REFDES | COMP_DEVICE_TYPE | COMP_VALUE | SYM_NAME |
D1 | DIODE TVS BI-DIR_0_X4DFN2_0201_ESDL2011PFCT5G/NC | ESDL2011PFCT5G/NC | X4DFN2_0201 |
D17 | SK34,D_LL34_0_DO-214AB_SMC_SK34/NC | SK34/NC | DO-214AB_SMC |
D19 | SK34,D_LL34_1_SOD-323_1N4148 | 1N4148 | SOD-323 |
D20 | SK34,D_LL34_0_DO-214AB_SMC_SK34/NC | SK34/NC | DO-214AB_SMC |
D21 | SK34,D_LL34_0_DO-214AB_SMC_SK34/NC | SK34/NC | DO-214AB_SMC |
DCJ1 | DCJACK-AJ210AC_0_PW_PLUG_DCAC-XAP-A | DCAC-XAP-A | PW_PLUG |
ESD3 | RCLAMP0544T_0_DFN2510A-10_PUSB3AB4(NC) | PUSB3AB4(NC) | DFN2510A-10 |
ESD4 | RCLAMP0544T_0_DFN2510A-10_PUSB3AB4(NC) | PUSB3AB4(NC) | DFN2510A-10 |
ESD5 | RCLAMP0544T_0_DFN2510A-10_PUSB3AB4(NC) | PUSB3AB4(NC) | DFN2510A-10 |
ESD6 | PGB1010603MR_SOD962-2_PESD2V8R1BSF/NC_ESD105B102ELSE6327XTSA1 | PESD2V8R1BSF/NC | SOD962-2 |
ESD29 | PGB1010603MR_SOD962-2_PESD2V8R1BSF/NC_ESD105B102ELSE6327XTSA1 | PESD2V8R1BSF/NC | SOD962-2 |
FB1 | BEAD_R0402_BLE32PN260SN1 | BLE32PN260SN1 | R0402 |
FB2 | BEAD_R0402_BLE32PN260SN1 | BLE32PN260SN1 | R0402 |
FB3 | BEAD_R0402_BLE32PN260SN1 | BLE32PN260SN1 | R0402 |
FB4 | BEAD_R0402_BLE32PN260SN1 | BLE32PN260SN1 | R0402 |
FB5 | BEAD_R0402_BLE32PN260SN1 | BLE32PN260SN1 | R0402 |
FB6 | BEAD_R0402_BLE32PN260SN1 | BLE32PN260SN1 | R0402 |
H1 | H1-8VIA_MH_3R2_8VIA_H1-8VIA | H1-8VIA | MH_3R2_8VIA |
H2 | H1-8VIA_MH_3R2_8VIA_H1-8VIA | H1-8VIA | MH_3R2_8VIA |
H3 | H1-8VIA_MH_3R2_8VIA_H1-8VIA | H1-8VIA | MH_3R2_8VIA |
H4 | H1-8VIA_MH_3R2_8VIA_H1-8VIA | H1-8VIA | MH_3R2_8VIA |
J1 | 1R3P-6_1_JUMPER_1R2P-6 | 1R2P-6 | JUMPER |
J2 | 1R3P-6_1_JUMPER_1R2P-6 | 1R2P-6 | JUMPER |
J3 | 1R3P-6_1_JUMPER_1R2P-6 | 1R2P-6 | JUMPER |
J4 | 1R3P-6_1_JUMPER_1R2P-6 | 1R2P-6 | JUMPER |
J5 | USB_C_0_USB4_PUC050_USB_TYPEC | USB_TypeC | USB4_PUC050 |
J6 | 1R3P-6_5_SIP1_1R1P-6 | 1R1P-6 | SIP1 |
J7 | 1R3P-6_1_JUMPER_1R2P-6 | 1R2P-6 | JUMPER |
J8 | CON2_JUMPER_CON 2 | CON 2 | JUMPER |
J9 | CON2_JUMPER_CON 2 | CON 2 | JUMPER |
J10 | CON2_JUMPER_CON 2 | CON 2 | JUMPER |
J11 | CON2_JUMPER_CON 2 | CON 2 | JUMPER |
J13 | CON2_JUMPER_CON 2 | CON 2 | JUMPER |
J17 | 1R3P-6_5_SIP1_1R1P-6 | 1R1P-6 | SIP1 |
J33 | 1R3P-6_5_SIP1_1R1P-6 | 1R1P-6 | SIP1 |
