查看: 36|回复: 0
[Allegro17.4以下] ADG1607BRUZ+MC74HC390ADG 做的一个主板PCB
    终身成就奖社区居民忠实会员宣传大使奖优秀斑竹奖
    发表于 2025-6-5 15:36:16 | 显示全部楼层 |阅读模式
    重要提示:PCB作品文件展下载说明
    MT_FS4664_B137_SIB_BD_V1_0-PCB-20250413.7z (3.9 MB, 下载次数: 0)
    C1409DCAP-C_CC1608-0603_100NF/NC100nF/NCCC1608-0603
    C1409ECAP-C_CC1608-0603_100NF/NC100nF/NCCC1608-0603
    C1409FCAP-C_CC1608-0603_100NF/NC100nF/NCCC1608-0603
    D500AT05LC_DO-214AC_SMAJ28CASMAJ28CADO-214AC
    D500BT05LC_DO-214AC_SMAJ28CASMAJ28CADO-214AC
    D500CT05LC_DO-214AC_SMAJ28CASMAJ28CADO-214AC
    D500DT05LC_DO-214AC_SMAJ28CASMAJ28CADO-214AC
    D500ET05LC_DO-214AC_SMAJ28CASMAJ28CADO-214AC
    D500FT05LC_DO-214AC_SMAJ28CASMAJ28CADO-214AC
    D501A1N4148_1_SMB-S_B340A-13-FB340A-13-FSMB-S
    D501B1N4148_1_SMB-S_B340A-13-FB340A-13-FSMB-S
    D501C1N4148_1_SMB-S_B340A-13-FB340A-13-FSMB-S
    D501D1N4148_1_SMB-S_B340A-13-FB340A-13-FSMB-S
    D501E1N4148_1_SMB-S_B340A-13-FB340A-13-FSMB-S
    D501F1N4148_1_SMB-S_B340A-13-FB340A-13-FSMB-S
    D502A1N4148_1_SMB-S_B340A-13-FB340A-13-FSMB-S
    D502B1N4148_1_SMB-S_B340A-13-FB340A-13-FSMB-S
    D502C1N4148_1_SMB-S_B340A-13-FB340A-13-FSMB-S
    D502D1N4148_1_SMB-S_B340A-13-FB340A-13-FSMB-S
    D502E1N4148_1_SMB-S_B340A-13-FB340A-13-FSMB-S
    D502F1N4148_1_SMB-S_B340A-13-FB340A-13-FSMB-S
    D600A1N4148_1_SOD-80_1N41481N4148SOD-80
    D600B1N4148_1_SOD-80_1N41481N4148SOD-80
    D600C1N4148_1_SOD-80_1N41481N4148SOD-80
    D600D1N4148_1_SOD-80_1N41481N4148SOD-80
    D600E1N4148_1_SOD-80_1N41481N4148SOD-80
    D600F1N4148_1_SOD-80_1N41481N4148SOD-80
    FB500AFERRITE-BEAD_2_CL2012-0805_MPZ2MPZ2012S300ATD25CL2012-0805
    FB500BFERRITE-BEAD_2_CL2012-0805_MPZ2MPZ2012S300ATD25CL2012-0805
    FB500CFERRITE-BEAD_2_CL2012-0805_MPZ2MPZ2012S300ATD25CL2012-0805
    FB500DFERRITE-BEAD_2_CL2012-0805_MPZ2MPZ2012S300ATD25CL2012-0805
    FB500EFERRITE-BEAD_2_CL2012-0805_MPZ2MPZ2012S300ATD25CL2012-0805
    FB500FFERRITE-BEAD_2_CL2012-0805_MPZ2MPZ2012S300ATD25CL2012-0805
    FB501AFERRITE-BEAD_2_CL2012-0805_MPZ2MPZ2012S300ATD25CL2012-0805
    FB501BFERRITE-BEAD_2_CL2012-0805_MPZ2MPZ2012S300ATD25CL2012-0805
    FB501CFERRITE-BEAD_2_CL2012-0805_MPZ2MPZ2012S300ATD25CL2012-0805
    FB501DFERRITE-BEAD_2_CL2012-0805_MPZ2MPZ2012S300ATD25CL2012-0805
    FB501EFERRITE-BEAD_2_CL2012-0805_MPZ2MPZ2012S300ATD25CL2012-0805
