查看: 2244|回复: 3
MSP430+NRF2401无线温度接受部分
社区居民终身成就奖贴图大师奖金点子奖宣传大使奖灌水天才奖幽默大师奖新人进步奖
发表于 2014-7-7 22:48:52 | 显示全部楼层 |阅读模式
#include <msp430x14x.h>
#define  RF24L01_CE_0        P3OUT &=~BIT1
#define  RF24L01_CE_1        P3OUT |= BIT1
//=============================RF24L01_CSN端口==================================
#define  RF24L01_CSN_0       P3OUT &=~BIT3
#define  RF24L01_CSN_1       P3OUT |= BIT3
//=============================RF24L01_SCK======================================
#define  RF24L01_SCK_0       P3OUT &=~BIT2
#define  RF24L01_SCK_1       P3OUT |= BIT2
//=============================MISO端口=========================================
#define  RF24L01_MISO_0      P3OUT &=~BIT0
#define  RF24L01_MISO_1      P3OUT |= BIT0
//============================= RF24L01_MOSI端口================================
#define  RF24L01_MOSI_0      P2OUT &=~BIT6
#define  RF24L01_MOSI_1      P2OUT |= BIT6
//==========================IRQ状态============================================
#define  RF24L01_IRQ_0       P2OUT &=~BIT7
#define  RF24L01_IRQ_1       P2OUT |= BIT7
#define  LED1_0              P6OUT &=~BIT1          //输出0
#define  LED1_1              P6OUT |= BIT1          //输出1
#define  LED2_0              P6OUT &=~BIT2          //输出0
#define  LED2_1              P6OUT |= BIT2          //输出1
//==================================BELL========================================
#define  BELL_0     P6OUT &=~BIT3          //输出0
#define  BELL_1     P6OUT |= BIT3          //输出1
//===================================LCD========================================
#define  DataDir             P4DIR
#define  DataPort            P4OUT
#define  Busy                 0x80
#define  CtrlDir             P6DIR
#define  CLR_RS              P6OUT&=~BIT6;         //RS = P6.6
#define  SET_RS              P6OUT|=BIT6;
#define  CLR_RW              P6OUT&=~BIT5;      //RW = P6.5
#define  SET_RW              P6OUT|=BIT5;
#define  CLR_EN              P6OUT&=~BIT4;      //EN = P6.4
#define  SET_EN              P6OUT|=BIT4;
//==========================NRF24L01============================================
#define TX_ADR_WIDTH    5       // 5 uints TX address width
#define RX_ADR_WIDTH    5       // 5 uints RX address width
#define TX_PLOAD_WIDTH  32      // 32 TX payload
#define RX_PLOAD_WIDTH  32      // 32 uints TX payload
//=========================NRF24L01寄存器指令===================================
#define READ_REG        0x00      // 读寄存器指令
#define WRITE_REG       0x20     // 写寄存器指令
#define RD_RX_PLOAD     0x61      // 读取接收数据指令
#define WR_TX_PLOAD     0xA0      // 写待发数据指令
#define FLUSH_TX        0xE1     // 冲洗发送 FIFO指令
#define FLUSH_RX        0xE2      // 冲洗接收 FIFO指令
#define REUSE_TX_PL     0xE3      // 定义重复装载数据指令
#define NOP1            0xFF      // 保留
//========================SPI(nRF24L01)寄存器地址===============================
#define CONFIG          0x00  // 配置收发状态,CRC校验模式以及收发状态响应方式
#define EN_AA           0x01  // 自动应答功能设置
#define EN_RXADDR       0x02  // 可用信道设置
#define SETUP_AW        0x03  // 收发地址宽度设置
#define SETUP_RETR      0x04  // 自动重发功能设置
#define RF_CH           0x05  // 工作频率设置
#define RF_SETUP        0x06  // 发射速率、功耗功能设置
#define STATUS          0x07  // 状态寄存器
#define OBSERVE_TX      0x08  // 发送监测功能
#define CD              0x09  // 地址检测
#define RX_ADDR_P0      0x0A  // 频道0接收数据地址
#define RX_ADDR_P1      0x0B  // 频道1接收数据地址
#define RX_ADDR_P2      0x0C  // 频道2接收数据地址
