查看: 8382|回复: 36
[PADS2007以下] STI7710机顶盒PCB layout
  • 签到天数: 26 天
    QQ2644020224
    发表于 2014-5-22 16:20:44 | 显示全部楼层 |阅读模式
    重要提示:PCB作品文件展下载说明
    STI7710  机顶盒PCB layout
    , 主芯片 ST公
    司的STI7710   MPEG2 高清机顶盒方案.
    sti7710 PCB
    sti7710 PCB
    STI7710-0362_PCB.zip (1.07 MB, 下载次数: 32)
    ****************以下信息由管理员 @老吴   整理补充*******************
    板子有以下元件和封装库,如有需要可以下载提取使用。
    NameValuePCB DecalPart Type
    C110nFC0402MINICAP-SMD
    C210nFC0402MINICAP-SMD
    C3100nFC0402MINICAP-SMD
    C410nFC0402MINICAP-SMD
    C510nFC0603MINICAP-SMD
    C610nFC0402MINICAP-SMD
    C7100nFC0402MINICAP-SMD
    C810nFC0402MINICAP-SMD
    C910nFC0402MINICAP-SMD
    C1310nFC0402MINICAP-SMD
    C1410nFC0402MINICAP-SMD
    C1510nFC0402MINICAP-SMD
    CA13n3C0603MINICAP-SMD
    CA2(DNI)100nFC0603MINICAP-SMD
    CA33n3C0603MINICAP-SMD
    CA43n3C0603MINICAP-SMD
    CA53n3C0603MINICAP-SMD
    CA6100nFC0603MINICAP-SMD
    CA7100nFC0603MINICAP-SMD
    CA839pFC0603MINICAP-SMD
    CA9100nFC0603MINICAP-SMD
    CA1039pFC0603MINICAP-SMD
    CAX1100nFC0603MINICAP-SMD
    CAX210nFC0603MINICAP-SMD
    CAX339pFC0603MINICAP-SMD
    CC1100nFC0603MINICAP-SMD
    CC2100nFC0603MINICAP-SMD
    CC3100nFC0603MINICAP-SMD
    CF1100nFC0603MINICAP-SMD
    CH1100nFC0603MINICAP-SMD
    CH2100nFC0603MINICAP-SMD
    CH3100nFC0603MINICAP-SMD
    CH4100nFC0603MINICAP-SMD
    CH5100nFC0603MINICAP-SMD
    CH6100nFC0603MINICAP-SMD
    CM1100nFC0603MINICAP-SMD
    CM2100nFC0603MINICAP-SMD
    CM310nFC0603MINICAP-SMD
    CM4100nFC0603MINICAP-SMD
    CM510nFC0603MINICAP-SMD
    CM610nFC0603MINICAP-SMD
    CM710nFC0603MINICAP-SMD
    CM810nFC0603MINICAP-SMD
    CM910nFC0603MINICAP-SMD
    CM1010nFC0603MINICAP-SMD
    CM1110nFC0603MINICAP-SMD
    CM1210nFC0603MINICAP-SMD
    CM1310nFC0603MINICAP-SMD
    CM1410nFC0603MINICAP-SMD
    CM1510nFC0603MINICAP-SMD
    CM1610nFC0603MINICAP-SMD
    CM1710nFC0603MINICAP-SMD
    CM1810nFC0603MINICAP-SMD
    CM1910nFC0603MINICAP-SMD
    CM2010nFC0603MINICAP-SMD
    CM21100nFC0603MINICAP-SMD
    CM22100nFC0603MINICAP-SMD
    CM2310nFC0603MINICAP-SMD
    CM24100nFC0603MINICAP-SMD
    CON1JACK-DCDC-JACKJACK-DC
    CON25PIN/2.54mmCON-5PINX2.54MMCON-5PINX2MM
    CON3USB-BUSB_V
    CON4RCAx6RCAX6ARCAX6A
    CON5HDMI MINIHDMI_CONHDMI_MINI
    CON6DASW-02MINIDIN_RCAX2MINIDIN_RCAX2
    CON7(OOP)TOT179LOPTICOPTIC_TRANSMITER_2
    CON8CON4_2.00CON4_2.00
    CON95x2 PIN/2.54mmSIP/5X2C-PH/5X2/2.54
    CON1016PIN2.02_8PIN2.0MM
    CP1100nFC0603MINICAP-SMD
    CP2100nFC0603MINICAP-SMD
    CP3104C0603MINICAP-SMD
    CQ1100nCC0603/SSCAP-SMD