    FB501FFERRITE-BEAD_2_CL2012-0805_MPZ2MPZ2012S300ATD25CL2012-0805
    FB502AFERRITE-BEAD_2_CL2012-0805_MPZ2MPZ2012S300ATD25CL2012-0805
    FB502BFERRITE-BEAD_2_CL2012-0805_MPZ2MPZ2012S300ATD25CL2012-0805
    FB502CFERRITE-BEAD_2_CL2012-0805_MPZ2MPZ2012S300ATD25CL2012-0805
    FB502DFERRITE-BEAD_2_CL2012-0805_MPZ2MPZ2012S300ATD25CL2012-0805
    FB502EFERRITE-BEAD_2_CL2012-0805_MPZ2MPZ2012S300ATD25CL2012-0805
    FB502FFERRITE-BEAD_2_CL2012-0805_MPZ2MPZ2012S300ATD25CL2012-0805
    FB1300ADANIEL_MPZ1608B471ATA00_0_CR160NC/0RCR1608-0603
    FB1300BDANIEL_MPZ1608B471ATA00_0_CR160NC/0RCR1608-0603
    FB1300CDANIEL_MPZ1608B471ATA00_0_CR160NC/0RCR1608-0603
    FB1300DDANIEL_MPZ1608B471ATA00_0_CR160NC/0RCR1608-0603
    FB1300EDANIEL_MPZ1608B471ATA00_0_CR160NC/0RCR1608-0603
    FB1300FDANIEL_MPZ1608B471ATA00_0_CR160NC/0RCR1608-0603
    FB1301AINDUCTOR_1_CL1005-0402_MPZ1005FMPZ1005F470ETD25CL1005-0402
    FB1301BINDUCTOR_1_CL1005-0402_MPZ1005FMPZ1005F470ETD25CL1005-0402
    FB1402FINDUCTOR_1_CL1005-0402_MPZ1005FMPZ1005F470ETD25CL1005-0402
    J500ACONN  SOCKET 4_CON-381-1X4P-DIP_F83-5-3.81-4PCON-381-1X4P-DIP
    J500BCONN  SOCKET 4_CON-381-1X4P-DIP_F83-5-3.81-4PCON-381-1X4P-DIP
    J500CCONN  SOCKET 4_CON-381-1X4P-DIP_F83-5-3.81-4PCON-381-1X4P-DIP
    J500DCONN  SOCKET 4_CON-381-1X4P-DIP_F83-5-3.81-4PCON-381-1X4P-DIP
    J500ECONN  SOCKET 4_CON-381-1X4P-DIP_F83-5-3.81-4PCON-381-1X4P-DIP
    J500FCONN  SOCKET 4_CON-381-1X4P-DIP_F83-5-3.81-4PCON-381-1X4P-DIP
    J501ACONN  SOCKET 2_CON-254-HX-1X2P-DXH2.54-2PCON-254-HX-1X2P-DIP
    J501BCONN  SOCKET 2_CON-254-HX-1X2P-DXH2.54-2PCON-254-HX-1X2P-DIP
    J501CCONN  SOCKET 2_CON-254-HX-1X2P-DXH2.54-2PCON-254-HX-1X2P-DIP
    J501DCONN  SOCKET 2_CON-254-HX-1X2P-DXH2.54-2PCON-254-HX-1X2P-DIP
    J501ECONN  SOCKET 2_CON-254-HX-1X2P-DXH2.54-2PCON-254-HX-1X2P-DIP
    J501FCONN  SOCKET 2_CON-254-HX-1X2P-DXH2.54-2PCON-254-HX-1X2P-DIP
    J700ACON-2X13P_1_CON-DIN41612-254-FHPCN10C-32S-2.54DSA(72)CON-DIN41612-254-FH-2X16P
    J700BCON-2X13P_1_CON-DIN41612-254-FHPCN10C-32S-2.54DSA(72)CON-DIN41612-254-FH-2X16P
    J700CCON-2X13P_1_CON-DIN41612-254-FHPCN10C-32S-2.54DSA(72)CON-DIN41612-254-FH-2X16P
    J700DCON-2X13P_1_CON-DIN41612-254-FHPCN10C-32S-2.54DSA(72)CON-DIN41612-254-FH-2X16P
    J700ECON-2X13P_1_CON-DIN41612-254-FHPCN10C-32S-2.54DSA(72)CON-DIN41612-254-FH-2X16P
