查看: 4195|回复: 4
u-boot fat
发表于 2014-3-26 21:35:12 | 显示全部楼层 |阅读模式
* fat.c
* R/O (V)FAT 12/16/32 filesystem implementation by Marcus Sundberg
* 2002-07-28 - rjones@nexus-tech.net - ported to ppcboot v1.1.6
* 2003-03-10 - kharris@nexus-tech.net - ported to uboot
* See file CREDITS for list of people who contributed to this
* project.
* This program is free software; you can redistribute it and/or
* modify it under the terms of the GNU General Public License as
* published by the Free Software Foundation; either version 2 of
* the License, or (at your option) any later version.
* This program is distributed in the hope that it will be useful,
* but WITHOUT ANY WARRANTY; without even the implied warranty of
* MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE.  See the
* GNU General Public License for more details.
* You should have received a copy of the GNU General Public License
* along with this program; if not, write to the Free Software
* Foundation, Inc., 59 Temple Place, Suite 330, Boston,
* MA 02111-1307 USA
#include <common.h>
#include <config.h>
#include <fat.h>
#include <asm/byteorder.h>
#include <part.h>
#if defined(CONFIG_CMD_FAT)
* Convert a string to lowercase.
static void
downcase(char *str)
while (*str != '\0') {
  TOLOWER(*str);
  str++;
static  block_dev_desc_t *cur_dev = NULL;
static unsigned long part_offset = 0;
static int cur_part = 1;
#define DOS_PART_TBL_OFFSET 0x1be
#define DOS_PART_MAGIC_OFFSET 0x1fe
#define DOS_FS_TYPE_OFFSET 0x36
int disk_read (__u32 startblock, __u32 getsize, __u8 * bufptr)
startblock += part_offset;
if (cur_dev == NULL)
  return -1;
if (cur_dev->block_read) {
  return cur_dev->block_read (cur_dev->dev
   , startblock, getsize, (unsigned long *)bufptr);
return -1;
int
fat_register_device(block_dev_desc_t *dev_desc, int part_no)
unsigned char buffer[SECTOR_SIZE];
disk_partition_t info;
if (!dev_desc->block_read)
  return -1;
cur_dev = dev_desc;
/* check if we have a MBR (on floppies we have only a PBR) */
if (dev_desc->block_read (dev_desc->dev, 0, 1, (ulong *) buffer) != 1) {
  printf ("** Can't read from device %d **\n", dev_desc->dev);
  return -1;
if (buffer[DOS_PART_MAGIC_OFFSET] != 0x55 ||
  buffer[DOS_PART_MAGIC_OFFSET + 1] != 0xaa) {
  /* no signature found */
  return -1;
#if (defined(CONFIG_CMD_IDE) || \
     defined(CONFIG_CMD_SCSI) || \
     defined(CONFIG_CMD_USB) || \
     defined(CONFIG_MMC) || \
     defined(CONFIG_SYSTEMACE) )
/* First we assume, there is a MBR */
if (!get_partition_info (dev_desc, part_no, &info)) {
  part_offset = info.start;
  cur_part = part_no;
} else if (!strncmp((char *)&buffer[DOS_FS_TYPE_OFFSET], "FAT", 3)) {
  /* ok, we assume we are on a PBR only */
  cur_part = 1;
  part_offset = 0;
} else {
  printf ("** Partition %d not valid on device %d **\n",
    part_no, dev_desc->dev);
  return -1;
#else
if (!strncmp((char *)&buffer[DOS_FS_TYPE_OFFSET],"FAT",3)) {
  cur_part = 1;
  part_offset = 0;
  info.start = part_offset;
} else {
  /* FIXME we need to determine the start block of the
   * partition where the DOS FS resides. This can be done
   * by using the get_partition_info routine. For this
   * purpose the libpart must be included.
  part_offset = 32;
  cur_part = 1;
#endif
return 0;
* Get the first occurence of a directory delimiter ('/' or '\') in a string.
* Return index into string if found, -1 otherwise.
static int
dirdelim(char *str)
char *start = str;
  if (ISDIRDELIM(*str)) return str - start;
  str++;
return -1;
* Match volume_info fs_type strings.