    CQ2100nCC0603/SSCAP-SMD
    CQ3100nCC0603/SSCAP-SMD
    CQ4100nCC0603/SSCAP-SMD
    CQ5100nCC0603/SSCAP-SMD
    CQ6100nCC0603/SSCAP-SMD
    CQ7100nCC0603/SSCAP-SMD
    CR110nFC0402MINICAP-SMD
    CR2100nFC0603MINICAP-SMD
    CR310pF/COGC0603MINICAP-SMD
    CS110nFC0402MINICAP-SMD
    CS22.2uFC0603MINICAP-SMD
    CS310nFC0402MINICAP-SMD
    CS410nFC0402MINICAP-SMD
    CS510nFC0402MINICAP-SMD
    CS610nFC0402MINICAP-SMD
    CS710nFC0402MINICAP-SMD
    CS9100nFC0402MINICAP-SMD
    CS1010nFC0402MINICAP-SMD
    CS1110nFC0402MINICAP-SMD
    CS1210nFC0402MINICAP-SMD
    CS1310nFC0402MINICAP-SMD
    CS14100nFC0603MINICAP-SMD
    CS1510nFC0603MINICAP-SMD
    CS1610nFC0402MINICAP-SMD
    CS1710nFC0603MINICAP-SMD
    CS1810nFC0603MINICAP-SMD
    CS1910nFC0402MINICAP-SMD
    CS202.2uFC0603MINICAP-SMD
    CS21100nFC0402MINICAP-SMD
    CS22100nFC0603MINICAP-SMD
    CS2310nFC0402MINICAP-SMD
    CS2410nFC0603MINICAP-SMD
    CS2510nFC0603MINICAP-SMD
    CS26100nFC0603MINICAP-SMD
    CS2710nFC0402MINICAP-SMD
    CS2810nFC0402MINICAP-SMD
    CS2910nFC0402MINICAP-SMD
    CS3010nFC0402MINICAP-SMD
    CS3110nFC0402MINICAP-SMD
    CS3710nFC0402MINICAP-SMD
    CS3810nFC0603MINICAP-SMD
    CS3922pF/COGC0603MINICAP-SMD
    CS4010nFC0402MINICAP-SMD
    CS4110nFC0603MINICAP-SMD
    CS4210nFC0402MINICAP-SMD
    CS4310nFC0402MINICAP-SMD
    CS4410nFC0603MINICAP-SMD
    CS45100nFC0402MINICAP-SMD
    CS46100nFC0603MINICAP-SMD
    CS4710nFC0402MINICAP-SMD
    CS4810nFC0402MINICAP-SMD
    CS4910nFC0402MINICAP-SMD
    CS5010nFC0402MINICAP-SMD
    CS5110nFC0402MINICAP-SMD
    CS5210nFC0402MINICAP-SMD
    CS53150pFC0603MINICAP-SMD
    CS54150pFC0603MINICAP-SMD
    CS55150pFC0603MINICAP-SMD
    CS56150pFC0603MINICAP-SMD
    CS5710nFC0402MINICAP-SMD
    CS58100nFC0603MINICAP-SMD
    CS5910nFC0603MINICAP-SMD
    CS6010nFC0402MINICAP-SMD
    CS6110nFC0402MINICAP-SMD
    CS6210nFC0402MINICAP-SMD
    CS6310nFC0402MINICAP-SMD
    CS6410nFC0402MINICAP-SMD
    CS65100nFC0603MINICAP-SMD
    CS6610nFC0402MINICAP-SMD
    CS6710nFC0402MINICAP-SMD
    CS6810nFC0603MINICAP-SMD
    CS69100nFC0603MINICAP-SMD
    CS70100nFC0603MINICAP-SMD
    CS7110nFC0603MINICAP-SMD
    CS7210nFC0402MINICAP-SMD
    CS7310nFC0402MINICAP-SMD
    CS7410nFC0402MINICAP-SMD
    CS7510nFC0402MINICAP-SMD
    CS7610nFC0402MINICAP-SMD
    CS7710nFC0402MINICAP-SMD
    CS7810nFC0402MINICAP-SMD
    CS7910nFC0603MINICAP-SMD
    CS8010nFC0402MINICAP-SMD
    CS8210nFC0402MINICAP-SMD
    CS83100nFC0402MINICAP-SMD
    CS8410nFC0402MINICAP-SMD
    CS8510nFC0603MINICAP-SMD
    CS8610nFC0402MINICAP-SMD
