REFDES | COMP_DEVICE_TYPE | COMP_VALUE | SYM_NAME |
D5 | DIODE SCHOTTKY-SOD523_SOD-523_R | RB520S-30 | SOD-523 |
D7 | TVS_CA_A179_D_0402_5V_CG0402MLC | 5V | A179_D_0402 |
D8 | TVS_CA_A179_D_0402_5V_CG0402MLC | 5V | A179_D_0402 |
D405 | TVS_CA_A179_D_0402_5V_CG0402MLC | 5V | A179_D_0402 |
D406 | TVS_CA_A179_D_0402_5V_CG0402MLC | 5V | A179_D_0402 |
D407 | TVS_CA_A179_D_0402_5V_CG0402MLC | 5V | A179_D_0402 |
D408 | TVS_CA_A179_D_0402_5V_CG0402MLC | 5V | A179_D_0402 |
D409 | TVS_CA_A179_D_0402_5V_CG0402MLC | 5V | A179_D_0402 |
D500 | DIODE SCHOTTKY-SOD523_SOD523_30 | 30V_0.2A | SOD523 |
D501 | TVS_CDSOD323-T08C_A091_SOD323_H | 8V_17A_350W | A091_SOD323_H100 |
D1000 | TVS_CA_A179_D_0402_5V_CG0402MLC | 5V | A179_D_0402 |
D1001 | TVS_CA_A179_D_0402_5V_CG0402MLC | 5V | A179_D_0402 |
D1002 | TVS_CA_A179_D_0402_5V_CG0402MLC | 5V | A179_D_0402 |
D1003 | TVS_CA_A179_D_0402_5V_CG0402MLC | 5V | A179_D_0402 |
D1004 | TVS_CA_A179_D_0402_5V_CG0402MLC | 5V | A179_D_0402 |
D1005 | TVS_CA_A179_D_0402_5V_CG0402MLC | 5V | A179_D_0402 |
D1006 | TVS_CA_A179_D_0402_5V_CG0402MLC | 5V | A179_D_0402 |
D1200 | TVS_CA_A179_D_0402_5V_CG0402MLC | 5V | A179_D_0402 |
D1201 | TVS_CA_A179_D_0402_5V_CG0402MLC | 5V | A179_D_0402 |
D1202 | TVS_CA_A179_D_0402_5V_CG0402MLC | 5V | A179_D_0402 |
D1203 | TVS_CDSOD323-T08C_A091_SOD323_H | 8V_17A_350W | A091_SOD323_H100 |
D2001 | DIODE_DO_214AA_H244_20V_SS22 | 20V | DO_214AA_H244 |
D2002 | DIODE_DO_214AA_H244_6.2V 1W_1SM | 6.2V 1W | DO_214AA_H244 |
D2003 | BAT54S_SOT-23-3_30V_BAT54S | 30V | SOT-23-3 |
D2004 | BAT54S_SOT-23-3_30V_BAT54S | 30V | SOT-23-3 |
D2009 | DIODE_DO_214AA_H244_18V 1W_1SMA | 18V 1W | DO_214AA_H244 |
D2010 | DIODE_DO_214AA_H244_20V_SS22 | 20V | DO_214AA_H244 |
D2903 | LED_SINGLE_LED0805_LED_SINGLE_5 | LED_SINGLE | LED0805 |
D5000 | DIODE SCHOTTKY-SOD523_SOD523_30 | 30V_0.2A | SOD523 |
D5001 | TVS_CDSOD323-T08C_A091_SOD323_H | 8V_17A_350W | A091_SOD323_H100 |
D20000 | DIODE SCHOTTKY_SOD-123_40V_2A_S | 40V_2A | SOD-123 |
D20001 | TVS_CA_A018_DO_214AA_H244_15V_6 | 15V_600W | A018_DO_214AA_H244 |
D20002 | TVS_CA_A179_D_0402_12V_CG0402ML | 12V | A179_D_0402 |
D20004 | DIODE_DFN0603-2L_PSBD2XD30V05F_ | PSBD2XD30V05F | DFN0603-2L |
D20005 | DIODE_DFN0603-2L_PSBD2XD30V05F_ | PSBD2XD30V05F | DFN0603-2L |
