查看: 267|回复: 4
[Allegro17.4以下] ISL58365+DAC8563SDGSR+STM32F405RGT6+USB2514B+ADV7611BSWZ 做的PCB文件主板和核心板
人人为我,我为人人。
社区居民最爱沙发宣传大使奖终身成就奖社区明星忠实会员优秀斑竹奖
发表于 2024-7-23 11:54:08 | 显示全部楼层 |阅读模式
重要提示:PCB作品文件展下载说明
CR001A-DB-P1_V11_20240518_1149.7z (683.69 KB, 下载次数: 12)
CR001A-MB-P1_20240520_2308.7z (2.27 MB, 下载次数: 19)
SCH_pdf格式.zip (319.91 KB, 下载次数: 5)
REFDES
COMP_DEVICE_TYPE
COMP_VALUE
SYM_NAME
B107
10OHM_BLM15AG100SN1D_B0402_10OH
10ohm
B0402
D2
PMEG6020ER_0_SOD-123W_PMEG6020E
PMEG6020ER
SOD-123W
D3
PMEG6020ER
SOD-123W
D15
PMEG6020ER_SOD-123W_PMEG6020ER
PMEG6020ER
SOD-123W
F1
FUSE_R1808_3A
3A
R1808
J1
CONNECTOR-60P-0MM8_CON-2X30P-0M
CONNECTOR-60P-0MM8-2
CON-2X30P-0MM8-PLUG
L1
IND_1.0UH_20%_WPN4020H1R0MT_L40
3.3uH
L404020
L2
3.3uH
L404020
L7
820UH/2512_R2512_820UH/2520
820uH/2520
R2512
L9
INDUCTOR  IRON_L404020_10UH/4.7U
10uH/4.7uH
L404020
L10
INDUCTOR  IRON_L8040_47UH
47uH
L8040
L11
47uH
L8040
L12
47uH
L8040
L13
47uH
L8040
L14
3.3uH
L404020
L15
3.3uH
L404020
L16
820uH/2520
R2512
Q11
MMBT3904_SOT-23_MMBT3904
MMBT3904
SOT-23
T10
CIRCLE  120_F120_2MM
2mm
F120
T12
CIRCLE  120_F120_2MM
2mm
F120
U1
ISL58365_DRTZ_1_TQFN-40_ISL5836
ISL58365
TQFN-40
U2
ISL58365
TQFN-40
U3
ISL58365
TQFN-40
U4
TPS563208DDCR_SOT23-6_TPS563208
TPS563208DDCR
SOT23-6
U5
AD24C02_SOT23-5_AD24C02
AD24C02
SOT23-5
U6
LMC6482AIM_FP_LMC6482IMM_LMC648
LMC6482AIM
FP_LMC6482IMM
U7
DAC8563SDGSR_VSSOP10_DAC8563SDG
DAC8563SDGSR
VSSOP10
U8
LMC6482AIM
FP_LMC6482IMM
U9
LTC6090_FP_LTC6090_LTC6090
LTC6090
FP_LTC6090
U10
LTC6090
FP_LTC6090
U11
LTC6090
FP_LTC6090
U12
TPS563208DDCR
SOT23-6
U17
LT8361_MSE16_12_LT8361
LT8361
MSE16_12
U26
LT8361
MSE16_12
U27
TPS563208DDCR
SOT23-6
U28
TPS563208DDCR
SOT23-6
U33
LMC6482AIM
FP_LMC6482IMM
U34
LTC6090
FP_LTC6090
U35
DAC8563SDGSR
VSSOP10
U36
LMC6482AIM
FP_LMC6482IMM
U41
TLV76601QWDRBRQ1_IC-WSON-8PIN_T
TLV76601QWDRBRQ1
IC-WSON-8PIN
U100
ISL58365
TQFN-40
U115
TPS63700_IC-QFN10-0MM5_TPS63700
TPS63700
IC-QFN10-0MM5
U118
SM3303PSQG_DIP8_P0_65_B3_1X3_1_
SM3303PSQG
DIP8_P0_65_B3_1X3_1
REFDES
COMP_DEVICE_TYPE
COMP_VALUE
SYM_NAME
B1
10ohm
B0402
B2
10ohm
B0402
B3
10ohm
B0402
B4
10ohm
B0402
B5
10ohm
B0402
B6
10ohm
B0402
B7
10ohm
B0402
B8
10ohm
B0402
B9
10ohm
B0402
D1
10S45SP_TO-277_FSV1045V
FSV1045V
TO-277
D2
FSV1045V
TO-277
D3
PMEG6020ER
SOD-123W
D4
PMEG6020ER
SOD-123W
D5
RCLAMP0524P-N_RCLAMP0524P_RCLAM
RCLAMP0524P-N
RCLAMP0524P
D6
RCLAMP0524P-N
RCLAMP0524P
D7
RCLAMP0524P-N
RCLAMP0524P
D8
1N4148WS_SOD-323_1N4148WS
1N4148WS
SOD-323
D9
PMEG6020ER
SOD-123W
D10
1N4148WS
SOD-323
D11
1N4148WS
SOD-323
D12
BLUE,  0603, 46MCD, TOP VIEW_LED
Blue
LEDT160804
D13
1N4148WS
SOD-323
D14
1N4148WS
SOD-323
D15
1N4148WS
SOD-323
D16
1N4148WS
SOD-323
D17
PESDUC2FD5VB_DFN1006-2L_5V  / 0.
