REFDES | COMP_DEVICE_TYPE | COMP_VALUE | SYM_NAME |
B1 | FB-0402_L0402_600R/100M | 600R/100M | L0402 |
B2 | FB-0402_L0402_NC/600R/100M | NC/600R/100M | L0402 |
B3 | FB-0402_L0402_600R/100M | 600R/100M | L0402 |
B4 | FB-0603_L0603_100R-1A | 100R-1A | L0603 |
B5 | FB-0603_L0603_100R-1A | 100R-1A | L0603 |
B6 | FB-0603_L0603_100R-1A | 100R-1A | L0603 |
B7 | FB-0603_L0603_100R-1A | 100R-1A | L0603 |
BAT2 | 1 | CR927 | CSE |
D1 | ESD5451X_ESD0402_ESD5451X-2-TR | ESD5451X-2-TR | ESD0402 |
D2 | ESD5451X_ESD0402_NC/ESD5451X-2- | NC/ESD5451X-2-TR | ESD0402 |
D3 | ESD5451X_ESD0402_ESD5451X-2-TR | ESD5451X-2-TR | ESD0402 |
D4 | ESD9B5VL_ESD0402_ESD5451X | ESD5451X | ESD0402 |
D5 | ESD9B5VL_ESD0402_ESD5451X | ESD5451X | ESD0402 |
D6 | ESD5451X_ESD0402_ESD5451X-2-TR | ESD5451X-2-TR | ESD0402 |
D7 | ESD5451X_ESD0402_ESD5451X-2-TR | ESD5451X-2-TR | ESD0402 |
D12 | ESD5451X_ESD0402_ESD5451X-2-TR | ESD5451X-2-TR | ESD0402 |
D13 | ESD5451X_ESD0402_NC/ESD5451X-2- | NC/ESD5451X-2-TR | ESD0402 |
D14 | DIO-B5819W_SOD155_270H118_B5819 | B5819W | SOD155_270H118 |
D15 | ESD9B5VL_ESD0402_ESD5451X | ESD5451X | ESD0402 |
D16 | ESD9B5VL_ESD0402_ESD5451X | ESD5451X | ESD0402 |
D17 | ESD5451X_ESD0402_ESD5451X-2-TR | ESD5451X-2-TR | ESD0402 |
D18 | DIO-B5819W_SOD155_270H118_B5819 | B5819W | SOD155_270H118 |
D19 | ESD5451X_ESD0402_ESD5451X-2-TR | ESD5451X-2-TR | ESD0402 |
D20 | ESD5451X_ESD0402_ESD5451X-2-TR | ESD5451X-2-TR | ESD0402 |
DC1 | ESD9B5VL_ESD0402_ESD9B5VL-2-TR | ESD9B5VL-2-TR | ESD0402 |
DC2 | ESD9B5VL_ESD0402_ESD9B5VL-2-TR | ESD9B5VL-2-TR | ESD0402 |
DC3 | ESD9B5VL_ESD0402_ESD9B5VL-2-TR | ESD9B5VL-2-TR | ESD0402 |
DC4 | ESD5451X_ESD0402_NC/ESD5451X-2- | NC/ESD5451X-2-TR | ESD0402 |
DC5 | ESD5451X_ESD0402_ESD5451X-2-TR | ESD5451X-2-TR | ESD0402 |
DC6 | ESD9B5VL_ESD0402_ESD9B5VL-2-TR | ESD9B5VL-2-TR | ESD0402 |
DC7 | ESD9B5VL_ESD0402_ESD9B5VL-2-TR | ESD9B5VL-2-TR | ESD0402 |
DC8 | ESD9B5VL_ESD0402_ESD9B5VL-2-TR | ESD9B5VL-2-TR | ESD0402 |
DL1 | DIO-SS16F_SOD250_380H100_SS16F | SS16F | SOD250_380H100 |
DM10 | SPD9103W_SOD323_NC/SPD9103W | NC/SPD9103W | SOD323 |
DM11 | SPD9103W_SOD323_NC/SPD9103W | NC/SPD9103W | SOD323 |
DM12 | SPD4200B_SMB_NC/SPD4200B | NC/SPD4200B | SMB |
DM13 | SPD4200B_SMB_NC/SPD4200B | NC/SPD4200B | SMB |
DP1 | LED-0603-G_LED0603_LED-0603-G | LED-0603-G | LED0603 |
DP2 | LED-0805-R_LED0805_LED-0805-R | LED-0805-R | LED0805 |
DP3 | LED-0805_LED0603_BLUE | BLUE | LED0603 |