    CS87100nFC0603MINICAP-SMD
    CS8810nFC0402MINICAP-SMD
    CS892.2uFC0603MINICAP-SMD
    CS9010nFC0402MINICAP-SMD
    CS9110nFC0603MINICAP-SMD
    CS9210nFC0402MINICAP-SMD
    CS9310nFC0402MINICAP-SMD
    CS9410nFC0402MINICAP-SMD
    CS95100nFC0603MINICAP-SMD
    CS9610nFC0402MINICAP-SMD
    CS9710nFC0402MINICAP-SMD
    CS9810nFC0402MINICAP-SMD
    CS9910nFC0402MINICAP-SMD
    CT1100nCC0603/SSCAP-SMD
    CT11(DNI)100nFC0603MINICAP-SMD
    CT21100nFC0603MINICAP-SMD
    CT31100nCC0603/SSCAP-SMD
    CT32100nCC0603/SSCAP-SMD
    CT33100nCC0603/SSCAP-SMD
    CT34100nCC0603/SSCAP-SMD
    CT35100nCC0603/SSCAP-SMD
    CT36100nCC0603/SSCAP-SMD
    CT37100nCC0603/SSCAP-SMD
    CT38100nCC0603/SSCAP-SMD
    CT3910uF/6.3VC0805CAP-SMD0805
    CT40100nCC0603/SSCAP-SMD
    CT4110uF/6.3VC0805CAP-SMD0805
    CT42100nCC0603/SSCAP-SMD
    CT43100nCC0603/SSCAP-SMD
    CT44100nCC0603/SSCAP-SMD
    CT45100nCC0603/SSCAP-SMD
    CT46100nCC0603/SSCAP-SMD
    CT47100nCC0603/SSCAP-SMD
    CT48100nCC0603/SSCAP-SMD
    CT49100nCC0603/SSCAP-SMD
    CT50100nCC0603/SSCAP-SMD
    CT51100nCC0603/SSCAP-SMD
    CV156pFC0603MINICAP-SMD
    CV256pFC0603MINICAP-SMD
    CV356pFC0603MINICAP-SMD
    CV4100nFC0603MINICAP-SMD
    CV5100nFC0603MINICAP-SMD
    CV647pFC0603MINICAP-SMD
    CV7(DNI)47pC0603MINICAP-SMD
    CV847pFC0603MINICAP-SMD
    CV947pFC0603MINICAP-SMD
    CV1047pFC0603MINICAP-SMD
    CV11(DNI)47pC0603MINICAP-SMD
    CV12(DNI)47pFC0603MINICAP-SMD
    CV1347pFC0603MINICAP-SMD
    CV1447pFC0603MINICAP-SMD
    CV1539pFC0603MINICAP-SMD
    CV1639pFC0603MINICAP-SMD
    CV1739pFC0603MINICAP-SMD
    CV1839pFC0603MINICAP-SMD
    CV1939pFC0603MINICAP-SMD
    CV2039pFC0603MINICAP-SMD
    CX1100nFC0603MINICAP-SMD
    CX2470pFC0603MINICAP-SMD
    CX3100nFC0603MINICAP-SMD
    CX43.3nFC0603MINICAP-SMD
    CX53.3nFC0603MINICAP-SMD
    CX6100nFC0603MINICAP-SMD
    CX7104C0603MINICAP-C
    CX8NCC0603MINICAP-SMD
    CX9NCC0603MINICAP-SMD
    CX10100nFC0603MINICAP-SMD
    CX11100nFC0603MINICAP-SMD
    CX12100nFC0603MINICAP-SMD
    CX13100nFC0603MINICAP-SMD
    CX141.5nFC0603MINICAP-SMD
    CX15100nFC0603MINICAP-SMD
    CX16100nFC0603MINICAP-SMD
    CX17100nFC0603MINICAP-SMD
    CX181u/10VC0805MILL-INDMLD
    CX19100nFC0603MINICAP-SMD
    CX201u/10VC0805MILL-INDMLD
    CX21100nFC0603MINICAP-SMD
    CX221u/10VC0805MILL-INDMLD
    CX23100nFC0603MINICAP-SMD
    CX241u/10VC0805MILL-INDMLD
    CX25100nFC0603MINICAP-SMD
    CX26100nFC0603MINICAP-SMD
    CX281u/10VC0805MILL-INDMLD
    CX29100nFC0603MINICAP-SMD
    CX30100nFC0603MINICAP-SMD
    CX311u/10VC0805MILL-INDMLD
