查看: 61|回复: 4
[Pads_VX.2x] 国芯车载DSP DEMO板 CCD5001+ADAU1962A+ADAU1979+AD2428WCCSZ
    终身成就奖社区居民忠实会员宣传大使奖优秀斑竹奖
    发表于 4 天前 | 显示全部楼层 |阅读模式
    重要提示:PCB作品文件展下载说明
    转换的PADS格式。仅供参考。有错误。不要拿去商用
    CCD5001_pads.7z (381.37 KB, 下载次数: 1)
    NamePart TypePCB Decal
    C414CAP_C0805_2700PF/16VC0805
    C415CAP+_CAPAE430X540N_10UF/16VCAPAE430X540N
    C416CAP_C0805_2700PF/16VC0805
    C417CAP+_CAPAE430X540N_10UF/16VCAPAE430X540N
    C418CAP_C0805_2700PF/16VC0805
    C419CAP+_CAPAE430X540N_10UF/16VCAPAE430X540N
    C420CAP_C0805_2700PF/16VC0805
    C421CAP+_CAPAE430X540N_10UF/16VCAPAE430X540N
    C422CAP0805_C0603_1UF/25VC0603
    C423CAP0805_C0603_0.1UF/25VC0603
    D1DIODE_0_SOD-323-MA729_CDBU0130LSOD-323-MA729
    D2DIODE_0_SOD-323-MA729_ZLLS400SOD-323-MA729
    D3DIODE_0_SOD-123_TPSMF4L28ASOD-123
    D4DIODE_0_SOD-123_CDBU0130LSOD-123
    D5PESDNC3D12VB_DO-214AA_SMBJ12CADO-214AA
    D6PESDNC3D12VB_SOD_123_SMF3.3CASOD_123
    D7PESDNC3D12VB_SOD_123_SMF3.3CASOD_123
    D8PESDNC3D12VB_SOD_123_SMF3.3CASOD_123
    D9PESDNC3D12VB_SOD_123_SMF3.3CASOD_123
    D10PESDNC3D12VB_SOD_123_SMF3.3CASOD_123
    D11PESDNC3D12VB_SOD_123_SMF3.3CASOD_123
    D12PESDNC3D12VB_SOD_123_SMF3.3CASOD_123
    D13PESDNC3D12VB_SOD_123_SMF3.3CASOD_123
    FB2FB_FB0603_120_OHM/2AFB0603
    FB3FB_FB0603_120_OHM/2AFB0603
    FB5FB_FB0603_120_OHM/2AFB0603
    FB9FB_FB0603_120_OHM/2AFB0603
    FB10FB_FB0603_120_OHM/2AFB0603
    HOLE1HOLE3MM_HOLE3MM_HOLE3MMHOLE3MM
    HOLE2HOLE3MM_HOLE3MM_HOLE3MMHOLE3MM
    HOLE3HOLE3MM_HOLE3MM_HOLE3MMHOLE3MM
    HOLE4HOLE3MM_HOLE3MM_HOLE3MMHOLE3MM
    J10SIP3_SIP3_SIP3SIP3
    J11JUMPER_SIP2_JUMPERSIP2
    J12JUMPER_SIP2_JUMPERSIP2
    J13JUMPER_SIP2_JUMPERSIP2
    J14JUMPER_SIP2_JUMPERSIP2
    J15JUMPER_SIP2_JUMPERSIP2
    J16SIP3_SIP3_SIP3SIP3
    J17SIP2_0_DURACLIK_502352-0200_502DURACLIK_502352-0200
    J18SIP2_0_DURACLIK_502352-0200_502DURACLIK_502352-0200
    J19SIP2_SIP2_SIP2SIP2
    J265SIP4_SIP4_SIP4SIP4
    J269CON2X10_CON2X10_254MM_M_CON2X10CON2X10_254MM_M
    J270JUMPER_SIP2_JUMPERSIP2
    J273DB9_DB9-FM_DB9_FEMALEDB9-FM
    J274SIP3_SIP3_SIP3SIP3
    J285JUMPER_SIP2_JUMPERSIP2
    J286JUMPER_SIP2_JUMPERSIP2
    J289TP_SIP1_TPSIP1
    J295SIP2_SIP2_SIP2SIP2
    J296PHONEJACK_STEREO_SJ_3523_SMT_CUCUI_SJ3523SMTTR
    J297PHONEJACK_STEREO_SJ_3523_SMT_CUCUI_SJ3523SMTTR
    J298PHONEJACK_STEREO_SJ_3523_SMT_CUCUI_SJ3523SMTTR
    J299JUMPER_SIP2_JUMPERSIP2
    J300JUMPER_SIP2_JUMPERSIP2
    J301PHONEJACK_STEREO_SJ_3523_SMT_CUCUI_SJ3523SMTTR
    J302JUMPER_SIP2_JUMPERSIP2
    J303JUMPER_SIP2_JUMPERSIP2
    J304PHONEJACK_STEREO_SJ_3523_SMT_CUCUI_SJ3523SMTTR
    J305PHONEJACK_STEREO_SJ_3523_SMT_CUCUI_SJ3523SMTTR
    J306SIP5_SIP5_SIP5SIP5