DU1 | ESD9B5VL_ESD0402_ESD9B5VL-2-TR | ESD9B5VL-2-TR | ESD0402 |
DU2 | ESD9B5VL_ESD0402_ESD9B5VL-2-TR | ESD9B5VL-2-TR | ESD0402 |
DU3 | ESD5451X_ESD0402_ESD5451X-2-TR | ESD5451X-2-TR | ESD0402 |
DU4 | ESD5451X_ESD0402_ESD5451X-2-TR | ESD5451X-2-TR | ESD0402 |
DU6 | DIO-SS24_SOD362_432H229_SS24 | SS24 | SOD362_432H229 |
DU7 | ESD9B5VL_ESD0402_ESD9B5VL-2-TR | ESD9B5VL-2-TR | ESD0402 |
DU8 | ESD9B5VL_ESD0402_ESD9B5VL-2-TR | ESD9B5VL-2-TR | ESD0402 |
DU9 | ESD5451X_ESD0402_ESD5451X-2-TR | ESD5451X-2-TR | ESD0402 |
DU10 | ESD9B5VL_ESD0402_ESD9B5VL-2-TR | ESD9B5VL-2-TR | ESD0402 |
DU11 | ESD9B5VL_ESD0402_ESD9B5VL-2-TR | ESD9B5VL-2-TR | ESD0402 |
DU12 | ESD5451X_ESD0402_ESD5451X-2-TR | ESD5451X-2-TR | ESD0402 |
FB1 | FB-0603_L0603_100R-1A | 100R-1A | L0603 |
FB2 | FB-0603_L0603_100R-1A | 100R-1A | L0603 |
FB3 | FB-0603_L0603_100R-1A | 100R-1A | L0603 |
FB4 | FB-0603_L0603_100R-1A | 100R-1A | L0603 |
FB5 | FB-0603_L0603_100R-1A | 100R-1A | L0603 |
FB6 | FB-0603_L0603_100R-1A | 100R-1A | L0603 |
FB7 | FB-0603_L0603_NC/100R-1A | NC/100R-1A | L0603 |
FB8 | FB-0603_L0603_100R-1A | 100R-1A | L0603 |
FB10 | FB-0603_L0603_100R-1A | 100R-1A | L0603 |
H1 | HOLE_MTH635D320_HOLE | HOLE | MTH635D320 |
H2 | HOLE_MTH635D320_HOLE | HOLE | MTH635D320 |
H3 | HOLE_MTH635D320_HOLE | HOLE | MTH635D320 |
H4 | HOLE_MTH635D320_HOLE | HOLE | MTH635D320 |
J4 | JUMPER-2_HDR1_2P254B250_508H2_2 | JTAG-SEL | HDR1_2P254B250_508H254 |
J5 | CON1X2-2.54-M_HDR1_2P254B250__1 | CON1X2-2.54-M | HDR1_2P254B250_508H254 |
J6 | CON1X2-2.54-M_HDR1_2P254B250__1 | CON1X2-2.54-M | HDR1_2P254B250_508H254 |
J7 | CON1X2-2.54-M_HDR1_2P254B250__1 | CON1X2-2.54-M | HDR1_2P254B250_508H254 |
J8 | CON1X2-2.54-M_HDR1_2P254B250__1 | CON1X2-2.54-M | HDR1_2P254B250_508H254 |
J9 | CON1X2-2.54-M_HDR1_2P254B250__1 | CON1X2-2.54-M | HDR1_2P254B250_508H254 |
J10 | PHONOJACK_1_SG_PJ_327FBH4_2C_SG | SG_PJ_327FBH4_2C | SG_PJ_327FBH4_2C |
J11 | XH2.54MM-5P-M_HDR1_5P250B570_15 | XH2.54MM-5P-M | HDR1_5P250B570_1500H700 |
J12 | DC3-2.0MM-14P_HDR2_7P200B550_21 | DC3-2.0MM-14P | HDR2_7P200B550_2130H560 |
J14 | CON1X2-2.54-M_HDR1_2P254B250_50 | NC/CON1X2-2.54-M | HDR1_2P254B250_508H254 |
J18 | PJ-327F_HP5B650_1400H500_PJ-327 | PJ-327F | HP5B650_1400H500 |
J20 | CON1X6-2.54-M_HDR1_6P254B250_15 | CON1X6-2.54-M | HDR1_6P254B250_1524H254 |
J22 | DF40HC-90DS-0.4V_SEDSKT90P40B29 | DF40HC(3.0)-90DS-0.4V(58) | SEDSKT90P40B294_2060H290 |
J23 | FPC-26P-0.5MM-B-SDV_FPC28P50B19 | FPC-26P-0.5MM-V | FPC28P50B190_1850H300 |