    CX321u/10VC0805MILL-INDMLD
    CX33100nFC0603MINICAP-SMD
    CX34100nFC0603MINICAP-SMD
    CX351u/10VC0805MILL-INDMLD
    CX361u/10VC0805MILL-INDMLD
    CX37100nFC0603MINICAP-SMD
    CX38100nFC0603MINICAP-SMD
    DA1(DNI) 5.6V/0.5WZENER-SMT-MLL34ZPD10
    DX11N5819DIODE-SMT-SMAZPD10
    DX21N5819DIODE-SMT-SMAZPD10
    DX31N5819DIODE-SMT-SMAZPD10
    DX41N5819DIODE-SMT-SMAZPD10
    EA1100uF/25VCAPE-D5XP2CAPE-D4XP2
    EA2100uF/25VCAPE-D5XP2CAPE-D4XP2
    EA3(DNI)100uF/25VCAPE-D5XP2CAPE-D4XP2
    EA410uF/25VCAPE-D5XP2CAPE-D4XP2
    EA510uF/25VCAPE-D5XP2CAPE-D4XP2
    EAX1100uF/10VC0805MILL-INDMLD
    EC1100uF/10VCAPE-D5XP2CAPE-D4XP2
    EC2100uF/6.3VCAPE/2.5/6.3CAPE/2.5/6.3
    ECT1CAPE/2/5CAPE/10/16
    EH1100uF/10VC0603MINICAP-SMD
    EH2100uF/10VC0805MILL-INDMLD
    EM1100uF/6.3VCAPE/2.5/6.3CAPE/2.5/6.3
    EM2100uF/6.3VC0805MILL-INDMLD
    ES1100uF/10VC0805MILL-INDMLD
    ES2100uF/10VC0603MINICAP-SMD
    ES3100uF/10VC0603MINICAP-SMD
    ES4100uF/6.3VC0603MINICAP-SMD
    ES5100uF/10VC0603MINICAP-SMD
    ES610uF/25VC0603MINICAP-SMD
    ES7100uF/6.3VC0805MILL-INDMLD
    ES8100uF/10VCAPE/2.5/6.3CAPE/2.5/6.3
    ES9220uF/10VC0805MILL-INDMLD
    ET7220uF/6.3VCAPE-D6X100CAPE-D6X100
    EV1100uF/10VC0805MILL-INDMLD
    EX1100uF/25VCAPE-D5XP2CAPE-D4XP2
    EX210u/10V/L_ESRC0805MILL-INDMLD
    EX31000uF/25V/L_ESRCAPE-D8.2XP3.6CAPE-D8.2XP3.6
    EX422u/10V/L_ESRC0805MILL-INDMLD
    EX51000uF/25V/L_ESRCAPE-D8.2XP3.6CAPE-D8.2XP3.6
    EX610u/10V/L_ESRCAPE-D5XP2CAPE-D4XP2
    EX722u/10V/L_ESRC0805MILL-INDMLD
    EX810uF/25V/L_ESRCAPE/2.5/6.3CAPE/2.5/6.3
    EX922u/10V/L_ESRC0805MILL-INDMLD
    EX1010uF/10V/L_ESRC0805MILL-INDMLD
    EX1122u/10V/L_ESRCAPE/2.5/6.3CAPE/2.5/6.3
    EX121000uF/25V/L_ESRCAPE-D8.2XP3.6CAPE-D8.2XP3.6
    EX13100uF/10VC0805MILL-INDMLD
    EX1410u/10V/L_ESRC0805MILL-INDMLD
    FB130ohm@100MHzL0603MINIR-1/4W
    FB430ohm@100MHzPL0603MINIR-1/4W
    FB530ohm@100MHzPL0603MINIR-1/4W
    FB630ohm@100MHzPL0603MINIR-1/4W
    FB730ohm@100MHzPL0603MINIR-1/4W
    FB830ohm@100MHzPL0603MINIR-1/4W
    FB930ohm@100MHzPL0603MINIR-1/4W
    FB1030ohm@100MHzPL0603MINIR-1/4W
    FB1130ohm@100MHzPL0603MINIR-1/4W
    FB1230ohm@100MHzPL0603MINIR-1/4W
    FB1330ohm@100MHzPL0603MINIR-1/4W
    FB1430ohm@100MHzPL0603MINIR-1/4W
    FB1530ohm@100MHzPL0603MINIR-1/4W
    FB1630ohm@100MHzPL0603MINIR-1/4W
    FB17BLM11B601SL0603MINIR-1/4W
    FB21BLM11B601SL0603MINIR-1/4W
    FB22220nHL0603MINIR-1/4W
    FB23BLM11B601SL0603MINIR-1/4W
    FB24BLM11B601SL0603MINIR-1/4W
    FB2530ohm@100MHzPL0603MINIR-1/4W
    FB26FB2FB2
    FB27FB2FB2