J57 | CON2_JUMPER_CON 2 | CON 2 | JUMPER |
J58 | CON2_JUMPER_CON 2 | CON 2 | JUMPER |
J59 | 1R3P-6_1_JUMPER_1R2P-6 | 1R2P-6 | JUMPER |
J60 | CON2_JUMPER_CON 2 | CON 2 | JUMPER |
J61 | CON2_JUMPER_CON 2 | CON 2 | JUMPER |
J62 | 1R3P-6_1_JUMPER_1R2P-6 | 1R2P-6 | JUMPER |
J63 | CON2_JUMPER_CON 2 | CON 2 | JUMPER |
J64 | CON2_JUMPER_CON 2 | CON 2 | JUMPER |
J65 | CON2_JUMPER_CON 2 | CON 2 | JUMPER |
J66 | CON2_JUMPER_CON 2 | CON 2 | JUMPER |
J67 | 1R3P-6_1_JUMPER_1R2P-6 | 1R2P-6 | JUMPER |
J68 | CON2_JUMPER_CON 2 | CON 2 | JUMPER |
J69 | CON6_SIP6_CON 6 | CON 6 | SIP6 |
J70 | 1X4P_FL-SIP2_54-4P_1X4P-6 | 1X4P-6 | FL-SIP2_54-4P |
J71 | DPCON_SOURCE_DPCONNECTOR_2D1_DPCON_SOURCE | DPCON_SOURCE | DPCONNECTOR_2D1 |
J72 | DPCON_SOURCE_DPCONNECTOR_2D1_DPCON_SOURCE | DPCON_SOURCE | DPCONNECTOR_2D1 |
J73 | CON2_JUMPER_CON 2 | CON 2 | JUMPER |
J74 | CON2_JUMPER_CON 2 | CON 2 | JUMPER |
J75 | CON2_JUMPER_CON 2 | CON 2 | JUMPER |
J76 | 1X4P_FL-SIP2_54-4P_1X4P-6 | 1X4P-6 | FL-SIP2_54-4P |
J77 | SIP3_0_FL-SIP2_54-3P_1R3P-6 | 1R3P-6 | FL-SIP2_54-3P |
J78 | CON2_JUMPER_CON 2 | CON 2 | JUMPER |
J79 | SIP3_0_FL-SIP2_54-3P_1R3P-6 | 1R3P-6 | FL-SIP2_54-3P |
J80 | HDMI_HDMI2D1_SMT_HDMI_CON | HDMI_CON | HDMI2D1_SMT |
J82 | CON2_JUMPER_CON 2 | CON 2 | JUMPER |
J83 | CON2_JUMPER_CON 2 | CON 2 | JUMPER |
J86 | CON2_JUMPER_CON 2 | CON 2 | JUMPER |
J87 | CON2_JUMPER_CON 2 | CON 2 | JUMPER |
J88 | CON2_JUMPER_CON 2 | CON 2 | JUMPER |
J89 | CON2_JUMPER_CON 2 | CON 2 | JUMPER |
J90 | CON2_JUMPER_CON 2 | CON 2 | JUMPER |
J91 | 1R3P-6_1_JUMPER_1R2P-6 | 1R2P-6 | JUMPER |
J92 | 1R3P-6_1_JUMPER_1R2P-6 | 1R2P-6 | JUMPER |
J93 | 1R3P-6_1_JUMPER_1R2P-6 | 1R2P-6 | JUMPER |
J108 | CON2_JUMPER_CON 2 | CON 2 | JUMPER |
J109 | JUMPER_JUMPER_CON 2 | CON 2 | JUMPER |
J110 | CON10_HEADER_DIP10_2X2D54MM_D102_CON10_HEADER | CON10_HEADER | DIP10_2X2D54MM_D102 |
J111 | CON2_JUMPER_CON 2 | CON 2 | JUMPER |
J112 | CON2_JUMPER_CON 2 | CON 2 | JUMPER |
JP1 | 1R3P-6_0_SIP3_1R3P-6 | 1R3P-6 | SIP3 |
JP2 | 1R3P-6_0_SIP3_1R3P-6 | 1R3P-6 | SIP3 |
JP3 | 1R3P-6_0_SIP3_1R3P-6 | 1R3P-6 | SIP3 |
JP4 | 1R3P-6_0_SIP3_1R3P-6 | 1R3P-6 | SIP3 |