5V  / 0.3pF
DFN1006-2L
D18
5V  / 0.3pF
DFN1006-2L
D19
5V  / 0.3pF
DFN1006-2L
D20
5V  / 0.3pF
DFN1006-2L
D21
SJD12C51L01_SOD-123S_SJD12C51L0
SJD12C51L01
SOD-123S
D22
SJD12C51L01
SOD-123S
D23
SJD12C51L01
SOD-123S
D24
SJD12C51L01
SOD-123S
D25
SJD12C51L01
SOD-123S
D26
SJD12C51L01
SOD-123S
D27
SJD12C51L01
SOD-123S
D28
SJD12C51L01
SOD-123S
D29
5V  / 0.3pF
DFN1006-2L
D30
5V  / 0.3pF
DFN1006-2L
D31
5V  / 0.3pF
DFN1006-2L
D32
5V  / 0.3pF
DFN1006-2L
D33
SJD12C51L01
SOD-123S
D34
SJD12C51L01
SOD-123S
D35
SJD12C51L01
SOD-123S
D36
SJD12C51L01
SOD-123S
D37
SJD12C51L01
SOD-123S
D38
SJD12C51L01
SOD-123S
D39
SJD12C51L01
SOD-123S
D40
SJD12C51L01
SOD-123S
D41
5V  / 0.3pF
DFN1006-2L
D42
5V  / 0.3pF
DFN1006-2L
D43
5V  / 0.3pF
DFN1006-2L
D44
5V  / 0.3pF
DFN1006-2L
D45
5V  / 0.3pF
DFN1006-2L
D46
5V  / 0.3pF
DFN1006-2L
D47
5V  / 0.3pF
DFN1006-2L
D48
5V  / 0.3pF
DFN1006-2L
D49
SJD12C51L01
SOD-123S
D75
5V  / 0.3pF
DFN1006-2L
D76
SJD12C51L01_SOD-123S_SJD12C06L0
SJD12C06L01
SOD-123S
D77
SJD12C51L01
SOD-123S
D78
5V  / 0.3pF
DFN1006-2L
D79
5V  / 0.3pF
DFN1006-2L
D80
Blue
LEDT160804
D81
5V  / 0.3pF
DFN1006-2L
D82
5V  / 0.3pF
DFN1006-2L
D83
SJD12C06L01
SOD-123S
D84
5V  / 0.3pF
DFN1006-2L
D85
5V  / 0.3pF
DFN1006-2L
D86
SJD12C51L01_SOD-123S_SJD12C24L0
SJD12C24L01
SOD-123S
D87
5V  / 0.3pF
DFN1006-2L
D88
Blue
LEDT160804
F1
FUSE_R0805_12V/300MA
12V/300mA
R0805
F2
12V/300mA
R0805
F3
12V/300mA
R0805
F4
12V/300mA
R0805
F5
12V/300mA
R0805
F6
12V/300mA
R0805
J1
HDMI-MICRO-FE_HDMI-MICRO_HDMI-M
HDMI-MICRO
HDMI-MICRO
J2
TYPE-C-16P_USB_TYPEC_16P_TYPE-C
TYPE-C-16P
USB_TYPEC_16P
J3
TYPE-C-16P
USB_TYPEC_16P
J4
HDMI-MICRO
HDMI-MICRO
J5
CONNECTOR-60P-0MM8_LD_MD_DS_CON
LD_MD_DS
J6
LD_MD_DS
J7
LD_MD_DS
J8
CON-1X2P-1MM25+2GND_CON-1MM25-2
CON-1X2P-1MM25+2GND
CON-1MM25-2P
J9
TYPE-C-16P
USB_TYPEC_16P
J10
HDMI-MICRO
HDMI-MICRO
J11
HDMI-MICRO
HDMI-MICRO
J12
CON-2X15P-1MM_CON-2X15P-1MM_X10
X1011WRS-2X15-9TV01
CON-2X15P-1MM
J13
HDMI-MICRO
HDMI-MICRO
J14
HDMI-MICRO
HDMI-MICRO
J15