    FB28BLM11B601SL0603MINIR-1/4W
    FB29BLM11B601SL0603MINIR-1/4W
    FBA1BLM11B601SL0603MINIR-1/4W
    FBA2BLM11B601SL0603MINIR-1/4W
    FBA3BLM11B601SL0603MINIR-1/4W
    FBA4BLM11B601SL0603MINIR-1/4W
    FBA5BLM11B601SL0603MINIR-1/4W
    FBA6BLM11B601SL0603MINIR-1/4W
    FBC160ohm@100MHzL0603MINIR-1/4W
    FBH160ohm@100MHzL0603MINIR-1/4W
    FBH2(DNI) 60ohm@100MHzL0603MINIR-1/4W
    FBM160ohm@100MHzPL0603MINIR-1/4W
    FBP160ohm@100MHzPL0603MINIR-1/4W
    FBV1BLM11B601SL0603MINIR-1/4W
    FBV2BLM11B601SL0603MINIR-1/4W
    FBX160ohm@100MHz/0805L0805MILL-INDMLD
    FBX260ohm@100MHzPL0603MINIR-1/4W
    FBX3BLM11B601SL0603MINIR-1/4W
    FBX460ohm@100MHzPL0603MINIR-1/4W
    FBX5BLM11B601SL0603MINIR-1/4W
    FBX660ohm@100MHzPL0603MINIR-1/4W
    H23.5mm/8mmMRING8-3.5MHOLE8A
    H43.5mm/8mmMRING8-3.5MHOLE8A
    H53.5mm/8mmMRING8-3.5MHOLE8A
    LA110uHL0603MINIR-1/4W
    LB1BLM11B601S603L-IND
    LB2BLM11B601S603L-IND
    LT30.47uH/200mAL0805MILL-INDMLD
    LV1220nHL0805MILL-INDMLD
    LV2220nHL0805MILL-INDMLD
    LV3220nHL0805MILL-INDMLD
    LV4220nHL0805MILL-INDMLD
    LV5220nHL0805MILL-INDMLD
    LV6220nHL0805MILL-INDMLD
    LV710uHL0603MINIR-1/4W
    LV810uHL0603MINIR-1/4W
    LV910uHL0603MINIR-1/4W
    LV1010uHL0603MINIR-1/4W
    LX13.3UHDRH73BL_DRH73
    LX23.3uHDRH73BL_DRH73
    LX310uHDRH73BL_DRH73
    LX4220uHDRH73BL_DRH73
    LX590uHDRH73BL_DRH73
    LX63.3UHDRH73BL_DRH73
    QAX1MMBT39042N39042SC1815
    QH1MMBT39042N39042SC1815
    QH2MMBT39042N39042SC1815
    QN12N2907SOT-23Q-2N3906
    QP1MMBT39042N39042SC1815
    QP3BC8072N39042SC1815
    QP4MMBT39042N39042SC1815
    QP585502N39042SC1815
    QQ12N2222SOT-23Q-2N3904
    QS1ST809R2N39042SC1815
    R12K4R0603MINIR-1/4W
    R2490R/1%R0603MINIR-1/4W
    R30RR0603MINIR-1/4W
    RA1490R/1%R0603MINIR-1/4W
    RA3(DNI) 100R0603MINIR-1/4W
    RA4100KR0603MINIR-1/4W
    RA5490R/1%R0603MINIR-1/4W
    RA6100KR0603MINIR-1/4W
    RA8490R/1%R0603MINIR-1/4W
    RA924RR0603MINIR-1/4W
    RA10560RR0603MINIR-1/4W
    RA1124RR0603MINIR-1/4W
    RA1224RR0603MINIR-1/4W
    RA1324RR0603MINIR-1/4W
    RA14(DNI) 0R0603MINIR-1/4W
    RA15560RR0603MINIR-1/4W
    RA16560RR0603MINIR-1/4W
    RA18560RR0603MINIR-1/4W
    RA20560RR0603MINIR-1/4W
    RA21560RR0603MINIR-1/4W
    RA22560RR0603MINIR-1/4W
    RA23560RR0603MINIR-1/4W
    RA24560RR0603MINIR-1/4W
    RA31560RR0603MINIR-1/4W
    RAX1100RR0603MINIR-1/4W
    RAX2220RR0603MINIR-1/4W
    RC1100RR0603MINIR
    RC2100RR0603MINIR
    RC35.6KR0603MINIR
    RC4100RR0603MINIR
    RC5100RR0603MINIR
    RC6100RR0603MINIR
    RC7100R0603MINIR