JP5 | 1R3P-6_0_SIP3_1R3P-6 | 1R3P-6 | SIP3 |
JP6 | 1R3P-6_0_SIP3_1R3P-6 | 1R3P-6 | SIP3 |
JP7 | 1R3P-6_0_SIP3_1R3P-6 | 1R3P-6 | SIP3 |
JP8 | 1R3P-6_1_JUMPER_1R2P-6 | 1R2P-6 | JUMPER |
JP9 | SIP3_0_FL-SIP2_54-3P_1R3P-6 | 1R3P-6 | FL-SIP2_54-3P |
K1 | BOTT4_SMD_BUTTON_BOTT1 | BOTT1 | SMD_BUTTON |
K2 | BOTT4_SMD_BUTTON_BOTT1 | BOTT1 | SMD_BUTTON |
K3 | BOTT4_SMD_BUTTON_BOTT4 | BOTT4 | SMD_BUTTON |
K4 | BOTT4_SMD_BUTTON_BOTT1 | BOTT1 | SMD_BUTTON |
K5 | BOTT4_SMD_BUTTON_BOTT1 | BOTT1 | SMD_BUTTON |
L1 | L_EMI-744232090_L1206-4P_744232090_744232090 | 744232090 | 744232090 |
L2 | L_EMI-744232090_L1206-4P_744232090_744232090 | 744232090 | 744232090 |
L3 | INDUCTOR_FL-L7X7_6.8UH | 6.8uH | FL-L7X7 |
L4 | INDUCTOR_FL-L7X7_6.8UH | 6.8uH | FL-L7X7 |
L5 | INDUCTOR_LQH3NP_1UH/3A | 1uH/3A | LQH3NP |
L6 | INDUCTOR_LQH3NP_0.47UH/3A | 0.47uH/3A | LQH3NP |
L7 | BEAD_1206_BLE32PN260SN1 | BLE32PN260SN1 | 1206 |
L8 | BEAD_1206_BLE32PN260SN1 | BLE32PN260SN1 | 1206 |
L10 | BEAD_1206_BLE32PN260SN1 | BLE32PN260SN1 | 1206 |
L11 | BEAD_0603_BLM18KG331SN1D | BLM18KG331SN1D | 603 |
L12 | BEAD_1206_BLM31PG121SN1L | BLM31PG121SN1L | 1206 |
L13 | BEAD_0603_BLM31KN271BH1L | BLM31KN271BH1L | 603 |
L14 | BEAD_0603_BLM31KN271BH1L | BLM31KN271BH1L | 603 |
L15 | INDUCTOR_LQH3NP_0.47UH/3A | 0.47uH/3A | LQH3NP |
L16 | INDUCTOR_LQH3NP_0.47UH/3A | 0.47uH/3A | LQH3NP |
L17 | BEAD_1206_BLE32PN260SN1 | BLE32PN260SN1 | 1206 |
L18 | BEAD_1206_BLE32PN260SN1 | BLE32PN260SN1 | 1206 |
L19 | BEAD_1206_BLE32PN260SN1 | BLE32PN260SN1 | 1206 |
L20 | BEAD_1206_BLE32PN260SN1 | BLE32PN260SN1 | 1206 |
L21 | BEAD_1206_BLE32PN260SN1 | BLE32PN260SN1 | 1206 |
L22 | BEAD_1206_BLE32PN260SN1 | BLE32PN260SN1 | 1206 |
L23 | BEAD_1206_BLE32PN260SN1 | BLE32PN260SN1 | 1206 |
L24 | BEAD_1206_BLE32PN260SN1 | BLE32PN260SN1 | 1206 |
L25 | INDUCTOR_LQH3NP_0.47UH/3A | 0.47uH/3A | LQH3NP |
L26 | L_2220A_MWSA0804S_1UH | 1uH | MWSA0804S |
L27 | 4.7UH,4_0.2A,20%,SMD_SB0805_FL-L3X3_0.47UH/3A | 0.47uH/3A | FL-L3X3 |
L28 | 4.7UH,4_0.2A,20%,SMD_SB0805_FL-L3X3_0.47UH/3A | 0.47uH/3A | FL-L3X3 |
L29 | L_EMI-744232090_L1206-4P_744232090_744232090 | 744232090 | 744232090 |
