查看: 44|回复: 2
[Allegro17.4以下] LT8912B+YT8521S 做的主板PCB文件
    终身成就奖社区居民忠实会员宣传大使奖优秀斑竹奖
    发表于 2025-6-9 15:54:18 | 显示全部楼层 |阅读模式
    重要提示:PCB作品文件展下载说明
    TLT113-MiniEVM-A1.1-000.7z (546.39 KB, 下载次数: 1)
    CON0SOM-TLT113_SMD_140P_35X45_SOM_SSOM-TLT113SMD_140P_35X45_SOM
    CON1USB  3_0.0 TYPE-C FEMALE_TYPE-C_KH-TYPE-C-16PTYPE-C_16P_90_SMD
    CON2PROCONN  SDC009-52-D_3_CON_TF_CA1060802AR013CON_TF_CARD
    CON3USB  PORT A_CON_USBA_FEMALE_USBUSB  PORT ACON_USBA_FEMALE
    CON4USB  3_0.0 TYPE-C FEMALE_TYPE-C_KH-TYPE-C-16PTYPE-C_16P_90_SMD
    CON5KRJ-320DNL_1_KRJ-320DNL_14P_KRJKRJ-320DNLKRJ-320DNL_14P
    CON62C_CONN_HDMI_TYPEA_DIP_HDMI-A_FFHD14-FDB300K6KDIP_HDMI-A
    CON7PHONEJACK  STEREO SW_3_PJ-342E_JJQ-PJ-3106A-1PJ-342E
    D2DIODE  TVS BI-DIR_SMB_P6SMB6.8CAP6SMB6.8CASMB
    D3DIODE200MA250V_2_SOD-323_B5817WB5817WS-SJSOD-323
    D4DIODE  BREAKDOWN_2_SOD323_BI_DW0DW03D-B-SSOD323_BI
    D5DIODE  BREAKDOWN_2_SOD323_BI_DW0DW03D-B-SSOD323_BI
    D6DIODE  BREAKDOWN_2_SOD323_BI_DW0DW03D-B-SSOD323_BI
    D7DIODE200MA250V_2_SOD-323_B5817WB5817WS-SJSOD-323
    D8DIODE200MA250V_2_SOD-323_B5817WB5817WS-SJSOD-323
    D9DIODE200MA250V_2_SOD-323_B5817WB5817WS-SJSOD-323
    D10DIODE  BI-DIR TRIG_2_D0603_PESD0PESD0863L150D0603
    D11DIODE  BI-DIR TRIG_2_D0603_PESD0PESD0863L150D0603
    D12DIODE  BI-DIR TRIG_2_D0603_PESD0PESD0863L150D0603
    D13DIODE  BI-DIR TRIG_3_D0603_PESD0PESD0863L150D0603
    FB1FERRITE  BEAD_0_L0603_220R_100MH220R_100MHz_2AL0603
    FB2FERRITE  BEAD_0_L0603_220R_100MH220R_100MHz_2AL0603
    FB3FERRITE  BEAD_0_L0603_CBG160808UCBG160808U150TL0603
    FB4FERRITE  BEAD_0_L0603_DNP_CBG160DNP_CBG160808U150TL0603
    FB5FERRITE  BEAD_0_L0603_220R_100MH220R_100MHz_2AL0603
    FB6FERRITE  BEAD_0_L0603_CBG160808UCBG160808U150TL0603
    FB7FERRITE  BEAD_0_L0603_CBG160808UCBG160808U150TL0603
    FB8FERRITE  BEAD_0_L0603_CBG160808UCBG160808U150TL0603
    FB9FERRITE  BEAD_0_L0603_CBG160808UCBG160808U150TL0603
    FB10FERRITE  BEAD_0_L0603_CBG160808UCBG160808U150TL0603
    FB11FERRITE  BEAD_0_L0603_CBG160808UCBG160808U150TL0603
    FB12FERRITE  BEAD_L0603_220R_100MHZ_220R_100MHz_2AL0603
    FB13FERRITE  BEAD_L0603_220R_100MHZ_220R_100MHz_2AL0603
    FB14FERRITE  BEAD_L0603_220R_100MHZ_220R_100MHz_2AL0603
    FB15FERRITE  BEAD_L0603_220R_100MHZ_220R_100MHz_2AL0603
    FB16FERRITE  BEAD_L0603_220R_100MHZ_220R_100MHz_2AL0603
    FB17FERRITE  BEAD_L0603_220R_100MHZ_220R_100MHz_2AL0603
    H1HOLE_MHOLE_C200D125_HOLEHOLEMHOLE_C200D125
    H2HOLE_MHOLE_C200D125_HOLEHOLEMHOLE_C200D125
    H3HOLE_MHOLE_C200D125_HOLEHOLEMHOLE_C200D125