J24 | FPC-50P-0.5MM-V_FPC52P50B450_30 | FPC-50P-0.5MM-V | FPC52P50B450_3065H520 |
J25 | TD030673_8_FPC34P50B190_2150H30 | 32PIN | FPC34P50B190_2150H300 |
J26 | DF40HC-90DS-0.4V_SEDSKT90P40B_1 | DF40HC-90DS-0.4V | SEDSKT90P40B294_2060H290 |
J27 | JUMPER-2_HDR1_2P254B250_508H254 | NC/CSI-HS/VS | HDR1_2P254B250_508H254 |
J30 | CON1X4-2.54-M_HDR1_4P254B250_10 | CON1X4-2.54-M | HDR1_4P254B250_1016H254 |
J34 | JUMPER-2_HDR1_2P254B250_508H2_1 | 12V-OUT | HDR1_2P254B250_508H254 |
J52 | JUMPER-2_HDR1_2P254B250_508H2_3 | LINEOUTP | HDR1_2P254B250_508H254 |
J53 | JUMPER-2_HDR1_2P254B250_508H2_4 | LINEOUTN | HDR1_2P254B250_508H254 |
J55 | JUMPER-2_HDR1_2P254B250_508H2_5 | BOOT-SEL1 | HDR1_2P254B250_508H254 |
J56 | JUMPER-2_HDR1_2P254B250_508H2_6 | BOOT-SEL0 | HDR1_2P254B250_508H254 |
J57 | CON2X6-2.54-M_HDR2_6P254B500_15 | CON2X6-2.54-M | HDR2_6P254B500_1524H254 |
J59 | XH1.25MM-2P-M_CON2-PT1_25-3_2X4 | NC/XH1.25MM-2P-M | CON2-PT1_25-3_2X4_35H4_8B-UP |
J64 | XH1.25MM-4P-M_CON4-PT1_25-3_2X6 | NC/XH1.25MM-4P-M | CON4-PT1_25-3_2X6_85H4_8A-UP |
J65 | XH1.25MM-7P-M_CON7-PT1_25-3_2X1 | NC/XH1.25MM-7P-M | CON7-PT1_25-3_2X10_6H4_8A-UP |
J66 | XH1.25MM-7P-M_CON7-PT1_25-3_2X1 | NC/XH1.25MM-7P-M | CON7-PT1_25-3_2X10_6H4_8A-UP |
J68 | CON1X4-2.54-M_HDR1_4P254B250__1 | NC/CON1X4-2.54-M | HDR1_4P254B250_1016H254 |
J69 | XH2.54MM-5P-M_HDR1_5P250B570_15 | XH2.54MM-5P-M | HDR1_5P250B570_1500H700 |
J70 | XH1.25MM-4P-M_CON4-PT1_25-3_2X6 | NC/XH1.25MM-4P-M | CON4-PT1_25-3_2X6_85H4_8A-UP |
J71 | JUMPER-2_HDR1_2P254B250_508H2_7 | DBG-CLK | HDR1_2P254B250_508H254 |
J72 | CON1X2-2.54-M_HDR1_2P254B250_50 | NC/CON1X2-2.54-M | HDR1_2P254B250_508H254 |
JC1 | TF-SLOT_SDC13B1450_1472H245_TF- | TF-SLOT | SDC13B1450_1472H245 |
JL5 | FPC-6P-0.5MM-V_FPC8P50B233_850H | FPC-6P-0.5MM-V | FPC8P50B233_850H300 |
JM6 | RJ45-LED_RJ14P102B1645_1650H134 | NC/RJ45-LED | RJ14P102B1645_1650H1346 |
JS1 | DCIN-12V_PWR3B900_1400H1100_DCI | DCIN-12V | PWR3B900_1400H1100 |
JS3 | XH2.0MM-3P-M_CON3-PT2_XH2.0MM-3 | XH2.0MM-3P-M | CON3-PT2 |
JU1 | USB2.0-MICRO-01F_USB9P65B500_69 | USB2.0-MICRO-01F | USB9P65B500_690H240 |
JU2 | JUMPER-2_HDR1_2P254B250_508H2_8 | USB-SEL | HDR1_2P254B250_508H254 |
JU3 | XH1.25MM-5P-M_CON5-PT1_25-3_2X8 | NC/XH1.25MM-5P-M | CON5-PT1_25-3_2X8_1H4_8A-UP |
JU4 | USB2.0-A-02F_USB8P200B512_1925H | NC/USB-A-02F | USB8P200B512_1925H1250 |
JU5 | XH1.25MM-5P-M_CON5-PT1_25-3_2X8 | NC/XH1.25MM-5P-M | CON5-PT1_25-3_2X8_1H4_8A-UP |
