重要提示:PCB作品文件展下载说明
tdadp-sil-usbc-65w-design-files-20210514.zip
(14.85 MB, 下载次数: 8)
Comment | Pattern | Quantity | Components | | | | | | | | R0603-HD | 1 | R31 | RES SMD 0 OHM 1/10W 0603 | 0 R | R0603-HD | 2 | R18, R50 | RES 0 OHM JUMPER 1/10W 0603 | 1 nF | C0805-HD | 1 | C10 | CAP CER 1000PF 200V X7R 0805 | 1.8 nF | C0603-HD | 1 | C50 | CAP CER 1800PF 25V X7R 0603 | 100nF | C0603-HD | 2 | C34, C37 | CAP CER 0.1UF 50V X7R 0603 | 10k | R0603-HD | 1 | R39 | RES SMD 10K OHM 1% 1/10W 0603 | 10uF | C0603-HD | 2 | C30, C35 | CAP CER 10UF 25V X5R 0603 | 1k | R0603-HD | 1 | R35 | RES SMD 1K OHM 1% 1/10W 0603 | 1M | R0603-HD | 1 | R37 | RES SMD 1M OHM 1% 1/10W 0603 | 1nF | C0603-HD | 1 | C40 | CAP CER 1000PF 25V X7R 0603 | 1uF | C0603-HD | 2 | C41, C48 | CAP CER 1UF 35V X7R 0603 | 200 K | RT0603-HD | 1 | RT3 | THERMISTOR NTC 200K OHM 5% 0603 | 22 K | R0603-HD | 1 | R11 | RES SMD 22K OHM 1% 1/10W 0603 | 22nF | C0603-HD | 1 | C45 | CAP CER 0.022UF 50V X7R 0603 | 270 R | R0603-HD | 1 | R13 | RES SMD 270 OHM 5% 1/10W 0603 | 270pF | C0603-HD | 4 | C36, C38, C39, C42 | CAP CER 270PF 50V X7R 0603 | 33nF | C0603-HD | 3 | C43, C44, C47 | CAP CER 0.033UF 50V X7R 0603 | 4.7k | R0603-HD | 1 | R42 | RES SMD 4.7K OHM 1% 1/10W 0603 | 470 uF | CAP_ALU_6.3x14.7 | 1 | C5 | CAP ALUM 470UF 20% 25V T/H | 47k | R0603-HD | 1 | R44 | RES SMD 47K OHM 1% 1/10W 0603 | 47R | R0603-HD | 2 | R20, R36 | RES SMD 47 OHM 1% 1/10W 0603 | 47uF 16V | CAP_ALU_5x11 | 1 | C33 | CAP ALUM 47UF 20% 16V RADIAL | 5 R | R0805-HD | 1 | R4 | RES SMD 5 OHM 1% 1/5W 0805 | 5.11k | R0603-HD | 1 | R38 | RES SMD 5.1K OHM 1% 1/10W 0603 | 5mohm | R1206-HD | 1 | R25 | RES 0.005 OHM 1% 1W 1206 | 680 uF | CAP_ALU_6.3x16.11 | 1 | C6 | CAP ALUM 680UF 20% 25V T/H | BRIDGERECT_2 | Z4-D_1 | 2 | BR1, BR2 | BRIDGE RECT 1PHASE 1KV 4A Z4-D | CAP Y1 | CT7-400VAC-Y1-B-681K | 1 | C49 | | CAPNP | C0603-HD | 16 | C7, C11, C12, C14, C15, C16, C17, C18, C19, C24, C25, C27, C28, C31, C32, C46 | CAP CER 0.1UF 50V X7R 0603 | CAPNP | C0805-HD | 1 | C4 | TBD CAP 0805 | CAPNP | C1206-HD | 5 | C8, C9, C13, C22, C23 | CAP CER 10UF 25V X7R 1206 | CAPNP | CAP_FILM_13X6P10_1 | 1 | C1 | CAP CER 220NF X2 | CAPPOL | CAP_ALU_10x18P5 | 4 | C2, C3, C26, C29 | CAP ALUM 33UF 20% 400V T/H | CAPPOL | CAP_ALU_6.3x11P2.5 | 1 | C21 | CAP ALUM 68UF 80V 20% T/H | CAPPOL | CAP_ALU_6.3x14P2.5 | 1 | C20 | CAP ALUM 560UF 20% 25V T/H | CMC1324 | CUSTOM_10X15 | 1 | L1 | CMC 9 mH 10X15 | CMC1324 | CUSTOM_4.5x9 | 1 | L2 | CMC 100uH 4.5X9 | CON_UJC-HP-3-SMT-TR | CON_UJC-HP-3-SMT-TR | 1 | J1 | USB JACK, C TYPE, POWER ONLY, 6 | Dcard-TP65H300 | TO-251 | 1 | Q2 | Dcard-GANFET N-CH 650V 6.5A 3PQFN | DIODE | SOD123FA | 2 | D1, D3 | DIODE GEN PURP 1KV 1A SOD123FA | DIODE | SOD123FL | 2 | D6, D7 | 50NS 1A 300V HIGH EFFICIENT RECO | DIODE-SCHOTTKY | SOD323F | 1 | D10 | DIODE SCHOTTKY 100V 250MA SOD323 | DIODE-ZENER | SOD-123 | 1 | Z1 | DIODE ZENER 24V 500MW SOD123 | DIODE-ZENER | SOD123FL | 3 | D4, D8, Z4 | ZENER SOD-123 5.6V 0.5W 2% | DIODE-ZENER | SOD323F | 2 | D2, Z2 | DIODE ZENER 4.7V 200MW | DNI | R0603-HD | 1 | R46 | DNI RES 0603 | DNI | SOD-123 | 1 | Z3 | DNI DIODE SOD-123 | FLYLEAD | FL_1.75MM | 2 | FL1, FL2 | FLYLEAD 1.75MM | FUSE | FUSE_TR2/1025TD3-R | 1 | F1 | FUSE BOARD MNT 3A 250VAC 125VDC | INPUT | HOLE_1.0MM | 2 | L, N | INPUT 1MM HOLE | MOSFET_DMN61D9UDW-7 | SOT363_DMN61D9UDW-7 | 1 | Q3 | MOSFET 2N-CH 60V 0.35A | MOSFET_N_2 | 8-POWERWDFN | 1 | Q4 | MOSFET N-CH 25V 124A 8PQFN | MOSFET_N_2 | PQFN8 5X6 | 1 | Q1 | PTNG 120V N-FET PQFN56 | MP6908AGJ-Z | SOT23-6-HD | 1 | U3 | FAST TURN-OFF INTELLIGENT RECTIF | OPTOISO | TLP383 | 1 | U4 | OPTOISO 5KV TRANSISTOR SO6L | RES | C0805-HD | 4 | R3, R5, R7, R30 | RES SMD 22M OHM 1% 1/4W 0805 | RES | R0402-HD | 3 | R32, R33, R45 | RES SMD 619K OHM 1% 1/16W 0402 | RES | R0603-HD | 21 | R8, R9, R10, R12, R14, R15, R19, R21, R22, R23, R26, R27, R28, R29, R34, R40, R41, R43, R47, R48, R49 | RES SMD 470 OHM 1% 1/10W 0603 | RES | R1206-HD | 6 | R1, R2, R6, R16, R17, R24 | DNI RES 1206 | RM8_2 | RM8_2 | 1 | T1 | TRANSFORMER RM 8 | SZ1130 | SOIC 14L (16L-2L) | 1 | U1 | Flyback PWM Controller with Integrated Active Clamp Circuit | THERMISTOR | RT0402-HD | 1 | RT2 | THERM NTC 100KOHM 4485K 0402 | TP-SMD | SMD TP 1.6x0.8 | 2 | TP1, TP2 | PC TEST POINT NATURAL | VARISTOR | MOV-V430CH8 | 1 | RV1 | VARISTOR 430V 250A 2SMD NO LEAD | VREF | SOT-23-3 | 1 | U5 | IC VREF SHUNT 36V 1% SOT23-3 | WT6633P | QFN65P400X400X80_HS-17N | 1 | U2 | WT6633P USB PD Controller |
重要提示:PCB作品文件展下载说明