* Return 0 on match, -1 otherwise.
static int
compare_sign(char *str1, char *str2)
char *end = str1+SIGNLEN;
while (str1 != end) {
  if (*str1 != *str2) {
   return -1;
  str1++;
  str2++;
return 0;
* Extract zero terminated short name from a directory entry.
static void get_name (dir_entry *dirent, char *s_name)
char *ptr;
memcpy (s_name, dirent->name, 8);
s_name[8] = '\0';
ptr = s_name;
while (*ptr && *ptr != ' ')
  ptr++;
if (dirent->ext[0] && dirent->ext[0] != ' ') {
  *ptr = '.';
  ptr++;
  memcpy (ptr, dirent->ext, 3);
  ptr[3] = '\0';
   ptr++;
*ptr = '\0';
if (*s_name == DELETED_FLAG)
  *s_name = '\0';
else if (*s_name == aRING)
  *s_name = '?;
downcase (s_name);
* Get the entry at index 'entry' in a FAT (12/16/32) table.
* On failure 0x00 is returned.
static __u32
get_fatent(fsdata *mydata, __u32 entry)
__u32 bufnum;
__u32 offset;
__u32 ret = 0x00;
switch (mydata->fatsize) {
case 32:
  bufnum = entry / FAT32BUFSIZE;
  offset = entry - bufnum * FAT32BUFSIZE;
  break;
case 16:
  bufnum = entry / FAT16BUFSIZE;
  offset = entry - bufnum * FAT16BUFSIZE;
  break;
case 12:
  bufnum = entry / FAT12BUFSIZE;
  offset = entry - bufnum * FAT12BUFSIZE;
  break;
default:
  /* Unsupported FAT size */
  return ret;
/* Read a new block of FAT entries into the cache. */
if (bufnum != mydata->fatbufnum) {
  int getsize = FATBUFSIZE/FS_BLOCK_SIZE;
  __u8 *bufptr = mydata->fatbuf;
  __u32 fatlength = mydata->fatlength;
  __u32 startblock = bufnum * FATBUFBLOCKS;
  fatlength *= SECTOR_SIZE; /* We want it in bytes now */
  startblock += mydata->fat_sect; /* Offset from start of disk */
  if (getsize > fatlength) getsize = fatlength;
  if (disk_read(startblock, getsize, bufptr) < 0) {
   FAT_DPRINT("Error reading FAT blocks\n");
   return ret;
  mydata->fatbufnum = bufnum;
/* Get the actual entry from the table */
case 32:
  ret = FAT2CPU32(((__u32*)mydata->fatbuf)[offset]);
  break;
case 16:
  ret = FAT2CPU16(((__u16*)mydata->fatbuf)[offset]);
  break;
case 12: {
  __u32 off16 = (offset*3)/4;
  __u16 val1, val2;
  switch (offset & 0x3) {
  case 0:
   ret = FAT2CPU16(((__u16*)mydata->fatbuf)[off16]);
   ret &= 0xfff;
   break;
  case 1:
   val1 = FAT2CPU16(((__u16*)mydata->fatbuf)[off16]);
   val1 &= 0xf000;
   val2 = FAT2CPU16(((__u16*)mydata->fatbuf)[off16+1]);
   val2 &= 0x00ff;
   ret = (val2 << 4) | (val1 >> 12);
   break;
  case 2:
   val1 &= 0xff00;
   val2 &= 0x000f;
   ret = (val2 << 8) | (val1 >> 8);
   break;
  case 3:
   ret = FAT2CPU16(((__u16*)mydata->fatbuf)[off16]);;
   ret = (ret & 0xfff0) >> 4;
   break;
  default:
   break;
break;
FAT_DPRINT("ret: %d, offset: %d\n", ret, offset);
return ret;
* Read at most 'size' bytes from the specified cluster into 'buffer'.