JW2 | ANT-IPX_ANT3B300_310H125_ANT-IP | ANT-IPX | ANT3B300_310H125 |
JW3 | ANT-IPX_ANT3B300_310H125_ANT-IP | ANT-IPX | ANT3B300_310H125 |
K1 | KEY-04P-SMD-03_KEY4B450_450H380 | VOL+ | KEY4B450_450H380 |
K2 | KEY-04P-SMD-03_KEY4B450_450H3_1 | VOL- | KEY4B450_450H380 |
K3 | KEY-04P-SMD-03_KEY4B450_450H3_2 | MENU | KEY4B450_450H380 |
K4 | KEY-04P-SMD-03_KEY4B450_450H3_3 | ENTER | KEY4B450_450H380 |
K5 | KEY-04P-SMD-03_KEY4B450_450H3_4 | HOME | KEY4B450_450H380 |
K6 | KEY-04P-SMD-03_KEY4B450_450H3_5 | UBOOT | KEY4B450_450H380 |
KP1 | KEY-04P-SMD-03_KEY4B450_450H3_6 | RESET | KEY4B450_450H380 |
KP2 | KEY-04P-SMD-03_KEY4B450_450H3_7 | PWRON | KEY4B450_450H380 |
KS1 | SW-5P-DIP_SW5B830_1995H520_SW-5 | SW-5P-DIP | SW5B830_1995H520 |
L14 | L-L2520_LP200_250H100_NC/2.2UH- | NC/2.2uH-2A | LP200_250H100 |
LCD1 | LCD-TD043MGEB_FPC42P50B190_2550 | T27P02 | FPC42P50B190_2550H300 |
LCD2 | CON25-0.5MM_CON25-PT0_6-3_6X9H1 | CON25 | CON25-PT0_6-3_6X9H1B |
LL1 | L-L2520_LP200_250H100_10UH-0.9A | 10uH-0.9A-DCR<0.02R | LP200_250H100 |
LP1 | L-L3225_CD32_1UH-2A | 1uH-2A | CD32 |
LP2 | L-L3225_CD32_1UH-2A | 1uH-2A | CD32 |
LP3 | L-L3225_CD32_NC/1UH-2A | NC/1uH-2A | CD32 |
LP4 | L-L3225_CD32_1UH-2A | 1uH-2A | CD32 |
LP5 | L-L3225_CD32_1UH-2A | 1uH-2A | CD32 |
LS1 | L-L8080_LP800_800H420_6.8UH-DCR | 6.8uH-DCR<0.1R-4A | LP800_800H420 |
LW1 | L-L2016_LP2_00X1_60H1_00_4.7UH/ | 4.7uH/1A DCR<0.1R | LP2_00X1_60H1_00 |
LW2 | L-L0805_L0805_0R | 0R | L0805 |
MIC1 | MIC-DGHSEM6050_MIC2B600H500_DGH | DGHSEM6050 | MIC2B600H500 |
MIC2 | MIC-DGHSEM6050_MIC2B600H500_DGH | DGHSEM6050 | MIC2B600H500 |
MIC10 | XH1.25MM-2P-M_CON2-PT1_25-3_2X4 | NC/XH1.25MM-2P-M | CON2-PT1_25-3_2X4_35H4_8B-UP |
MIC20 | XH1.25MM-2P-M_CON2-PT1_25-3_2X4 | NC/XH1.25MM-2P-M | CON2-PT1_25-3_2X4_35H4_8B-UP |
Q3 | NPN-MMBT3904_SOT3P95B130_290H10 | MMBT3904 | SOT3P95B130_290H103 |
Q5 | PMOS-STS2301_SOT3P95B130_290H10 | STS2301 | SOT3P95B130_290H103 |
Q9 | NPN-MMBT3904_SOT3P95B130_290H10 | MMBT3904 | SOT3P95B130_290H103 |
Q12 | NMOS-WNM2021_SOT3P95B130_290H10 | NC/WNM2021 | SOT3P95B130_290H103 |
Q13 | NMOS-WNM2021_SOT3P95B130_290H10 | NC/WNM2021 | SOT3P95B130_290H103 |
Q14 | NMOS-WNM2021_SOT3P95B130_290H10 | NC/WNM2021 | SOT3P95B130_290H103 |
Q15 | NMOS-WNM2021_SOT3P95B130_290H10 | NC/WNM2021 | SOT3P95B130_290H103 |
QC1 | PMOS-STS2301_SOT3P95B130_290H10 | STS2301 | SOT3P95B130_290H103 |
QW3 | NMOS-BSN20_SOT3P95B130_290H103_ | BSN20 | SOT3P95B130_290H103 |
