REFDES | COMP_DEVICE_TYPE | COMP_VALUE | SYM_NAME |
3V3_JP | JPD2X3_2P54 | HEADER/S120-S-06-2-60/25/30-E1 | JPD2X3_2P54 |
3V3_SB | SB-6MIL | SOLDER_SB | SB-6MIL |
3V4_SB | SB-6MIL | NC/SOLDER_SB | SB-6MIL |
12V_JP | JPD2X3_2P54 | HEADER/S120-S-06-2-60/25/30-E1 | JPD2X3_2P54 |
12V_PW | PJD3_9X14P5_13P6_5P8_4P8 | 12V_IN | PJD3_9X14P5_13P6_5P8_4P8 |
CON1 | PCI_E_X16_1P0_FINGER_G5 | PCI-E AIC/x16/GEN5 | PCI_E_X16_1P0_FINGER_G5 |
CON2 | PCIECONN164_7P9X19P3_L2_E | PCIe Add-IN Card x16 Slot Connector | PCIECONN164_7P9X19P3_L2_E |
F1 | FID2_SC40_SM67 | FID/1mm/1.7mm/Double-side | FID2_SC40_SM67 |
F2 | FID2_SC40_SM67 | FID/1mm/1.7mm/Double-side | FID2_SC40_SM67 |
F3 | FID2_SC40_SM67 | FID/1mm/1.7mm/Double-side | FID2_SC40_SM67 |
GND_JP | JPD3_2P54 | HEADER/S110-S-03-2-60/15/30 | JPD3_2P54 |
H1 | H_3P2_NPTH | NPTH/3.2mm | H_3P2_NPTH |
H2 | H_3P2_NPTH | NPTH/3.2mm | H_3P2_NPTH |
JP1 | JPD4_2P54 | HEADER/S110-S-04-2-60/15/30 | JPD4_2P54 |
JP2 | JPD3_2P54 | HEADER/S110-S-03-2-60/15/30 | JPD3_2P54 |
JP3 | JPD3_2P54 | HEADER/S110-S-03-2-60/15/30 | JPD3_2P54 |
JP5 | JPD3_2P54 | HEADER/S110-S-03-2-60/15/30 | JPD3_2P54 |
Q1 | SOT_23_GSD | NC/AO3418 | SOT_23_GSD |
Q2 | SOT_23_GSD | NC/AO3418 | SOT_23_GSD |
S5 | 9DSW18_1P25X6P6_2P54_W9P6 | SESD109EZ | 9DSW18_1P25X6P6_2P54_W9P6 |
S6 | 4DSW8_1P25X6P6_2P54_W9P6 | SESD104EZ | 4DSW8_1P25X6P6_2P54_W9P6 |
S7 | 9DSW18_1P25X6P6_2P54_W9P6 | SESD109EZ | 9DSW18_1P25X6P6_2P54_W9P6 |
S8 | 4DSW8_1P25X6P6_2P54_W9P6 | SESD104EZ | 4DSW8_1P25X6P6_2P54_W9P6 |
SW1 | PSWD4_6X6_4P5X6P5_H7 | TS-A3PS-160-3 | PSWD4_6X6_4P5X6P5_H7 |
SW2 | PSWD4_6X6_4P5X6P5_H7 | TS-A3PS-160-3 | PSWD4_6X6_4P5X6P5_H7 |
U1_S1 | 9DSW18_1P25X6P6_2P54_W9P6 | SESD109EZ | 9DSW18_1P25X6P6_2P54_W9P6 |
U1 | WQFN64_10X5P5_0P4 | PS7102 | WQFN64_10X5P5_0P4 |
U2 | WQFN64_10X5P5_0P4 | PS7102 | WQFN64_10X5P5_0P4 |
U3 | WQFN64_10X5P5_0P4 | PS7102 | WQFN64_10X5P5_0P4 |
U4 | WQFN64_10X5P5_0P4 | PS7102 | WQFN64_10X5P5_0P4 |
U5 | LTS_SK_10P6X9P46_SOP8_1P27_6 | M24C08-WMN6TP_SOCKET_SO-8 | LTS_SK_10P6X9P46_SOP8_1P27_6 |
VR_SB | SB-6MIL | NC/SOLDER_SB | SB-6MIL |
V_D1 | LED0603 | LED/19-215SUBC/S280/TR8 | LED0603 |
V_D2 | LED0603 | LED/19-213SDRC/S259/TR8 | LED0603 |
V_L1 | L0604 | ? ohm/3A/25%/ZFB-0402HP3P0-330N | L0604 |
V_L2 | L0604 | ? ohm/3A/25%/ZFB-0402HP3P0-330N | L0604 |
V_L3 | L0604 | ? ohm/3A/25%/ZFB-0402HP3P0-330N | L0604 |
V_L4 | L0604 | ? ohm/3A/25%/ZFB-0402HP3P0-330N | L0604 |
V_L5 | L_545218 | 1.5uH/9A/20%/ZPWM-5018ML-1R5M | L_545218 |
V_U1 | SY_QFN20P_3X3_0P45_EP | SY8286ARAC/QFN3x3-20/3.1x3.1mm | SY_QFN20P_3X3_0P45_EP |
V_U2 | DFN10P_3X3_0P5_EP | SY6875ADBC | DFN10P_3X3_0P5_EP |
V_VR1 | RV9MM_2P5_DIP | NC/VR/30K | RV9MM_2P5_DIP |