* Return 0 on success, -1 otherwise.
static int
get_cluster(fsdata *mydata, __u32 clustnum, __u8 *buffer, unsigned long size)
int idx = 0;
__u32 startsect;
if (clustnum > 0) {
  startsect = mydata->data_begin + clustnum*mydata->clust_size;
} else {
  startsect = mydata->rootdir_sect;
FAT_DPRINT("gc - clustnum: %d, startsect: %d\n", clustnum, startsect);
if (disk_read(startsect, size/FS_BLOCK_SIZE , buffer) < 0) {
  FAT_DPRINT("Error reading data\n");
  return -1;
if(size % FS_BLOCK_SIZE) {
  __u8 tmpbuf[FS_BLOCK_SIZE];
  idx= size/FS_BLOCK_SIZE;
  if (disk_read(startsect + idx, 1, tmpbuf) < 0) {
   return -1;
  buffer += idx*FS_BLOCK_SIZE;
  memcpy(buffer, tmpbuf, size % FS_BLOCK_SIZE);
  return 0;
return 0;
* Read at most 'maxsize' bytes from the file associated with 'dentptr'
* into 'buffer'.
* Return the number of bytes read or -1 on fatal errors.
static long
get_contents(fsdata *mydata, dir_entry *dentptr, __u8 *buffer,
      unsigned long maxsize)
unsigned long filesize = FAT2CPU32(dentptr->size), gotsize = 0;
unsigned int bytesperclust = mydata->clust_size * SECTOR_SIZE;
__u32 curclust = START(dentptr);
__u32 endclust, newclust;
unsigned long actsize;
FAT_DPRINT("Filesize: %ld bytes\n", filesize);
if (maxsize > 0 && filesize > maxsize) filesize = maxsize;
FAT_DPRINT("Reading: %ld bytes\n", filesize);
actsize=bytesperclust;
endclust=curclust;
do {
  /* search for consecutive clusters */
  while(actsize < filesize) {
   newclust = get_fatent(mydata, endclust);
   if((newclust -1)!=endclust)
    goto getit;
   if (CHECK_CLUST(newclust, mydata->fatsize)) {
    FAT_DPRINT("curclust: 0x%x\n", newclust);
    FAT_DPRINT("Invalid FAT entry\n");
    return gotsize;
   endclust=newclust;
   actsize+= bytesperclust;
  /* actsize >= file size */
  actsize -= bytesperclust;
  /* get remaining clusters */
  if (get_cluster(mydata, curclust, buffer, (int)actsize) != 0) {
   FAT_ERROR("Error reading cluster\n");
   return -1;
  /* get remaining bytes */
  gotsize += (int)actsize;
  filesize -= actsize;
  buffer += actsize;
  actsize= filesize;
  if (get_cluster(mydata, endclust, buffer, (int)actsize) != 0) {
   return -1;
  gotsize+=actsize;
  return gotsize;
getit:
   return -1;
  buffer += actsize;
  curclust = get_fatent(mydata, endclust);
  if (CHECK_CLUST(curclust, mydata->fatsize)) {
   FAT_DPRINT("curclust: 0x%x\n", curclust);
   FAT_ERROR("Invalid FAT entry\n");
   return gotsize;
  endclust=curclust;
} while (1);
#ifdef CONFIG_SUPPORT_VFAT
* Extract the file name information from 'slotptr' into 'l_name',
* starting at l_name[*idx].
* Return 1 if terminator (zero byte) is found, 0 otherwise.