D20006 | LED_SINGLE_LED0805_LED_SINGLE_5 | LED_SINGLE | LED0805 |
D20007 | DIODE_DFN0603-2L_PSBD2XD30V05F_ | PSBD2XD30V05F | DFN0603-2L |
D20008 | TVS_CA_A179_D_0402_5V_CG0402MLC | 5V | A179_D_0402 |
D20009 | TVS_CA_A179_D_0402_5V_CG0402MLC | 5V | A179_D_0402 |
D20010 | DIODE SCHOTTKY-SOD523_SOD-523_R | RB520S-30 | SOD-523 |
D20012 | LED_SINGLE_LED0805_LED_SINGLE_5 | LED_SINGLE | LED0805 |
D20013 | DIODE SCHOTTKY-SOD523_SOD523_30 | 30V_0.2A | SOD523 |
FB400 | BEAD_A454_C_0201_H33_BLM03PX800 | BLM03PX800SN1 | A454_C_0201_H33 |
FB401 | BEAD_A454_C_0201_H33_BLM03PX800 | BLM03PX800SN1 | A454_C_0201_H33 |
FB1200 | BEAD_A041_L_0402_H60_120OHM_100 | 120ohm_100MHz_1.5A | A041_L_0402_H60 |
FB2001 | BEAD_A041_L_0402_H60_120OHM_100 | 120ohm_100MHz_1.5A | A041_L_0402_H60 |
FB5000 | BEAD_A041_L_0402_H60_120OHM_100 | 120ohm_100MHz_1.5A | A041_L_0402_H60 |
FB5001 | BEAD_A041_L_0402_H60_120OHM_100 | 120ohm_100MHz_1.5A | A041_L_0402_H60 |
FB5002 | BEAD_A041_L_0402_H60_120OHM_100 | 120ohm_100MHz_1.5A | A041_L_0402_H60 |
FB5003 | BEAD_A041_L_0402_H60_120OHM_100 | 120ohm_100MHz_1.5A | A041_L_0402_H60 |
FB5004 | BEAD_A041_L_0402_H60_120OHM_100 | 120ohm_100MHz_1.5A | A041_L_0402_H60 |
FB9025 | BEAD_A042_L_0603_H95_220OHM_100 | 220OHM_100MHz_1.4A | A042_L_0603_H95 |
FB9026 | BEAD_A042_L_0603_H95_220OHM_100 | 220OHM_100MHz_1.4A | A042_L_0603_H95 |
FB9027 | BEAD_A042_L_0603_H95_220OHM_100 | 220OHM_100MHz_1.4A | A042_L_0603_H95 |
FB9028 | BEAD_A042_L_0603_H95_220OHM_100 | 220OHM_100MHz_1.4A | A042_L_0603_H95 |
FB9029 | BEAD_A042_L_0603_H95_220OHM_100 | 220OHM_100MHz_1.4A | A042_L_0603_H95 |
FB9030 | BEAD_A042_L_0603_H95_70OHM_100M | 70OHM_100MHz_1.4A | A042_L_0603_H95 |
FB9031 | BEAD_A042_L_0603_H95_70OHM_100M | 70OHM_100MHz_1.4A | A042_L_0603_H95 |
FB9032 | BEAD_A042_L_0603_H95_70OHM_100M | 70OHM_100MHz_1.4A | A042_L_0603_H95 |
FB9033 | BEAD_A042_L_0603_H95_70OHM_100M | 70OHM_100MHz_1.4A | A042_L_0603_H95 |
FB9034 | BEAD_A042_L_0603_H95_70OHM_100M | 70OHM_100MHz_1.4A | A042_L_0603_H95 |
J3 | CON3_HEADER3_CON3_22-28-5034 | CON3 | HEADER3 |
J500 | HDMI TYPE A CONN_0_A359_HDMIS_F | HDMI(TYPE A) | A359_HDMIS_F_H618 |
J1001 | TF_CARD_A088_SDCMIC_MRAP03_H190 | TF_CARD | A088_SDCMIC_MRAP03_H190 |
J1200 | USB_MICRO_B_A441_USBSF_5X1_MICB | USB_MICRO_B | A441_USBSF_5X1_MICB_H290 |