L30 | L_EMI-744232090_L1206-4P_744232090_744232090 | 744232090 | 744232090 |
L31 | L_EMI-744232090_L1206-4P_744232090_744232090 | 744232090 | 744232090 |
L32 | L_EMI-744232090_L1206-4P_744232090_744232090 | 744232090 | 744232090 |
L33 | L_EMI-744232090_L1206-4P_744232090_744232090 | 744232090 | 744232090 |
L34 | BEAD_1206_BLE32PN260SN1 | BLE32PN260SN1 | 1206 |
L35 | BEAD_1210_BLM31PG500SN1L | BLM31PG500SN1L | 1210 |
L36 | BEAD_0603_BLM18KG331SN1D | BLM18KG331SN1D | 603 |
L37 | INDUCTOR_FL-L7X7_6.8UH | 6.8uH | FL-L7X7 |
L38 | INDUCTOR_LQH3NP_0.47UH/3A | 0.47uH/3A | LQH3NP |
L39 | INDUCTOR_LQH3NP_0.47UH/3A | 0.47uH/3A | LQH3NP |
L40 | BEAD_0603_BLM18KG331SN1D | BLM18KG331SN1D | 603 |
L41 | INDUCTOR_FL-L7X7_22UH | 22uH | FL-L7X7 |
L42 | INDUCTOR_FL-L7X7_FXL0630-4R7-M | FXL0630-4R7-M | FL-L7X7 |
LED1 | RED,SMD0603_1_LED_0603_GREEN | GREEN | LED_0603 |
PC3 | C_D2 | 100uF/50V | EC_D10H5 |
PC4 | C_D2 | 100uF/50V | EC_D10H5 |
PC5 | C_D2 | 100uF/50V | EC_D10H5 |
Q1 | HY7002K_1_FL-SOT-23-GDS_L2N7002KLTIG | L2N7002KLTIG | FL-SOT-23-GDS |
Q2 | HY7002K_1_FL-SOT-23-GDS_L2N7002KLTIG | L2N7002KLTIG | FL-SOT-23-GDS |
Q3 | HY7002K_1_FL-SOT-23-GDS_L2N7002KLTIG | L2N7002KLTIG | FL-SOT-23-GDS |
Q4 | HY7002K_1_FL-SOT-23-GDS_L2N7002KLTIG | L2N7002KLTIG | FL-SOT-23-GDS |
Q5 | HY7002K_1_FL-SOT-23-GDS_L2N7002KLTIG | L2N7002KLTIG | FL-SOT-23-GDS |
Q6 | HY7002K_1_FL-SOT-23-GDS_L2N7002KLTIG | L2N7002KLTIG | FL-SOT-23-GDS |
Q11 | SRDA3_3.3/SO_DFNWB3X3_8L_CJAE35SN06 | CJAE35SN06 | DFNWB3X3_8L |
Q12 | HY7002K_1_SOT23_L2N7002KLTIG | L2N7002KLTIG | SOT23 |
Q13 | SRDA3_2.3/SO_DFNWB3X3_8L_CJAE35SN06 | CJAE35SN06 | DFNWB3X3_8L |
Q14 | HY7002K_1_FL-SOT-23-GDS_L2N7002KLTIG | L2N7002KLTIG | FL-SOT-23-GDS |
RS5 | 0805_R1206H10_0.01R_1% | 0.01R_1% | R1206H10 |
TP170 | T POINT R_TESTPAD_TESTPOINT | TESTPOINT | TESTPAD |
TP171 | TEST POINT_2_FL-TP-1R0_DEO | DEO | FL-TP-1R0 |
U1 | PS9010_PS9010_BGA274_PS9010 | PS9010 | PS9010_BGA274 |
U3 | IC_SST25VF010A_SOIC8_FL-SOIC8_GT25Q16A-UGLI-TR | GT25Q16A-UGLI-TR | FL-SOIC8 |
U4 | G517G2P81U_3_FL_DFN3X3_10L_MT7201A | MT7201A | FL_DFN3X3_10L |