static int
slot2str(dir_slot *slotptr, char *l_name, int *idx)
int j;
for (j = 0; j <= 8; j += 2) {
  l_name[*idx] = slotptr->name0_4[j];
  if (l_name[*idx] == 0x00) return 1;
  (*idx)++;
for (j = 0; j <= 10; j += 2) {
  l_name[*idx] = slotptr->name5_10[j];
  (*idx)++;
for (j = 0; j <= 2; j += 2) {
  l_name[*idx] = slotptr->name11_12[j];
  (*idx)++;
return 0;
* Extract the full long filename starting at 'retdent' (which is really
* a slot) into 'l_name'. If successful also copy the real directory entry
* into 'retdent'
__u8  get_vfatname_block[MAX_CLUSTSIZE];
static int
get_vfatname(fsdata *mydata, int curclust, __u8 *cluster,
      dir_entry *retdent, char *l_name)
dir_entry *realdent;
dir_slot  *slotptr = (dir_slot*) retdent;
__u8   *nextclust = cluster + mydata->clust_size * SECTOR_SIZE;
__u8    counter = (slotptr->id & ~LAST_LONG_ENTRY_MASK) & 0xff;
int idx = 0;
while ((__u8*)slotptr < nextclust) {
  if (counter == 0) break;
  if (((slotptr->id & ~LAST_LONG_ENTRY_MASK) & 0xff) != counter)
   return -1;
  slotptr++;
  counter--;
if ((__u8*)slotptr >= nextclust) {
  dir_slot *slotptr2;
  slotptr--;
  curclust = get_fatent(mydata, curclust);
   return -1;
  if (get_cluster(mydata, curclust, get_vfatname_block,
    mydata->clust_size * SECTOR_SIZE) != 0) {
   FAT_DPRINT("Error: reading directory block\n");
   return -1;
  slotptr2 = (dir_slot*) get_vfatname_block;
  while (slotptr2->id > 0x01) {
   slotptr2++;
  /* Save the real directory entry */
  realdent = (dir_entry*)slotptr2 + 1;
  while ((__u8*)slotptr2 >= get_vfatname_block) {
   slot2str(slotptr2, l_name, &idx);
   slotptr2--;
} else {
  realdent = (dir_entry*)slotptr;
do {
  slotptr--;
  if (slot2str(slotptr, l_name, &idx)) break;
} while (!(slotptr->id & LAST_LONG_ENTRY_MASK));
l_name[idx] = '\0';
if (*l_name == DELETED_FLAG) *l_name = '\0';
else if (*l_name == aRING) *l_name = '?;
downcase(l_name);
/* Return the real directory entry */
memcpy(retdent, realdent, sizeof(dir_entry));
return 0;
/* Calculate short name checksum */
static __u8
mkcksum(const char *str)
int i;
__u8 ret = 0;
for (i = 0; i < 11; i++) {
  ret = (((ret&1)<<7)|((ret&0xfe)>>1)) + str;
return ret;
#endif
* Get the directory entry associated with 'filename' from the directory
* starting at 'startsect'
__u8 get_dentfromdir_block[MAX_CLUSTSIZE];
static dir_entry *get_dentfromdir (fsdata * mydata, int startsect,
       char *filename, dir_entry * retdent,
       int dols)
    __u16 prevcksum = 0xffff;
    __u32 curclust = START (retdent);
    int files = 0, dirs = 0;
    FAT_DPRINT ("get_dentfromdir: %s\n", filename);
    while (1) {
dir_entry *dentptr;
int i;
if (get_cluster (mydata, curclust, get_dentfromdir_block,
     FAT_DPRINT ("Error: reading directory block\n");
     return NULL;
dentptr = (dir_entry *) get_dentfromdir_block;
for (i = 0; i < DIRENTSPERCLUST; i++) {
     char s_name[14], l_name[256];
     l_name[0] = '\0';
     if (dentptr->name[0] == DELETED_FLAG) {
      dentptr++;
      continue;
     if ((dentptr->attr & ATTR_VOLUME)) {
  if ((dentptr->attr & ATTR_VFAT) &&
      (dentptr->name[0] & LAST_LONG_ENTRY_MASK)) {
      prevcksum = ((dir_slot *) dentptr)
