TA的每日心情 | 开心 2024-12-11 13:20 |
签到天数: 1 天 [LV.1]初来乍到
管理员
我和白富美只差一个字
- 719
重要提示:PCB作品文件展下载说明
收音机op1112.7z
(812.97 KB, 下载次数: 0)
Name | Part Type | PCB Decal | Value | AMVT | TP | TP | | BLACK | PAD | PADA | | BPF201 | EXC-FF88108L | BPF | | CF201 | FILTER | FAAA | CQB50 | CF202 | FILTER | F1AAA | 10.7MJ | CF203 | F/CDA10.7MG18A | CAPAA | 10.7MG82A | CN201 | CN10P | CN10P/2R | | CN301 | CN5 | CN5C | 5Pin P=2 | CN302 | CN2P | CN2AAA | | CN303 | CON6P | CON6P/2V | 6Pin p=2 | CN304 | CN10P | CN10P/2R | | D201 | DIODE | DIODE7.5MM | 1N4148 | D202 | DIODE | DIODE7.5MM | 1N4148 | D205 | DIO | D12MM | 1N4148 | D301 | DIO | D12MM | 1N4148 | D302 | DIO | D12MM | 1N4148 | D303 | DIODE | DIODE7.5MM | 1N4148 | D304 | DIODE | DIODE7.5MM | 1N4148 | D305 | DIO | D10MMAB | 1N4001 | FMANT | PAD | PADB | | FMVT | TP | TP | | GND | PAD | PAD | | GND1 | J | PAD/3.5ABAAAAA | | GND2 | J | PAD/3.5ABBAAAA | | GND3 | PAD | PAD2.5MMAEAAA | | GND4 | PAD | PAD2.5MMAEAAA | | GND5 | PAD | PAD2.5MMAD | | GREEN | PAD | PADA | | INPUT1 | PAD | PAD2.5MMAEAAA | | J1 | JUMP | J12.5A | 1N4148 | J19 | JUMP | J7.5 | | L | J | PAD/3.5AABAAAAA | | L201 | IND-AX | COIL7 | 0.56uH | L203 | IND\MOLDED | COIL/RF5/CCWA | 5.5mm 2.5T | L204 | IND\MOLDED | COIL/RF5/CCWA | 5.5mm 3.5T | L205 | IND-AX | COIL12A | 10uH | L208 | IND\MOLDED | COIL/RF5/CCWA | 4T5/5.5mm | L301 | 47MH | COIL5MMV | 47mH | L302 | 47MH | COIL5MMV | | L303 | RESSMT | RS0603B | bead | L304 | RESSMT | RS0603B | bead | L305 | RESSMT | RS0603B | bead | L306 | RESSMT | RS0603B | bead | L307 | IND-AX | COIL15 | Ferrite | L308 | IND-AX | COIL10 | 10mm | L309 | RESSMT | RS0603B | bead | L310 | RESSMT | RS0603B | bead | L311 | RESSMT | RS0603B | bead | L312 | RESSMT | RS0603B | bead | L313 | RESSMT | RS0603B | bead | L314 | RESSMT | RS0603B | bead | L315 | RESSMT | RS0603B | bead | L316 | RESSMT | RS0603B | bead | OSC1 | J | PAD/3.5AAAAAA | | OSC2 | J | PAD/3.5AABAAAB | | OUTPUT1 | PAD | PAD2.5MMAEAAA | | Q1A1 | SOT23A | SOT23A | 9014 | Q201 | SOT23A | SOT23A | 9018 | Q202 | SOT23A | SOT23A | 9014 | Q203 | SOT23A | SOT23A | 9014 | Q204 | SOT23A | SOT23A | 9014 | Q205 | SOT23A | SOT23A | 9013 | Q206 | SOT23A | SOT23A | 9013 | Q207 | SOT23A | SOT23A | 9013 | Q208 | SOT23A | SOT23A | 9014 | Q260 | SOT23A | SOT23A | 9014 | Q261 | SOT23A | SOT23A | 9014 | Q262 | SOT23A | SOT23A | 9014 | Q263 | SOT23A | SOT23A | 9014 | Q280 | SOT23A | SOT23A | 9013 | Q281 | TR | 90AA | 8550 | Q301 | SOT23A | SOT23A | 2412k | Q302 | SOT23A | SOT23A | 2412k | Q303 | SOT23A | SOT23A | | Q304 | SOT23A | SOT23A | 2412k | Q305 | SOT23A | SOT23A | 2412k | Q306 | SOT23A | SOT23A | 2412k | Q307 | SOT23A | SOT23A | 8050 | Q308 | SOT23A | SOT23A | 9013 | Q309 | SOT23A | SOT23A | 8550 | Q310 | SOT23A | SOT23AAA | 9013 | Q311 | SOT23A | SOT23A | 9013 | Q312 | SOT23A | SOT23A | | Q313 | SOT23A | SOT23A | 9013 | R | J | PAD/3.5AABAAAAA | | RED | PAD | PADA | | T201 | IFT7 | T77 | | T202 | IFT/10 | IFT/10ABAAAAA | A1014N | T301 | 900-011 | COILAAABAAA | H053 | TS24 | PCAB | PCAB | | U201 | TA2104 | TA2104AFN | SA2104S | U260 | TC9257F | SOP20-P-300 | SC9257S | U301 | TA8142AP | TA8142APAAAA | CD7316CP | VC201 | TC | TC | VC-20P | VC202 | TC | TC | VC-10p | VCC1 | PAD | PAD2.5MMAEAAA | | VD201 | D/SVC | 3330U | SVC348 | VD202 | TUDIO | TUD | 2CC101 | VD203 | TUDIO | TUD | 2CC101 | VD204 | TUDIO | TUD | 2CC101 | VD205 | TUDIO | TUD | 2CC101 | WHITE | PAD | PADA | | X260 | XTAL | XRY | 7.2MHz |
重要提示:PCB作品文件展下载说明