    J700FCON-2X13P_1_CON-DIN41612-254-FHPCN10C-32S-2.54DSA(72)CON-DIN41612-254-FH-2X16P
    J800ACON-2X8P_CON-254-IDC-2X8P-DIP_AA2547WV-N-2x8PCON-254-IDC-2X8P-DIP
    J800BCON-2X8P_CON-254-IDC-2X8P-DIP_AA2547WV-N-2x8PCON-254-IDC-2X8P-DIP
    J800CCON-2X8P_CON-254-IDC-2X8P-DIP_AA2547WV-N-2x8PCON-254-IDC-2X8P-DIP
    J800DCON-2X8P_CON-254-IDC-2X8P-DIP_AA2547WV-N-2x8PCON-254-IDC-2X8P-DIP
    J800ECON-2X8P_CON-254-IDC-2X8P-DIP_AA2547WV-N-2x8PCON-254-IDC-2X8P-DIP
    J800FCON-2X8P_CON-254-IDC-2X8P-DIP_AA2547WV-N-2x8PCON-254-IDC-2X8P-DIP
    J1300AUSB-20-A-RA_USB-20-B_M701-33044M701-330442USB-20-B
    J1300BUSB-20-A-RA_USB-20-B_M701-33044M701-330442USB-20-B
    J1300CUSB-20-A-RA_USB-20-B_M701-33044M701-330442USB-20-B
    J1300DUSB-20-A-RA_USB-20-B_M701-33044M701-330442USB-20-B
    J1300EUSB-20-A-RA_USB-20-B_M701-33044M701-330442USB-20-B
    J1300FUSB-20-A-RA_USB-20-B_M701-33044M701-330442USB-20-B
    J1301ACON5_1_CON-254-MH-1X4P-DIP_1043104346-2CON-254-MH-1X4P-DIP
    J1301BCON5_1_CON-254-MH-1X4P-DIP_1043104346-2CON-254-MH-1X4P-DIP
    J1301CCON5_1_CON-254-MH-1X4P-DIP_1043104346-2CON-254-MH-1X4P-DIP
    J1301DCON5_1_CON-254-MH-1X4P-DIP_1043104346-2CON-254-MH-1X4P-DIP
    J1301ECON5_1_CON-254-MH-1X4P-DIP_1043104346-2CON-254-MH-1X4P-DIP
    J1301FCON5_1_CON-254-MH-1X4P-DIP_1043104346-2CON-254-MH-1X4P-DIP
    K600ASW  KEY-Y2011_4_RL-G6K-2F-Y-AB_GG6K-2F  DC5VRL-G6K-2F-Y-AB
    K600BSW  KEY-Y2011_4_RL-G6K-2F-Y-AB_GG6K-2F  DC5VRL-G6K-2F-Y-AB
    K600CSW  KEY-Y2011_4_RL-G6K-2F-Y-AB_GG6K-2F  DC5VRL-G6K-2F-Y-AB
    K600DSW  KEY-Y2011_4_RL-G6K-2F-Y-AB_GG6K-2F  DC5VRL-G6K-2F-Y-AB
    K600ESW  KEY-Y2011_4_RL-G6K-2F-Y-AB_GG6K-2F  DC5VRL-G6K-2F-Y-AB
    K600FSW  KEY-Y2011_4_RL-G6K-2F-Y-AB_GG6K-2F  DC5VRL-G6K-2F-Y-AB
    L500AL_0_L-P-W8_10X8_10-H9_00-SMD_IHIHLP3232DZER220M11L-P-W8_10X8_10-H9_00-SMD
    L500BL_0_L-P-W8_10X8_10-H9_00-SMD_IHIHLP3232DZER220M11L-P-W8_10X8_10-H9_00-SMD
    L500CL_0_L-P-W8_10X8_10-H9_00-SMD_IHIHLP3232DZER220M11L-P-W8_10X8_10-H9_00-SMD
    L500DL_0_L-P-W8_10X8_10-H9_00-SMD_IHIHLP3232DZER220M11L-P-W8_10X8_10-H9_00-SMD
    L500EL_0_L-P-W8_10X8_10-H9_00-SMD_IHIHLP3232DZER220M11L-P-W8_10X8_10-H9_00-SMD
    L500FL_0_L-P-W8_10X8_10-H9_00-SMD_IHIHLP3232DZER220M11L-P-W8_10X8_10-H9_00-SMD
    L501AL_0_L-P-W8_10X8_10-H9_00-SMD_IHIHLP3232DZER220M11L-P-W8_10X8_10-H9_00-SMD
