REFDES | COMP_DEVICE_TYPE | COMP_VALUE | SYM_NAME |
CON1 | USB3-A_5_USB9_A_D_H_F_USB3.0 TYPE-A-9P | USB3.0 TYPE-A-9P | USB9_A_D_H_F |
CON2 | USB3-A_5_USB9_A_D_H_F_USB3.0 TYPE-A-9P | USB3.0 TYPE-A-9P | USB9_A_D_H_F |
CON3 | USB3-A_5_USB9_A_D_H_F_USB3.0 TYPE-A-9P | USB3.0 TYPE-A-9P | USB9_A_D_H_F |
CON4 | USB3-A_5_USB9_A_D_H_F_USB3.0 TYPE-A-9P | USB3.0 TYPE-A-9P | USB9_A_D_H_F |
CON5 | USB3-A_4_USB9_A_D_H_F_USB3.0 TYPE-A-9P | USB3.0 TYPE-A-9P | USB9_A_D_H_F |
CON6 | USB3-A_4_USB9_A_D_H_F_USB3.0 TYPE-A-9P | USB3.0 TYPE-A-9P | USB9_A_D_H_F |
D1 | DZ_L_0_DFN1006-2L_L1D0-W0D6-P0D70-BI_ESD7571N2T5G | ESD7571N2T5G | DFN1006-2L_L1D0-W0D6-P0D70-BI |
D2 | DZ_L_0_DFN1006-2L_L1D0-W0D6-P0D70-BI_ESD7571N2T5G | ESD7571N2T5G | DFN1006-2L_L1D0-W0D6-P0D70-BI |
D3 | DZ_L_0_DFN1006-2L_L1D0-W0D6-P0D70-BI_ESD7571N2T5G | ESD7571N2T5G | DFN1006-2L_L1D0-W0D6-P0D70-BI |
D4 | DZ_L_0_DFN1006-2L_L1D0-W0D6-P0D70-BI_ESD7571N2T5G | ESD7571N2T5G | DFN1006-2L_L1D0-W0D6-P0D70-BI |
D5 | DIODE SCHOTTKY_1_SOD-123_L2D7-W1D6-LS3D7-RD_ZMM5V6 | ZMM5V6 | SOD-123_L2D7-W1D6-LS3D7-RD |
D13 | DZ_L_0_DFN1006-2L_L1D0-W0D6-P0D70-BI_ESD7571N2T5G | ESD7571N2T5G | DFN1006-2L_L1D0-W0D6-P0D70-BI |
D14 | LED_LED-TH_BD4D3-P2D54_LED/BLUE | LED/BLUE | LED-TH_BD4D3-P2D54 |
D15 | LED_LED-TH_BD4D3-P2D54_LED/BLUE | LED/BLUE | LED-TH_BD4D3-P2D54 |
D16 | LED_LED-TH_BD4D3-P2D54_LED/BLUE | LED/BLUE | LED-TH_BD4D3-P2D54 |
D17 | LED_LED-TH_BD4D3-P2D54_LED/BLUE | LED/BLUE | LED-TH_BD4D3-P2D54 |
FB1 | FERRITBEAD_L0603_120R@ | 120R@ | L0603 |
FB2 | FERRITBEAD_L0603_120R@ | 120R@ | L0603 |
J1 | CON2_CONN-TH_A3961WV-2P_A3961WV-2P | A3961WV-2P | CONN-TH_A3961WV-2P |
J14 | CON2_HDR1X2_2R54_H7R5_VM_HEADER2_2.54MM | header2_2.54mm | HDR1X2_2R54_H7R5_VM |
L1 | INDUCTOR_HSL1008_4.7UH | 4.7uH | HSL1008 |
L2 | L_0_L_7D1X6D5X3D0_SMMS0650-4R7M | SMMS0650-4R7M | L_7D1X6D5X3D0 |
L3 | L_0_L_7D1X6D5X3D0_SMMS0650-4R7M | SMMS0650-4R7M | L_7D1X6D5X3D0 |
M1 | HOLE_THC_197X138_CIR_NC | NC | THC_197X138_CIR |
