB24
13.2V/1.5A/LUHAI
SR1206
LB25
6V/1.5A/BOURNS
SR1206
M1
HOLE-8STARS_0_HOLE160-8STAR_NC
NC
HOLE160-8STAR
M2
NC
HOLE160-8STAR
M3
NC
HOLE160-8STAR
M4
NC
HOLE160-8STAR
P2
TP_MARK_TP
TP
MARK
P3
TP_MARK_TP
TP
MARK
P4
TP_MARK_TP
TP
MARK
P10
TP_MARK_TP
TP
MARK
Q1
BPW37/TO_0_SOT23_BC847ALT1/NPN
BC847ALT1/NPN
SOT23
Q2
BC847ALT1/NPN
SOT23
Q3
FETP-GSD_0_SOT23_AO3401
AO3401
SOT23
Q4
NPN-BEC_2_SOT23_BC847ALT1/NPN
BC847ALT1/NPN
SOT23
Q5
FETP-GSD_0_SOT23_PMOS-GSD
PMOS-GSD
SOT23
Q6
BC847ALT1
SOT23
S1
MSW4_1_SW_90_SW6X6X4.2_SIDE_90
SW6X6X4.2_SIDE_90
SW_90
SW1
SW  TACT-SPST_SW3X6_SMT2P-3X6
SMT2P-3X6
SW3X6
T1
RCLAMP0524P_MLF10-050-0301L_RCL
RCLAMP0524P
MLF10-050-0301L
T2
RCLAMP0524P
MLF10-050-0301L
T3
RCLAMP0524P
MLF10-050-0301L
U1
TXS0102DQER_X2SON8_TXS0102DQER
TXS0102DQER
X2SON8
U2
1117_0_SOT-223_TLV1117-1.8V
TLV1117-1.8V
SOT-223
U3
LT9611_0_QFN64-PAD_LT9611
LT9611
QFN64-PAD
U4
AT24C04_SOP8_AT24C08/NC
AT24C08/NC
SOP8
U5
TXS0102DQER
X2SON8
U6
TXS0108PWR_0_TSSOP20_TXS0108EPW
TXS0108EPWR
TSSOP20
U7
TLV1117-1.8V
SOT-223
U8
SGM8903_SGM8903_SGM8903
SGM8903
SGM8903
U9
TXS0108EPWR
TSSOP20
U10
MAX3485E_0_SOP8-50-150_ADM3485E
ADM3485EAR_REEL7
SOP8-50-150
U11
MAX3232E_SOP16_SP3232EEN
SP3232EEN
SOP16
U12
AT1366X_0_SOT23-5_SY8089AAC
SY8089AAC
SOT23-5
U13
MP1494S_0_TSOT23-8_MP1495DJ-LF-
MP1495DJ-LF-Z
TSOT23-8
U15
DIMM36M2_3_QFN76G_DIMM36M2
DIMM36M2
QFN76G
U16
SPIFLASH-WINBOND25P16_0_SOP8_W2
W25X40BVSSIG
SOP8
U17
1117_0_SOT-223_BL1117-1V8
BL1117-1V8
SOT-223
U18
LT7911C_0_QFN64-PAD_  LT6911UXC
LT6911UXC
QFN64-PAD
U19
AZC199-04S_0_SOT23-6L_ESD5325E
ESD5325E
SOT23-6L
U20
1117_0_SOT-223_BL1117-1V2
BL1117-1V2
SOT-223
U21
TXB0304_4_MLF12A-040-0202L_NLSX
NLSX5014MUTAG
MLF12A-040-0202L
U22
RTL8211FI_CG_QFN40-8211FI_RTL82
RTL8211FI_CG
QFN40-8211FI
U23
ESD5325E
SOT23-6L
U31
GF_MXM2_P230H6_7_AS0B326-S43N_5
gf_mxm2_p230h6
AS0B326-S43N_5
U32
ESD5344D
DFN2510P10E_AZ1045
U33
ESD5344D
DFN2510P10E_AZ1045
U127
MP8765_0_QFN16-8765_MP8765GQ
MP8765GQ
QFN16-8765
U129
MP8765GQ
QFN16-8765
X1
CRYSTAL_0_XT3225_24MHZ
24MHZ
XT3225
X2
CRYSTAL_0_HSX4-0302_25MHZ
25MHZ
HSX4-0302
X4
X_B_HSX4-0302_25MHZ
25MHZ
HSX4-0302
Y1
CRYSTAL_4PIN_XT3225_27MHZ
27MHz
XT3225
重要提示:PCB作品文件展下载说明