    L501BL_0_L-P-W8_10X8_10-H9_00-SMD_IHIHLP3232DZER220M11L-P-W8_10X8_10-H9_00-SMD
    L501CL_0_L-P-W8_10X8_10-H9_00-SMD_IHIHLP3232DZER220M11L-P-W8_10X8_10-H9_00-SMD
    L501DL_0_L-P-W8_10X8_10-H9_00-SMD_IHIHLP3232DZER220M11L-P-W8_10X8_10-H9_00-SMD
    L501EL_0_L-P-W8_10X8_10-H9_00-SMD_IHIHLP3232DZER220M11L-P-W8_10X8_10-H9_00-SMD
    L501FL_0_L-P-W8_10X8_10-H9_00-SMD_IHIHLP3232DZER220M11L-P-W8_10X8_10-H9_00-SMD
    L800AL_5_CL1608-0603_MPZ1608B471ATA0MPZ1608B471ATA00CL1608-0603
    LED600FLED0805_0_LED1608-0603-G_LTW-C1LTW-C190DA5LED1608-0603-G
    Q600A2N7002_0_SOT-23-3_2N70022N7002SOT-23-3
    Q600B2N7002_0_SOT-23-3_2N70022N7002SOT-23-3
    Q600C2N7002_0_SOT-23-3_2N70022N7002SOT-23-3
    Q600D2N7002_0_SOT-23-3_2N70022N7002SOT-23-3
    Q600E2N7002_0_SOT-23-3_2N70022N7002SOT-23-3
    Q600F2N7002_0_SOT-23-3_2N70022N7002SOT-23-3
    Q601A2N7002_0_SOT-23-3_2N70022N7002SOT-23-3
    Q601B2N7002_0_SOT-23-3_2N70022N7002SOT-23-3
    Q601C2N7002_0_SOT-23-3_2N70022N7002SOT-23-3
    Q601D2N7002_0_SOT-23-3_2N70022N7002SOT-23-3
    Q601E2N7002_0_SOT-23-3_2N70022N7002SOT-23-3
    Q601F2N7002_0_SOT-23-3_2N70022N7002SOT-23-3
    U500ATPS5450DDAR_1_SOIC-8G-P1_27-W6_TPS5450DDARSOIC-8G-P1_27-W6_00
    U500BTPS5450DDAR_1_SOIC-8G-P1_27-W6_TPS5450DDARSOIC-8G-P1_27-W6_00
    U500CTPS5450DDAR_1_SOIC-8G-P1_27-W6_TPS5450DDARSOIC-8G-P1_27-W6_00
    U500DTPS5450DDAR_1_SOIC-8G-P1_27-W6_TPS5450DDARSOIC-8G-P1_27-W6_00
    U500ETPS5450DDAR_1_SOIC-8G-P1_27-W6_TPS5450DDARSOIC-8G-P1_27-W6_00
    U500FTPS5450DDAR_1_SOIC-8G-P1_27-W6_TPS5450DDARSOIC-8G-P1_27-W6_00
    U501ATPS5450DDAR_1_SOIC-8G-P1_27-W6_TPS5450DDARSOIC-8G-P1_27-W6_00
    U501BTPS5450DDAR_1_SOIC-8G-P1_27-W6_TPS5450DDARSOIC-8G-P1_27-W6_00
    U501CTPS5450DDAR_1_SOIC-8G-P1_27-W6_TPS5450DDARSOIC-8G-P1_27-W6_00
    U501DTPS5450DDAR_1_SOIC-8G-P1_27-W6_TPS5450DDARSOIC-8G-P1_27-W6_00
    U501ETPS5450DDAR_1_SOIC-8G-P1_27-W6_TPS5450DDARSOIC-8G-P1_27-W6_00
    U501FTPS5450DDAR_1_SOIC-8G-P1_27-W6_TPS5450DDARSOIC-8G-P1_27-W6_00
    U502ALM1117_6_SOT-223-3-P2_30-W5_64_LM1117MPX-3.3SOT-223-3-P2_30-W5_64
    U502BLM1117_6_SOT-223-3-P2_30-W5_64_LM1117MPX-3.3SOT-223-3-P2_30-W5_64
    U502CLM1117_6_SOT-223-3-P2_30-W5_64_LM1117MPX-3.3SOT-223-3-P2_30-W5_64
    U502DLM1117_6_SOT-223-3-P2_30-W5_64_LM1117MPX-3.3SOT-223-3-P2_30-W5_64