    H4HOLE_MHOLE_C200D125_HOLEHOLEMHOLE_C200D125
    J22H_HEADER12X2_3_CON_2X18P_2D54_PM254-2-18-Z-8.5CON_2X18P_2D54_H_F_DIP
    J32H_HEADER12X2_3_CON_2X18P_2D54_PM254-2-18-Z-8.5CON_2X18P_2D54_H_F_DIP
    J4CON3_0_CON_TH_1X4P_2D54_H_DIP_KKH-2.54PH180-1X4P-L11.5CON_TH_1X4P_2D54_H_DIP
    KEY0SW  PUSHBUTTON-SPST SHIELD_0_SMDKEY_2P_3x6SMD_2P_3X6
    KEY1SW  PUSHBUTTON-SPST SHIELD_0_SMDKEY_2P_3x6SMD_2P_3X6
    KEY2SW  PUSHBUTTON-SPST SHIELD_0_SMDKEY_2P_3x6SMD_2P_3X6
    L1INDUCTOR_SMD_CSAB0518__CSAB0518CSAB0518-2R2MSMD_CSAB0518
    L2INDUCTOR_SMD_CSAB0518__CSAB0518CSAB0518-2R2MSMD_CSAB0518
    L3INDUCTOR_L1008__WPN252010U2R2MTWPN252010U2R2MTL1008
    LED0LED_LED_0603_RED_LEDRED_LEDLED_0603
    LED1LED_0_LED_0603_GREEN_LEDGREEN_LEDLED_0603
    Q1MMBT3904/SOT_SOT23-3_DBZ3_MMBT3MMBT3904SOT23-3_DBZ3
    Q2MMBT3904/SOT_SOT23-3_DBZ3_MMBT3MMBT3904SOT23-3_DBZ3
    Q3MMBT3904/SOT_SOT23-3_DBZ3_MMBT3MMBT3904SOT23-3_DBZ3
    TP300_TP-S40_0_TP_DIP_BLACK  TEST PBlack  Test PointTP_DIP
    TP6T  POINT R_TP30_IC_DNP_TP30DNP_TP30TP30
    TP7T  POINT R_TP30_IC_DNP_TP30DNP_TP30TP30
    U1TXS0102DCUR_0_VSSOP8-DCU_RS0102RS0102YVS8VSSOP8-DCU
    U2CH340T_TSSOP-20_CH340TCH340TTSSOP-20
    U3PRTR5V0U4Y_SOT363_LC0504FLC0504FSOT363
    U4WD1304E30_0_SOT-23-6L_EC2232EEC2232ESOT-23-6L
    U5WD1304E30_0_SOT-23-6L_EC2232EEC2232ESOT-23-6L
    U6PRTR5V0U4Y_0_SOT363_LC0504FLC0504FSOT363
    U7PRTR5V0U4Y_0_SOT363_LC0504FLC0504FSOT363
    U8PRTR5V0U4Y_0_SOT363_LC0504FLC0504FSOT363
    U9TPS2041BDGN_0_SOT23-5_WS4612EBBWS4612EBB-5/TRSOT23-5
    U10PRTR5V0U4Y_SOT363_LC0504FLC0504FSOT363
    U11TPS54286PWP_2_QFN1616-12L_DNP_WDNP_WUSB3801Q-12/TRQFN1616-12L
    U12YT8521S_QFN48_YT8521SH-CAYT8521SH-CAQFN48
    U13SU099PGTR_DFN-10-2510_PESDALC10PESDALC10N5VUDFN-10-2510
    U14SU099PGTR_DFN-10-2510_PESDALC10PESDALC10N5VUDFN-10-2510
    U1574LVC1G08_SC70-5-43M_SGM7SZ08YCSGM7SZ08YC5G/TRSC70-5-43M
    U16TXS0102DCUR_0_VSSOP8-DCU_RS0102RS0102YVS8VSSOP8-DCU
    U17LT8912B_QFN64_0_QFN64_LT8912B_LLT8912BQFN64_LT8912B
    U18RCLAMP0524P_DFN-10L_RCLAMP0524PRCLAMP0524PDFN-10L
    U19RCLAMP0524P_DFN-10L_RCLAMP0524PRCLAMP0524PDFN-10L
    U20RCLAMP0524P_DFN-10L_RCLAMP0524PRCLAMP0524PDFN-10L
    U21TXS0102DCUR_0_VSSOP8-DCU_DNP_RSDNP_RS0102YVS8VSSOP8-DCU
    Y1CRYSTAL_SMD_3225_S3B12.000F1210S3B12.000F1210F30SMD_3225
    Y2CRYSTAL-4  PIN_SMD_3225_S3B25.00S3B25.000F1210F30SMD_3225
    Y3CRYS-4PIN_SMD_3225_S3B25.000F12S3B25.000F1210F30SMD_3225
    重要提示:PCB作品文件展下载说明
    终身成就奖社区居民忠实会员灌水天才奖新人进步奖幽默大师奖贴图大师奖优秀斑竹奖宣传大使奖金点子奖社区明星
    发表于 2025-6-9 16:16:45 | 显示全部楼层
    12 小时前
  • 签到天数: 7 天
    发表于 7 天前 | 显示全部楼层