    RC8100R0603MINIR
    RC947RR0603MINIR
    RC10100RR0603MINIR
    RC11100RR0603MINIR
    RC12100RR0603MINIR
    RC13100RR0603MINIR
    RF147RR0603MINIR-1/4W
    RF247RR0603MINIR-1/4W
    RH1100RR0603MINIR-1/4W
    RH20RR0603MINIR-1/4W
    RH3100RR0603MINIR-1/4W
    RH4100RR0603MINIR-1/4W
    RH5(DNI)0R0603MINIR-1/4W
    RH6(DNI)0R0603MINIR-1/4W
    RH7(DNI)0R0603MINIR-1/4W
    RH8(DNI)0R0603MINIR-1/4W
    RH910KR0603MINIR-1/4W
    RH104K7R0603MINIR-1/4W
    RH114K7R0603MINIR-1/4W
    RH1210KR0603MINIR-1/4W
    RH134K7R0603MINIR-1/4W
    RM110KR0603MINIR-1/4W
    RM24K7R0603MINIR-1/4W
    RM3220RR0603MINIR-1/4W
    RM4220RR0603MINIR-1/4W
    RM51k/1%R0603MINIR-1/4W
    RM61k/1%R0603MINIR-1/4W
    RM710KR0603MINIR-1/4W
    RMP122R0402ARRAYRES_SERIAL_0402
    RMP222R0402ARRAYRES_SERIAL_0402
    RMP322R0402ARRAYRES_SERIAL_0402
    RMP422R0402ARRAYRES_SERIAL_0402
    RMP522R0402ARRAYRES_SERIAL_0402
    RMP622R0402ARRAYRES_SERIAL_0402
    RMP722R0402ARRAYRES_SERIAL_0402
    RMP822R0402ARRAYRES_SERIAL_0402
    RMP922R0402ARRAYRES_SERIAL_0402
    RMP1022R0402ARRAYRES_SERIAL_0402
    RMP1122R0402ARRAYRES_SERIAL_0402
    RMP1222R0402ARRAYRES_SERIAL_0402
    RMP1322R0402ARRAYRES_SERIAL_0402
    RMP1422R0402ARRAYRES_SERIAL_0402
    RMP1522R0402ARRAYRES_SERIAL_0402
    RMP1622R0402ARRAYRES_SERIAL_0402
    RN110K0603JUMPERR-1/4W-0805
    RN210K0603JUMPERR-1/4W-0805
    RN3100K0603JUMPERR-1/4W-0805
    RN40R0603JUMPERR-1/4W-0805
    RN50R0603JUMPERR-1/4W-0805
    RN60R0603JUMPER_NR-1/4W-0805
    RN70R0603JUMPER_NR-1/4W-0805
    RN80R0603JUMPER_NR-1/4W-0805
    RN90R0603JUMPER_NR-1/4W-0805
    RP1???R1/4WRES-1/4W
    RP2100KR0603MINIR-1/4W
    RP3100KR0603MINIR-1/4W
    RP4100KR0603MINIR-1/4W
    RP5100KR0603MINIR-1/4W
    RP6100KR0603MINIR-1/4W
    RP7100KR0603MINIR-1/4W
    RP8100KR0603MINIR-1/4W
    RP9100KR0603MINIR-1/4W
    RP12100KR0603MINIR-1/4W
    RP13100KR0603MINIR-1/4W
    RP14100KR0603MINIR-1/4W
    RP15100KR0603MINIR-1/4W
    RQ11k603R-1/4W
    RQ21k603R-1/4W
    RQ31k603R-1/4W
    RQ41k603R-1/4W
    RQ51k603R-1/4W
    RQ61k603R-1/4W
    RQ71k603R-1/4W
    RQ81k603R-1/4W
    RQ91k603R-1/4W
    RQ101k603R-1/4W
    RQ111k603R-1/4W
    RQ121k603R-1/4W
    RQ131k603R-1/4W
    RQ141k603R-1/4W
    RQ151k603R-1/4W
    RQ161k603R-1/4W
    RQ171k603R-1/4W
    RS1BLM11B601SR0603MINIR-1/4W
    RS2100RR0603MINIR-1/4W
    RS310K/1%R0603MINIR-1/4W
    RS4100RR0603MINIR-1/4W
    RS568RR0603MINIR-1/4W
    RS6100RR0603MINIR-1/4W
    RS310R0603MINIR-1/4W
    RS3210KR0603MINIR-1/4W
    RS3310KR0603MINIR-1/4W
    RS3475RR0603MINIR-1/4W