    U502ELM1117_6_SOT-223-3-P2_30-W5_64_LM1117MPX-3.3SOT-223-3-P2_30-W5_64
    U502FLM1117_6_SOT-223-3-P2_30-W5_64_LM1117MPX-3.3SOT-223-3-P2_30-W5_64
    U503AVRB1205S-6WR3_0_DC-DC-URA_YMD-1URB2412YMD-15WR3DC-DC-URA_YMD-15WR3
    U503BVRB1205S-6WR3_0_DC-DC-URA_YMD-1URB2412YMD-15WR3DC-DC-URA_YMD-15WR3
    U503CVRB1205S-6WR3_0_DC-DC-URA_YMD-1URB2412YMD-15WR3DC-DC-URA_YMD-15WR3
    U503DVRB1205S-6WR3_0_DC-DC-URA_YMD-1URB2412YMD-15WR3DC-DC-URA_YMD-15WR3
    U503EVRB1205S-6WR3_0_DC-DC-URA_YMD-1URB2412YMD-15WR3DC-DC-URA_YMD-15WR3
    U503FVRB1205S-6WR3_0_DC-DC-URA_YMD-1URB2412YMD-15WR3DC-DC-URA_YMD-15WR3
    U600AIRF7316PBF_0_SOIC-8-P1_27-W5_75IRF7316PBFSOIC-8-P1_27-W5_75
    U600BIRF7316PBF_0_SOIC-8-P1_27-W5_75IRF7316PBFSOIC-8-P1_27-W5_75
    U600CIRF7316PBF_0_SOIC-8-P1_27-W5_75IRF7316PBFSOIC-8-P1_27-W5_75
    U600DIRF7316PBF_0_SOIC-8-P1_27-W5_75IRF7316PBFSOIC-8-P1_27-W5_75
    U600EIRF7316PBF_0_SOIC-8-P1_27-W5_75IRF7316PBFSOIC-8-P1_27-W5_75
    U600FIRF7316PBF_0_SOIC-8-P1_27-W5_75IRF7316PBFSOIC-8-P1_27-W5_75
    U601ALM1117_6_SOT-223-3-P2_30-W5_64_LM1117MPX-3.3SOT-223-3-P2_30-W5_64
    U601BLM1117_6_SOT-223-3-P2_30-W5_64_LM1117MPX-3.3SOT-223-3-P2_30-W5_64
    U601CLM1117_6_SOT-223-3-P2_30-W5_64_LM1117MPX-3.3SOT-223-3-P2_30-W5_64
    U601DLM1117_6_SOT-223-3-P2_30-W5_64_LM1117MPX-3.3SOT-223-3-P2_30-W5_64
    U601ELM1117_6_SOT-223-3-P2_30-W5_64_LM1117MPX-3.3SOT-223-3-P2_30-W5_64
    U601FLM1117_6_SOT-223-3-P2_30-W5_64_LM1117MPX-3.3SOT-223-3-P2_30-W5_64
    U602ATLP240A(TP1,FTLP240ARELAY-SMD_TLP240A
    U602BTLP240A(TP1,FTLP240ARELAY-SMD_TLP240A
    U602CTLP240A(TP1,FTLP240ARELAY-SMD_TLP240A
    U602DTLP240A(TP1,FTLP240ARELAY-SMD_TLP240A
    U602ETLP240A(TP1,FTLP240ARELAY-SMD_TLP240A
    U602FTLP240A(TP1,FTLP240ARELAY-SMD_TLP240A
    U800AADG1607BRUZ_TSSOP-28-P0_65-W6_4ADG1607BRUZTSSOP-28-P0_65-W6_40
    U800BADG1607BRUZ_TSSOP-28-P0_65-W6_4ADG1607BRUZTSSOP-28-P0_65-W6_40
    U800CADG1607BRUZ_TSSOP-28-P0_65-W6_4ADG1607BRUZTSSOP-28-P0_65-W6_40
    U800DADG1607BRUZ_TSSOP-28-P0_65-W6_4ADG1607BRUZTSSOP-28-P0_65-W6_40
    U800EADG1607BRUZ_TSSOP-28-P0_65-W6_4ADG1607BRUZTSSOP-28-P0_65-W6_40
    U800FADG1607BRUZ_TSSOP-28-P0_65-W6_4ADG1607BRUZTSSOP-28-P0_65-W6_40
    U801AADG1607BRUZ_TSSOP-28-P0_65-W6_4ADG1607BRUZTSSOP-28-P0_65-W6_40
    U801BADG1607BRUZ_TSSOP-28-P0_65-W6_4ADG1607BRUZTSSOP-28-P0_65-W6_40