#define RX_ADDR_P3      0x0D  // 频道3接收数据地址
#define RX_ADDR_P4      0x0E  // 频道4接收数据地址
#define RX_ADDR_P5      0x0F  // 频道5接收数据地址
#define TX_ADDR         0x10  // 发送地址寄存器
#define RX_PW_P0        0x11  // 接收频道0接收数据长度
#define RX_PW_P1        0x12  // 接收频道0接收数据长度
#define RX_PW_P2        0x13  // 接收频道0接收数据长度
#define RX_PW_P3        0x14  // 接收频道0接收数据长度
#define RX_PW_P4        0x15  // 接收频道0接收数据长度
#define RX_PW_P5        0x16  // 接收频道0接收数据长度
#define FIFO_STATUS     0x17  // FIFO栈入栈出状态寄存器设置
//=============================RF24l01状态=====================================
char  TX_ADDRESS[TX_ADR_WIDTH]= {0x34,0x43,0x10,0x10,0x01};    //本地地址
char  RX_ADDRESS[RX_ADR_WIDTH]= {0x34,0x43,0x10,0x10,0x01};    //接收地址
char  sta;
char  RxBuf[32],temp[6];
char seg[10]={0x30,0x31,0x32,0x33,0x34,0x35,0x36,0x37,0x38,0x39};
//系统初始化
void InitSys()
   unsigned int iq0;
   _DINT();
   BCSCTL1 &=~XT2OFF;
   do
      IFG1 &= ~OFIFG;                            // 清除振荡器失效标志
      for (iq0 = 0xFF; iq0 > 0; iq0--);    // 延时,等待XT2起振
   while ((IFG1 & OFIFG) != 0);        // 判断XT2是否起振
   BCSCTL2 =SELM1+SELS;                // MCLK,SMCLK时钟为XT2
//===========================LED端口设置==========================================
void LED_IO_set(void)
      P6DIR |= 0x06;   P6SEL&=0xf9;
//===========================RF24L01端口设置==========================================
void RF24L01_IO_set(void)
      P2DIR &= 0x7f;    P2DIR |= 0x40;  P2SEL&=0x3F;   P2IE=P2IE&0x7f;
      P3DIR &= 0xFE;    P3DIR |= 0x0E;  P3SEL&=0xF0;
void LCD_IO_set()
    CtrlDir |= 0x70;                 //控制线端口设为输出状态
    DataDir  = 0xFF;                 //数据端口设为输出状态
    P4SEL=0x00;                    //设置P4为一般数字IO口
    P6SEL&=0x8f;                  //设置P6为一般数字IO口
void BELL_IO_set(void)
        P6DIR |= 0x08;   P6SEL&=0xF7;
//========================延时约5ms=============================================
void ms_delay(void)
   unsigned int i=40000;
    while (i != 0)
        i--;
//========================================长延时================================
void Delay(int s)
    unsigned int i,j;
    for(i=0; i<s; i++);
    for(j=0; j<s; j++);
//函数:uint SPI_RW(uint uchar)
//功能:NRF24L01的SPI写时序
char SPI_RW(char data)
        char i,temp=0;
       for(i=0;i<8;i++) // output 8-bit
    if((data & 0x80)==0x80)
        RF24L01_MOSI_1;         // output 'uchar', MSB to MOSI
    else
         RF24L01_MOSI_0;
        data = (data << 1);            // shift next bit into MSB..
        temp<<=1;
        RF24L01_SCK_1;                // Set SCK high..
        if((P3IN&0x01)==0x01)temp++;         // capture current MISO bit
        RF24L01_SCK_0;              // ..then set SCK low again
    return(temp);                     // return read uchar
//函数:uchar SPI_Read(uchar reg)
//功能:NRF24L01的SPI时序
char SPI_Read(char reg)
    char reg_val;
    RF24L01_CSN_0;           // CSN low, initialize SPI communication...
    SPI_RW(reg);            // Select register to read from..
    reg_val = SPI_RW(0);    // ..then read registervalue
    RF24L01_CSN_1;         // CSN high, terminate SPI communication
    return(reg_val);       // return register value
//功能:NRF24L01读写寄存器函数
char SPI_RW_Reg(char reg, char value)
    char status1;
    RF24L01_CSN_0;                   // CSN low, init SPI transaction
    status1 = SPI_RW(reg);      // select register
    SPI_RW(value);             // ..and write value to it..