J2001 | FPC-0.5-CON30_FPCS_05PITCH_30P_ | FPC-0.5-CON30 | FPCS_05PITCH_30P |
J2210 | RF_JACK_4P_A395_RFC_VFSMT_H125_ | RF_JACK_4P | A395_RFC_VFSMT_H125 |
J2211 | RF_JACK_4P_A395_RFC_VFSMT_H125_ | RF_JACK_4P | A395_RFC_VFSMT_H125 |
J2212 | SMA JACK CON_S_0_SMA-SMT_SMA-KH | SMA-KHDC3 | SMA-SMT |
J2213 | SMA JACK CON_S_0_SMA-SMT_SMA-KH | SMA-KHDC3 | SMA-SMT |
J2712 | CON3_HEADER3_CON3_22-28-5034 | CON3 | HEADER3 |
J5000 | HDMI TYPE A CONN_0_A359_HDMIS_F | HDMI(TYPE A) | A359_HDMIS_F_H618 |
J20000 | DC_5P_A016_DC63100088_H720_DC_5 | DC_5P | A016_DC63100088_H720 |
J20002 | HEADER 5X2_HEADER5X2_HEADER 5X2 | HEADER 5X2 | HEADER5X2 |
J20003 | HDMI TYPE A CONN_0_A359_HDMIS_F | HDMI(TYPE A) | A359_HDMIS_F_H618 |
J20004 | CON3_HEADER3_CON3_22-28-5034 | CON3 | HEADER3 |
J20005 | PJ-320F_PJ-320F-3P_PJ-320F_PJ-3 | PJ-320F | PJ-320F-3P |
J20006 | CON3_HEADER3_CON3_22-28-5034 | CON3 | HEADER3 |
J20007 | PJ-320F_PJ-320F-3P_PJ-320F_PJ-3 | PJ-320F | PJ-320F-3P |
J20008 | CON5_HEADER5_CON5_22-28-5054 | CON5 | HEADER5 |
J20009 | HEADER 9X2_HEADER9X2_HEADER 9X2 | HEADER 9X2 | HEADER9X2 |
J20010 | CON2_XH254_1X2P_XH254_1X2P_XH25 | XH254_1X2P | XH254_1X2P |
L4 | INDUCTOR-COM_A142_SDCW_2012_H12 | BWCU00201212900M02 | A142_SDCW_2012_H120 |
L400 | INDUCTOR_L1700X0950H080_3.3UH_L | 3.3uH | L1700X0950H080 |
L2001 | INDUCTOR_L_P450X400_H320_10UH_S | 10uH | L_P450X400_H320 |
L2002 | INDUCTOR_L_P300X300_H150_3.3UH_ | 3.3uH | L_P300X300_H150 |
L3001 | INDUCTOR_A344_L_P350X500_H200_3 | 3.3uH | A344_L_P350X500_H200 |
L20000 | INDUCTOR_A196_L_P300X400_H200_2 | 2.2uH | A196_L_P300X400_H200 |
L20002 | INDUCTOR_A196_L_P300X400_H200_1 | 2.2uH | A196_L_P300X400_H200 |
L20004 | INDUCTOR_A196_L_P300X400_H200_1 | 2.2uH | A196_L_P300X400_H200 |
L20006 | INDUCTOR_A196_L_P300X400_H200_1 | 2.2uH | A196_L_P300X400_H200 |
L20080 | INDUCTOR_A196_L_P300X400_H200_2 | 2.2uH | A196_L_P300X400_H200 |
L20081 | INDUCTOR-COM_A142_SDCW_2012_H12 | BWCU00201212900M02 | A142_SDCW_2012_H120 |
L20082 | INDUCTOR-COM_A142_SDCW_2012_H12 | BWCU00201212900M02 | A142_SDCW_2012_H120 |
L20083 | INDUCTOR-COM_A142_SDCW_2012_H12 | BWCU00201212900M02 | A142_SDCW_2012_H120 |
MH2901 | MH_MTG-250D126_MH | MH | MTG-250D126 |
MH2902 | MH_MTG-250D126_MH | MH | MTG-250D126 |