TS1 | TESTPOINT-SMD_TP100_ACIN | ACIN | TP100 |
U1 | AW8010CSR_BGA9P50B145_145H65_AW | AW8010CSR | BGA9P50B145_145H65 |
U3 | SGM2028_SOT5P95B160_300H130_RT9 | RT9078-2.8V | SOT5P95B160_300H130 |
U4 | GPR25L005B_0_SOP10-PT05-MMA7660 | DA380 | SOP10-PT05-MMA7660FC-H1A |
U5 | CS8302_MSOP-8P_NC/NS4890 | NC/NS4890 | MSOP-8P |
U6 | SGM2028_SOT5P95B160_300H130_AP2 | AP2127-2.8V | SOT5P95B160_300H130 |
U23 | XR819S_QFN41P40B500_500H85_XR81 | XR819S | QFN41P40B500_500H85 |
U24 | SY6280_SOT5P95B160_300H130_SY62 | SY6280 | SOT5P95B160_300H130 |
U38 | INA226_SOP10P50B300_300H110_A_I | INA226 | SOP10P50B300_300H110_A |
U39 | INA226_SOP10P50B300_300H110_A_I | INA226 | SOP10P50B300_300H110_A |
U44 | SY8008B_SOT5P95B160_300H130_NC/ | NC/SY8008B | SOT5P95B160_300H130 |
U45 | INA226_SOP10P50B300_300H110_A_I | INA226 | SOP10P50B300_300H110_A |
U46 | INA226_SOP10P50B300_300H110_A_I | INA226 | SOP10P50B300_300H110_A |
U47 | SENSOR-BMA250_LGA12P50B200_200H | NC/SC7A20TR | LGA12P50B200_200H100 |
UD1 | DDR3-FBGA96_BGA96P80B1000_1400H | DDR3-FBGA96 | BGA96P80B1000_1400H120 |
UL1 | SY7200A_SOT6P95B160_290H145_LP3 | LP3380B6F | SOT6P95B160_290H145 |
UL5 | SGM2028_SOT5P95B160_300H130_AP2 | AP2127-2.8V | SOT5P95B160_300H130 |
UM1 | EMMC5.0-BGA169_BGA169P50B1200_1 | value | BGA169P50B1200_1600H100 |
UM2 | SPI-NOR-SOP8_SOP8P127B528_528H1 | value | SOP8P127B528_528H195 |
UM3 | SPI-NOR-SOP16_SOP16P127B749_102 | value | SOP16P127B749_1029H264 |
UM4 | H1601CG_SOP16P127B690_1260H584_ | H1601CG | SOP16P127B690_1260H584 |
UP1 | AXP2101_0_QFN41P40B500_500H75_A | AXP2101 | QFN41P40B500_500H75 |
UP2 | SGM2028_SOT5P95B160_300H130_A_1 | AP2127K-1.8TRG1 | SOT5P95B160_300H130 |
US1 | SY8105_SOT6P95B160_290H145_SY81 | SY8105 | SOT6P95B160_290H145 |
UU1 | V853_0621_BGA318P50B1200_1200H1 | V853 | BGA318P50B1200_1200H113 |
UU3 | SGM7227_SOP10P50B300_300H110_NC | NC/SGM7227 | SOP10P50B300_300H110 |
UU4 | GL850G_SSOP28-5_3X10_2PT0_65H2A | NC/GL850G-SSOP28 | SSOP28-5_3X10_2PT0_65H2A |
UW1 | AP6XXX_0_SUB_WIFI44B1200_1200H1 | AP6255 | SUB_WIFI44B1200_1200H150 |
X1 | CRY-32.768KHZ-3215-SMD_CRYSTAL- | ETST00327000JE | CRYSTAL-2P-3215-H0_85A |
Y1 | CRY-24MHZ-3225-SMD_X4B250_320H1 | 24M-16pF-10ppm | X4B250_320H120_SMD |
Y3 | CRY-24MHZ-3225-SMD-WIFI_0_X4B25 | 24M-16pF-10ppm | X4B250_320H120_SMD |
Y4 | CRY-12MHZ-3225-SMD_X4B250_320H1 | 12M-20pF-10ppm | X4B250_320H120_SMD |
YW1 | CRY-37.4MHZ-3225-SMD_X4B250_320 | 26M/37.4M-12pF-10ppm | X4B250_320H120_SMD |