    RF24L01_CSN_1;                   // CSN high again
    return(status1);            // return nRF24L01 status uchar
//函数:uint SPI_Read_Buf(uchar reg, uchar *pBuf, uchar uchars)
//功能: 用于读数据,reg:为寄存器地址,pBuf:为待读出数据地址,uchars:读出数据的个数
char SPI_Read_Buf(char reg, char *pBuf, char chars)
    char status2,uchar_ctr;
    RF24L01_CSN_0;                            // Set CSN low, init SPI tranaction
    status2 = SPI_RW(reg);               // Select register to write to and read status uchar
    for(uchar_ctr=0;uchar_ctr<chars;uchar_ctr++)
    pBuf[uchar_ctr] = SPI_RW(0);    //
    RF24L01_CSN_1;
    return(status2);
//函数:uint SPI_Write_Buf(uchar reg, uchar *pBuf, uchar uchars)
//功能: 用于写数据:为寄存器地址,pBuf:为待写入数据地址,uchars:写入数据的个数
char SPI_Write_Buf(char reg, char *pBuf, char chars)
    char status1,uchar_ctr;
    RF24L01_CSN_0;             //SPI使能
    for(uchar_ctr=0; uchar_ctr<chars; uchar_ctr++) //
    SPI_RW(*pBuf++);
    RF24L01_CSN_1;           //关闭SPI
    return(status1);              //
//函数:void SetRX_Mode(void)
//功能:数据接收配置
    RF24L01_CE_0 ;
        Delay(1);
    RF24L01_CE_1;
    Delay(1000);//注意不能太小
//函数:unsigned char nRF24L01_RxPacket(unsigned char* rx_buf)
//功能:数据读取后放如rx_buf接收缓冲区中
char nRF24L01_RxPacket(char* rx_buf)
    char revale=0;
    sta=SPI_Read(STATUS);         // 读取状态寄存其来判断数据接收状况
    if(sta&0x40)                 // 判断是否接收到数据
        RF24L01_CE_0 ;             //SPI使能
        SPI_Read_Buf(RD_RX_PLOAD,rx_buf,TX_PLOAD_WIDTH);// read receive payload from RX_FIFO buffer
        revale =1;            //读取数据完成标志
        else
              revale =0;
    SPI_RW_Reg(WRITE_REG+STATUS,sta);   //接收到数据后RX_DR,TX_DS,MAX_PT都置高为1,通过写1来清楚中断标志
    return revale;
//函数:void nRF24L01_TxPacket(char * tx_buf)
//功能:发送 tx_buf中数据
    RF24L01_CE_0 ;            //StandBy I模式
    SPI_Write_Buf(WRITE_REG + RX_ADDR_P0, TX_ADDRESS, TX_ADR_WIDTH); // 装载接收端地址
    SPI_Write_Buf(WR_TX_PLOAD, tx_buf, TX_PLOAD_WIDTH);              // 装载数据
//    SPI_RW_Reg(WRITE_REG + CONFIG, 0x0e);            // IRQ收发完成中断响应,16位CRC,主发送
    RF24L01_CE_1;         //置高CE,激发数据发送
    Delay(600);
//NRF24L01初始化
void init_NRF24L01(void)
     RF24L01_CE_0 ;    // chip enable
     RF24L01_CSN_1;   // Spi disable
     RF24L01_SCK_0;   // Spi clock line init high
    SPI_Write_Buf(WRITE_REG + TX_ADDR, TX_ADDRESS, TX_ADR_WIDTH);    // 写本地地址
    SPI_Write_Buf(WRITE_REG + RX_ADDR_P0, RX_ADDRESS, RX_ADR_WIDTH); // 写接收端地址
    SPI_RW_Reg(WRITE_REG + EN_AA, 0x01);      //  频道0自动    ACK应答允许
    SPI_RW_Reg(WRITE_REG + EN_RXADDR, 0x01);  //  允许接收地址只有频道0,如果需要多频道可以参考Page21
    SPI_RW_Reg(WRITE_REG + RF_CH, 0);        //   设置信道工作为2.4GHZ,收发必须一致
    SPI_RW_Reg(WRITE_REG + RX_PW_P0, RX_PLOAD_WIDTH); //设置接收数据长度,本次设置为32字节
    SPI_RW_Reg(WRITE_REG + RF_SETUP, 0x07);           //设置发射速率为1MHZ,发射功率为最大值0dB
    SPI_RW_Reg(WRITE_REG + CONFIG, 0x0f);           // IRQ收发完成中断响应,16位CRC    ,主接收}
        Delay(1000);
//===============================串口初始化=====================================