       ->alias_checksum;
      get_vfatname (mydata, curclust, get_dentfromdir_block,
      dentptr, l_name);
      if (dols) {
   int isdir = (dentptr->attr & ATTR_DIR);
   char dirc;
   int doit = 0;
   if (isdir) {
       dirs++;
       dirc = '/';
       doit = 1;
   } else {
       dirc = ' ';
       if (l_name[0] != 0) {
    files++;
    doit = 1;
   if (doit) {
       if (dirc == ' ') {
    printf (" %8ld   %s%c\n",
     (long) FAT2CPU32 (dentptr->size),
     l_name, dirc);
       } else {
    printf ("            %s%c\n", l_name, dirc);
   dentptr++;
   continue;
      FAT_DPRINT ("vfatname: |%s|\n", l_name);
  } else
#endif
      /* Volume label or VFAT entry */
      dentptr++;
      continue;
     if (dentptr->name[0] == 0) {
  if (dols) {
      printf ("\n%d file(s), %d dir(s)\n\n", files, dirs);
  FAT_DPRINT ("Dentname == NULL - %d\n", i);
  return NULL;
     if (dols && mkcksum (dentptr->name) == prevcksum) {
  dentptr++;
  continue;
#endif
     get_name (dentptr, s_name);
     if (dols) {
  char dirc;
  int doit = 0;
  if (isdir) {
      dirs++;
      dirc = '/';
      doit = 1;
  } else {
      dirc = ' ';
      if (s_name[0] != 0) {
   files++;
   doit = 1;
  if (doit) {
      if (dirc == ' ') {
    (long) FAT2CPU32 (dentptr->size), s_name,
    dirc);
      } else {
   printf ("            %s%c\n", s_name, dirc);
  dentptr++;
  continue;
     if (strcmp (filename, s_name) && strcmp (filename, l_name)) {
  FAT_DPRINT ("Mismatch: |%s|%s|\n", s_name, l_name);
  dentptr++;
  continue;
     memcpy (retdent, dentptr, sizeof (dir_entry));
     FAT_DPRINT ("DentName: %s", s_name);
     FAT_DPRINT (", start: 0x%x", START (dentptr));
     FAT_DPRINT (", size:  0x%x %s\n",
   (dentptr->attr & ATTR_DIR) ? "(DIR)" : "");
     return retdent;
curclust = get_fatent (mydata, curclust);
     FAT_DPRINT ("curclust: 0x%x\n", curclust);
     FAT_ERROR ("Invalid FAT entry\n");
     return NULL;
    return NULL;
* Read boot sector and volume info from a FAT filesystem
static int
read_bootsectandvi(boot_sector *bs, volume_info *volinfo, int *fatsize)
__u8 block[FS_BLOCK_SIZE];
volume_info *vistart;
if (disk_read(0, 1, block) < 0) {
  FAT_DPRINT("Error: reading block\n");
  return -1;
memcpy(bs, block, sizeof(boot_sector));
bs->reserved = FAT2CPU16(bs->reserved);
bs->fat_length = FAT2CPU16(bs->fat_length);
bs->secs_track = FAT2CPU16(bs->secs_track);
bs->heads = FAT2CPU16(bs->heads);
#if 0 /* UNUSED */
bs->hidden = FAT2CPU32(bs->hidden);
#endif
bs->total_sect = FAT2CPU32(bs->total_sect);
/* FAT32 entries */
if (bs->fat_length == 0) {
  /* Assume FAT32 */
  bs->fat32_length = FAT2CPU32(bs->fat32_length);
  bs->flags  = FAT2CPU16(bs->flags);
  bs->root_cluster = FAT2CPU32(bs->root_cluster);
  bs->info_sector  = FAT2CPU16(bs->info_sector);
  bs->backup_boot  = FAT2CPU16(bs->backup_boot);
  vistart = (volume_info*) (block + sizeof(boot_sector));
  *fatsize = 32;
} else {
  vistart = (volume_info*) &(bs->fat32_length);
  *fatsize = 0;
memcpy(volinfo, vistart, sizeof(volume_info));
/* Terminate fs_type string. Writing past the end of vistart
    is ok - it's just the buffer. */
vistart->fs_type[8] = '\0';