U5 | G517G2P81U_3_FL_DFN3X3_10L_MT7201A | MT7201A | FL_DFN3X3_10L |
U6 | 356GD563006600_0_FL_DFN_4X3_14L_MT3905 | MT3905 | FL_DFN_4X3_14L |
U7 | 356GD563006600_0_FL_DFN_4X3_14L_MT3905 | MT3905 | FL_DFN_4X3_14L |
U8 | SY8089_5_DFN2X2-8_MT8133NDAR | MT8133NDAR | DFN2X2-8 |
U9 | MIC49150BMM,MSOP8_0_FL-SOIC8_AP4407GM | AP4407GM | FL-SOIC8 |
U10 | MIC49150BMM,MSOP8_1_FL-SOIC8_AP4407GM | AP4407GM | FL-SOIC8 |
U11 | SY8089_5_FL_DFN_2X2_6L_MT8102NDER | MT8102NDER | FL_DFN_2X2_6L |
U12 | CY7C68013A_56PIN_SSOP56_CY7C68013A_56P | CY7C68013A_56P | SSOP56 |
U13 | USB_B_USB-B_USB_B | USB_B | USB-B |
U14 | LD1117_SOT-223_LD1117 | LD1117 | SOT-223 |
U15 | 74HC4052_SO16_74HC4052 | 74hc4052 | SO16 |
U16 | AT24C_SOIC8EXTPAD_AT24LC64 | AT24LC64 | SOIC8EXTPAD |
U17 | IC_FL5500-1Q0_QFN88-10X10X0R4_6_QFN100_NS_PS188_QFN100 | PS188_QFN100 | QFN100_NS |
U18 | IC_SST25VF010A_SOIC8_FL-SOIC8_MX25V4035FM1I | MX25V4035FM1I | FL-SOIC8 |
U19 | SY8089_5_FL_DFN_2X2_6L_MT8102NDER | MT8102NDER | FL_DFN_2X2_6L |
U20 | SY8089_5_FL_DFN_2X2_6L_MT8102NDER | MT8102NDER | FL_DFN_2X2_6L |
U21 | IC_FL7112-1X0_QFN48-6X6X0R4_8_QFN52L_5D5X5D5_PS5513 | PS5513 | QFN52L_5D5X5D5 |
U22 | PS8650BGA274_BGA274_H_T_(S1+S2+S3+S4)_PS8650BGA | PS8650BGA | BGA274_H_T |
U23 | IC_SST25VF010A_SOIC8_FL-SOIC8_W25Q16JVSNIM | W25Q16JVSNIM | FL-SOIC8 |
U24 | RCLAMP0524_RCLAMP0524_RCLAMP0524/NC | RCLAMP0524/NC | RCLAMP0524 |
U25 | RCLAMP0524_RCLAMP0524_RCLAMP0524/NC | RCLAMP0524/NC | RCLAMP0524 |
U27 | SY8089_5_FL_DFN_2X2_6L_MT8102NDER | MT8102NDER | FL_DFN_2X2_6L |
U28 | TPS548A28_RWW0021A_TPS548A28 | TPS548A28 | RWW0021A |
U29 | SY8089_5_FL_DFN_2X2_6L_MT8102NDER | MT8102NDER | FL_DFN_2X2_6L |
U30 | SY8089_5_FL_DFN_2X2_6L_MT8102NDER | MT8102NDER | FL_DFN_2X2_6L |
U31 | PS196_1_WMQFN74_NO_S_PS196QFN | PS196QFN | WMQFN74_NO_S |
U32 | IC_SST25VF010A_SOIC8_FL-SOIC8_W25Q16JVSNIM | W25Q16JVSNIM | FL-SOIC8 |
U33 | TMP_4_FL-QFN88-10X10X0R4_PS5512A2 | PS5512A2 | FL-QFN88-10X10X0R4 |
U34 | IC_SST25VF010A_SOIC8_FL-SOIC8_XT25F04B | XT25F04B | FL-SOIC8 |
U35 | G517G2P81U_3_FL_DFN3X3_10L_MT7201A | MT7201A | FL_DFN3X3_10L |