    U801CADG1607BRUZ_TSSOP-28-P0_65-W6_4ADG1607BRUZTSSOP-28-P0_65-W6_40
    U801DADG1607BRUZ_TSSOP-28-P0_65-W6_4ADG1607BRUZTSSOP-28-P0_65-W6_40
    U801EADG1607BRUZ_TSSOP-28-P0_65-W6_4ADG1607BRUZTSSOP-28-P0_65-W6_40
    U801FADG1607BRUZ_TSSOP-28-P0_65-W6_4ADG1607BRUZTSSOP-28-P0_65-W6_40
    U802AADG1607BRUZ_TSSOP-28-P0_65-W6_4ADG1607BRUZTSSOP-28-P0_65-W6_40
    U802BADG1607BRUZ_TSSOP-28-P0_65-W6_4ADG1607BRUZTSSOP-28-P0_65-W6_40
    U802CADG1607BRUZ_TSSOP-28-P0_65-W6_4ADG1607BRUZTSSOP-28-P0_65-W6_40
    U802DADG1607BRUZ_TSSOP-28-P0_65-W6_4ADG1607BRUZTSSOP-28-P0_65-W6_40
    U802EADG1607BRUZ_TSSOP-28-P0_65-W6_4ADG1607BRUZTSSOP-28-P0_65-W6_40
    U802FADG1607BRUZ_TSSOP-28-P0_65-W6_4ADG1607BRUZTSSOP-28-P0_65-W6_40
    U1000AADG1409YRUZ_1_TSSOP-16-P0_65-W6ADG1409YRUZTSSOP-16-P0_65-W6_40
    U1000BADG1409YRUZ_1_TSSOP-16-P0_65-W6ADG1409YRUZTSSOP-16-P0_65-W6_40
    U1000CADG1409YRUZ_1_TSSOP-16-P0_65-W6ADG1409YRUZTSSOP-16-P0_65-W6_40
    U1000DADG1409YRUZ_1_TSSOP-16-P0_65-W6ADG1409YRUZTSSOP-16-P0_65-W6_40
    U1000EADG1409YRUZ_1_TSSOP-16-P0_65-W6ADG1409YRUZTSSOP-16-P0_65-W6_40
    U1000FADG1409YRUZ_1_TSSOP-16-P0_65-W6ADG1409YRUZTSSOP-16-P0_65-W6_40
    U1001AAD8221ARZ_0_SOIC-8-P1_27-W6_00_AD8221ARZSOIC-8-P1_27-W6_00
    U1001BAD8221ARZ_0_SOIC-8-P1_27-W6_00_AD8221ARZSOIC-8-P1_27-W6_00
    U1001CAD8221ARZ_0_SOIC-8-P1_27-W6_00_AD8221ARZSOIC-8-P1_27-W6_00
    U1001DAD8221ARZ_0_SOIC-8-P1_27-W6_00_AD8221ARZSOIC-8-P1_27-W6_00
    U1001EAD8221ARZ_0_SOIC-8-P1_27-W6_00_AD8221ARZSOIC-8-P1_27-W6_00
    U1001FAD8221ARZ_0_SOIC-8-P1_27-W6_00_AD8221ARZSOIC-8-P1_27-W6_00
    U1100AMUX_ADG1606-TSSOP_1_TSSOP-28-P0ADG1606BRUZ-REEL7TSSOP-28-P0_65-W6_40
    U1100BMUX_ADG1606-TSSOP_1_TSSOP-28-P0ADG1606BRUZ-REEL7TSSOP-28-P0_65-W6_40
    U1100CMUX_ADG1606-TSSOP_1_TSSOP-28-P0ADG1606BRUZ-REEL7TSSOP-28-P0_65-W6_40
    U1100DMUX_ADG1606-TSSOP_1_TSSOP-28-P0ADG1606BRUZ-REEL7TSSOP-28-P0_65-W6_40
    U1100EMUX_ADG1606-TSSOP_1_TSSOP-28-P0ADG1606BRUZ-REEL7TSSOP-28-P0_65-W6_40
    U1100FMUX_ADG1606-TSSOP_1_TSSOP-28-P0ADG1606BRUZ-REEL7TSSOP-28-P0_65-W6_40
    U1200AMT_DMM_24BIT_2CH_V1.0_MT_DMM_24MT_DMM_24Bit_2CH_V1.0MT_DMM_24BIT_2CH_V1_0
    U1200CMT_DMM_24BIT_2CH_V1.0_MT_DMM_24MT_DMM_24Bit_2CH_V1.0MT_DMM_24BIT_2CH_V1_0
    U1200DMT_DMM_24BIT_2CH_V1.0_MT_DMM_24MT_DMM_24Bit_2CH_V1.0MT_DMM_24BIT_2CH_V1_0