if (*fatsize == 32) {
  if (compare_sign(FAT32_SIGN, vistart->fs_type) == 0) {
   return 0;
} else {
  if (compare_sign(FAT12_SIGN, vistart->fs_type) == 0) {
   *fatsize = 12;
   return 0;
  if (compare_sign(FAT16_SIGN, vistart->fs_type) == 0) {
   *fatsize = 16;
   return 0;
FAT_DPRINT("Error: broken fs_type sign\n");
return -1;
__u8 do_fat_read_block[MAX_CLUSTSIZE];  /* Block buffer */
long
do_fat_read (const char *filename, void *buffer, unsigned long maxsize,
      int dols)
#if CONFIG_NIOS /* NIOS CPU cannot access big automatic arrays */
    static
#endif
    char fnamecopy[2048];
    boot_sector bs;
    volume_info volinfo;
    fsdata datablock;
    fsdata *mydata = &datablock;
    dir_entry *dentptr;
    char *subname = "";
    int rootdir_size, cursect;
    int idx, isdir = 0;
    long ret = 0;
    int firsttime;
    if (read_bootsectandvi (&bs, &volinfo, &mydata->fatsize)) {
FAT_DPRINT ("Error: reading boot sector\n");
return -1;
    if (mydata->fatsize == 32) {
mydata->fatlength = bs.fat32_length;
    } else {
mydata->fatlength = bs.fat_length;
    mydata->fat_sect = bs.reserved;
    cursect = mydata->rootdir_sect
     = mydata->fat_sect + mydata->fatlength * bs.fats;
    mydata->clust_size = bs.cluster_size;
rootdir_size = mydata->clust_size;
mydata->data_begin = mydata->rootdir_sect   /* + rootdir_size */
  - (mydata->clust_size * 2);
    } else {
rootdir_size = ((bs.dir_entries[1] * (int) 256 + bs.dir_entries[0])
   * sizeof (dir_entry)) / SECTOR_SIZE;
mydata->data_begin = mydata->rootdir_sect + rootdir_size
    mydata->fatbufnum = -1;
    FAT_DPRINT ("FAT%d, fatlength: %d\n", mydata->fatsize,
  mydata->fatlength);
    FAT_DPRINT ("Rootdir begins at sector: %d, offset: %x, size: %d\n"
  "Data begins at: %d\n",
  mydata->rootdir_sect, mydata->rootdir_sect * SECTOR_SIZE,
  rootdir_size, mydata->data_begin);
    FAT_DPRINT ("Cluster size: %d\n", mydata->clust_size);
    /* "cwd" is always the root... */
    while (ISDIRDELIM (*filename))
filename++;
    /* Make a copy of the filename and convert it to lowercase */
    strcpy (fnamecopy, filename);
    downcase (fnamecopy);
    if (*fnamecopy == '\0') {
if (!dols)
     return -1;
dols = LS_ROOT;
    } else if ((idx = dirdelim (fnamecopy)) >= 0) {
isdir = 1;
fnamecopy[idx] = '\0';
subname = fnamecopy + idx + 1;
/* Handle multiple delimiters */
while (ISDIRDELIM (*subname))
     subname++;
    } else if (dols) {
isdir = 1;
    while (1) {
int i;
if (disk_read (cursect, mydata->clust_size, do_fat_read_block) < 0) {
     FAT_DPRINT ("Error: reading rootdir block\n");
     return -1;
dentptr = (dir_entry *) do_fat_read_block;
for (i = 0; i < DIRENTSPERBLOCK; i++) {
     l_name[0] = '\0';
      prevcksum = ((dir_slot *) dentptr)->alias_checksum;
      get_vfatname (mydata, 0, do_fat_read_block, dentptr, l_name);
      if (dols == LS_ROOT) {
   char dirc;
   int doit = 0;
   if (isdir) {
       dirs++;
       dirc = '/';
       doit = 1;
   } else {
       dirc = ' ';
    files++;
    doit = 1;
   if (doit) {
       if (dirc == ' ') {
     l_name, dirc);
       } else {
   dentptr++;
   continue;
      FAT_DPRINT ("Rootvfatname: |%s|\n", l_name);