void init_uart0(void)
//====================串口工作模式设置========================================
    U0CTL=0x00;      // U0CTL包含串口0通信协议、通信模式、校验位等设置,允许UART0
    U0CTL +=CHAR;    //(CHAR=0x10)当CHAR=0时位7位数据,当 CHAR=1时为8位数据
                     //不需要校验,数据位为8位,无反馈,异步UART通信,UART被允许
//====================串口发送操作设置========================================
    U0TCTL=0x00;     //U0TCTL包含串口0发送功能操作
    U0TCTL +=SSEL0;  //波特率发生器选择ACLK
                     //#define SSEL1  (0x20)       #define SSEL0  (0x10)
//====================串口拨特率设置9600====================================
//===================拨特率计算公式:拨特率=BRCLK/(UBR+(M7+M6+。。。。+M0)/8)
    UBR0_0=0x03;     //UBR0_0为串口0波特率整数部分低地址
    UBR1_0=0x00;     //UBR1_0为串口0波特率整数部分高地址
    UMCTL_0=0x4A;    //UBR1_0为串口0波特率小数部分高地址
//===================串口收发使能控制=========================================
    ME1 |= UTXE0;    //串口0发送功能使能
    ME1 |= URXE0;    //串口0接收功能使能
//===================串口中断使能控制=========================================
//  IE1 |= URXIE0;   //串口0接收中断使能
//   IE1 |= UTXIE0;   //串口0发送中断使能
//===================端口第二功能使能=========================================
    P3SEL |=BIT4;    //设置P3。4为UART0 的TXD
    P3SEL |=BIT5;    //设置P3。5为UART0 的RXD
    P3DIR |=BIT4;    //设置P3。4为输出
void   R_S_Byte(char R_Byte)
    while((IFG1&UTXIFG0)==0);    //
    TXBUF0=R_Byte;
//========================等待1602液晶完成内部操作==============================
void WaitForEnable(void)
    P4DIR &= 0x00;  //将P4口切换为输入状态
    CLR_RS;
    SET_RW;
    _NOP();
    SET_EN;
    _NOP();
    _NOP();
    while((P4IN & Busy)!=0);  //检测忙标志
    CLR_EN;
    P4DIR |= 0xFF;  //将P4口切换为输出状态
//==========================向液晶模块写入命令==================================
//=================cmd--命令,chk--是否判忙的标志,1:判忙,0:不判=============
void LcdWriteCommand(char cmd,char chk)
    if (chk) WaitForEnable();   // 检测忙信号?
    CLR_RS;
    CLR_RW;
    _NOP();
    DataPort = cmd;             //将命令字写入数据端口
    _NOP();
    SET_EN;                     //产生使能脉冲信号
    _NOP();
    _NOP();
    CLR_EN;
//=====================向液晶显示的当前地址写入显示数据=========================
void LcdWriteData(char data )
    WaitForEnable();        //等待液晶不忙
    SET_RS;
    CLR_RW;
    _NOP();
    DataPort = data;        //将显示数据写入数据端口
    _NOP();
    SET_EN;                 //产生使能脉冲信号
    _NOP();
    _NOP();
    CLR_EN;
//==================向液晶输入显示字符位置的坐标信息============================
void LocateXY(char x,char y)
   char temp;
    x&= 0x01;
    temp = y&0x0f;
    if(x)   temp |= 0x40;  //如果在第2行
    temp |= 0x80;
    LcdWriteCommand(temp,0);
//==========================在某个位置显示一个字符==============================
//============x--位置的列坐标   y--位置的行坐标data--显示的字符数据=============
void DisoneChar(char x,char y,char data)
    LocateXY( x, y );
    LcdWriteData( data );
//==============================让液晶从某个位置起连续显示一个字符==============
//==============================y--位置的列坐标  x--位置的行坐标================
void DispStr(char x,char y,char *ptr)