    RS3575RR0603MINIR-1/4W
    RS4510KR0603MINIR-1/4W
    RS4610KR0603MINIR-1/4W
    RS5010KR0603MINIR-1/4W
    RS61215R/1%R0603MINIR-1/4W
    RS6212K/1%R0603MINIR-1/4W
    RS6351R/1%R0603MINIR-1/4W
    RS6410KR0603MINIR-1/4W
    RS6510KR0603MINIR-1/4W
    RS6610KR0603MINIR-1/4W
    RS67100RR0603MINIR-1/4W
    RS682K7R0603MINIR-1/4W
    RS692K7R0603MINIR-1/4W
    RS702K7R0603MINIR-1/4W
    RS712K7R0603MINIR-1/4W
    RS72100RR0603MINIR-1/4W
    RS74100RR0603MINIR-1/4W
    RS76100RR0603MINIR-1/4W
    RS77100RR0603MINIR-1/4W
    RS81100RR0603MINIR-1/4W
    RS82100RR0603MINIR-1/4W
    RS83100RR0603MINIR-1/4W
    RS8510KR0603MINIR-1/4W
    RS8610KR0603MINIR-1/4W
    RS87BLM11B601SR0603MINIR-1/4W
    RS92BLM11B601SR0603MINIR-1/4W
    RS93BLM11B601SR0603MINIR-1/4W
    RS9468RR0603MINIR-1/4W
    RS9510KR0603MINIR-1/4W
    RS9610KR0603MINIR-1/4W
    RS9710KR0603MINIR-1/4W
    RS9810KR0603MINIR-1/4W
    RS9910KR0603MINIR-1/4W
    RS102BLM11B601SR0603MINIR-1/4W
    RS103BLM11B601SR0603MINIR-1/4W
    RS104100RR0603MINIR-1/4W
    RS105BLM11B601SR0603MINIR-1/4W
    RS106100RR0603MINIR-1/4W
    RS10710KR0603MINIR-1/4W
    RS1080RR0603MINIR-1/4W
    RS11068RR0603MINIR-1/4W
    RT11k603R-1/4W
    RTQ133RN8-ARN8
    RTQ233RN8-ARN8
    RTQ333RN8-ARN8
    RV175RR0603MINIR-1/4W
    RV2470RR0603MINIR-1/4W
    RV30RR0603MINIR-1/4W
    RV4330RR0603MINIR-1/4W
    RV5330RR0603MINIR-1/4W
    RV6330RR0603MINIR-1/4W
    RV7330RR0603MINIR-1/4W
    RV8330RR0603MINIR-1/4W
    RV9330RR0603MINIR-1/4W
    RV10470RR0603MINIR-1/4W
    RV11470RR0603MINIR-1/4W
    RV12470RR0603MINIR-1/4W
    RV1475RR0603MINIR-1/4W
    RV1575RR0603MINIR-1/4W
    RV1675RR0603MINIR-1/4W
    RV18470RR0603MINIR-1/4W
    RV19470RR0603MINIR-1/4W
    RV2175RR0603MINIR-1/4W
    RV2375RR0603MINIR-1/4W
    RX11.1KR0603MINIR-1/4W
    RX216KR0603MINIR-1/4W
    RX31K8R0603MINIR-1/4W
    RX41RR0603MINIR-1/4W
    RX5DNIR0603MINIR-1/4W
    RX6100KR0603MINIR-1/4W
    RX70.5RR0603MINIR-1/4W
    RX80.5RR0603MINIR-1/4W
    RX91K8R0603MINIR-1/4W
    RX102K2R0603MINIR-1/4W
    RX112.458K1%R0603MINIR-1/4W
    RX12100KR0603MINIR-1/4W
    RX13100KR0603MINIR-1/4W
    RX141.1KR0603MINIR-1/4W
    RX15100KR0603MINIR-1/4W
    RX16100KR0603MINIR-1/4W
    RX17100KR0603MINIR-1/4W
    RX18100KR0603MINIR-1/4W
    RX191.1KR0603MINIR-1/4W
    RX2010K1%R0603MINIR-1/4W
    RX2110K1%R0603MINIR-1/4W
    RX2210K1%R0603MINIR-1/4W
    RX2310K1%R0603MINIR-1/4W
    RX2410K1%R0603MINIR-1/4W
    RX2510K1%R0603MINIR-1/4W
    RX2610K1%R0603MINIR-1/4W
    RX27100KR0603MINIR-1/4W
    RX28100KR0603MINIR-1/4W
    RX29100KR0603MINIR-1/4W