    U1200EMT_DMM_24BIT_2CH_V1.0_MT_DMM_24MT_DMM_24Bit_2CH_V1.0MT_DMM_24BIT_2CH_V1_0
    U1200FMT_DMM_24BIT_2CH_V1.0_MT_DMM_24MT_DMM_24Bit_2CH_V1.0MT_DMM_24BIT_2CH_V1_0
    U1300AMTSTD-AC003-002_MTSTD-AC003-002MTSTD-AC003-002MTSTD-AC003-002
    U1300BMTSTD-AC003-002_MTSTD-AC003-002MTSTD-AC003-002MTSTD-AC003-002
    U1300CMTSTD-AC003-002_MTSTD-AC003-002MTSTD-AC003-002MTSTD-AC003-002
    U1300DMTSTD-AC003-002_MTSTD-AC003-002MTSTD-AC003-002MTSTD-AC003-002
    U1300EMTSTD-AC003-002_MTSTD-AC003-002MTSTD-AC003-002MTSTD-AC003-002
    U1300FMTSTD-AC003-002_MTSTD-AC003-002MTSTD-AC003-002MTSTD-AC003-002
    U1301ACAT9555_U1300_2_TSSOP-24-P0_65-CAT9555YITSSOP-24-P0_65-W6_40
    U1301BCAT9555_U1300_2_TSSOP-24-P0_65-CAT9555YITSSOP-24-P0_65-W6_40
    U1301CCAT9555_U1300_2_TSSOP-24-P0_65-CAT9555YITSSOP-24-P0_65-W6_40
    U1301DCAT9555_U1300_2_TSSOP-24-P0_65-CAT9555YITSSOP-24-P0_65-W6_40
    U1301ECAT9555_U1300_2_TSSOP-24-P0_65-CAT9555YITSSOP-24-P0_65-W6_40
    U1301FCAT9555_U1300_2_TSSOP-24-P0_65-CAT9555YITSSOP-24-P0_65-W6_40
    U1302ACAT9555_U1300_2_TSSOP-24-P0_65-CAT9555YITSSOP-24-P0_65-W6_40
    U1302BCAT9555_U1300_2_TSSOP-24-P0_65-CAT9555YITSSOP-24-P0_65-W6_40
    U1302CCAT9555_U1300_2_TSSOP-24-P0_65-CAT9555YITSSOP-24-P0_65-W6_40
    U1302DCAT9555_U1300_2_TSSOP-24-P0_65-CAT9555YITSSOP-24-P0_65-W6_40
    U1302ECAT9555_U1300_2_TSSOP-24-P0_65-CAT9555YITSSOP-24-P0_65-W6_40
    U1302FCAT9555_U1300_2_TSSOP-24-P0_65-CAT9555YITSSOP-24-P0_65-W6_40
    U1303A24CXXX_U1301_0_SOIC-8-P1_27-W6_AT24C512C-SSHM-TSOIC-8-P1_27-W6_00
    U1303B24CXXX_U1301_0_SOIC-8-P1_27-W6_AT24C512C-SSHM-TSOIC-8-P1_27-W6_00
    U1303C24CXXX_U1301_0_SOIC-8-P1_27-W6_AT24C512C-SSHM-TSOIC-8-P1_27-W6_00
    U1303D24CXXX_U1301_0_SOIC-8-P1_27-W6_AT24C512C-SSHM-TSOIC-8-P1_27-W6_00
    U1303E24CXXX_U1301_0_SOIC-8-P1_27-W6_AT24C512C-SSHM-TSOIC-8-P1_27-W6_00
    U1303F24CXXX_U1301_0_SOIC-8-P1_27-W6_AT24C512C-SSHM-TSOIC-8-P1_27-W6_00
    U1304ADHNF-02-V-T/R_SW-4P-P4_50X3_80-DHNF-02-V-T/RSW-4P-P4_50X3_80-SMD
    U1304BDHNF-02-V-T/R_SW-4P-P4_50X3_80-DHNF-02-V-T/RSW-4P-P4_50X3_80-SMD
    U1304CDHNF-02-V-T/R_SW-4P-P4_50X3_80-DHNF-02-V-T/RSW-4P-P4_50X3_80-SMD
    U1304DDHNF-02-V-T/R_SW-4P-P4_50X3_80-DHNF-02-V-T/RSW-4P-P4_50X3_80-SMD
    U1304EDHNF-02-V-T/R_SW-4P-P4_50X3_80-DHNF-02-V-T/RSW-4P-P4_50X3_80-SMD