MH2903 | MH_MTG-250D126_MH | MH | MTG-250D126 |
MH2904 | MH_MTG-250D126_MH | MH | MTG-250D126 |
Q1003 | AO3423_SOT23_-20V_AO3423 | -20V | SOT23 |
Q1004 | NPN_SOT23_PT23T8050L_PT23T8050L | PT23T8050L | SOT23 |
Q2001 | AO3423_SOT23_-20V_AO3423 | -20V | SOT23 |
Q2002 | NPN_SOT23_PT23T8050L_PT23T8050L | PT23T8050L | SOT23 |
Q5003 | NMOS_SOT-323_PNMUT20V06_PNMUT20 | PNMUT20V06 | SOT-323 |
Q5004 | NMOS_SOT-323_PNMUT20V06_PNMUT20 | PNMUT20V06 | SOT-323 |
Q5005 | NMOS_SOT-323_PNMUT20V06_PNMUT20 | PNMUT20V06 | SOT-323 |
Q5006 | NMOS_SOT-323_PNMUT20V06_PNMUT20 | PNMUT20V06 | SOT-323 |
Q5007 | NMOS_SOT-323_PNMUT20V06_PNMUT20 | PNMUT20V06 | SOT-323 |
Q5008 | NMOS_SOT-323_PNMUT20V06_PNMUT20 | PNMUT20V06 | SOT-323 |
Q5009 | NMOS_SOT-323_PNMUT20V06_PNMUT20 | PNMUT20V06 | SOT-323 |
Q5010 | NMOS_SOT-323_PNMUT20V06_PNMUT20 | PNMUT20V06 | SOT-323 |
Q5013 | NMOS_SOT-323_PNMUT20V06_PNMUT20 | PNMUT20V06 | SOT-323 |
Q5015 | NMOS_SOT-323_PNMUT20V06_PNMUT20 | PNMUT20V06 | SOT-323 |
S20000 | SW PUSHBUTTON_4P_A_SW_4-2P15-4P | SKRPACE010 | SW_4-2P15-4P2X3P2-2P5 |
SW801 | KF1027B-04P-G_0_DSIC02LSGET_DSI | DSIC02LSGET | DSIC02LSGET |
U1 | LT7911C_4_QFN64_750X750H080_ LT | LT6911UXE_U1 | QFN64_750X750H080 |
U2 | LT9611_0_QFN64_750X750H080_LT96 | LT9611 | QFN64_750X750H080 |
U6 | AT24C64D-XHM-T_SOIC8-150_24LC04 | 24LC04B | SOIC8-150 |
U9 | TCA9517_SOIC8_400X500H175_TCA95 | TCA9517 | SOIC8_400X500H175 |
U304 | TPS22912_DSBGA4-100X100-H060_AW | AW35122FDR | DSBGA4-100X100-H060 |
U400 | MS7024_QFP48_70X70H12_MS7024_MS | MS7024 | QFP48_70X70H12 |
U401 | I-PEX-20455-030E-66_20455-030E- | I-PEX-20455-030E-66 | 20455-030E-66 |
U402 | RCLAMP0524J_DFN-10_250X100_H65_ | RClamp0524J | DFN-10_250X100_H65 |
U403 | RCLAMP0524J_DFN-10_250X100_H65_ | RClamp0524J | DFN-10_250X100_H65 |
U404 | RCLAMP0524J_DFN-10_250X100_H65_ | RClamp0524J | DFN-10_250X100_H65 |
U500 | 74AVC8T245BQ_VQFN24_550X350H100 | 74AVC8T245BQ | VQFN24_550X350H100 |
U804 | SGM2019-1.5YN5G/TR_A099_SOT23_5 | SGM2019-1.5YN5G/TR | A099_SOT23_5_H145 |
U1200 | TPS2553_A100_SOT23_6_H145_DIO75 | DIO7553ST6 | A100_SOT23_6_H145 |
U1301 | ARS31L-C401-STAMP_C401-INTERFAC | ARS31L-C401-STAMP | C401-INTERFACE |
U2001 | SY7201ABC_SOT23-6_290X160H110_S | SY7201ABC | SOT23-6_290X160H110 |