U36 | G517G2P81U_3_FL_DFN3X3_10L_MT7201A | MT7201A | FL_DFN3X3_10L |
U37 | G517G2P81U_3_FL_DFN3X3_10L_MT7201A | MT7201A | FL_DFN3X3_10L |
U38 | G517G2P81U_3_FL_DFN3X3_10L_MT7201A | MT7201A | FL_DFN3X3_10L |
U39 | G517G2P81U_3_FL_DFN3X3_10L_MT7201A | MT7201A | FL_DFN3X3_10L |
U40 | 356GD563006600_0_FL_DFN_4X3_14L_MT3905 | MT3905 | FL_DFN_4X3_14L |
U41 | SY8089_5_FL_DFN_2X2_6L_MT8102NDER | MT8102NDER | FL_DFN_2X2_6L |
U42 | SY8089_5_FL_DFN_2X2_6L_MT8102NDER | MT8102NDER | FL_DFN_2X2_6L |
U43 | PANTHER CREEK QFN40_0_QFN40-0_4M-B5X5_SOCKET_A_FL7102-2Q0 | FL7102-2Q0 | QFN40-0_4M-B5X5_SOCKET_A |
U44 | 356GD563006600_0_SOP8EP_MT3901 | MT3901 | SOP8EP |
U47 | SY8089_3_FL-SOT-23-5_INA138 | INA138 | FL-SOT-23-5 |
U48 | INA181_0_QFN_20_MP4248 | MP4248 | QFN_20 |
U49 | MIC49150BMM,MSOP8_0_FL-SOIC8_IRF9310TRPBF | IRF9310TRPBF | FL-SOIC8 |
U50 | MIC49150BMM,MSOP8_0_FL-SOIC8_IRF9310TRPBF | IRF9310TRPBF | FL-SOIC8 |
U51 | TS3USB221DRCR_1_FL-MSOP10-3X3X0R5_SGM7227YUWQ10G/TR | SGM7227YUWQ10G/TR | FL-MSOP10-3X3X0R5 |
U90 | TMUX1574RSV_UQFN-16_TMUX1574RSV | TMUX1574RSV | UQFN-16 |
USB1 | CON_USB2.0_A_FL-USB2_0_USB2.0-A | USB2.0-A | FL-USB2_0 |
USB2 | CON_USB_TYPEC_MA15-02CA2_1_USB4_PUC050_MA15-02CA2 | MA15-02CA2 | USB4_PUC050 |
USB3 | CON_USB31_TYPEA_3C2A_CON-USB3_1-TYPEA-3C2A-NPTH_USB3.1-TYPE-A | USB3.1-Type-A | CON-USB3_1-TYPEA-3C2A-NPTH |
USB4 | CON_USB_TYPEC_MA15-02CA2_0_USB4_PUC050_MA15-02CA2 | MA15-02CA2 | USB4_PUC050 |
USB5 | CON_USB31_TYPEA_3C2A_CON-USB3_1-TYPEA-3C2A-NPTH_USB3.1-TYPE-A | USB3.1-Type-A | CON-USB3_1-TYPEA-3C2A-NPTH |
USB6 | CON_USB_TYPEC_MA15-02CA2_0_USB4_PUC050_MA15-02CA2 | MA15-02CA2 | USB4_PUC050 |
USB7 | CON_USB2.0_A_FL-USB2_0_USB2.0-A | USB2.0-A | FL-USB2_0 |
X1 | CRYSTAL_CRYSTAL_24M | 24M | CRYSTAL |
X2 | CRYSTAL_SM3225_SM3225_25M | 25M | SM3225 |
X3 | CRYSTAL_SM3225_SM3225_25M | 25M | SM3225 |
Y1 | 30MHZ,CRY,30PPM,SMD_2_SM3225_25MHZ/NOPWR | 25MHz/NoPwr | SM3225 |
Y2 | 30MHZ,CRY,30PPM,SMD_2_SM3225_25MHZ/NOPWR | 25MHz/NoPwr | SM3225 |
Y3 | 30MHZ,CRY,30PPM,SMD_2_FL-CRYSTAL-SMD3225_25MHZ | 25MHz | FL-CRYSTAL-SMD3225 |
Y4 | 30MHZ,CRY,30PPM,SMD_2_FL-CRYSTAL-SMD3225_12MHZ | 12MHZ | FL-CRYSTAL-SMD3225 |