    U1304FDHNF-02-V-T/R_SW-4P-P4_50X3_80-DHNF-02-V-T/RSW-4P-P4_50X3_80-SMD
    U1400ALTC6226IS6#TRMPBF_0_SOT-23-5-P0LT6274HS5SOT-23-5-P0_95-W2_80
    U1400BLTC6226IS6#TRMPBF_0_SOT-23-5-P0LT6274HS5SOT-23-5-P0_95-W2_80
    U1400CLTC6226IS6#TRMPBF_0_SOT-23-5-P0LT6274HS5SOT-23-5-P0_95-W2_80
    U1400DLTC6226IS6#TRMPBF_0_SOT-23-5-P0LT6274HS5SOT-23-5-P0_95-W2_80
    U1400ELTC6226IS6#TRMPBF_0_SOT-23-5-P0LT6274HS5SOT-23-5-P0_95-W2_80
    U1400FLTC6226IS6#TRMPBF_0_SOT-23-5-P0LT6274HS5SOT-23-5-P0_95-W2_80
    U1401AADG1408YRUZ_2_TSSOP-16-P0_65-W6MC74HC390ADGTSSOP-16-P0_65-W6_40
    U1401BADG1408YRUZ_2_TSSOP-16-P0_65-W6MC74HC390ADGTSSOP-16-P0_65-W6_40
    U1401CADG1408YRUZ_2_TSSOP-16-P0_65-W6MC74HC390ADGTSSOP-16-P0_65-W6_40
    U1401DADG1408YRUZ_2_TSSOP-16-P0_65-W6MC74HC390ADGTSSOP-16-P0_65-W6_40
    U1401EADG1408YRUZ_2_TSSOP-16-P0_65-W6MC74HC390ADGTSSOP-16-P0_65-W6_40
    U1401FADG1408YRUZ_2_TSSOP-16-P0_65-W6MC74HC390ADGTSSOP-16-P0_65-W6_40
    U1402AOPA188_2_SOT-23-5-P0_95-W2_80_TTLV7011DBVRSOT-23-5-P0_95-W2_80
    U1402BOPA188_2_SOT-23-5-P0_95-W2_80_TTLV7011DBVRSOT-23-5-P0_95-W2_80
    U1402COPA188_2_SOT-23-5-P0_95-W2_80_TTLV7011DBVRSOT-23-5-P0_95-W2_80
    U1402DOPA188_2_SOT-23-5-P0_95-W2_80_TTLV7011DBVRSOT-23-5-P0_95-W2_80
    U1402EOPA188_2_SOT-23-5-P0_95-W2_80_TTLV7011DBVRSOT-23-5-P0_95-W2_80
    U1402FOPA188_2_SOT-23-5-P0_95-W2_80_TTLV7011DBVRSOT-23-5-P0_95-W2_80
    U2200BMT_DMM_24BIT_2CH_V1.0_MT_DMM_24MT_DMM_24Bit_2CH_V1.0MT_DMM_24BIT_2CH_V1_0
    ZD1400ABZX84C12-V-G_SOT-23-3_BZX84C4V7BZX84C4V7-V-G/NCSOT-23-3
    ZD1400BBZX84C12-V-G_SOT-23-3_BZX84C4V7BZX84C4V7-V-G/NCSOT-23-3
    ZD1400CBZX84C12-V-G_SOT-23-3_BZX84C4V7BZX84C4V7-V-G/NCSOT-23-3
    ZD1400DBZX84C12-V-G_SOT-23-3_BZX84C4V7BZX84C4V7-V-G/NCSOT-23-3
    ZD1400EBZX84C12-V-G_SOT-23-3_BZX84C4V7BZX84C4V7-V-G/NCSOT-23-3
    ZD1400FBZX84C12-V-G_SOT-23-3_BZX84C4V7BZX84C4V7-V-G/NCSOT-23-3
    ZD1401ABZX84C12-V-G_SOT-23-3_BZX84C4V7BZX84C4V7-V-G/NCSOT-23-3
    ZD1401BBZX84C12-V-G_SOT-23-3_BZX84C4V7BZX84C4V7-V-G/NCSOT-23-3
    ZD1401CBZX84C12-V-G_SOT-23-3_BZX84C4V7BZX84C4V7-V-G/NCSOT-23-3
    ZD1401DBZX84C12-V-G_SOT-23-3_BZX84C4V7BZX84C4V7-V-G/NCSOT-23-3
    ZD1401EBZX84C12-V-G_SOT-23-3_BZX84C4V7BZX84C4V7-V-G/NCSOT-23-3
    ZD1401FBZX84C12-V-G_SOT-23-3_BZX84C4V7BZX84C4V7-V-G/NCSOT-23-3
    重要提示:PCB作品文件展下载说明