   char *temp;
   char i,n = 0;
    temp = ptr;
    while(*ptr++ != '\0')   n++;    //计算字符串有效字符的个数
    for (i=0;i<n;i++)
        DisoneChar(x++,y,temp);
        if (x == 0x0f)
           x  = 0;
           y ^= 1;
//让液晶从某个位置起连续显示N个字符
void DispNChar(char x,char y,char n,char *ptr)
   char i;
    for (i=0;i<n;i++)
        DisoneChar(x++,y,ptr);
        if (x == 0x0f)
           x = 0;
           y ^= 1;
//========================对1602液晶模块进行复位操作============================
void LcdReset(void)
    LcdWriteCommand(0x38, 0);        //规定的复位操作
    ms_delay();
    ms_delay();
    ms_delay();
    LcdWriteCommand(0x38, 1);        //显示模式设置
    LcdWriteCommand(0x08, 1);        //显示关闭
    LcdWriteCommand(0x01, 1);            //显示清屏
    LcdWriteCommand(0x06, 1);        //写字符时整体不移动
    LcdWriteCommand(0x0c, 1);        //显示开,不开游标,不闪烁
//==================================NEWMSG-JASK3000=============================
void NewmsgJASK3000()
     DisoneChar(0,1,0x4e) ;
     DisoneChar(0,2,0x45) ;
     DisoneChar(0,3,0x57) ;
     DisoneChar(0,4,0x4d) ;
     DisoneChar(0,5,0x53) ;
     DisoneChar(0,6,0x47) ;
     DisoneChar(0,7,0x2d) ;
     DisoneChar(0,8,0x2d) ;
     DisoneChar(0,9,0x4a) ;
     DisoneChar(0,10,0x41) ;
     DisoneChar(0,11,0x53) ;
     DisoneChar(0,12,0x4b) ;
     DisoneChar(0,13,0x33) ;
     DisoneChar(0,14,0x30) ;
     DisoneChar(0,15,0x30) ;
     DisoneChar(0,16,0x30) ;
     ms_delay();
//====================================温度 显示 ================================
void wen_xianshi()
     DisoneChar(1,3,0x4e) ; // now : XX.X 度
     DisoneChar(1,4,0x4f) ;
     DisoneChar(1,5,0x57) ;
     DisoneChar(1,6,0x20) ;
     DisoneChar(1,7,0x20) ;
     DisoneChar(1,8,seg[temp[4]]) ;
     DisoneChar(1,9,seg[temp[5]]) ;
     DisoneChar(1,10,0x2e) ;
     DisoneChar(1,11,seg[temp[1]]) ;
     DisoneChar(1,12,0xdf) ;
     DisoneChar(1,13,0x43) ;
main()
      char i;
      WDTCTL = WDTPW + WDTHOLD; //禁止看门狗
      LED_IO_set();
      BELL_IO_set();
      LCD_IO_set();      //LCD端口设置
      RF24L01_IO_set();
      InitSys();
      init_uart0();
      init_NRF24L01() ;
      LcdReset();        //LCD初始化
      NewmsgJASK3000();
      LED1_1;LED2_1;
      while(1)
     SetRX_Mode();
  if(nRF24L01_RxPacket(RxBuf))   //判断是否收到数据
       temp[0]=RxBuf[3];      //符号位
       temp[2]=((RxBuf[2]<<4)|RxBuf[1]);        //整数位
       temp[1]=RxBuf[0];                //小数位
       temp[4]=RxBuf[2];                //十位
       temp[5]=RxBuf[1];    //个位
       LED1_1;
   for(i=0;i<3;i++)
       R_S_Byte(temp[2-i]);     //串口上传温度
       Delay(10);
    if(temp[2]>=53)//大于35度时报警,0x35转换成10进制为53
        BELL_0;  //打开蜂明器报警
    else
         BELL_1 ;//关闭蜂明器报警
        wen_xianshi();    //LCD温度显示
        LED1_0;
  • 签到天数: 103 天
    7万
    发表于 2014-7-8 00:01:41 | 显示全部楼层
    社区居民忠实会员社区劳模优秀斑竹奖终身成就奖最爱沙发原创达人
    发表于 2014-7-8 06:49:38 | 显示全部楼层
    难过
    9 小时前
  • 签到天数: 164 天
    终身成就奖社区居民忠实会员社区劳模最爱沙发特殊贡献奖优秀斑竹奖
    发表于 2014-7-8 09:10:06 | 显示全部楼层