    RX301RR0603MINIR-1/4W
    RX31100KR0603MINIR-1/4W
    RX3210KR0603MINIR-1/4W
    RX33100KR0603MINIR-1/4W
    RX34100KR0603MINIR-1/4W
    RX35100KR0603MINIR-1/4W
    RX36100KR0603MINIR-1/4W
    RX37100KR0603MINIR-1/4W
    RX38100KR0603MINIR-1/4W
    TP1SB_PTSTP-SB_S
    TP2SB_PTSTP-SB_S
    TP3SB_PTSTP-SB_S
    TP42mmFMARKFMARK
    TP52mmFMARKFMARK
    TP62mmFMARKFMARK
    TP72mmFMARKFMARK
    TP122mmFMARKFMARK
    TP132mmFMARKFMARK
    TP14TESTPOINT1.5MMTP-SB
    TP15TESTPOINT1.5MMTP-SB
    TP16TESTPOINT1.5MMTP-SB
    TP17TESTPOINT1MMTP-SB
    TP18TESTPOINT1MMTP-SB
    U1DTT75408NDTT75408N
    U2STV0360STV0362STV0362
    U14PAD_SQPASD_SQ
    UA1LM833/LM4558DSO8LM833
    UC1TSSOP14P89LPC915
    UC2DIP14P89LPC915_DIP
    UD1STi7710STI7710BGA456STI7710
    UH1CMD2020TSSOP38HDMI_ESD
    UM164MBit Flash Top BootM29WM29W
    UM224C64SO8NB24C64
    UM3256MTSOPII66DDRSDRAM16MX16
    UM4256MTSOPII66DDRSDRAM16MX16
    UU1STMPS2151MTRSO-8SO-8
    UU2USBLC6-2SC6SOT23-6LSOT23-6L
    UV1TSH73SO14NBTSH73
    UX1MC34063ASO8MC134063A
    UX2SO8MP1482A
    UX3MP2012MP2012_QFN6
    UX4MP2012-NMP2012-N
    UX5MP2012MP2012_QFN6
    UX6LM1117MPX-5SOT23-5SG2002
    UX7LM1117MPX-5SOT23-5SG2002
    UX8MC34063ASO8MC134063A
    UX9LM1117MPX-5SOT23-5SG2002
    UX10LM1117MPX-5SOT23-5SG2002
    XS127MHzX1AXTL-XTAL
    XT227MHzX1AXTL-XTAL
    Z115V/0.5WDO35ACR-ZENER
    评分
    参与人数 1威望 +5 收起 理由
    元芳 + 5 好东西,奖励一个,支持共享
    查看全部评分
    重要提示:PCB作品文件展下载说明
    通信,物联网,机器视觉
    半小时前
  • 签到天数: 146 天
    7万
    发表于 2014-5-22 16:27:16 | 显示全部楼层
    半小时前
  • 签到天数: 146 天
    7万
    发表于 2014-5-22 16:28:01 | 显示全部楼层
  • 签到天数: 26 天
    QQ2644020224
     楼主| 发表于 2014-5-22 16:13:06 | 显示全部楼层
    STI7710  机顶盒原理图(PADS2007)
    STI7710  机顶盒原理图, 主芯片 ST公[img]file:///Cocuments and SettingsAdministratorApplication DataTencentUsers534025934QQWinTempRichOleWN2S%U4~)LR0~(6~IH1JYAK.jpg[/img]司的STI7710   MPEG2 高清机顶盒方案,
    STI7710_0362_sch.zip
    198 KB, 下载次数: 3, 下载积分: 金币 -5 枚
    通信,物联网,机器视觉
    13万
    管理员
    原创先锋奖终身成就奖优秀斑竹奖宣传大使奖社区居民社区明星社区劳模最爱沙发新人进步奖忠实会员金点子奖特殊贡献奖
    发表于 2014-5-22 16:34:06 | 显示全部楼层
    好东西,奖励一个,支持共享
    社区居民忠实会员终身成就奖最爱沙发幽默大师奖灌水天才奖优秀斑竹奖贴图大师奖新人进步奖
    发表于 2014-5-22 18:05:05 | 显示全部楼层
  • 签到天数: 49 天
    PADS-180606高级班
    终身成就奖社区居民忠实会员社区劳模最爱沙发优秀斑竹奖特殊贡献奖原创先锋奖
    发表于 2014-5-22 18:18:51 | 显示全部楼层
    Re:STI7710机顶盒PCB layout
    好东东!
    终身成就奖社区居民忠实会员社区劳模最爱沙发原创达人优秀斑竹奖
    发表于 2014-5-22 20:54:38 | 显示全部楼层
    看看...
    社区居民忠实会员社区劳模优秀斑竹奖终身成就奖最爱沙发原创达人
    发表于 2014-5-23 06:23:23 | 显示全部楼层
    终身成就奖社区居民忠实会员社区劳模宣传大使奖优秀斑竹奖灌水天才奖最爱沙发
    发表于 2014-5-23 07:37:54 | 显示全部楼层