M2 | HOLE_THC_197X138_CIR_NC | NC | THC_197X138_CIR |
M3 | HOLE_THC_197X138_CIR_NC | NC | THC_197X138_CIR |
M4 | HOLE_THC_197X138_CIR_NC | NC | THC_197X138_CIR |
R58 | 4_1.7K,1/10W,1%,SMD0603_R0603_1K | 1K | R0603 |
TP3 | TESTPOINT_0_TP24-SMD_5V | 5V | TP24-SMD |
TP4 | TESTPOINT_0_TP24-SMD_5V | 5V | TP24-SMD |
U1 | G547E1P81U_0_MSOP-8_3X4D9_0D65_G547E1P81U | G547E1P81U | MSOP-8_3X4D9_0D65 |
U2 | FSUSB30MUX_MSOP-10_L3D0-W3D0-P0D50_FSUSB30MUX | FSUSB30MUX | MSOP-10_L3D0-W3D0-P0D50 |
U3 | AZ1045-04F_0.R7G_DFN2510-10_L2D5-W1D0-P0_AZ1045-04F.R7G | AZ1045-04F.R7G | DFN2510-10_L2D5-W1D0-P0 |
U4 | G547E1P81U_0_MSOP-8_3X4D9_0D65_G547E1P81U | G547E1P81U | MSOP-8_3X4D9_0D65 |
U5 | AZ1045-04F_0.R7G_DFN2510-10_L2D5-W1D0-P0_AZ1045-04F.R7G | AZ1045-04F.R7G | DFN2510-10_L2D5-W1D0-P0 |
U6 | VT3491A-QFN16_0_QFN28-3D5X4D5-0D4E_VL161 | VL161 | QFN28-3D5X4D5-0D4E |
U7 | G547E1P81U_0_MSOP-8_3X4D9_0D65_G547E1P81U | G547E1P81U | MSOP-8_3X4D9_0D65 |
U8 | AZ1045-04F_0.R7G_DFN2510-10_L2D5-W1D0-P0_AZ1045-04F.R7G | AZ1045-04F.R7G | DFN2510-10_L2D5-W1D0-P0 |
U9 | AZ1045-04F_0.R7G_DFN2510-10_L2D5-W1D0-P0_AZ1045-04F.R7G | AZ1045-04F.R7G | DFN2510-10_L2D5-W1D0-P0 |
U10 | AZ1045-04F_0.R7G_DFN2510-10_L2D5-W1D0-P0_AZ1045-04F.R7G | AZ1045-04F.R7G | DFN2510-10_L2D5-W1D0-P0 |
U11 | G547E1P81U_0_MSOP-8_3X4D9_0D65_G547E1P81U | G547E1P81U | MSOP-8_3X4D9_0D65 |
U12 | AZ1045-04F_0.R7G_DFN2510-10_L2D5-W1D0-P0_AZ1045-04F.R7G | AZ1045-04F.R7G | DFN2510-10_L2D5-W1D0-P0 |
U13 | VT3538_A0_HUB QFN76_V0_5.13_QFN76-9X9-0D4E_VL817/815_QFN-76_HUB | VL817/815_QFN-76_Hub | QFN76-9X9-0D4E |
U14 | MX25L512COI-12G_SOIJ-8_L5D3-W5D3-P1D27-LS8D3-BL_MX25L512CMI-12G | MX25L512CMI-12G | SOIJ-8_L5D3-W5D3-P1D27-LS8D3-BL |
U15 | MP1494S_5_TSOT23-8_MP1495S | MP1495S | TSOT23-8 |
U16 | MP1494S_5_TSOT23-8_MP1495S | MP1495S | TSOT23-8 |
U17 | AMS1117-3_1.3V_SOT-223_AMS1117-3.3V | AMS1117-3.3V | SOT-223 |
X1 | SMD_CRYSTAL_0_OSC4_3225_SM_25MHZ | 25MHz | OSC4_3225_SM |