    J307TP_SIP1_TPSIP1
    J308TP_SIP1_TPSIP1
    J309TP_SIP1_TPSIP1
    J311TP_SIP1_TPSIP1
    J313SIP7_SIP7_SIP7SIP7
    J314JUMPER_SIP2_JUMPERSIP2
    J315SIP6_SIP6_SIP6SIP6
    J316JUMPER_SIP2_JUMPERSIP2
    J317JUMPER_SIP2_JUMPERSIP2
    J318SIP9_3_5MM_EDGE_9P_3_5MM_EDGE_93_5MM_EDGE_9P
    L2L_1_FB0603_600FB0603
    L3L_1_FB0603_600FB0603
    L4L_1_FB0603_600FB0603
    L5L_1_FB0603_600FB0603
    L6L_1_FB0603_600FB0603
    L7L_1_INDC2012X145N_3.3UHINDC2012X145N
    L8L_1_INDC1005X55N_180NHINDC1005X55N
    L9L_1_INDC2012X105N_1000INDC2012X105N
    L10L_1_INDC2012X105N_1000INDC2012X105N
    L11L_1_INDC2012X145N_3.3UHINDC2012X145N
    L12L_1_INDC1005X55N_180NHINDC1005X55N
    L13L_1_INDC2012X145N_3.3UHINDC2012X145N
    L14L_1_INDC1005X55N_180NHINDC1005X55N
    L15L_1_INDC2012X105N_1000INDC2012X105N
    L16L_1_INDC2012X105N_1000INDC2012X105N
    L17L_1_INDC2012X145N_3.3UHINDC2012X145N
    L18L_1_INDC1005X55N_180NHINDC1005X55N
    L19L_LSM2_5R7X5R4_H3_6.8UH_2.0ALSM2_5R7X5R4_H3
    L20L_LSM2_5R7X5R4_H3_6.8UH_2.0ALSM2_5R7X5R4_H3
    LED1LED_0_LED0805_REDLED0805
    LED2LED_0_LED0805_REDLED0805
    LED3LED_LED0805_REDLED0805
    LED4LED_LED0805_REDLED0805
    LED9LED_LED0805_REDLED0805
    Q1IRL6402_SOT-23-3_IRML6402SOT-23-3
    Q2PNP_1_SOT-223_FZT953SOT-223
    SW1SW-P-5_SPDT-SWITCH_SW-P-5SPDT-SWITCH
    SW2SWITCH_SW_6X6_SWITCHSW_6X6
    U1W25Q128FVSSIG_SOIC8_1R27_5R28X7SOIC8_1R27_5R28X7R9
    U45962-9211701_SOP8_AD8606ARZSOP8
    U55962-9211701_SOP8_AD8606ARZSOP8
    U65962-9211701_SOP8_AD8606ARZSOP8
    U75962-9211701_SOP8_AD8606ARZSOP8
    U12BL8033_SOT-23-6_BL8033SOT-23-6
    U16AD2428WCCSZ_0_QFN50P500X500X80-QFN50P500X500X80-33W4N
    U17SCM7038F-701_0_IND_ACT1210_2600IND_ACT1210
    U18SCM7038F-701_0_IND_ACT1210_2600IND_ACT1210
    U19ICS_ADAU1962A_2_QFP65P1600X1600QFP65P1600X1600X160-80N
    U25ADAU1979_QFN50P600X600X80-41W2NQFN50P600X600X80-41W2N
    U26CCD5001_LQFP120_1_LQFP120_16MMXLQFP120_16MMX16MM_SCK
    U27BL8033_SOT-23-6_BL8033SOT-23-6
    U29MAX3232CSE_SOIC16_MAX3232IDRSOIC16
    U30RCA_2_RCJ-2221_RCARCJ-2221
    U31SN65LVDS2DBVR_SOT23-5_SN65LVDS2SOT23-5
    U33SN74LVC1G08_0_SOT23-5_SN74LVC1GSOT23-5
    U35ASM1117-ADJ_SOT-223_LD1117-ADJSOT-223
    U39ASM1117-ADJ_SOT-223_1117-5.0SOT-223
    U40ASM1117-ADJ_SOT-223_1117-1.8SOT-223
    X4CRYSTAL_HXO-3225_24.576M_OSCHXO-3225
    Y3XV_CRY3225_24.576MHZ/25MHZCRY3225
    重要提示:PCB作品文件展下载说明
    昨天 08:41
  • 签到天数: 166 天
    1元学习Allegro(1期)
    终身成就奖优秀斑竹奖特殊贡献奖原创先锋奖
    发表于 3 天前 | 显示全部楼层
    2 小时前
  • 签到天数: 274 天
    发表于 3 天前 | 显示全部楼层
    3 天前
  • 签到天数: 76 天
    发表于 3 天前 | 显示全部楼层
    3 天前
  • 签到天数: 77 天
    1元学习Allegro(1期)
    社区居民终身成就奖特殊贡献奖
    发表于 3 天前 | 显示全部楼层
    感谢分享,楼主有没有规格书工具之类的资料呢?
