重要提示:PCB作品文件展下载说明
Name | Part Type | PCB Decal | Value | BT1 | RTC | RTC | CR1220 | CN1 | DC44H-A2060RJ03A | DC-044B | DC44H-A2060RJ03A | CN2 | MINI_USB | USB-MICRO | Mini_USB | CN100 | MINI_USB | USB-MICRO | Mini_USB | J1 | SLIM_9M_DIP-0 | DMR-9P | SLIM_9M_DIP | J2 | SLIM_9M_DIP-0 | DMR-9P | SLIM_9M_DIP | J3 | HEADPHONE | HEADPHONE | HeadPhone | J4 | CON1 | ZPK | | J5 | CON1 | ZPK | | J6 | CON1 | ZPK | | J7 | CON1 | ZPK | | JP0 | 2043WV/2.0MM | 2043WV | MHDR1×3 | JP1 | 2-10P/2.0MM | 20PIN2.0MM | 2X15 2.0MM | JP2 | 2043WV/2.0MM | 2043WV | MHDR1×3 | JP3 | 2043WV/2.0MM | 2043WV | MHDR1×3 | JP5 | 2043WV/2.0MM | 2043WV | MHDR1×3 | JP6 | 2043WV/2.0MM | 2043WV | MHDR1×3 | JP7 | 2043WV | 2043WV | 3P 2MM | JP8 | 2-15P/2.0MM | 30PIN2.0MMA | 2X15 2.0MM | JP9 | 2-15P/2.0MM | 30PIN2.0MMA | 2X15 2.0MM | JP10 | 2-15P/2.0MM | 30PIN2.0MMA | 2X15 2.0MM | JP11 | 2-15P/2.0MM | 30PIN2.0MMA | 2X15 2.0MM | JP12 | 2043WV/2.0MM | 2043WV | MHDR1×3 | JP14 | 2542WV | 2542WV | HEADER 2 | JP15 | 2542WV | 2542WV | HEADER 2 | JP23 | 2-16P/2.0MM | 32PIN2.0MM | 2X15 2.0MM | JP100 | 4P/2.54MM | 2544WV | 4-1P2.54MM | K1 | SW_PUSHBUTTON | KEY-3X4.5MM | | K2 | SW_PUSHBUTTON | KEY-3X4.5MM | | K3 | SW_PUSHBUTTON | KEY-3X4.5MM | | K4 | SW_PUSHBUTTON | KEY-3X4.5MM | | LED1 | LED | LED0603 | BLUE | LED2 | LED | LED0603 | BLUE | LED3 | LED | LED0603 | BLUE | LED4 | LED | LED0603 | BLUE | LED5 | LED | LED0603 | BLUE | LED6 | LED | LED0603 | BLUE | LED_PER | LED | LED0603 | RED | P1 | R1206 | R1206 | CC12H3A-TR | P2 | 2043WV/2.0MM | 2043WV | MHDR1×3 | P3 | 2043WV/2.0MM | 2043WV | MHDR1×3 | P4 | 2043WV/2.0MM | 2043WV | MHDR1×3 | Q1 | PNP | SOT_23 | S8550 | SW1 | PH-2.0-5P-LC-CHX | PH-2.0-5P-LC-CHX | PH-2.0-5P-LC-CHX | TP1 | TP | TP_1R00 | | TP2 | TP | TP_1R00 | | U0 | GD32F103C8T6 | LQFP48 | GD32F103C8T6 | U1 | GD32C113VBT6 | LQFP-100 | GD32C113VBT6 | U2 | AMS1117-3.3V | SOT-223 | AMS1117-3.3V | U3 | C23MAX3232CSE+ | SOIC-16 | C23MAX3232CSE+ | U4 | AT24C02C-SSHM-T | SOP8-1.27MM | AT24C02C-SSHM-T | U5 | SPI_FLASH_8PIN_T | SOIC-5X6 | W25Q128JWSSIQ | U6 | NCA1042 | SOP8_4R9X3R9 | NCA1042 | U7 | NCA1042 | SOP8_4R9X3R9 | NCA1042 | U10 | CS4344 | MSOP10-0.65MM | CS4344 | VR1 | VR1 | 2043WV | 10K | Y1 | HC-49SMD-8MHZ | HC-49S | HC-49SMD-8MHZ | Y2 | HC-49SMD-8MHZ | CRY2_6R90X1R40X1R30_B | HC-49SMD-8MHZ | Y101 | HC-49SMD-8MHZ | HC-49S | HC-49SMD-8MHZ |
重要提示:PCB作品文件展下载说明