  } else
#endif
      dentptr++;
      continue;
     } else if (dentptr->name[0] == 0) {
  FAT_DPRINT ("RootDentname == NULL - %d\n", i);
      return 0;
  return -1;
     else if (dols == LS_ROOT
  dentptr++;
  continue;
#endif
  char dirc;
  int doit = 0;
  if (isdir) {
      dirc = '/';
   dirs++;
   doit = 1;
  } else {
      dirc = ' ';
   files++;
   doit = 1;
  if (doit) {
      if (dirc == ' ') {
    dirc);
      } else {
  dentptr++;
  continue;
     if (strcmp (fnamecopy, s_name) && strcmp (fnamecopy, l_name)) {
  FAT_DPRINT ("RootMismatch: |%s|%s|\n", s_name, l_name);
  dentptr++;
  continue;
     if (isdir && !(dentptr->attr & ATTR_DIR))
  return -1;
     FAT_DPRINT ("RootName: %s", s_name);
   FAT2CPU32 (dentptr->size), isdir ? "(DIR)" : "");
     goto rootdir_done;  /* We got a match */
cursect++;
  rootdir_done:
    firsttime = 1;
    while (isdir) {
int startsect = mydata->data_begin
  + START (dentptr) * mydata->clust_size;
dir_entry dent;
char *nextname = NULL;
dent = *dentptr;
dentptr = &dent;
idx = dirdelim (subname);
if (idx >= 0) {
     subname[idx] = '\0';
     nextname = subname + idx + 1;
     while (ISDIRDELIM (*nextname))
  nextname++;
     if (dols && *nextname == '\0')
  firsttime = 0;
} else {
     if (dols && firsttime) {
  firsttime = 0;
     } else {
  isdir = 0;
if (get_dentfromdir (mydata, startsect, subname, dentptr,
        isdir ? 0 : dols) == NULL) {
     if (dols && !isdir)
  return 0;
     return -1;
if (idx >= 0) {
     if (!(dentptr->attr & ATTR_DIR))
  return -1;
     subname = nextname;
    ret = get_contents (mydata, dentptr, buffer, maxsize);
    FAT_DPRINT ("Size: %d, got: %ld\n", FAT2CPU32 (dentptr->size), ret);
    return ret;
int
file_fat_detectfs(void)
boot_sector bs;
int  fatsize;
char vol_label[12];
if(cur_dev==NULL) {
  printf("No current device\n");
  return 1;
#if defined(CONFIG_CMD_IDE) || \
    defined(CONFIG_MMC)
printf("Interface:  ");
switch(cur_dev->if_type) {
  case IF_TYPE_IDE : printf("IDE"); break;
  case IF_TYPE_SCSI : printf("SCSI"); break;
  case IF_TYPE_ATAPI : printf("ATAPI"); break;
  case IF_TYPE_USB : printf("USB"); break;
  case IF_TYPE_DOC : printf("DOC"); break;
  case IF_TYPE_MMC : printf("MMC"); break;
  default :  printf("Unknown");
printf("\n  Device %d: ",cur_dev->dev);
dev_print(cur_dev);
#endif
if(read_bootsectandvi(&bs, &volinfo, &fatsize)) {
  printf("\nNo valid FAT fs found\n");
  return 1;
memcpy (vol_label, volinfo.volume_label, 11);
vol_label[11] = '\0';
volinfo.fs_type[5]='\0';
printf(&quotartition %d: Filesystem: %s \"%s\"\n"
   ,cur_part,volinfo.fs_type,vol_label);
return 0;
int
file_fat_ls(const char *dir)
return do_fat_read(dir, NULL, 0, LS_YES);
long
file_fat_read(const char *filename, void *buffer, unsigned long maxsize)
printf("reading %s\n",filename);
return do_fat_read(filename, buffer, maxsize, LS_NO);
#endif
    发表于 2014-3-26 23:09:22 | 显示全部楼层
    昨天 14:55
  • 签到天数: 140 天
    4万
    终身成就奖特殊贡献奖社区居民忠实会员社区劳模最爱沙发社区明星优秀斑竹奖宣传大使奖
    发表于 2014-3-27 06:56:46 | 显示全部楼层
  • 签到天数: 103 天
    7万
    发表于 2014-3-27 08:32:33 | 显示全部楼层
    12 小时前
  • 签到天数: 146 天
    终身成就奖特殊贡献奖社区居民忠实会员
    发表于 2014-3-27 08:43:46 | 显示全部楼层