U2002 | RCLAMP0524J_DFN-10_250X100_H65_ | RClamp0524J | DFN-10_250X100_H65 |
U2003 | RCLAMP0524J_DFN-10_250X100_H65_ | RClamp0524J | DFN-10_250X100_H65 |
U2004 | RCLAMP0524J_DFN-10_250X100_H65_ | RClamp0524J | DFN-10_250X100_H65 |
U2005 | SY7201ABC_SOT23-6_290X160H110_1 | SY7208CABC | SOT23-6_290X160H110 |
U2006 | TXS0108E_R-PQFP-N20_-_TXS0108ER | - | R-PQFP-N20 |
U2101 | RCLAMP0524J_DFN-10_250X100_H65_ | RClamp0524J | DFN-10_250X100_H65 |
U3002 | SY8120IADC_SOT23-6_SY8113IADC_S | SY8113IADC | SOT23-6 |
U5000 | IT66121FN_IT66121FN-64-PIN-QFN_ | IT66122FN | IT66121FN-64-PIN-QFN |
U5001 | RCLAMP0524J_DFN-10_250X100_H65_ | RClamp0524J | DFN-10_250X100_H65 |
U5002 | RCLAMP0524J_DFN-10_250X100_H65_ | RClamp0524J | DFN-10_250X100_H65 |
U5003 | RCLAMP0524J_DFN-10_250X100_H65_ | RClamp0524J | DFN-10_250X100_H65 |
U9609 | MP1541DJ_2_A085_SC_70_6_H100_BL | BL1551B | A085_SC_70_6_H100 |
U9610 | MP1541DJ_2_A085_SC_70_6_H100_BL | BL1551B | A085_SC_70_6_H100 |
U20000 | BOARDSWITCH_SW133X850_SS01_SS01 | SS01 | SW133X850 |
U20001 | SY8254_QFN20_300X300H090_SY8254 | SY8254RAC | QFN20_300X300H090 |
U20004 | SY8120IADC_SOT23-6_SY8113IADC_S | SY8113IADC | SOT23-6 |
U20006 | SY8120IADC_SOT23-6_SY8113IADC_S | SY8113IADC | SOT23-6 |
U20008 | SY8120IADC_SOT23-6_SY8113IADC_S | SY8113IADC | SOT23-6 |
U20068 | SY8254_QFN20_300X300H090_SY8254 | SY8254RAC | QFN20_300X300H090 |
U20069 | RCLAMP0524J_DFN-10_250X100_H65_ | RClamp0524J | DFN-10_250X100_H65 |
U20070 | RCLAMP0524J_DFN-10_250X100_H65_ | RClamp0524J | DFN-10_250X100_H65 |
U20071 | RCLAMP0524J_DFN-10_250X100_H65_ | RClamp0524J | DFN-10_250X100_H65 |
U20072 | RCLAMP0524J_DFN-10_250X100_H65_ | RClamp0524J | DFN-10_250X100_H65 |
U20073 | RCLAMP0524J_DFN-10_250X100_H65_ | RClamp0524J | DFN-10_250X100_H65 |
U20074 | 74AVC8T245BQ_VQFN24_550X350H100 | 74AVC8T245BQ | VQFN24_550X350H100 |
U20075 | 74AVC8T245BQ_VQFN24_550X350H100 | 74AVC8T245BQ | VQFN24_550X350H100 |
U20076 | TPS2553_A100_SOT23_6_H145_DIO75 | DIO7553ST6 | A100_SOT23_6_H145 |
U21014 | W25Q32JV-XSON_USON8_200X300H060 | W25Q16JVUXIQ | USON8_200X300H060 |
X401 | OSC_DIP_4P_1_X3225_37.125MHZ_DS | 37.125MHz | X3225 |
X2201 | CRYSTAL_4P_A481_OSCS_2520_P180E | 27MHz | A481_OSCS_2520_P180E115_H90 |
X2202 | CRYSTAL_4P_OSC2016_24MHZ_E1SB24 | 24MHz | OSC2016 |