X1011WRS-2X15-9TV01
CON-2X15P-1MM
J16
HDMI-MICRO
HDMI-MICRO
J17
HDMI-MICRO
HDMI-MICRO
J18
X1011WRS-2X15-9TV01
CON-2X15P-1MM
J19
CON-2X3-3MM_CON-2X3-3MM_CON-2X3
CON-2X3-3MM
CON-2X3-3MM
J21
CON-1X2P-1MM25+2GND_CON-2P-1MM2
X1251WRS-02HF-LPSW
CON-2P-1MM25_LOCK
L1
INDUCTOR  IRON_L7X7_3.3UH
3.3uH
L7X7
L2
3.3uH
L7X7
L3
3.3uH
L7X7
L4
3.3uH
L7X7
L5
3.3uH
L7X7
L6
47uH
L8040
L7
47uH
L8040
L8
47uH
L8040
L9
47uH
L8040
L10
10uH/4.7uH
L404020
L11
3.3uH
L404020
L12
INDUCTOR  IRON_L060750_3.3UH
3.3uH
L060750
L13
3.3uH
L060750
L14
3.3uH
L060750
L15
INDUCTOR  IRON_L-8X11-SMD_330UH
330uH
L-8X11-SMD
L16
330uH
L-8X11-SMD
L17
330uH
L-8X11-SMD
L18
330uH
L-8X11-SMD
L19
330uH
L-8X11-SMD
L20
330uH
L-8X11-SMD
MD1
BERRYPI_MD_BERRYPI_MD_BERRYPI_M
BERRYPI_MD
BERRYPI_MD
MD2
FPGA_CORE_MD_FPGA_MD_FPGA_CORE_
FPGA_CORE_MD
FPGA_MD
MH1
SCREW_HOLE_0_HOLE-2MM7-6MM_HOLE
Hole_3.18mm
HOLE-2MM7-6MM
MH2
Hole_3.18mm
HOLE-2MM7-6MM
MH3
Hole_3.18mm
HOLE-2MM7-6MM
MH4
Hole_3.18mm
HOLE-2MM7-6MM
MH5
Hole_3.18mm
HOLE-2MM7-6MM
MH6
Hole_3.18mm
HOLE-2MM7-6MM
MH7
Hole_3.18mm
HOLE-2MM7-6MM
MH8
Hole_3.18mm
HOLE-2MM7-6MM
MH9
Hole_3.18mm
HOLE-2MM7-6MM
Q1
MMBT3904_SOT-723_MMBT3904M
MMBT3904M
SOT-723
Q2
MMBT3904_SOT-723_MMBT3904M_1N
MMBT3904M_1N
SOT-723
Q3
MMBT3904M_1N
SOT-723
Q4
NMOS,  300MA, SOT-723_SOT-723_NM
NMOS
SOT-723
Q5
MMBT3904M_1N
SOT-723
Q6
MMBT3904M_1N
SOT-723
Q7
MMBT3904M_1N
SOT-723
Q8
MMBT3904M_1N
SOT-723
Q9
MMBT3904_SOT-89_NPN
NPN
SOT-89
Q10
MMBT3904_SOT-89_NPN
NPN
SOT-89
Q11
MMBT3904_SOT-89_NPN
NPN
SOT-89
Q12
MMBT3904_SOT-89_NPN
NPN
SOT-89
Q13
MMBT3904M
SOT-723
Q22
MMBT3904M
SOT-723
U1
SCT2432_IC-SOP8_PAD_SCT2432STE
SCT2432STE
IC-SOP8_PAD
U2
SCT2432STE
IC-SOP8_PAD
U3
SCT2432STE
IC-SOP8_PAD
U4
SCT2432STE
IC-SOP8_PAD
U5
SCT2432STE
IC-SOP8_PAD
U6
LT8361
MSE16_12
U7
LT8361
MSE16_12
U8
SGM2036-3.3_SOT23-5_SGM2036-ADJ
SGM2036-ADJ
SOT23-5
U9
USB2514B-I/M2_IC-QFN36-OMM5_USB
USB2514B-I/M2
IC-QFN36-OMM5
U10
AP22653W6-7_SOT23-6_AP22653W6
AP22653W6
SOT23-6
U11
ADV7611BSWZ_ADV7611BSWZ_ADV7611
ADV7611BSWZ
ADV7611BSWZ
U12
MCP2515-I/ST_IC-TSSOP20_MCP2515
MCP2515-I/ST
IC-TSSOP20
U13
TJA1050T/CM_IC-SOP8_SN65HVD230D
SN65HVD230DR
IC-SOP8
U14
HT7133_SOT-23_HT7133
HT7133
SOT-23
U15
LDR6328_IC-SOP8_LDR6328
LDR6328
IC-SOP8
U16
STM32F405RGT6_IC-LQFP64-0MM5_ST
STM32F405RGT6
IC-LQFP64-0MM5
U17
WSD3045DN_IC-QFN8-0MM65_WSD3045
WSD3045DN
IC-QFN8-0MM65
U18
WSD3045DN
IC-QFN8-0MM65
U19
WSD3045DN
IC-QFN8-0MM65
U20
WSD3045DN
IC-QFN8-0MM65
U21
WSD3045DN
IC-QFN8-0MM65
U22
WSD3045DN
IC-QFN8-0MM65
U23
TLV76601QWDRBRQ1
IC-WSON-8PIN
U24
TPS63700
IC-QFN10-0MM5
U25
TPS563208DDCR
SOT23-6
U26
TLV76601QWDRBRQ1
IC-WSON-8PIN
U27
TPS563208DDCR
SOT23-6
U28
TPL0401A-10-Q1_IC-SC70_TPL0401A
TPL0401A-10-Q1
IC-SC70
U29
TPS563208DDCR
SOT23-6
U30
TPL0401A-10-Q1
IC-SC70
U31
TPS563208DDCR
SOT23-6
U32
TPL0401A-10-Q1
IC-SC70
U33
LMC6482AIM_IC-TSSOP8_LMC6482IMM
LMC6482IMM
IC-TSSOP8
U34
BL1551B_IC-SC70_BL1551B
BL1551B
IC-SC70
U35
TLV2333IDGKR_IC-TSSOP8_LMC6482A
LMC6482AIM
IC-TSSOP8
U36
BL1551B
IC-SC70
U37
LMC6482IMM
IC-TSSOP8
U38
LMC6482AIM
IC-TSSOP8
U39
BL1551B
IC-SC70
U40
BL1551B
IC-SC70
U41
LMC6482IMM
IC-TSSOP8
U42
LMC6482AIM
IC-TSSOP8
U43
BL1551B
IC-SC70
U44
BL1551B
IC-SC70
U45
LM358DGKR_IC-TSSOP8_LM358DGKR
LM358DGKR
IC-TSSOP8
U46
LM358DGKR
IC-TSSOP8
U47
LM358DGKR
IC-TSSOP8
U48
LM358DGKR
IC-TSSOP8
U49
AP22653W6
SOT23-6
U50
SIT3232EEUE_IC-TSSOP16-0MM65_SI
SIT3232EEUE
IC-TSSOP16-0MM65
U51
LMC6482IMM
IC-TSSOP8
U52
LMC6482IMM
IC-TSSOP8
U53
LMC6482IMM
IC-TSSOP8
X1
XTAL,  28.63M, 3225, 20PPM, 12PF
28.63636MHz
X3225
Y1
ABM3BX_3225_24MHZ
24MHz
3225
Y2
ABM3BX_3225_20MHZ
20MHz
3225
Y3
ABM3BX_3225_8MHZ
8MHz
3225
重要提示:PCB作品文件展下载说明
    3 天前
  • 签到天数: 94 天
    1元学习Allegro(1期)
    发表于 2024-8-28 22:31:15 | 显示全部楼层
    下载了3次都没下载成功,不知道怎么回事
  • 签到天数: 96 天
    发表于 2024-9-19 10:01:00 | 显示全部楼层
    问你下这个是什么板子   是TEC控制板吗
    Allegro-230921高级班
    发表于 2024-9-29 10:58:04 | 显示全部楼层
    原理图能不能给工程文件?
  • 签到天数: 79 天
    终身成就奖新人进步奖社区居民
    发表于 2024-9-30 09:43:57 | 显示全部楼层
